Lokacija: Županja
Postovi: 17
![]() Moja konfa je: P4 1.4 Ghz socket 423 (Willamette) Abit TH7 - Raid matična ploča 256 Mb RDRAM 400 MHz Rambus IBM 40 GB HDD 7200 okr / min, 2 Mb cache Hercules 3D Prophet 4500 64 Mb SDRAM (Kyro 2) Sony 52 x CD - rom Napajanje: AC 230 V; 250 W Windows XP Professional + service pack 1 U Bios - u mi je AGP podešen na 4 x Imam veliki problem sa igrama - nijedna igra (osim 2D igara, one rade) ne radi. Instalirao sam najnovije drivere za Win XP (mislim v 16.055) i opet ništa ne radi. Kada pokrenem igru prvih par sekundi se sve normalno pokrene i onda grafika jednostavno "poludi" - kursora je oko 10 - ak na ekranu i konstantno se slika trza u jednoj te istoj sceni iz igre. Naravno, igra zablokira. ![]() ------------------ System Information ------------------ Time of this report: 12/22/2002, 11:44:22 Machine name: DARIO Operating System: Windows XP Professional (5.1, Build 2600) Service Pack 1 (2600.xpsp1.020828-1920) Language: English (Regional Setting: Croatian) System Manufacturer: ABIT System Model: 6A69SA19 BIOS: BIOS Rev:0.1 Processor: Intel(R) Pentium(R) 4 CPU 1400MHz Memory: 256MB RAM Page File: 110MB used, 423MB available Windows Dir: C:\WINDOWS DirectX Version: DirectX 9.0 (4.09.0000.0900) DX Setup Parameters: Not found DxDiag Version: 5.03.0000.0900 32bit Unicode ------------ DxDiag Notes ------------ DirectX Files Tab: No problems found. Display Tab 1: The file pmxdisp.dll is not digitally signed, which means that it has not been tested by Microsoft's Windows Hardware Quality Labs (WHQL). You may be able to get a WHQL logo'd driver from the hardware manufacturer. DirectDraw test results: All tests were successful. Direct3D 7 test results: Failure at step 32 (User verification of Direct3D rendering): HRESULT = 0x00000000 (error code) Direct3D 8 test results: Failure at step 32 (User verification of Direct3D rendering): HRESULT = 0x00000000 (error code) Direct3D 9 test results: Failure at step 32 (User verification of Direct3D rendering): HRESULT = 0x00000000 (error code) Sound Tab 1: The file als4000.sys is not digitally signed, which means that it has not been tested by Microsoft's Windows Hardware Quality Labs (WHQL). You may be able to get a WHQL logo'd driver from the hardware manufacturer. DirectSound test results: All tests were successful. Music Tab: DirectMusic test results: All tests were successful. Input Tab: No problems found. Network Tab: No problems found. DirectPlay test results: The tests were cancelled before completing. -------------------- DirectX Debug Levels -------------------- Direct3D: 0/4 (n/a) DirectDraw: 0/4 (retail) DirectInput: 0/5 (n/a) DirectMusic: 0/5 (n/a) DirectPlay: 0/9 (retail) DirectSound: 0/5 (retail) DirectShow: 0/6 (retail) --------------- Display Devices --------------- Card name: 3D Prophet 4500 Manufacturer: Hercules Chip type: PowerVR KYRO DAC type: PowerVR Device Key: Enum\PCI\VEN_104A&DEV_0010&SUBSYS_00101681&REV_07 Display Memory: 64.0 MB Current Mode: 1024 x 768 (32 bit) (100Hz) Monitor: SyncMaster 755DF(X)/705DF(X),MagicSyncMaster CDP17BDF(U)(UP) Monitor Max Res: 1792,1344 Driver Name: pmxdisp.dll Driver Version: 6.13.0010.6270 (English) DDI Version: 8 Driver Attributes: Beta Retail Driver Date/Size: 9/27/2002 16:34:52, 49376 bytes WHQL Logo'd: No WHQL Date Stamp: None VDD: n/a Mini VDD: powervr.sys Mini VDD Date: 9/27/2002 16:34:46, 566496 bytes Device Identifier: {D7B71EAA-4350-11CF-4F6D-1A20A5C2CB35} Vendor ID: 0x104A Device ID: 0x0010 SubSys ID: 0x00101681 Revision ID: 0x0007 Revision ID: 0x0007 Video Accel: ModeH263_A ModeMPEG1_A ModeMPEG2_A ModeMPEG2_C Deinterlace Caps: n/a Registry: OK DDraw Status: Enabled D3D Status: Enabled AGP Status: Enabled DDraw Test Result: All tests were successful. D3D7 Test Result: Failure at step 32 (User verification of Direct3D rendering): HRESULT = 0x00000000 (error code) D3D8 Test Result: Failure at step 32 (User verification of Direct3D rendering): HRESULT = 0x00000000 (error code) D3D9 Test Result: Failure at step 32 (User verification of Direct3D rendering): HRESULT = 0x00000000 (error code) Ne znam što nije uredu. :confused: Molim za pomoć! ![]() |
MadModerator
Datum registracije: Sep 2002
Lokacija: N/A
Postovi: 5,195
Mislim da ti je stvar u driverima. Odakle si ih skinuo? kod mene su verzija 6.13.10.6270(english) Skini nove drivere sa Herculesovog site-a.
#3 | |
MadModerator
Lokacija: N/A
Postovi: 5,195
Točnije skini ove drivere. Oni su za XP i Hercules 3d Prophet 4500 (bez TV-outa) http://europe.hercules.com/supportf....t=DRIVER&os=23 Citiraj:
Ovaj dio mi nije jasan. Beta?
#4 | |
Administrator
Lokacija: Sesvete
Postovi: 15,963
Koliko mi se čini nešto je prtljo s driverima. Imao sam tu grafulju i svašta mi se dešavalo ali ovako nešto nije a nema što nisam radio s njom. Igrao sam na njoj neku beta verziju UT 2003, nakon prtljanja po registriju pa mi nije ovakva iznenađenja priredila. Jesi možda radio nešto s BIOSOM od grafičke? Da je nisi možda OC-ao? Promijeni ti drivere koji ti je dao ludi boy pa vidi onda. Ona beta tamo mi je čudna. |
Lokacija: Županja
Postovi: 17
Ma, imao sam grafičku overclockiranu neko vrijeme na 185 / 185, ali sam ju vratio na staro. Drivere za nju sam uvijek skidao sa Herculesovog site - a, pa tako i ove. Bios grafičke nisam dirao. ![]() Ali OK skinit ću te drivere pa ću vam javiti kako je prošlo! ![]() |
Lokacija: Županja
Postovi: 17
Isto kao i prije...
Skinuo sam drivere s onog linka koji mi je MadBoy dao instalirao ih i shvatio da su to isti driveri koje ja imam. Također piše Beta retail i isto je ova verzija drivera - 6.13.0010.6270 (English). I opet isti problem... ![]() ![]() |
#7 | |
MadModerator
Lokacija: N/A
Postovi: 5,195
[ Citiraj:
Lokacija: Županja
Postovi: 17
AGP 2 x
Promijenio sam AGP Data Transfer rate na 2 x, ali je sve opet isto! ![]() |
#9 | |
MadModerator
Lokacija: N/A
Postovi: 5,195
Re: AGP 2 x
Onda reinstaliraj Windowse. Najprije instaliraj Windowse pa onda Service pack, pa onda drivere za matičnu, pa onda drivere za grafiču i nakon toga ostale. Ako ti ovo ne pomogne imaš ispriku za novu grafičku ![]() Koliko ti je grafička radila na 185/185? To ti nije bilo baš pametno ako nisi imao neko dodatno hlađenje i otvoreno kućište. ![]()
Lokacija: Republic Of Maximir
Postovi: 354
probaj resetirati BIOS na fail-safe opcije, ne znam kako to ide na win XP, ali potrazi jel imas kakve opcije za popravljanje windowsa, ostavi si reinstalaciju za kraj, tek ako ti nista vise ne pada na pamet...
Imao super komp koji sam poklonio curi, sad radim na sasvim prosjecnom laptopu i bas mi je OK ![]() |
Lokacija: Županja
Postovi: 17
Kada u Biosu ucitam fail-safe i restartiram komp ne mogu se Windowsi podići. Prvo mi kaže da nešto nije u redu s procesorom ili da sam ga promijenio, a onda pritisnem F1 za nastavak i onda bi se trebali ucitati Windowsi, ali nema nista, samo crni ekran smrti... ![]() ![]() ![]() Imam jos jedno pitanje. ![]() |
#12 | |
Administrator
Lokacija: Sesvete
Postovi: 15,963
Lokacija: Županja
Postovi: 17
Ma, 185 / 185 nije ništa.. ![]() ![]() |
#14 | |
MadModerator
Lokacija: N/A
Postovi: 5,195
190/190!!!!! meni sve puca na 183/183 tad se u nekim igrama pojavljuju čudne stvari. Nebi bilo čudno da ti je grafička malo pregorila ![]() ![]()
Administrator
Lokacija: Sesvete
Postovi: 15,963
Ajmo ofako. Ako imaš mogučnost isprobaj grafulju kod nekog drugog na compu pa čemo znati u čemu je fora. Mislim, ako iste stvari radi na drugom compu jebiga barem je jasno o čemu se radi... A ako ne; reinstal windoza i polako slaži nadalje programe, igrice dok ne vidiš što te točno jebe. |
#16 |
Lokacija: Županja
Postovi: 17
Ma nisam imao nikakvo dodatno hlađenje... Ali to ništa nije u usporedbi sa mojom starom TNT 2 M64. To je bila overclockerska zvijer! :clap: U Power Stripu sam je natjerivao do 200 / 200 Mhz!!! Al' je bilo vruće! ![]() ![]() |
#17 | |
Datum registracije: Oct 2001
Lokacija: Vinkovci
Postovi: 5,231
#18 | |
Datum registracije: Aug 2002
Lokacija: Zagreb, Croatia
Postovi: 1,332
#19 |
al se nekad dobro jelo...
Postovi: 3,312
Je , moguće je , mislim da je Guilemontov TNT2 Ultra radio na 175/183 po defaultu (Maxi Gamer Xentor 32 TNT2 Ultra , e to je drobiloooo.)
Zenfone 9 | Zephyrus M16 | HP Chromebook X2 | Tesla Model Y LR |
#23 |
Postovi: 3,312
Radi , ali nije igrivo , ali dobro dođe za interaktivni screensaver ![]()
