Staro 02.03.2016., 19:35   #5101
Facelessone
Facelessone's Avatar
Postovi: 4,204
Ak na temelju toga bude moguć raskid ugovora dok si pod obvezom meni paše
AMD Ryzen 7 5700X
BQ Pure Rock
MSI B450 Tomahawk Max
500GB Crucial MX500
Fractal Define R4
Corsair HX850 Platinum
Logitech MX Master 3
Logitech MX Keys
Logitech Z2300
Dell U2715H
Iskon 300/100 Mbps
CPU Intel i7-4810MQ
VGA nVidia GT730M 1 GB
RAM DDR3 16 GB 1600 MHz
SSD 500 GB Sandisk Ultra
LTE Modem
DVD-RW
9 cell battery
Napajanje 135 W
Windows 10 Pro
Logitech MX Anywhere 3s
AMD Ryzen 5 7640HS
AMD RadeonT 760M
14" 2,8K, 120Hz
16GB RAM
1TB HDD
Windows 11 Pro
H110M-DGS
Intel i3-7100
8GB RAM DDR4
WD Red 8TB
WD Purple 4TB
Seagate IronWolf 3TB
Seagate SkyHawk 6TB
Nanoxia Deep Silence 4
Seasonic X650 SS-650KM Gold
Staro 02.03.2016., 20:27   #5102
morbid_angel
Lokacija: Tokyo
Postovi: 196
Bome bi pasalo i meni. Za zamjenu amis tv prijamnika trebalo je 2 poziva prema tehnickoj podrsci, s tim da su me 3 puta zvali. Od tih 5 puta (poziva), 4 puta sam ponavljao ISTU stvar, da bi na kraju zakljucili da bi mozda bilo dobro zamijeniti uredjaj. I za tu zamjenu im treba 4 dana. Cijeli postupak poziva trajao tjedan dana... Ispada da je onaj Evo TV od poste bolji od Amis TV-a.
A kvaliteta tehnicke podrske je takva da nit sami neznaju koristiti uredjaje... Zalosno.
CPU: i7 4710HQ
MBO: NEXTGEAR-NOTE i5700
RAM: 4*8 GB DDR3 1600 MHz
GPU: nvidia GTX970M
SSD1: Crucial MX100 512 GB
SSD2: Samsung 850 EVO 1TB
OS: Windows 8.1
MBO: HP NW9440
CPU: C2D T7600
RAM: 2*2 GB DDR2 667 MHz
GPU: nvidia Quadro FX 1500M 512MB
SSD: SanDisk 32GB
HDD: Toshiba 100GB 7200 rpm
Dock: HP Advance Docking Station 180W
OS: Windows 8.1 Professional x64 / OpenSUSE 13
CPU: Intel Core i5 3570K & Scythe Mugen 4
MBO: ASRock Z77 Extreme 4
RAM: 4*8 GB DDRIII 1600 MHz
GPU: VTX3D 7970 & XFX 280X-TDFD
SSD: 2*Vertex 4 128GB (RAID 0)
HDD: Seagate 2TB
PSU: Coolermaster Silent Pro M2 1500W
Case: Coolermaster CM 690 III
LCD: 2*Dell U2412M
Periferija: Logitech G510 & G500, Denon AH-D400
CPU: AMD FX-6200 & Scythe Ninja 3
MBO: Asus M5A97 Evo R2 AMD3+
RAM: 2*8 GB DDRIII ECC
HDD: 2*WD Red 2TB
PSU: XFX 550W
Case: Fractal Design Define XL R2
OS: ESXi 5.5
CPU: AMD Athlon II X4 & Scythe Big Shuriken 2
MBO: ASRock 880G Extreme 3
RAM: 4*4 GB DDRIII 1333 MHz
HDD1: WD Red 2TB
HDD2,3,4: 3*WD Green 2TB
HDD5: Samsung 1 TB
HDD6: Seagate 1500GB
PSU: Corsair VX 450W
Case: Chieftec BA-02B-B-B
OS: Windows Server 2012 R2
CPU: AMD Athlon x2
MBO: Gigabyte GA-M55plus-S3G
RAM: 4*2 GB DDRII 800 MHz
HDD1,2,3: Seagate PATA 320GB
PSU: Corsair CX 400W
Case: White ;D
OS: ESXi 5.5
MBO&CPU&GPU: ASRock E350
RAM: 1*4 GB DDRIII 1333 MHz
SSD: SanDisk 32GB
Case&PSU: Inter-Tech e-i7
OS: Windows 7 Pro x64 + XBMC
SSD: SanDisk 32GB
CPU: C2D 2.4 GHz
MBO: MacBook Pro 13" mid-2010
RAM: 2*4 GB DDR3 1066 MHz
GPU: nvidia 320M
SSD: Kingston HyperX 3K 120GB
HDD: Toshiba 250GB 5400 rpm
OS: OS X 10.9
morbid_angel je offline   Reply With Quote
Staro 02.03.2016., 20:35   #5103
Marko :)
Datum registracije: Feb 2016
Lokacija: Unknown
Postovi: 718
Prije je kvaliteta usluge bila odlična, služba za korisnike se brzo javila i znali su riješiti problem. Ako pak nisu znali riješiti problem, rekli su kako ne znaju u čemu je problem i da će poslati tehničara. Danas je služba za korisnike 0 i sve se pomalo zatvara i tjeraju se korisnici na Vip/B.net. Žao mi je što će sve ovako završiti.
Marko :) je offline   Reply With Quote
Staro 02.03.2016., 20:52   #5104
Old Iggy
Old Iggy's Avatar
Postovi: 4,888
Autor Marko :) Pregled postova
Da, što je najgore kao kolateralna šteta.
Izgleda da i TV ima problema, ne daju se pogledati neke propuštene emisije...
Igor Batinic
Staro 02.03.2016., 21:04   #5105
Marko :)
Lokacija: Unknown
Postovi: 718
http://www.bug.hr/forum/post/poveziv...e/4943724.aspx
Ovdje je jedan forumaš napisao kako Amis na ugovorima ima novi logo. A što će im novi logo ako gase Amis u drugoj polovici ove godine. :/
Staro 02.03.2016., 22:19   #5106
Bono
Uptime 99.99%
Bono's Avatar
Postovi: 2,547
I tako opet problemi, dugo je trajao mir.
Edit sad je opet dobro.
Sad opet nije, ali cini mi se da je to samo na ADSL-u/VDSL-u:
traceroute to www.index.hr (104.23.128.79), 30 hops max, 60 byte packets
1 192.168.1.1 (192.168.1.1) 0.372 ms 0.400 ms 0.495 ms
2 194.146.109.189 (194.146.109.189) 34.130 ms 35.258 ms 35.210 ms
3 * * *
4 mx-lj1-xe-3-2-1.amis.net (212.18.41.5) 72.649 ms * 72.566 ms
5 mx-vi1-te-0-0-0.amis.net (212.18.44.142) 81.312 ms 81.282 ms 81.232 ms
6 vix.edge01.vie01.as13335.com (193.203.0.195) 81.202 ms * *
7 104.23.128.79 (104.23.128.79) 119.436 ms 117.143 ms 117.145 ms
Zadnje izmijenjeno od: Bono. 02.03.2016. u 22:35.
Staro 02.03.2016., 22:23   #5107
sinke.ZG
sinke.ZG's Avatar
Postovi: 733
Kak mislis da ih tjeraju na vip... pa vip je kupio amis tako da su svi korisnici amisa na vipu
sinke.ZG je offline   Reply With Quote
Staro 02.03.2016., 22:27   #5108
Thermaltake
1
Thermaltake's Avatar
Postovi: 3,565
I meni počelo štekat isto užasno stavio sam dns-ove od google odma je proradio, izgleda da im dns-ovi neš jebu.
EDIT:
Izgleda da dns-ovi nemaju veze i dalje šteka.
Zadnje izmijenjeno od: Thermaltake. 02.03.2016. u 22:36.
Staro 02.03.2016., 22:29   #5109
Marko :)
Lokacija: Unknown
Postovi: 718
Evo opet problema.
Autor sinke.ZG Pregled postova
Nije Vip kupio Amis. Telekom Austrija je kupio Amis i isti je dao Vipnetu da upravlja Amisom u HR. Amisom u SLO upravlja Si.mobil.
Lijepo, B.netovci zovu Amisove korisnike s Amisovog broja i nude usluge s većim brzinama nego što imaju sada. To za sada zovu samo korisnike na bakrenoj parici...
Zadnje izmijenjeno od: Marko :). 06.03.2016. u 18:37.
Staro 02.03.2016., 22:37   #5110
Bono
Uptime 99.99%
Bono's Avatar
Postovi: 2,547
Zovu ih da mogu upravi prikazati kako Amis nakon preuzimanja ima zanemariv broj korisnika i kako bi mogli brand ugasiti.
Naravno da steka packet loss je 75%.
Staro 02.03.2016., 22:40   #5111
Thermaltake
1
Postovi: 3,565
Meni jedino mogu ponudit gigabitnu vezu što čisto sumnjam da će ponudit tako da dok je ftth-a ja se ne mičem, a tel i tv ću kad tad odkantat samo ću net ostavit od njih jer i VoIP i ovaj stream im je valjda oduvijek bio najlošija strana.
Staro 02.03.2016., 22:40   #5112
Marko :)
Lokacija: Unknown
Postovi: 718
Nemam pojma. Ja sam na optici i isto imam problema. :/
Staro 02.03.2016., 22:41   #5113
dcesar13
Datum registracije: Mar 2016
Postovi: 2
Opet zeza 22:39. Nisu normalni.
dcesar13 je offline   Reply With Quote
Staro 02.03.2016., 22:43   #5114
Marko :)
Lokacija: Unknown
Postovi: 718
Jel netko pokušao zvati službu za korisnike, ponovno?
Staro 02.03.2016., 22:43   #5115
Bono
Uptime 99.99%
Bono's Avatar
Postovi: 2,547
Iskljucili su telefone i odmor
Staro 02.03.2016., 22:44   #5116
Thermaltake
1
Postovi: 3,565
Imamo svi trenutno problema, no inače do prije par dana od kako se ovo počelo dešavat meni je net radio super bez ikakvih problema, no tv i tel. su skroz druga priča.
EDIT:
Ja sam pokušao nazvat i dobio, odma automat na početku govori da imaju poteškoća te da intenzivno rade na tom da se uklone u najkraćem mogućem roku
Staro 02.03.2016., 22:45   #5117
Marko :)
Lokacija: Unknown
Postovi: 718
Meni je ovo prvi puta od kad ih je Vip preuzeo da imam poteškoća. :/
EDIT:
Da rade na otklonu kvara - doma, u krevetu, spavaju.
Zadnje izmijenjeno od: tor. 03.03.2016. u 07:29.
Staro 02.03.2016., 22:48   #5118
Bono
Uptime 99.99%
Bono's Avatar
Postovi: 2,547
Prvi put da si primjetio, ovo je drugi put danas i u nedjelju je isto bilo.
Staro 02.03.2016., 22:49   #5119
Marko :)
Lokacija: Unknown
Postovi: 718
Danas sam popodne oko 16h primjetio probleme. U nedjelju nisam imao nikakvih problema s internetom.
Staro 02.03.2016., 22:52   #5120
Bono
Uptime 99.99%
Bono's Avatar
Postovi: 2,547
Oko 12 sati je bilo problema, dobio sam alert na poslovnim linijama, tako da nema sanse da nije bilo problema. Uglavnom koliko vidim sad je OK.
Staro 02.03.2016., 22:55   #5121
Marko :)
Lokacija: Unknown
Postovi: 718
A dobro, u 12h nisam bio kod kuće tako da nisam koristio internet.
Staro 03.03.2016., 09:12   #5122
Cilim
Cilim's Avatar
Postovi: 1,542
Imam novi ugovor od prije par dana, na njemu isti logo koji je i na njihovim stranicama, stari logo.
Cilim je offline   Reply With Quote
Staro 03.03.2016., 10:33   #5123
Marko :)
Lokacija: Unknown
Postovi: 718
Čudno.
Staro 03.03.2016., 10:51   #5124
lutherus
lutherus's Avatar
Datum registracije: Sep 2011
Lokacija: Dubai UAE
Postovi: 714
Zapravo se Amis ne gasi u drugoj polovici godine već će amis, bneti i vip biti pod jednim imenom, vipnet. Izvor: 4g staža u vipnetu.
Note to the AMD haters: nobody cares
lutherus je offline   Reply With Quote
Staro 03.03.2016., 14:36   #5125
New One
New One's Avatar
Datum registracije: Apr 2008
Lokacija: Velika Gorica
Postovi: 471
Lutherus sry, ali nije drek neg se pas posro. Nivo usluge vipa je mizerija. Dovoljno da svoju poslovnu etiku prenesu...
New One je offline   Reply With Quote
Staro 03.03.2016., 14:45   #5126
Cilim
Cilim's Avatar
Postovi: 1,542
Net je i dalje spor, stranice se spori dizu.
Staro 03.03.2016., 14:48   #5127
FitzTN
FitzTN's Avatar
Lokacija: Samobor, HR
Postovi: 1,615
Počeli problemi prije 10ak minuta...uglavnom sve stranice hostane izvan Hrvatske ne rade ili se učitavaju "danima"
Staro 03.03.2016., 14:52   #5128
telefunken
telefunken's Avatar
Datum registracije: Apr 2015
Postovi: 705
meni isto loše. imam optiku i paket 100/100, samo internet. zadnjih par dana šteka grozno, nešto se popravi nakon reseta modema ali ne do kraja. evo sad mi je nakon reseta ping 26ms. 75,42/95,54. kad sam prešao, tamo u 11. mj bilo je stalno ping 1ms, ~99/~99
Pošten trgovac
Trgovine: 1, 2, 3, 4, 5, 6, 7
telefunken je offline   Reply With Quote
Staro 03.03.2016., 15:31   #5129
Marko :)
Lokacija: Unknown
Postovi: 718
Onaj mali Kuna Netw0rk na Twitteru kaže kak je jučer na Amis održao DDoS napade. HAHAHAHA!
Staro 03.03.2016., 18:24   #5130
sinke.ZG
sinke.ZG's Avatar
Postovi: 733
opet sranje kod mene na optici.....gubljenje paketa ogromno
