Staro 14.03.2016., 14:28   #721
Postovi: 23,714
For beginning welcome to PC Expert forum,
lately "fashion" is that ISP installs / sets devices with custom fw version in difference of some past times,
mostly they do it in order to hide this VoIP account settings or customize to their network (ACS server, TR069, remote config).
In particular your OTE version of Speedport is still good, the more options are open and available to user.
You have to pay attention to one detail, sometimes they deliberately set TR069 in correlation with the VoIP service,
In other words, if you kill TR069 may lose your VoIp (telephone) service.
Regarding the firmware, it is normal that there is a control mechanism that prevents insertion of inadequate versions,
That's why "do not pass" our (T-Kom HR) or DE versions.
What you can do:
a) figure out how to log on as an administrator, not as an ordinary user vulgaris
try to figure out how to stop and turn off the TR069 service
b) as you've already mentioned, ask from ISP to change device (Speedport) config and set Internet connection in Bridge mode,
behind you will connect your WAN (Wireless) Router
That's all, regards
Staro 14.03.2016., 18:01   #722
Divic
Divic's Avatar
Datum registracije: Mar 2016
Lokacija: Tunguzija
Postovi: 37
Exclamation Nije bila greška na kabelu!
Autor Divic Pregled postova
Okey je sada.
Kupio sam CAT6.
Do sada je bio neki polutan (Cat5) jer je bio Thomson za obični ADSL.
Nego je potrebno uključiti na g. switch-u (u ovome slučaju D-Linkov DGS-1100-24) tkzv. "Flow Control" na portu za priklj. na Router To "smiruje" komunikaciju sa Hub-om Routera i drži ju na 1Gb/s.
a znanje i ravnanje zainteresiranima!
Divic je offline   Reply With Quote
Staro 14.03.2016., 18:40   #723
Postovi: 23,714
Kod "glupih" switch - eva je u pameti (koju i ne možeš mijenjati) Flow Control upaljen,
kod "pametnih" (čitaj Managed) Flow Control bi valjda trebao biti upaljen po defaultu,
manual te igračke > http://www.dlink.com/-/media/Busines...l_v1_00_WW.pdf
kad si već tu vidi da je i SNTP podešen.
Staro 14.03.2016., 22:40   #724
CrAcKeZ
Lokacija: Greece
Postovi: 2
@Nikky
Thanks for your reply and the welcome message .
I don't use VOIP so I'll be ok if it's broken anyway heheh
a) easier said than done :P
b) say what? ...my isp offers this router to work with their vdsl2 line, they don't care about anything else. Only workaround to "remove" the TR069 is to chance either the firmware of this device or get a new router . No need to ask anything from my isp, router can be set in bridge mode and put a vdsl router with a single lan port and connect it to speedport but why do that? point is to have this router working as expected but without TR069 enabled
P.S. I've went back(older firmware) but ISP keeps updating my router to this latest crap ...damn I hate this
Zadnje izmijenjeno od: Nikky. 14.03.2016. u 23:22.
CrAcKeZ je offline   Reply With Quote
Staro 14.03.2016., 23:10   #725
.Delboy
.Delboy's Avatar
Lokacija: hr
Postovi: 755
Check this link, it describes a way to disable tr-69:
https://github.com/Psychotropos/serc...remote_mgmt.py
Also you can go to engineer menu and disable tr69 from there, just disable "Enable Periodic Inform", and erase acs url.
http://192.168.1.1/html/engineer/tr069.htm
Za ostale, isprobavanjem linkova sam uspio skinuti novu fw verziju, 09091601.00.338T2, stavio sam je u dropbox folder.
Staro 15.03.2016., 01:08   #726
Postovi: 23,714
@CrAcKeZ
To make it easier I will continue in a and b way,
a) look how our user community cooperate, investigating, looking for solutions,
We have found that in our case the ISP is deliberately disabled administrator account, for now without solution.
Try on the local forums find more info.
.Delboy was search and give you an example.
b) I understand your anger or frustration, VDSL routers are still rare and relatively expensive.
Switching device (Speedport) in Bridge mode for Internet connection and transferring routing job to another device solves your problem with the TR069 or remote management.
In this way you avoid remote access to your network (Lan) or remotely change your custom settings.
An investment in your router does not have to be expensive,
for example TL-WR841ND > http://www.e-shop.gr/tp-link-tl-wr84...r-p-PER.612324
29.90 €
or small beast TL-WR1043ND > http://www.e-shop.gr/tp-link-tl-wr10...r-p-PER.612438
59.90 €
Staro 15.03.2016., 09:35   #727
Ant3G
Lokacija: Gospić
Postovi: 71
Update vlastite situacije:
flashan je fw 38. za sad radi stabilno, uredno se reconnecta i čini se da je bar taj dio riješen.
Što se tiče potreba internog DNS-a i dalje mi "remeti" planove. Na svim računalima u host fajl sam stavio adrese pa sam našao alternativu.
Imajmo optimizma možda bude još ok uređaj kad ga dotjeraju.
Ako netko proba taj novi T fw, neka javi da li se što promijenilo od DNS postavki.
Ant3G je offline   Reply With Quote
Staro 15.03.2016., 09:39   #728
bachje
Datum registracije: Jul 2015
Postovi: 93
Pozdrav. Jel imao ili ima netko situaciju sa oscilacijom brzine na speedtestu? Kada mi počne mjeriti brzinu skoči do 400injak Mbps i onda se spušta do nekih 230 do kraja mjerenja?
Hvala.
bachje je offline   Reply With Quote
Staro 15.03.2016., 09:41   #729
MisterX021
Datum registracije: Apr 2012
Postovi: 36
Autor .Delboy Pregled postova
Zna li se u čemu je razlika između "običnih" .036....038 i ovih sa "T" oznakom (.334T3 ... .336T1 itd)
MisterX021 je offline   Reply With Quote
Staro 15.03.2016., 17:35   #730
Andrija M
Postovi: 469
Autor bachje Pregled postova
To isto pitanje si već postavio neki dan u poruci 716 i odgovoreno ti je na njega
Andrija M je offline   Reply With Quote
Staro 15.03.2016., 18:01   #731
bachje
Postovi: 93
Ok. Hvala na odgovoru. Ali ako je odgovor: "da li testiraš s kabela ili s wifi-a' zadovoljavajući odgovor i trebao bi mi nešto pomoći (mislim da smo ovdje da si svi međusobno pomognemo) onda je, odgovorno mi je. Hvala i sorry na duplom postu (Andrija)
Staro 15.03.2016., 19:12   #732
Andrija M
Postovi: 469
Neki dan vozio sam se od zagreba do karlovca, u gradu je bila gužva i prosjek brzine bio mi je 20-30 na sat, onda sam došao na autoput pa mi sam raspalio i 130-140, a kad sam došao u Karlovac opet sam se vozio 30-40 na sat.
Na kraju je kompjuter na autu pokazivao prosječnu brzinu oko 80 na sat. Tako ti je isto i sa internetom, zato i speedtest traje minutu a ne 5, 10 ili 15 sekundi.
A još isto može biti i da je neko na susjednom kompjuteru u drugoj sobi "raspalio" po torrentima ili nešto slično pa ti zato varira brzina
Staro 17.03.2016., 10:00   #733
Divic
Divic's Avatar
Lokacija: Tunguzija
Postovi: 37
na 1Gb/s.
Na znanje i ravnanje zainteresiranima!
Nažalost!
Nakon 5 autopromjena ISP-ovih IP adresa (u roku 5-6 dana) ipak se je veza Switch-a i Routera prekinula!
Što je najsmješnije, bilo je dovoljno na trenutak isključiti i uključiti glavni UTP kabel (Cat6) da se uspostavi rad!
Čini se da je Flow Control nemoćan za 100% kontrolu!
Zbog ukućana (prestane im raditi Internet jer su im AP-ovi preko Switch-a)
vjerojatno ću podesiti izlazni port na 100Mbita.
Staro 17.03.2016., 12:17   #734
Postovi: 23,714
Rekao bi da tom konkretnom switchu nisu sve na broju
Ne smije se događati da ga zaglupe kratkotrajni prekidi u "vezi sa svijetom".
Ranije sam te pitao jeli podešen SNTP ?
Da sa ne otvaram onaj manual, vidi jeli ima mogućnost da sam odradi reboot ako "ne vidi" router.
Isto tako, na kojoj je IP adresi (onoj defaultnoj 10.0. ili si ga prebacio u isti segment kao router) ?
Staro 17.03.2016., 15:09   #735
Divic
Divic's Avatar
Lokacija: Tunguzija
Postovi: 37
Nažalost ovaj Switch (DGS 1000-24 "EasySmart") nema SNTP podešavanje vremena, a niti autoreboot.
Na istom segmentu je kao i Router (IP: 192.168.1.4).
Što je najgore ovaj puta nije se niti promjenila ISP IP adresa, a on je izgubio vezu s Routerom!
Sada sam mu podesio port na 100 Mb pa ću vidjeti.
Zadnje izmijenjeno od: Nikky. 17.03.2016. u 20:17.
Staro 17.03.2016., 16:35   #736
Postovi: 23,714
Sad mi više nije ništa jasno ?
Ako je "EasySmart" serija onda bi oznaka / model trebao biti DGS-1100-24.
Ako to je "taj" model, postoje hw verzija A i B > http://support.dlink.ca/ProductInfo.aspx?m=DGS-1100-24
Za A verziju ima:
- Firmware (1.10.016) 24/02/15 - ftp://ftp.dlink.ca/PRODUCTS/DGS-1100...E_1.10.016.ZIP
- User Manual (English) (1.04) - 01/05/13 - ftp://ftp.dlink.ca/PRODUCTS/DGS-1100...AL_1.04_EN.PDF
- Smart Console Utility (3.00.10) - ftp://ftp.dlink.ca/SOFTWARE/D-LINK_S...TY_3.00.10.EXE
Za B verziju ima:
- Firmware (1.01.018) - 02/08/15 - ftp://ftp.dlink.ca/PRODUCTS/DGS-1100....01.018_WW.zip
- User Manual (English) (1.00) - 18/06/15 - ftp://ftp.dlink.ca/PRODUCTS/DGS-1100...1.00_EN_WW.PDF
- D-Link Network Assistant (2.0.2.0) - 18/06/15 - ftp://ftp.dlink.ca/SOFTWARE/D-LINK_N...NT_2.0.2.0.ZIP
Možda je u ovom tvom stara verzija pameti, ako je probaj napraviti update, nađi ispravnu proceduru.
Staro 17.03.2016., 17:43   #737
Divic
Divic's Avatar
Lokacija: Tunguzija
Postovi: 37
Fakat je da sam napravio update fw-a ali na 11 verziju s web-a za HR.
Na ovome kalifornijskome je ta 16-stica, a i govore nešto o tim problemima.
Niš! Idem dograditi na tu 16-sticu. Valjda preživim!
EDIT: Upgrade napravljen!
Vidljivih funkcionalnih promjena nema.
Za sada ću pustiti switch nekoliko dana da radi s 100 Mb ipak.
Zadnje izmijenjeno od: Nikky. 17.03.2016. u 18:57.
Staro 17.03.2016., 20:17   #738
Postovi: 23,714
Dakle, imaš A verziju.
Šta se tiče funkcionalnosti, po manualu treba imati SNTP mada vjerojatno nije presudno za tvoj problem.
U temi se spominjalo da ovaj Speedport između ostalih bisera ima i sa detekcijom / izborom brzine (100Mb/1GB) na pojedinom Lan portu.
Opće poznato za D-Link da imaju različiti support za isti uređaj a ovisno o "odabranoj" zemlji ...
Staro 17.03.2016., 21:36   #739
Divic
Divic's Avatar
Lokacija: Tunguzija
Postovi: 37
A u dokumentaciji od update-a firmware-a V 1.10.016 ima nešto jako zanimljivo.
Veli: Fixirana pogreška br.1:When Switch Gateway is configured, switch doesn´t send a ARP request to gateway!?
Very interesting!
Što je još jadnije ja sam se držao ovoga linka: http://www.dlink.com/hr/hr/support/p...smart-switches
gdje se posebno naglašava za 16/24 switch samo 1.10.011 firmware!
Staro 17.03.2016., 21:46   #740
Postovi: 23,714
Eto si sad saznao ovaj biser sa različitim supportom ... ja sam to davno skužio sa preko njihovih routera,
u nekim slučajevima ne igra / nema pristupa preko web stranica nego treba švrljati direktno preko ftp - a "odgovarajuće" zemlje.
Evo primjer za ovaj uređaj "CA" > ftp://ftp.dlink.ca/PRODUCTS/DGS-1100-24/
a ovo je Njemački (DE) > ftp://ftp.dlink.de/dgs/dgs-1100-24/driver_software/
u ovom slučaju postoje iste fw verzije, a nekad (za druge uređaje) nema.
Ovo "zanimljivo" sam i ja malo prije vidio / pročitao, možeš se samo nadati da ova fw verzija riješava tvoj problem.
Zadnje izmijenjeno od: Nikky. 17.03.2016. u 21:54.
Staro 17.03.2016., 22:11   #741
Divic
Divic's Avatar
Lokacija: Tunguzija
Postovi: 37
Da.
Sada ću ga ostaviti na 100-tici jer nitko u kući ne radi po mreži od AP-ova, a nakon par dana "podignuti" na Gb kako treba.
U SmartConsol utilu sam vidio "Trap" da je update firmware-a obavljen a to sam u Trap podešavanju i stavio. Tu vidim da je zaprimljeno vrijeme i datum. Preko SNTP-a?
Staro 17.03.2016., 22:30   #742
Postovi: 23,714
Fala bogu da je zabilježio odr. datum / sat.
A otvori manual pa vidi, prvo ispravno podesiš a kasnije lakše pratiš logove,
bilo da gledaš kroz browser ili ove aplikacije.
Staro 17.03.2016., 23:24   #743
.Delboy
.Delboy's Avatar
Lokacija: hr
Postovi: 755
U dropboxu je 09091601.00.338T3 firmware
Staro 17.03.2016., 23:32   #744
Divic
Divic's Avatar
Lokacija: Tunguzija
Postovi: 37
Nema nigdje SNTP server podešavanja. Vjerojatno je negdje fiksno uprogramiran.
Niš onda.
Staro 18.03.2016., 00:06   #745
Postovi: 23,714
@Divic
Sad išao uspoređivati manuale za A i B verziju,
izgleda da A verzija nema a B verzija ima opciju podešavanja date / time / sntp.
@.Delboy
Jel imaš naznaka šta krpa / rješava ova zadnja fw verzija.
Staro 18.03.2016., 00:25   #746
.Delboy
.Delboy's Avatar
Lokacija: hr
Postovi: 755
A valjda nešto sa maxtv-om, tako je netko na bug forumu napisao za onu .038 verziju.
Staro 18.03.2016., 00:58   #747
Divic
Divic's Avatar
Lokacija: Tunguzija
Postovi: 37
Autor Nikky Pregled postova
@Divic
@.Delboy
@Nikky
Pa da. Prvo su napravili switch bez pdešavanja vremena, a onda su vidjeli fuš pa su korekciju nazvali B. To je distribuirao Msan, a oni su stvarno, zadnja rupa za switcheve.
Strašno je kakvi sve nadrimajstori rade u tim firmama! Danas nitko nije u stanju napraviti nešto a da to nema korekciju!
Staro 18.03.2016., 11:52   #748
Karlo666
Karlo666's Avatar
Datum registracije: Oct 2010
Lokacija: Kaštel Lukšić
Postovi: 1,652
Flashnuo jutros u firmi.
Vidim da je dodan još jedan DDNS provider.
Pošten trgovac:
1,2,3,4,5,6,
Zadnje izmijenjeno od: Karlo666. 18.03.2016. u 12:05.
Karlo666 je online   Reply With Quote
Staro 18.03.2016., 12:08   #749
Divic
Divic's Avatar
Lokacija: Tunguzija
Postovi: 37
Thankful!
Staro 19.03.2016., 14:52   #750
athmo
diff između T2 i T3, možda posluži nekom...:
DECT podrška, izmijene u izgledu (XML)
Zadnje izmijenjeno od: athmo. 07.04.2016. u 10:30. Razlog: copy/paste fail
