#3271 |
Datum registracije: Mar 2015
Postovi: 1,254
markdeejay 1 x XFX R9-280X-TDFD, DD Radeon R9 280X 1000M Boost 3GB DDR5 1 x Procesor Intel Core i5-4460 (3.20GHz,1MB,6MB,84 W,1150) Box 1 x Asrock B85 ANNIVERSARY - Supports 4th Gen & 5th 1 x DDR3 8GB (2x4GB) Kingston, 1866MHz, CL10, HyperX Fury 1 x Napajanje Corsair 550W, CS550M Modular PSU, 550 Watt, ATX 1 x HDD WD 1TB, Caviar Blue 10EZEX, 1000 GB, SATA3,64 MB, 3,5", 24mj 1 x ASUS DRW-24F1ST/BLK/B/AS SATA, DVD-R 24x, DVD-RW 6x, DVD+R 24x 1 x Kućište ANTEC GX505, MIDI, window edition, crno, bez PS Ukupno: 6.114,95Kn besplatno slaganje i dostava! Ja bi ovako za pocetak nauštrb SSD-a poboljsao ostale komponente, pa kasnije isao na neki od 240GB. |
#3272 |
Datum registracije: Dec 2009
Lokacija: Koprivnica
Postovi: 40
Pozdrav. Malo sam kombiniral vaše prijedloge i došel sam do slijedeće konfiguracije. Išel bi na jaču grafičku u kombinaciji sa AMD-om i, za sada, bez SSD-a. Procesor AMD FX-Series X8 8300 3.3GHz,16MB,125W,AM3+, FD8300WMHK Gigabyte 970A-DS3P, AM3+, AMD 970 SB950, 4x DDR3 2000(O.C.)/1866 Sapphire R9 390 NITRO, Tri-X OC, 8GB GDDR5, 512 bit DDR3 8GB (2x4GB) Kingston, 1866MHz, CL10, HyperX Fury HDD Seagate 1TB, Serial ATA III, 7200 rpm, ST1000DM003 Zalman Z1 mid tower case. 199(W)x432(H)x457(D)mm. MB standard Napajanje Fortron 600W, Hyper, PPA6003302, 12cm ventilator ASUS DRW-24F1ST/BLK/B/AS SATA, DVD-R 24x, DVD-RW 6x, DVD+R 24x Cijena: 6.238,98Kn Kaj kažete? |
#3275 |
Postovi: 40
Pozdrav još jednom. Dobio sam u jednom dućanu slijedeću ponudu pa me zanima vaše mišljenje. MB ASROCK AMD AM3+ SOC 760G CHIPSET M-ATX 583kn CPU AMD X8 8350 AM3+ 1449kn VGA POWERCOLOR R9 390 8GB DDR5 3099kn DDR3 2X4GB CORSAIR 1600 VENGEANCE 513kn KUĆIŠTE SHARKOON BD28 MIDI TOWER ATX, BEZ NAPAJANJA 519kn POWER SUPPLY ZALMAN 600W LX SERIES 449kn HLADNJAK ZA CPU COOLER MASTER HYPER TX3 EVO 183kn HDD 1TB TOSHIBA DT01ACA100 3,5 SATA 6GB/S 7200 RPM 32MB 439kn DVD-RW LG GH24NSD1 BULK BLACK SATA 89kn U totalu 7323kn, al na to mogu dobiti 10% popusta pa bi me izašlo 6590,70kn. Hvala. ![]() |
#3277 |
MiningMod
Postovi: 8,715
1. užasna ploča, nikako nije za takav procesor 2. preskupo kućište 3. jako loše napajanje za takav komp Za 6600kn se složi puno kvalitetnije: 1 x AMD FX X8 8300 (3.3GHz,16MB,95W,AM3+) box 1 x CPU Hladnjak Alpenföhn Ben Nevis, 120mm, PWM 1 x GIGABYTE GA-970A-DS3P, AM3+, R2.0, 4+1 Phase, 125W CPU 1 x KINGSTON ValueRAM DDR3 (8GB,1600MHz(PC3-12800)) CL11, Retail 1 x HDD TOSHIBA DT01ACA100 (3.5", 1TB, 32MB, SATA III) 1 x VGA SAPPHIRE NITRO R9 390 8G GDDR5, retail 1 x Optički uređaj LG GH24NSD1 SATA Bulk Black 24x 1 x Kućište Kolink Deathclaw Gaming, Black, USB3.0, 3x120mm 1 x Fortron Hyper 600W, 80+ Ukupno: 6619,00 kn Besplatno slaganje i besplatna dostava |
#3278 |
Datum registracije: Feb 2015
Postovi: 601
1 x Procesor Intel Core i5-4460 (3.20GHz,1MB,6MB,84 W,1150) Box 1 x Asrock H81M-HDS, s1150, Intel H81, M-ATX, Dual Channel 2xDDR3 1 x Sapphire R9 390 NITRO, Tri-X OC, 8GB GDDR5, 512 bit 1 x DDR3 8GB (1x8GB) Kingston, HyperX Fury, 1600MHz, CL10 1 x HDD Seagate 1TB, Serial ATA III, 7200 rpm, ST1000DM003 1 x Napajanje FORTRON 650W Raider, RA650, 12cm ventilator, Act PFC 1 x Kućište ANTEC GX505, MIDI, window edition, crno, bez PS 6.698,02Kn |
#3279 |
Lokacija: Chernobyl NPP
Postovi: 4,778
Slažem za nekog komp i gledavši ovih par postova tu uzeo sam iz svega po nešto i ispalo ovo: Intel Core i5-4460 3.2GHz Kingston Technology HyperX Fury Memory Black 8GB 1866MHz DDR3 (2x4) Asrock B85 Pro4 Kingston Technology HyperX FURY SSD 120GB FSP/Fortron Raider 650 Grafa će ić Sapphire R9 390 8GB NITRO OC ili će u taj komp ić moja sadašnja 970 pa si ja neš drugo uzimam. Ima dakle sve osim kućišta. Htio sam Z1 ili Antec GX505 ali gdje mislim uzeti sve da odmah slože nemaju ni jedno. Što bi bila alternativa? Ne bih baš neko papirnato kućište koje bi se klimalo, cijenom do 350-400kn. HDD ne treba, tog ima ![]() |
#3282 |
MiningMod
Postovi: 8,715
#3284 |
Postovi: 1,254
Ja bi ovo antec gx 505 ta Sharkoon kucista su mi premalenkasta i nemaju mogucnost nekog dobrog airflowa. |
#3285 |
Datum registracije: Feb 2010
Postovi: 15
Pozdrav svima, Želja mi je složiti konfiguraciju cca 6.500 kn Konfiguracija bi sluzila kao gamer/stream platforma. Od periferija mi nije nista potrebno. Vec samo kuciste, bez SSD. Naravno ukoliko je moguče složiti takvu konfiguraciju za ovako ograničen iznos. Hvala svima Mero p.s tu sam za sva pitanja |
#3286 |
Datum registracije: Apr 2013
Postovi: 1,336
Intel Core i5-4460 Gigabyte GA-B85M-D3H motherboard Kingston HyperX FURY Black 4GB DDR3 x2 Palit GeForce GTX 970 4GB Toshiba 1TB HDD Fractal Core 1000 kućište, ili neko po izboru FSP/Fortron Hyper 600 možeš i sa nekim slabijim, ovo je dobro, jeftino i s dugom garancijom cijena ispod 6500 (6435 tamo di sam ja slagao)...ako nemaš SSD svakako ga preporučujem, stavio sam nvdia karticu pa možeš jako dobro streamat uz Shadowplay, uz minimalan gubitak performansi |
#3287 |
Postovi: 430
1 x Intel CPU Desktop Core i5-4460 (3.2GHz, 6MB,LGA1150) box 1 x KINGSTON ValueRAM DDR3 (8GB,1600MHz(PC3-12800)) CL11, Retail 1 x Asrock s1150 H81M-HDS R2.0 1 x HDD Toshiba P300 1TB, 64MB, 7200rpm 1 x Kućište Raijintek Arcadia, USB3.0, white 1 x GIGABYTE GTX 970 GDDR5 4GB/256bit, ITX + Igra 1 x Fortron Raider S 550W, 80+ SILVER Ukupno: 6531,00 kn sa slaganjem i dostavom u cijeni |
#3288 |
Postovi: 1,254
1 x XFX R9 390 8GB 512bit DDR5 Black Ed. 1 x Intel CPU Desktop Core i5-4460 (3.2GHz, 6MB,LGA1150) box 1 x Asrock s1150 H81M-HDS R2.0 1 x Kingston HyperX FURY Black 8GB 1866MHz DDR3 CL10 1 x Fortron Raider S 550W, 80+ SILVER 1 x HDD Toshiba P300 1TB, 64MB, 7200rpm 1 x Zalman Z3+, USB3.0 black Ukupno: 6548kn, besplatno slaganje i dostava! |
#3290 |
Postovi: 14,589
Zar nije fx83xx zbog headrooma bolji izbor za gaming + streaming. Čak je i teck syndicate imao neki fx 8350 vs i5 3570K video while straming Znam da streaming pojede nekih 30% cpu snage i7 (4c + HT), a fx 83xx ima više headrooma od i5, pa to sve iz syndicate videa ima i neke logike Znači FX 8300 ili 8320E + ga-970a-ds3p ili asus M5A97 R2.0 (ne LE) + neki cooler ovisno dali se misli ići na neki ozbiljiji oc iznad 4ghz Zadnje izmijenjeno od: Manuel Calavera. 03.12.2015. u 18:16. |
#3291 |
Postovi: 1,336
Zato sam ja stavio nvidija grafu koja će obavit taj dio preko shadowplaya u sasvim zadovoljavajućoj kvaliteti, a gubitak performansi je nikakav (ja mogu streamat sa gtx 750Ti bez problema) a u tom slučaju mi je i5 draži ![]() |
#3292 |
Postovi: 14,589
Zar se shadowplay koristi i za streaming (ne mislim na videorecording)? Izgleda da da, nisam znao, ali izgleda da nije nešto https://www.reddit.com/r/Twitch/comm...lay_work_with/ kako god neovisno s čim radi mora dodatno opterećivati i cpu, ne vjerujem da sve gpu odradi |
#3293 |
Postovi: 1,336
Sa našim internetom prije će mu bit bottlenck upload nego kvaliteta Shadoplaya, osim ako nije na opakoj optici..isprobao sam Shadowplay, tu i tamo lupim preko njega na twitch ponešto čisto zezancije radi, radi sasvim dobro i bez gubitaka performansi (bar ih ja ne mogu uočit)..ako nije neki profi streamer (a sumnjam da je ) shadowplay je sasvim dovoljan..ako želi u te vode ozbiljnije ionako mu treba capture card i slične gluposti koje ga koštaju pol budžeta..tako da ono, nvidia is the way to go po meni ![]() |
#3295 |
Postovi: 1,254
Ma taj shadowplay ovisi od igre do igre koliko uzme na performansama nije bas da nezna "poludit", ima dobrih programa i za AMD kartice, sve u svemu na 1080p igre ionako idu na 70-80 fpsa sa r9 390 na max postavkama, pa i d aizgubi 10-15 fpsa nista mu ne znaci. EDIT: Evo vec se vidi da su cijene svega skocile gore, ovo jedno vrijeme dobrih cijena ko je iskoristio, iskoristio je sad opet pocinje "terapija" ![]() |
#3297 |
Postovi: 159
Pozdrav ekipa, trebao bi mi savjet za PC. Brat planira uzet PC za igranje na FULL HD, htio bi sve uzet na jednom mjestu te preferiram UZIshop. Buđet je oko 5500kn (ovo je oko 5800 s popustom od 3%). Je ovo ok ili imate neki prijedlog/izmjenu. HVALA! http://imgur.com/mUjdSFK |
#3299 |
Postovi: 1,254
crusher Ja bi odma isao na gtx 970, a SSD lako kasnije dokupis. Zotac GeForce GTX 970, 4GB (3.5GB+0.5GB) , DDR5, 256 Bit AMD FX-6300 Box 3,5GHz - 14MB Cache - 95W BOX Gigabyte GA-78LMT-USB3 (rev. 4.1) Cosmo Cool LC-CC-95 - CPU cooler Kingston Technology HyperX FURY Black 8GB 1866MHz DDR3 XFX Pro 450W Toshiba 1TB 3.5" 7.2k SATA Gb/s 32MB Enermax Vostok ADV Midi Tower ATX, bez napajanja, crno (ECA3122-B/U3) Ukupno: 5 705,27 kn UZI, ako odbijes 3 posto popusta to je 5529kn i ostajes na buđetu bez prelaženja. Moglo bi se to jos bolje sloziti, da im ponuda kucista i napajanja nije ocajna, tj dobar dio stvari je nedostupan. |
#3300 |
Datum registracije: Mar 2011
Postovi: 2,707
1 x XFX R9-280X-TDFD, DD Radeon R9 280X 1000M Boost 3GB DDR5 1 x Samsung 250GB 850 Series EVO Basic, Kapacitet 250 GB, 2,5" 1 x Procesor Intel Core i5-4460 (3.20GHz,1MB,6MB,84 W,1150) Box 1 x MS RAIDER RED gaming kućište bez napajanja 2 x Thermaltake Pure 12 case fan, Promjer 12 cm, 1000 o/min, 19.5 dB 1 x DDR3 8GB (1x8GB) Kingston, Value, 1600MHz, CL11, KVR16N11/8 1 x Asrock H81M-HDS, s1150, Intel H81, M-ATX, Dual Channel 2xDDR3 1 x Napajanje EVGA 500W 500B, 100-B1-0500-KR, Bronze Power Supply 5.753,98Kn |
