#4771 |
Postovi: 3,783
Teško da će reagirati. Oni u paketu od 20 garantiraju između 14 i 20 ako se ne varam. Meni je padalo ispod 5 mbita (paket 20) pa su reagirali ali im je trebalo 2 mjeseca da to otklone. Eventualno ako te prebace na VDSL (pod pretpostavkom da si na ADSL-u) tad bi mogao dobiti traženih 20. |
#4772 | |
Lokacija: Čepin
Postovi: 1,520
#4773 |
Postovi: 380
Evo mene Optima prebacila na VDSL 30/5 za sada, zvali me 29.2 te danas došao tehničar sa routerom Innbox V51. Code:
Mode: VDSL2 Traffic Type: PTM Status: Up Link Power State: L0 Downstream Upstream Line Coding(Trellis): On On SNR Margin (0.1 dB): 121 158 Attenuation (0.1 dB): 0 0 Output Power (0.1 dBm): 145 92 Attainable Rate (Kbps): 56068 20040 Path 0 Path 1 Downstream Upstream Downstream Upstream Rate (Kbps): 36861 6143 0 0 B (# of bytes in Mux Data Frame): 31 15 0 0 M (# of Mux Data Frames in an RS codeword): 1 1 0 0 T (# of Mux Data Frames in an OH sub-frame): 64 51 0 0 R (# of redundancy bytes in the RS codeword): 10 16 0 0 S (# of data symbols over which the RS code word spans): 0.0276 0.0822 0.0000 0.0000 L (# of bits transmitted in each data symbol): 12184 3114 0 0 D (interleaver depth): 1331 195 0 0 I (interleaver block size in bytes): 42 16 0 0 N (RS codeword size): 42 32 0 0 Delay (msec): 9 2 0 0 INP (DMT symbol): 4.00 2.00 0.00 0.00 OH Frames: 583196 146099 0 0 OH Frame Errors: 0 0 0 0 RS Words: 223804523 2354867 0 0 RS Correctable Errors: 6682 0 0 0 RS Uncorrectable Errors: 0 0 0 0 HEC Errors: 0 0 0 0 OCD Errors: 0 0 0 0 LCD Errors: 0 0 0 0 Total Cells: 109874278 0 0 0 Data Cells: 9389438 0 0 0 Bit Errors: 0 0 0 0 Total ES: 0 0 Total SES: 0 0 Total UAS: 22 22 Zadnje izmijenjeno od: Gile. 21.03.2016. u 21:30. |
#4774 | |
Lokacija: Novska
Postovi: 2,433
Digli brzinu na 20Mbit, ali sada je kvaliteta na samoj margini i ima CRC-a (na 10Mbit nije bilo). Za divno cudo nije niti jednom puklo. Citiraj:
#4776 |
Lokacija: Novska
Postovi: 2,433
Mozda da malo ipak smanje profil, ali dok ne puca nek ostane tako. Btw. prije 20 dana bili neki momci na pregledu terena. Mjerili udaljenost izvoda i slikali gdje se sto nalazi. Rekose radit ce se nesto, ali nisu rekli sto. |
#4778 |
Lokacija: Varazdin
Postovi: 137
Pozdrav, Danas sam dobio pismeno da im trebam vratiti ruter. Tj. piše da bi opremu trebao vratiti unutar 30 dana od prestanka korištenja usluga. Pismo je poslano 21.4.2016. a na drugom operateru sam cca. 7mj. Ruter sam planirao bacit jer za drugo i nije, sva sreća pa nisam. Tako da u slučaju da ste prešli na drugog operatera ili to planirate napravit nemojte bacati rutere jer će te ostat kraći za 500-600kn. |
#4780 | |
Datum registracije: Mar 2009
Postovi: 157
#4781 |
Postovi: 1,238
Nije možda full vezano za temu, ali nisam znao gdje da pitam. Uglavnom u firmi na jednoj lokaciji koristimo Optima DSL, i sad imamo telefon preko splitera, i uveli bi drugi telefon ali ne u smislu sa drugim brojem, nego da Telefoni budu kao jedan. Da li je onda dovoljno samo zbrickati tva dva telefona i onda uštekati u splitter. Bude to radilo ? Ili ima za kupit nekih razdjelnika. Hvala. |
#4786 |
Postovi: 96
Da. Nazvat ce te oko toga za cca mjesec dana i poslati nekoga po ruter (tako su nedavno napravili meni) |
#4787 | |
hungry, for a little more
Postovi: 244
Naravno, poslati ću poštom, subotom ne rade, radnim danom do 16:00. Profesionalno, nema šta. |
#4789 |
Postovi: 3,514
A ima likova stvarno na Optima helpdesku... Danas mi baš trebao VPN do firme i kad ono ne ide.... CGN ![]() Skinem obrazac, vidim nema nigdje za slanje mailom, zovem podršku i javi se neka kvočka i 3 puta sam pokušavao postaviti pitanje kako i na koji mail da to pošaljem, svaki puta me prekinula: "Piše sve na webu" Ono, niti rečenicu nisam završio do kraja, ova neće niti pričati dalje, čim zaustim evo nje opet da sve piše na webu. Sad popunjavam obrazac, printam, potpisujem, skeniram i šaljem na sve emailove koje nađem od Optime. Baš da vidim jel prolazi ili će baš trebati pismeno poštom slati.U 2016.g. smo, dobro da ne moram javnom bilježniku na ovjeru ![]() |
#4791 |
Datum registracije: Jul 2009
Lokacija: Koliba
Postovi: 1
Pozdrav svima, Imam problem sa otvaranjem portova na ovom zadnjem modem od optime, u pitanju je Innbox V51,iako postoji opcija pod NAT-Virtual servers,ali nemoguće je otvoriti portove,. Isto tako imam više svojih routera,ali nemožže ni jedan drugi,jer kad sam ih zvao u SZK-optima rekli su da je modem vezan MAC-adresom za centralu,radi se o paketu TO2-40 Mibps,inače modem nije loš,ali nemože se portat niti bacit u bridge mode,pa da mogu probat spojit neki drugi modem za taj Inbox i tako dobiti portove na van,. ovo je moja linija inače,..jel dobra,jer nikad nisam kužio te brojke,.. Code:
Mode: VDSL2 Traffic Type: PTM Status: Up Link Power State: L0 Downstream Upstream Line Coding(Trellis): On On SNR Margin (0.1 dB): 177 272 Attenuation (0.1 dB): 0 0 Output Power (0.1 dBm): 139 93 Attainable Rate (Kbps): 89738 29586 Path 0 Path 1 Downstream Upstream Downstream Upstream Rate (Kbps): 45055 8192 0 0 B (# of bytes in Mux Data Frame): 31 34 0 0 M (# of Mux Data Frames in an RS codeword): 1 1 0 0 T (# of Mux Data Frames in an OH sub-frame): 61 1 0 0 R (# of redundancy bytes in the RS codeword): 10 16 0 0 S (# of data symbols over which the RS code word spans): 0.0226 0.1323 0.0000 0.0000 L (# of bits transmitted in each data symbol): 14872 3084 0 0 D (interleaver depth): 1625 61 0 0 I (interleaver block size in bytes): 42 51 0 0 N (RS codeword size): 42 51 0 0 Delay (msec): 9 2 0 0 INP (DMT symbol): 4.00 1.00 0.00 0.00 OH Frames: 481 90 0 0 OH Frame Errors: 0 0 0 0 RS Words: 176339 0 0 0 RS Correctable Errors: 0 0 0 0 RS Uncorrectable Errors: 0 0 0 0 HEC Errors: 0 0 0 0 OCD Errors: 0 0 0 0 LCD Errors: 0 0 0 0 Total Cells: 86635 0 0 0 Data Cells: 95 0 0 0 Bit Errors: 0 0 0 0 Total ES: 0 0 Total SES: 0 0 Total UAS: 0 0 xDSL BER Test Reset Statistics |
#4792 |
Lokacija: Varazdin
Postovi: 108
Pozdrav svima, Zamolio bi za pomoc, ako je netko imao iskustva s ranijim prekidom ugovora i slicno. Naime, podstanar sam, i vlasnik stana ima 2 ugovora, jedan kod sebe doma, i drugi u stanu gdje sam trenutno.. I stuck sam sa "O3TVSURFPLUS paketa imate ugovornu obavezu do 24.10.2016" Jebeni 4Mbit i kad upatim TV padne na 3Mbit.... Ne mogu vise tako, poludit cu, a placam jebenih 307 kn, da ne pricam da nis pametnog nema na televiziji jel... Upite njima na helpdesk dobivao info da nemogu ni promijeniti brzinu bez da se potpise novi ugovor na 24mj... Ima ko neki savjet, ili broj stranice, malo mi teze pretraziti cijeli thread za tocnu tematiku? Hvala ekipa ![]() |
#4793 |
Postovi: 3,783
http://www.optima.hr/hr/korisnicka-podrska/internet/ Prvo pitanje: Koliko puta mjesečno mogu promijeniti paket prometa/brzine, i koliko se to naplaćuje? "Možete jednom mjesečno. Promjena se ne naplaćuje." |
#4794 | |
Lokacija: Varazdin
Postovi: 108
Prvo sam mislio da me trollas, onda sam popizdio i isao zvat opet SZK. I opet mi pricali, da promjena paketa brzine povlaci i ugovornu obavezu jer te tarife vise nema u ponudi bla.... Pa sam bio malo uporan, i nakon 10 minuta, se sjetila A gle, mozemo vam ponuditi tarifu bez ugovorne obaveze koja je 30kn skuplja od one s ugovornom obavezom.... Znaci, sad cu dobit, mislim da O3, 10Mbit, za 275kn bez ugovora, i time pregaziti trenutni paket koji ima ugovornu obavezu do 10.2016.. I teoretski mogu prekinuti uslugu, recimo s 01.07.2016 bez penala... Ko je tu lud.. Ja se ne bunim... Ali.. Nema veze s mozgom...Samo u Hrvatistanu.. P.s.: nadam se da ce ovo nekome pomoci ![]() |
#4795 |
Postovi: 3,783
super da si si sredio. Ma nisam te trollao niti nista lose mislio nego sam cisto htio da imas argument kad kaze da ne moze, da fino kazes, "procitajte si na Vasem WEB-u..." ![]() Jer nemali broj puta mi se javio s druge strane operater koji nije bas najbolje upoznat s uslugama i mogucnostima koje mi mogu ponuditi/pruziti. Zasad mi je net ok, i samo neka tako ostane. Jer ako krenu problemi, jao si ga meni... Ne ponovilo se... |
#4796 |
Lokacija: Varazdin
Postovi: 108
Ma.. ispada da argumentat o informaciji na internetu je i nije pomogao.. Naime stara je bila tarifa, i naravno oni u sustavu nemaju vise "srodnih" tarifa vec samo nove.. koje nisu "kompatibilne" s mehanikom promjena paketa brzine... Naime u jednom trenutku mi je ponudila na postojeci tarifu koju vec placao preko 300kn, da dodaju veci paket brzine, do 10Mbit sa 65kn doplate... Skoro sam pitao da li su normalni.. Malo se zgrazao, pa vidi vraga pocele se otvarati opcije...Da bi na kraju dobio nesto "normalnije".. |
#4797 |
Postovi: 3,783
koji su to kraljevi u Optimi. Naime pod ugovornom obvezom sam još cca godinu dana (VDSL 20 mbita). Prilikom potpisivanja tog ugovora bilo mi je rečeno da ću brzinu moći promjeniti na veću, jer brzina više nije problem pošto je unutar iste usluge (VDSL). Jučer sam htio uzeti veću brzinu (40 mbit) i kaže mi Lucio (operater) s druge strane, da ne mogu samo tako promjeniti brzinu na veću, nego ako povećavam, onda moram potpisati novo produženje na 2 godine. Lijepo sam se zahvalio, i rekao da ću pričekati tu nekog lokalnog providera koji vuče optiku jer je ovo svinjarija. Za promjenu profila na centrali traže nove 2 godine ugovora. Koje gluposti... |
#4800 |
Datum registracije: Jun 2016
Lokacija: rijeka
Postovi: 2
Ima li neke razlike u v45 iv51 innbox modema, meni uvalili ovaj v45 i cini mi se jako los wlan |
