Datum registracije: Jun 2004
Postovi: 3,996
Problem sa Seagateom
Danas malo čačkam po HD tune-u i skontam da mi seagate izgleda ne valja ![]() Evo što kaže HD tune Ovo mi kaže SeaTools,ali morao sam iči na generic test,dakle za bilo koji hard,kad idem na seagate test baci mi neku grešku i moram restartat na dugme,CTRL-ALt-DEL ne reagira. "SeaTools Desktop v2.1.05 Copyright (c) 2004 Kroll Ontrack Inc. 10/11/2005 @ 11:59 PM The following information has been generated by the SeaTools Desktop. Use this information to help you recognize and resolve potential data access problems in a timely manner. System Information: BIOS Date 08/10/04 Conventional Memory size 638 K Extended Memory size 1016092 K IO Channel type PCI Drive Information: DRIVE SIZE MODEL ----- --------- --------------------- 1 80.02 GB ST380011A Serial Number = 3JV5BPPS Int13 Num = 81, PHYS CHS = 9729x255x63. ParmTable CHS, Rsvd = 9729x255x63 PARTITION CYLINDER SIZE ---------- ------------ ---- # Type Start End MB PRIMARY 1 NTFS 0 9728 80023 Diagnostic Results: Drive 1 (ST380011A) SMART Status Check Result: Unknown 90-Second Test Result: Passed File Structure Test Result: Failed Partition 1 (No Label) Result: Failed with critical Errors Complete Surface Scan Result: Not Selected S.M.A.R.T., (S)elf (M)onitoring (A)nalysis and (R)eporting (T)echnology, a built-in hard disk drive failure prediction method reports an 'Alert' if a problem has occurred. It reports 'Passed' if no problems are found and 'Unsupported' if a hard disk drive does not support S.M.A.R.T. ****************************************** Diagnostic Summary: System Memory Test Result: Passed Drive 1 (ST380011A) SMART Status Check Result: Unknown 90-Second Test Result: Passed File Structure Test Result: Failed Complete Surface Scan Result: Not Selected Recommendation: If you are not experiencing data loss and SeaTools reports File System Structure errors, they may be caused by a lock-up or failure to shutdown Windows correctly. Many times, these errors may be repaired through normal system maintenance. If you are experiencing a hardware error, you should isolate the cause and replace the failing component. If you are unsure how to proceed with repairs, contact a computer professional. After completing any maintenance tasks, run SeaTools again to verify that all errors have been repaired. If errors continue to occur, the system may not be stable. Again, contact a computer professional. SeaTools Desktop v2.1.05 Copyright (c) 2004 Kroll Ontrack Inc." A evo što kažu na netu o tome ovdje Probao sam formatirati ali opet je isto.Imao sam neke podatke na tom disku ali sam ih prebacio na hitachia za svaki slučaj.Dosad nisam primječivao neke probleme ali nisam tamo ni pristupao često. Sad kad sam formatirao svaki put kad ulazim u windowse provjerava onaj chdisk taj Seagate. ne znam što da radim,da reklamiram to,promam low level format ili što,ali na onoj stranici piše da je to hardwerske prirode pa pretpostavljam da format ne bi pomogao? Sorry na dužem postu ali ne mogu krače ![]() |
Postovi: 7,568
Reklamiraj. Sigurno je sigurno. |
#3 | |
Postovi: 3,996
A ništa,sutras ga nosim,reči ču da su mi nestali neki podaci ,da se javlja chdisk na startu,za te greške,ponjeti to na floppyu i tak.Zadnje izmijenjeno od: Veki-os. 13.10.2005. u 00:38. |
Datum registracije: Sep 2004
Lokacija: VG
Postovi: 846
Skroz mrtav hard se lako zamjeni.... nije dobro reklamirat skoro pa ispravan proizvod.... |
#7 | |
Postovi: 3,996
Ili je ispravan ili nije,nema srednje. |
Postovi: 7,568
Nemaš kaj čekati, idi nek ti daju novi i ne napuštaj dućan bez novog diska. |
Postovi: 7,568
Glavno da je reklamacija prošla, sad se jedino trebaš malo strpeti dok ne stigne novi. |
#11 | |
Datum registracije: May 2005
Lokacija: Zgb - shpaolin
Postovi: 641
Postovi: 7,568
Ak budu to rekli, onda su budale. Mislim da bu dobil novi disk. |
#13 | |
Postovi: 3,996
ozbiljno |
#14 | |
Strichek Moderator
Postovi: 9,346
nakon toga, JA sam išo sa starim i dobih novo napajanje. ![]() |
Postovi: 7,568
Ako su ljudima u stanju ''prodavati'' takve gluposti, onda oni imaju ozbiljnih problema......Psihičkih, a kad ih dohvati neki razjareni kupac, onda i fizičkih. ![]() |
