Staro 23.03.2016., 09:56   #6301
PointDexter
PointDexter's Avatar
Lokacija: Éire
Postovi: 1,812
Prijavio jucer problem sa netom kod staraca. Jutros vidim problem rijesen.
Inace je brzina 4/0.5 Mbps, a trenutno pokazuje
http://www.speedtest.net/my-result/5190809204
Praviti se blesav i pustiti dok vozi ili prijaviti da ne bi doslo po povecanja racuna?
EDIT: Zanimljivo, upravo zove teta iz tcom-a da vidi jel sve ok. Kaze da je to namjerno i besplatno povecanje
alien-smilies-0046.gif von smiliesuche.de
Zadnje izmijenjeno od: PointDexter. 23.03.2016. u 10:01.
PointDexter je offline   Reply With Quote
Staro 23.03.2016., 10:33   #6302
Ag008
RESPECT MY AUTHORITAH
Ag008's Avatar
Postovi: 7,500
Stavi parametre parice iz routera da vidimo do koliko ti ide linija.
Ag008 je online   Reply With Quote
Staro 23.03.2016., 10:48   #6303
extasy
Lokacija: st
Postovi: 371
evo i mene ce danas prespojit na vdsl samo neznam sta cu dobit sa ovom daljinom...
Link Status Connected
Modulation Type ADSL_2plus
Actual Rate (Up/Down) 780/12276 kbps
Attainable Rate (Up/Down) 1280/20640 kbps
Noise Margin (Up/Down) 16.9/6 dB
Line Attenuation (Up/Down) 17.1/26 dB
Output Power (Up/Down) 12.3/18.8 dBm
Data Path (Up/Down) Interleaved/Interleaved
Interleave Depth (Up/Down) 4/224
Interleave Delay (Up/Down) 2/4 ms
INP (Up/Down) 0.5/2.5 symbols
Profile N/A
LinkEncap G.992.3_Annex_K_ATM
CRC Errors (Up/Down) 0/0
FEC Errors (Up/Down) 0/44
HEC Errors (Up/Down) 0/0
extasy je offline   Reply With Quote
Staro 23.03.2016., 12:35   #6304
PointDexter
Lokacija: Éire
Postovi: 1,812
Autor Ag008 Pregled postova
Modulation Type VDSL2
Actual Rate (Up/Down) 3135/23319 kbps
Attainable Rate (Up/Down) 34811/95880 kbps
Noise Margin (Up/Down) 31/27.1 dB
Line Attenuation (Up/Down) 12.7/7.5 dB
Output Power (Up/Down) 1.9/14.4 dBm
Interleave Depth (Up/Down) 11/373
Interleave Delay (Up/Down) 1/4 ms
INP (Up/Down) 0.5/1.5 symbols
Profile 17a
LinkEncap G.993.2_Annex_K_PTM
FEC Errors (Up/Down) 0/30
Ova nova brzina je i vise nego dovoljna za starce. Sumnjam da bi bili sretni sa (i minimalnim) povecanjem recuna.
Staro 23.03.2016., 13:10   #6305
Froxie24
Datum registracije: Feb 2015
Lokacija: Sisak
Postovi: 827
Ako je vrijednost margine ispravna znaći 7.5dB po nekoj računici max po liniji može ići oko 65mbps down po VDSL2. A u ruteru mu čak piše 95mpbs što ne vjerujem da je baš točno jer po margini je oko 500m od centrale ili na što je već spojen, može biti i da je FTTC u pitanju.
Dobro.
EDIT: Joj cuj mene to su VDSL margine nije ni cudo sto mi racunica ne valja.
Ovo sto pise u routeru max 95mbps. Je vjerojatno tocno, ili zivis blizu centrale ili imas fttc jer po ovome je kratka parica dosta.
Zadnje izmijenjeno od: Froxie24. 23.03.2016. u 16:16.
Froxie24 je offline   Reply With Quote
Staro 23.03.2016., 17:47   #6306
geronimo_2
geronimo_2's Avatar
Lokacija: Rijeka / Grobnik
Postovi: 4,463
kod mene proslo vise od 24h, a ja jos uvjek na 4mb :-(.
Staro 23.03.2016., 18:43   #6307
mamutarka
ODUZIMAM VAM RIJEČ
mamutarka's Avatar
Postovi: 13,532
08009000 budi uporan nema druge
Staro 23.03.2016., 19:35   #6308
QS
QS's Avatar
Datum registracije: Mar 2009
Postovi: 284
a kako se tocno vdsl margine razlikuju od adsl margina? sta ne mora biti 6+ za internet i 8+ za internet+iptv i na jednom i na drugom?
QS je offline   Reply With Quote
Staro 23.03.2016., 19:42   #6309
Froxie24
Lokacija: Sisak
Postovi: 827
Autor QS Pregled postova
Mislim na line atennuation. Vrijednosti koje se prikazuju kod vdsl-a i adsl-a nisubiste vec se razlikuje. Ne znam jel javno postoji kakva formula za izračun moguće maximalne brzine i udaljenost od centrale pomoću margine vdsl-a tj vrijednosti line atennuation.
Staro 23.03.2016., 20:08   #6310
PointDexter
Lokacija: Éire
Postovi: 1,812
Autor Froxie24 Pregled postova
Vjerojatno jer je kratka. Oko 200 metara zracne linije sam od centrale
Staro 23.03.2016., 20:25   #6311
Ag008
Ag008's Avatar
Postovi: 7,500
Imaš novi bakreni kabel sa 200m ili živiš u centrali
Staro 23.03.2016., 20:41   #6312
animATrIx
animATrIx's Avatar
Lokacija: Vukovar-Osijek
Postovi: 491
sto manje prespoja i radit ce vece brzine na tim kratkim relacijama.
animATrIx je offline   Reply With Quote
Staro 24.03.2016., 14:46   #6313
geronimo_2
geronimo_2's Avatar
Postovi: 4,463
o Boze, pa ovaj T-com, pa to, pa to... .
daklem prvi meilovi su bili da imamo teh mogucnost za turbo 50, sto cisto sumnjam .
mi izaberemo turbo 10 tako da ostane router S555.
dolazi meil da ce opcija T10 biti aktivirana u max 24h.
nakon cekanja od dana i pol, 500 testiranja brzine i miljon resetiranja routera, posaljem meil da nije jos aktivirano i dolazi danas odgovor:
<!--[if gte mso 9]><xml> <w:WordDocument> <w:View>Normal</w:View> <w:Zoom>0</w:Zoom> <w:HyphenationZone>21</w:HyphenationZone> <w:PunctuationKerning/> <w:ValidateAgainstSchemas/> <w:SaveIfXMLInvalid>false</w:SaveIfXMLInvalid> <w:IgnoreMixedContent>false</w:IgnoreMixedContent> <w:AlwaysShowPlaceholderText>false</w:AlwaysShowPlaceholderText> <w:Compatibility> <w:BreakWrappedTables/> <w:SnapToGridInCell/> <w:WrapTextWithPunct/> <w:UseAsianBreakRules/> <wontGrowAutofit/> </w:Compatibility> <w:BrowserLevel>MicrosoftInternetExplorer4</w:BrowserLevel> </w:WordDocument> </xml><![endif]-->"...sve Turbo opcije aktiviraju se unutar 7 dana, ako se utvrdi da imate tehničke mogućnosti za istom<!--[if gte mso 9]><xml> <w:LatentStyles DefLockedState="false" LatentStyleCount="156"> </w:LatentStyles> </xml><![endif]--><!--[if gte mso 10]> <style> /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0cm 5.4pt 0cm 5.4pt; mso-para-margin:0cm; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman"; mso-ansi-language:#0400; mso-fareast-language:#0400; mso-bidi-language:#0400;} </style> <![endif]-->..."
Staro 24.03.2016., 14:57   #6314
pitomi
pitomi's Avatar
Datum registracije: Jun 2015
Lokacija: pitomaca
Postovi: 1
imao turbo10.ponedjeljak zvao za turbo 50.utorak došao ruter i u sredu navečer puštena tražena brzina bez zvanja službe za korisnike
pitomi je offline   Reply With Quote
Staro 24.03.2016., 15:23   #6315
Ag008
Ag008's Avatar
Postovi: 7,500
Ne znam zašto želiš zadržati to prastaro smeće od SE555. Još bi možda razumio za sx763 ali ovako...
Ista ti je cijena od 10-50Mbps. Mogao si si probati aktivirati veću brzinu a dobio bi sigurno bolji router od ovog. Čak je i speedport bolji od njega, vjerojatno i po dometu wifija.
Staro 24.03.2016., 15:45   #6316
back2quick
Datum registracije: Jan 2012
Lokacija: righthere
Postovi: 441
stavi si speedporta kad ti je bolji pa ćeš vidjet. domet wifi-a u rangu tg782 znači dno dna. uz sve ostale probleme speedport je dobar samo za jedno - čekićanje
back2quick je offline   Reply With Quote
Staro 24.03.2016., 15:57   #6317
Ag008
Ag008's Avatar
Postovi: 7,500
Ali ionako ne bi dobio Speedporta jer ga daju većinom za optiku već je tu za primjer.
Dobio bi 99% ZTE koji je ok. Glupo mi je da ostaje na adsl-u samo radi routera. 99% bi mogao na vdsl-u 20mbps uz veći i bolji upload.
Mislim, čak i da dobije neki koji ne želi neka ga zamijeni.
Kada sam svojevremeno bio na T-comu i dobio neželjeni router samo sam otišao do centrale i zamijenili su mi bez problema uz "respect my authority".
Staro 24.03.2016., 16:10   #6318
kopija
DIY DILETANT
kopija's Avatar
Lokacija: Čistilište
Postovi: 3,722
Rešpekt na dobroj ideji.
Svakako za zapamtiti i primjeniti!
Staro 24.03.2016., 16:37   #6319
D1viry
D1viry's Avatar
Lokacija: Slavonija
Postovi: 2,066
Ja sam kod punice i punca dobio ZTE i bespla 30/5. Meni su dali Speedport i plaćen 30/5. Ruter je dno. Možda nije dno dna, ali je dno.
Nije baš Kasda, ali tu negdje sam sa živcima .
Koristim ga samo za maxtv, telefon i da šalje wifi po dnevnoj sobi. Ostatak kuće i šogora pokrivam sa 2 linksysa.
Nisam imao mogućnost mijenjati jer nije bilo zte-a. Sad mi se ne da više mijenjati.
Nevezano uz to, jel dobio netko mail da mu gase nekakav telekom ID?
Imam jedan ugašen (bio od punca) i 2 koje aktivno koritim (starci i moje). Obrazloženje je da se više od jedne godine nisam ulogirao. Ono, wtf?
Primam račune samo na njihov portal i uredno ih pregledavam-plaćam i ako mi to ugase, naj*** sam.
Pošten trgovac: 1,2,3,4,5,6
Staro 24.03.2016., 16:40   #6320
animATrIx
animATrIx's Avatar
Postovi: 491
ili par dana za redom ga iskljucis iz struje 2-3 puta i onda zoves szk, kad ti dodje majstor zamijenit ce ti ga
dosao je novi ZTE v4 i za sada se cini da je dosta dobar modem pa nebi bilo lose to traziti
Staro 24.03.2016., 16:41   #6321
Razor
Postovi: 96
Nije mi jasno, zasto jednostavno ne uzmete neki jeftin Mikrotikov ruter i odjebete cijelu tu pricu sa telekomovim ruterima?
Razor je offline   Reply With Quote
Staro 24.03.2016., 17:29   #6322
mamutarka
ODUZIMAM VAM RIJEČ
mamutarka's Avatar
Postovi: 13,532
ja imam speedport kao primarni, a ZTE u ormaru stoji, zte je bolji?
animatrix kak znam jelv4 ili nešto drugo, ispod piše DEC 2013
Staro 24.03.2016., 17:32   #6323
geronimo_2
geronimo_2's Avatar
Postovi: 4,463
zelim zadrzat router jer je moj, otkljucan i imam 2 komada.
10mbit ako radi stabilno je meni vise nego dovoljno dok se ne odlucim preci na nesto vise. meni je s555 odlican. wifi mi nije bitan.
dali doticni ZTE ima mogucnost podesavanja naprednih funkcija kao port forward-a i da opcija ostane obzirom da je gofno zakljucano i da jedino tkoma ima admin pristup AFAIK.
poz
Staro 24.03.2016., 17:45   #6324
animATrIx
animATrIx's Avatar
Postovi: 491
@mamutarka ako ti se dogadja usporavanje veze ili kad ga opteretis sa max uploadom pa ti "pukne" veza i nemos na net par minuta onda stavi ZTE, ima jaci wifi signal i nema tih nekih problema. iako sad ima i novi fw za speedporta koji bi trebao ispraviti problem na wifi.
novi ZTE je mislim iz 2014-e ili 15-e, ista je oznaka za njega kao i za staroga ali posto je tek ovaj mjesec krenio u opticaj, jos su rijetkost.
@geronimo, te starije routere tehnicari ne uzimaju tako da ce ti ostati svejedno. za port forward nisam siguran, ali ako speedport ima,mora i zte imati, ako se moze, spremis si svoju konfiguraciju sa routera na pc pa ako i dodje do factory reseta, lako vratis sve nazad
Staro 24.03.2016., 17:50   #6325
mamutarka
ODUZIMAM VAM RIJEČ
mamutarka's Avatar
Postovi: 13,532
animatrix si siguran da ovaj novi firmware rješava wifi i to na speedpotru? do sada svaki fw nije sredio to
Staro 24.03.2016., 17:56   #6326
geronimo_2
geronimo_2's Avatar
Postovi: 4,463
ne brine me da ce mi teh odnest routere pobogu. moze ih slobodno odnest ak mi daju posteni novi (citaj otkljucan). zelim imati otvoren router jer to je moje pravo i ne kuzim koji k provideri zakljucavaju to.
ako se radi o tome da su ljudi glupi pa idu prckat po postavkama pa naprave probleme i sebi i provideru onda neka sloze neki dokument koji ce ti dat da potpises ako zelis user/pass na router i nemas vise pravo na podrsku nakon njihove zica koja je spojena u tvoju kucu i gotova prica.
tako svako moze izabrat dali zeli njihovu podrsku sto se tice postavljanja uredaja ili ne. meni sigurno ne trebaju. 100 puta vise cete mi vi ovdje na forumu pomoc i dat info nego oni.
nemam iskustva sa speedportom osim jednog kod frenda (preko VIP) gdje postavka port forward nije ostala odnosno resetirana je kod prvog reseta routera. zasto, nemam pojma.
nema smisla da se svaki dan logiravam u router i stavljam svoju postavku. radije cu kupit router svoj.
dajte neku preporuku za router do max 300kn (4 ili 5 portova 100mbit, wi-fi (ne treba nista snazno jer je ionak uvjek na off)).
Staro 24.03.2016., 18:21   #6327
animATrIx
animATrIx's Avatar
Postovi: 491
pa koliko mi je poznato da je fw 38 izasao kao popravak wifi problema, sad ovisi o situaciji, nekome ce raditi bolje a nekome mozda nece pomoci. znam kako bi trebalo biti a kako je zapravo, neznam. ja recimo nemam problema sa wifi-em na svome.
@geronimo, nece ti se svaki dan resetirati postavke routera, to se radi u slucaju da nesto stvarno ne radi ili kad prijavis kvar netko iz szk ti to odradi daljinski. zato nista te ne kosta sejvati konfiguraciju na pc i miran si.
Staro 24.03.2016., 18:23   #6328
mamutarka
ODUZIMAM VAM RIJEČ
mamutarka's Avatar
Postovi: 13,532
Danas je delboy stavio neki novi fw za speedport, mozda poboljsa stanje
Staro 24.03.2016., 18:31   #6329
RAUL
Lokacija: Worldwide
Postovi: 2,553
poz
Port forward radi odlicno.
Staro 24.03.2016., 18:34   #6330
geronimo_2
geronimo_2's Avatar
Postovi: 4,463
nisam mislio na reset postavki/routera od strane providera nego njegov nekakav reset ili stagod da mu se desi pa da izbrise postavku koju sam mu stavio za port forward u rekordnom roku.
edit: fala raul
