Staro 02.03.2016., 08:35   #331
Sam Fischer
Džabe si krečio!
Sam Fischer's Avatar
Postovi: 5,191
Autor Drvoje Pregled postova
Taman za podgrijavanje mesine na žderonjama
To "nešto" bi bilo naponska regulacija ili VRM, i takve temp za nju nažalost nisu rijetkost..
Jes to ti ima par komada - jednu ispod druge, drugu ispod treće, itd. razbojniče?
Hebiga, nisu neki radni uvjeti u rudnicima, nema baš radničkih prava
On topic, ne znam zašto imam potrebu pljuvat po tom XFX-u, ali potreba je prilično konzistentna. Uobičajeno rade najofrlje hladnjake, makar ja smatram da nije toliko loš bio na R9 280 koju sam imao... Ti Drvoje hejtaš i taj cooler ako se dobro sjećam?
Staro 02.03.2016., 13:33   #332
Drvoje
Split resist itself!
Drvoje's Avatar
Postovi: 4,037
Dobro se sićaš, stavili plastični plejt za ladit memoriju i VRM -.-
There are two parts to the cooler, one that cools the MOSFETs and memory and the huge GPU cooler itself. I like how the supplemental cooler contacts all memory chips as well as the MOSFETs, but I do have to wonder just how much good it’s doing. It seems like it’s plastic, and plastic isn’t the greatest of heat conductors. I have attempted to get XFX’s contact information from AMD and will update in case I’m wrong about the material, but I don’t think I am. The PCB behind the MOSFETs was hot, so much so I couldn’t leave my finger on it. Now, MOSFETs can take heat so it might not be a problem, but long term that might not be so good on the FETs. The plastic was definitely warm and wicking heat, but plastic will never do as good of a job as aluminum would.
http://www.overclockers.com/amd-xfx-...s-card-review/
A i tanki ("papirnati") PCB im nije stran, + kraće jamstvo od konkurencije (ASUS, GIGA, MSI) i stavljanje jamstvenih naljepnica na vijke...
Jedino im je cijena u rangu Gainward poluproizvoda - najniža
Pomelo mi sig -.-
Staro 02.03.2016., 20:58   #333
arrow
arrow's Avatar
Datum registracije: Nov 2014
Lokacija: Zd
Postovi: 609
overclockate li svoje doticne kartice?
danas sam se malo poigrao sa svojom ali bez diranja napona te sam dobio kojih 10-ak fps
gpu clock 1215mhz i memory clock 1730mhz, daljnjim povecavanjem gpu clock dobivam lagano trzanje, vjerovatno fali malo vise napona
arrow je offline   Reply With Quote
Staro 02.03.2016., 21:03   #334
Drvoje
Drvoje's Avatar
Postovi: 4,037
Lako se tebi igrat s "oton" vodenjarom
Pomelo mi sig -.-
Staro 02.03.2016., 21:19   #335
arrow
arrow's Avatar
Lokacija: Zd
Postovi: 609
nego, ima li smisla ici vise uz povecanje napona?
po pitanju temperature mogu je jos podosta dignuti ali me nekako strah da joj ne skratim "muke"
Staro 02.03.2016., 23:10   #336
Drvoje
Drvoje's Avatar
Postovi: 4,037
Baci sliku hlađenja regulacije napona, kolike su ti uopće VRM temp u full loadu (ako grafa podržava prikaz u npr. GPU-Z)?
Pomelo mi sig -.-
Staro 03.03.2016., 01:19   #337
arrow
arrow's Avatar
Lokacija: Zd
Postovi: 609
hladjenje je ok jer je tu full cover vodeni blok
te evo slika svih ostalih vrijednosti
Staro 03.03.2016., 09:49   #338
Drvoje
Drvoje's Avatar
Postovi: 4,037
Mislim da to fino možeš oderat s naponima bikoz full blok odradi svoje iz priloženog
Odlične temperature u "Furmrak" odronu brale onooooooooo, totalni lajk
Bilo je ekipa koje se hvalila kako ima je nepoderivi AMD (neke od starijih serija) vozija par godina s GPU temp 80-90 u "geymanju", mogu mislit na koliko im se kurila naponska regulacija - ovo tvoje triba čok ka VW dizel da se uopće zagrije
Pomelo mi sig -.-
Staro 03.03.2016., 18:30   #339
arrow
arrow's Avatar
Lokacija: Zd
Postovi: 609
evo probao ali nemam screenshot
gpu vcore 1.3v
gpu clock 1240mhz
memory clock 1815mhz
potrosnja preko 220w dok je default povuce oko 165w
temperatura gpu-a 49c te vrm-a 61c
mislim da nema potrebe za ovime, barem ne za moje potrebe
Staro 03.03.2016., 21:06   #340
Cloker
Cloker's Avatar
Datum registracije: Oct 2014
Lokacija: Bojnik
Postovi: 235
Autor arrow Pregled postova
gpu vcore 1.3v
gpu clock 1240mhz
Ne brini se nista joj nece biti,more to jos gore jer su ti dobre temperature
ja moju za 24/7 drzima na:
http://prntscr.com/aasgjp
A da ,u pitanju je r9 290 isto na H2O,inace za potrebe testiranja i benceva ide ona i na 1300 sa +250mV
Cloker je offline   Reply With Quote
Staro 05.03.2016., 17:51   #341
blava
blava's Avatar
Lokacija: スラボニア
Postovi: 3,064
Autor Cloker Pregled postova
Meni jos nije jasno koliko tih stavki za monitoring ima R9 280x,a kod R9 280 pola nedostaje
Staro 05.03.2016., 20:21   #342
Sam Fischer
Džabe si krečio!
Postovi: 5,191
Autor blava Pregled postova
Ja sam sve to imao na HD7950... Ovisi od samog proizvođača koliko senzora natrkelji, koji bios stavi, etc...
Staro 05.03.2016., 20:25   #343
blava
blava's Avatar
Lokacija: スラボニア
Postovi: 3,064
E onda je MSI stvarno skrt,vise opcija ima R7 240
Staro 05.03.2016., 21:59   #344
Drvoje
Drvoje's Avatar
Postovi: 4,037
Pripazi diraš se u MSI superirornost
Pomelo mi sig -.-
Staro 06.03.2016., 14:03   #345
Cloker
Cloker's Avatar
Lokacija: Bojnik
Postovi: 235
Flesni drugi bios mozda dobijes ostale instrukcije
Staro 07.03.2016., 18:45   #346
Prki
Prki's Avatar
Postovi: 1,317
Za sve koji imaju problema sa artefaktima i grijanjem dotične Bios 015.039.000.000.000000 (1000/1500) bi trebao riješiti problem.Ovo je za ASUS TOP Direct ii ali koliko vidim radi i na drugim karticama.Znači nije stvar u novijem nego u starijem biosu i da bude na 1000/1500MHZ.Ima i novija verzija 015.041.000.000.000000 (1000/1500) ali se na nekim modelima pokazalo kao loš BIOS dok je drugima i taj radio.Znači underclockat ju preko Bios-a i trebalo bi raditi.Underclock preko OC programa NE riješava problem.
Zadnje izmijenjeno od: Prki. 07.03.2016. u 19:31.
Staro 01.04.2016., 02:15   #347
MikaHR
Postovi: 1,264
MikaHR je offline   Reply With Quote
Staro 01.04.2016., 20:43   #348
blava
blava's Avatar
Lokacija: スラボニア
Postovi: 3,064
Jel ovo za reklamaciju ili moguce da napajanje uzrokuje posto je na knap ?
Pojavi se nakon 10-15 min igranja GTA 5,Witcher,AC Unity itd.
Najnoviji BIOS i sve default.
Staro 01.04.2016., 22:24   #349
webstartm
Sandy!!!
webstartm's Avatar
Postovi: 1,695
Nije to do napajanja
Taj xfx je dovoljno jak za proc i grafu (proc u full 150w-180w i grafa max 250w u benchmarcima, a u gejmingu nekih 200W)
Vjerojatno memorija na grafi rikaje
Vidi temperature i to pa nosi na reklamaciju
Staro 01.04.2016., 22:28   #350
blava
blava's Avatar
Lokacija: スラボニア
Postovi: 3,064
Autor webstartm Pregled postova
Temperature su oke,kad je auto ne prelazi 65-70 stupnjeva dok na rucnih 60 % fan ne prelazi opet 75 stupnjeva.
Memorija je Elpida na ovoj R9 280X,mislim jel to validan razlog za reklamaciju da ne bi oni testirali 5 min furmark i zakljucili da je sve u redu ( probao sam Furmark,nece da stressa graficku na 99 % GPU usage vec 50 - 60 % ) ?
Staro 01.04.2016., 22:44   #351
webstartm
Sandy!!!
webstartm's Avatar
Postovi: 1,695
Neznam za furmark zast nece da zakuca na 100%,probaj sa nekih drugim benchom.
Al mozes im snimit video sa mobitelom tih sjebanih textura i priloziti/pokazati kad budes predava grafu.
I stavi fanove na 100% pa probaj dobit te sjebane texture, jer vjerojatno ce oni opicit fanove na 100% eto dok testiraju
Staro 02.04.2016., 00:24   #352
Alfa_R
Alfa_R's Avatar
Postovi: 2,928
Zašto bi opičili 100% fan? Kartica mora raditi sve na stock postavkama.
Ako se ruši na stock fanu to je više nego dovoljno za je proglasiti neispravnom.
Furmark možda traži power target na +50% ili koliko već ide.... no to nije stock :P
Staro 02.04.2016., 00:38   #353
blava
blava's Avatar
Lokacija: スラボニア
Postovi: 3,064
Sad ne znam da li da reklamiram ili ne posto je prijasnji vlasnik isto imao artefakte u Witcher 3,a ima dosta jace napajanje ( Seasonic 600 W ).
To se uobicajeno dogodi nakon 10-15 min igre bio fiksiran fan na 60 % pa temperature 75 celzijusa ili Auto pa drzi ispod 65 stupnjeva,nema razlike.
Dogodi se u AC Unity,Witcher 3,Dying Light,a uz to cesto dropa core clock sa 1100 MHz na 1000 MHz.
Staro 02.04.2016., 02:04   #354
Mladenxy
Mladenxy's Avatar
Postovi: 4,511
po meni to je neispravna grafa.
Staro 02.04.2016., 10:43   #355
Drvoje
Drvoje's Avatar
Postovi: 4,037
Sad ne znam da li da reklamiram ili ne posto je prijasnji vlasnik isto imao artefakte u Witcher 3,a ima dosta jace napajanje ( Seasonic 600 W )...
Onda pogotvo odnesi, i javi šta je bilo (btw snimi mobitelom kako je kolega webstartm spomenija)
Pomelo mi sig -.-
Staro 02.04.2016., 11:19   #356
MikaHR
Postovi: 1,264
Tu bi se i ja složio, snimi što se dešava i reklamacija.
Staro 02.04.2016., 11:53   #357
Kal-EL
Kal-EL's Avatar
Lokacija: Vinkovci
Postovi: 478
@blava pa tebi se puno više događa nego meni, meni je znalo blokirat sa onim ekranom punim crtama, (artefakta ili čega već) ili izbacit pa ako "driver not responding".
Spremi ti ovo pa da šaljemo na reklamaciju.
Kal-EL je offline   Reply With Quote
Staro 09.04.2016., 14:24   #358
VoodooRain
VoodooRain's Avatar
Lokacija: Požega
Postovi: 706
evo moja je izgleda svoje odradila
sinoc dok sam gledao film na tv-u spojeno hdmi-jem skuzio sam nekakvo lomljenje slike dosada nevidjeno
i kada je film zavrsio isprobam wot i negdje negdje mi se raspadne tekstura i propadne mapa onako nestanu objekti izadjem van iz igre pokrenem furmark i dobijem ovo
https://www.youtube.com/watch?v=2NwE...ature=youtu.be
neznam sto je sumljam da je memorija svoje odbrojala jel mulci nisu bili pametni da povezu taj masivni hladnjak sa memorijom da i na nju nasjeda
i danas sam poslao grafu na garancju pa cemo vidjeti sto ce reci
VoodooRain je offline   Reply With Quote
Staro 15.04.2016., 22:35   #359
Dinozye
Datum registracije: Apr 2016
Postovi: 37
i5 2500k OC 4.5 GHz
Kupio bi 280x, a imam i5 2500k OC 4.5 GHz pa me zanima dal mi je dosta jak procesor da ne bottlenecka graficku
Dinozye je offline   Reply With Quote
Staro 15.04.2016., 22:36   #360
blava
blava's Avatar
Lokacija: スラボニア
Postovi: 3,064
Autor Dinozye Pregled postova
Miran si,ne brini,ne bottlenecka taj i5 puno jace graficke
https://www.youtube.com/results?sear...+2500k+r9+280x
