Staro 05.11.2015., 20:08   #4591
dh41400
Señor Audiophile
dh41400's Avatar
Lokacija: Zabreg
Postovi: 3,280
Je, prilično je jeftina.
Uzimam ju 100%, moram samo vidjeti da li ću prek Uzi-a ili prek mađara. Baš razgovaram s frendom koji je složio gaming rig za nekih 12k kuna, i uzeo 970 s 4gb, i tvrdi mi da je njegova bolja. I gledam usporedbe i vidim da je u krivu.
i5 6600k na 4.3, 16gb rama i R9 390 8gb, pa neka proba zatrzati neka igra. Odmah ide na tržnicu za bagatelu.
Pripazi kod te kartice na par stvari ... koliko vidim masovno se spominje "restart issue" gdje ekipa kada ide na shutdown sa tom karticom, komp se samo restarta, pa moraju čupati kabel od napajanja iz zida, kako bi komp ostao ugašen
This card has a very strange issue where it will force your computer to turn back on when you shut it off or put it to sleep. It will continue to do this until you pull the plug or shut off the power manually in some way. On my case even holding the power button to shut it off would cause it to instantly turn back on. I am not alone on this and people of all different system configurations are seeing this.
Computer would not shut down without pulling the plug. Just constantly restarted if turned off any other way. Before drivers were installed computer would just black screen after being on for 20 seconds. Ridiculously and pointlessly frustrating. Tech support is paid to lie about causes and will ignore anything you say and reply with pre-written responses. Avoid.
Need to make this known. The reboot/restart issue is definitely real. Thought maybe my specific system wouldn't be affected but unfortunately not the case.
I also experience the reboot issue caused from this card. Whenever I choose to shut off, or sleep. The pc shuts off / sleeps then quickly reboots. The only way to turn off is to switch my PSU off, or pull the plug. Unacceptable.
itd
Druga stvar je da koliko vidim, s tim hladnjakom temperature u pravilu idu iznad 80C, a kažu da pri tome taj dual hladnjak i nije baš tih.
Treća stvar je da sa iPonom nisu baš poznata reklamacijska iskustva, stoga oprez.
Moja topla preporuka bi bila (ako već ideš na 390-ku) uzeti model sa što boljim hladnjakom (tri-x, MSI ili Asus), jer ćeš to na ovoj kartici brzo osjetiti.
Staro 05.11.2015., 22:09   #4592
Sphere
Datum registracije: Mar 2015
Postovi: 1,254
Ja nemam nikakvih problema od ovoga sta si naveo, mozda je to do Gigabytea po srijedi da je izbacio fejlanu seriju, mozda na ovim novijim modelima nije tako.
Ako se gleda na nize temperature nikako Asus, te grafe se dosta griju, jer su gledali da grafa bude tisa, a na temperature nisu bacali previse oko, posto znaju i na 90 stupnjeva ic.
Meni je na mojoj max 83-84 stupnja na 2560x1440p sa max postavkama u AAA naslovima. Ako se gejma na 1920x1080p onda se moze ukljuciti v sync da se zakljuca fps, pa samim time i graficka radi na dosta nizim temperaturama.
Sa ukljucenim v syncom su temperature na nekih 76-77, a sa iskljucenim idu na 84.
I obratite paznju da ja imam kuciste sa osrednjim protokom zraka, sa nekim poštenim kucistem i prednja 2 venta bez HDD kaveza koji zaprecava protok zraka bi se sigurno skinulo 4-5 stupnja
Sphere je offline   Reply With Quote
Staro 05.11.2015., 22:52   #4593
dh41400
Señor Audiophile
dh41400's Avatar
Lokacija: Zabreg
Postovi: 3,280
Autor Sphere Pregled postova
To je relativno očito da nemaš tih problema, jer ... nemaš tu specifičnu karticu
Znam samo da skoro svaki user feedback na newegg-u spominje ovaj issue, stoga oprez nije na odmet, a taj problem nije baš nešto što se može riješiti driverima ili MSI AB-om
Definiraš profil u AB-u i riješen problem
Po defaultu i moja grafulja radi na 85C, ali uz malo igranja evo je na 65C, i to uz možda neznatno malo više buke (nisam mjerio dB metrom).
Pa i preporučio sam čovjeku taj MSI model Btw usporedba coolera.
Naravno, jer tada grafa ne radi na istom opterećenju i uz malo drukčije napone/taktove, što se teže zamjeti ako čovjek ne obraća pažnju.
Bitno da je solidan protok ... ne treba sada baš izvoditi nekakav Ultra Kaze 11-fan setup
Staro 05.11.2015., 23:09   #4594
Postovi: 17,143
Pa zato smo i tu, da diskutiramo.
Mogu se protegnuti na 3000kn, ali ni lipe više.
Pa molim preporuke. Kada pitam, nitko ništa, kada napišem nešto svi ste tu
Tražim pomoć, čovjek u nevolji
Da se razumijemo, tražim grafu koja bi bila high-end (jer za nekoga poput mene to je OGROMNA cifra), i da kad ju metnem u kantu, instaliram Withera 3 (karikiram), stavim sve na ultra i neću vidjeti ni jedan trzaj.
Slušam...
Staro 05.11.2015., 23:43   #4595
Sphere
Postovi: 1,254
dh41400
U vezi temperature, nema se tu sta poboljsati, ventovi se vrte na 100 posto kad je graf na 84 stupnja.
Witcher 3 na fullHD rezi sa r9 390 ide u 45-50 fpsa sa iskljucenim Hairworksom, to je uglavnom jedna od par igara koja bas veliki zalogaj i za puno skuplje graficke, ali veliku vecinu igara bez brige mozes igrati i na 2K rezi u 45-50fpsa, ovisno od naslova sa max postavkama.
Staro 06.11.2015., 00:16   #4596
yggdrasil
yggdrasil's Avatar
Postovi: 233
Da to sve bude tip top ja bi ti preporucio da uzmes ovo napajanje i ovaj hladnjak
Najljepša hvala Sphere i ostali na pomoći. Mislim da sada imam sve. Ako gdje zapne ili mi bude trebala neka zamjenska komponenata zbog neraspoloživosti kod narudžbe, bit ću toliko slobodan obratiti vam se opet za savjet
P.S. Da li mi je ovako nešto dovoljno kao wifi USB adapter?
Čujemo se,
Vedran
yggdrasil je offline   Reply With Quote
Staro 06.11.2015., 00:22   #4597
Sphere
Postovi: 1,254
Taj sta si linkao ti je rasprodan, a iskreno i kad vec uzimas wi fi adapter, uvijek gledaj na one sa antenicom, puno jaci signal imaju, recimo ovaj je ok.
Staro 06.11.2015., 00:56   #4598
dh41400
Señor Audiophile
dh41400's Avatar
Lokacija: Zabreg
Postovi: 3,280
Slušam...
Čini mi se da je MSI model par kn ispod 3k, pa baci oko. U svakom slučaju gledao bih modele sa 3g garancije i poštenim coolerom (MSI, Asus).
I kada je u pitanju "Ati", nekako volim da mi je servis blizu ... ne znam zašto
Kakvo je danas stanje sa karticama/igrama/driverima, za trzanje ne mogu garantirati ni na svojoj grafulji, a kamoli na duplo jeftinijem AMD-u
E vidiš, tu je razlika između GTX970 i R9 390
Naravno, ne igra ulogu samo postavljanje fan profila, već i Power limit opcija, kao i napon na grafi.
Tu se GPU Boost 2.0 pokazao vrhunskom tehnologijom jer na jednostavan način regulira međusobnu zavisnost napona/temperature/taktova i količine buke.
Staro 06.11.2015., 06:37   #4599
Postovi: 17,143
Sve jasno.
Trzanje sam spomenuo kao referencu za preslabu grafu. Na što možemo utjecati. Ali na optimizaciju ne možemo. Tako da te kužim.
Staro 06.11.2015., 07:24   #4600
Hawker
Datum registracije: Nov 2014
Postovi: 1,972
Sapphire Nitro je skoro besumna kartica.
Jedina mana je 2god. garancije,ali Sapphire je prakticki kucni proizvodjac AMDa i zato ga preferiram. Ko zeli 3godine i fancy led svjetla uzima MSI.
Opcenito izbor izmedju 970 i 390 uvijek pada na 390 jer je jednostavno bolja,a sa malo OC 390 lakocom dovedes do razine 390x.
Hawker je offline   Reply With Quote
Staro 06.11.2015., 07:36   #4601
Postovi: 17,143
Ma uzimam 390 ziher. Model ovisi o tome koliko ću love imati.
Staro 06.11.2015., 12:35   #4602
Igor_Zg
Igor_Zg's Avatar
Postovi: 909
Pod Moj Komp koja bi bila najjača grafa koja bi se mogla staviti da ju sustav može hraniti?
Igor_Zg je offline   Reply With Quote
Staro 06.11.2015., 12:42   #4603
Postovi: 17,143
Bilo koja.
Gtx 980 npr.
Staro 06.11.2015., 13:08   #4604
Manuel Calavera
Manuel Calavera's Avatar
Postovi: 14,589
Ma kakva gtx 980, to je cpu sličan q9650, gtx 960 je overkill za to. Igor zg tvoja hd7850 je optimalna za to.
Staro 06.11.2015., 14:22   #4605
Igor_Zg
Igor_Zg's Avatar
Postovi: 909
trenutno se GPU iskorištava na 100%
Htio bih nekaj jače da dovedem konfu na max kaj može, jer mi se trenutno ne daje novac na novi CPU,MBO,RAM.
Igram na 1920 x 1200, a tu je 1 GB RAM-a na GPU malo, a i mislim da bi sistem mogao nahraniti i jaču GPU, ali me zanima koliko jaču...
btw, neki su moj xeon uspoređivali da je nešto sitno slabiji ovako OC-an od serijskog 2500k ako kaj znači...
Staro 06.11.2015., 14:45   #4606
Sphere
Postovi: 1,254
Najbolje da uzmes sve polovno, i5 2500k sa prikladnom maticnom i 8GB rama nekih 1700kn, za 1300kn uzmes r9 280x i vozi brale, a proc ces moci iskoristit i za kasnije nadogradnje.
Staro 06.11.2015., 15:09   #4607
Postovi: 17,143
Tek sam sada vidio kaj sam napisao. Gtx 960 sam mislio.
Staro 07.11.2015., 13:20   #4608
tintin
tintin's Avatar
Lokacija: negdje
Postovi: 1,800
Trebam malo više ddr2 rama pa me zanima jel velika razlika u radu između 800 i 667mhz? Trenutno sam na 2x1gb 800mhz, a imam ponudu za 4x2gb 667mhz.
tintin je offline   Reply With Quote
Staro 07.11.2015., 13:21   #4609
Postovi: 17,143
Nije toliko.
Staro 07.11.2015., 13:39   #4610
tintin
tintin's Avatar
Lokacija: negdje
Postovi: 1,800
Proc mi ima fsb 1333mhz, jel to kakav problem ili je ok.
Ne interesiraju me nikakvi benčmarki samo ponašanje u normalnom radu.
Staro 07.11.2015., 16:12   #4611
Sphere
Postovi: 1,254
Ma sve ti je to dobro, nebi vidio razliku ni da imas ove od 2400MHz
Staro 09.11.2015., 08:13   #4612
tintin
tintin's Avatar
Lokacija: negdje
Postovi: 1,800
Jel može biti kakvih problema kod overkloka (u odnosu na 800mhz ddr2)?
Ne mislim nešto jako dizati proc, evntualno do 3-3,2ghz (defoult je na 2,66ghz).
Staro 09.11.2015., 08:51   #4613
Postovi: 17,143
Kod OC-a uvijek postoje potencijalni problemi, ali nestabilan OC većinom rezultira BLue Screenom ili reatartom kompa itd.
Staro 09.11.2015., 09:23   #4614
tintin
tintin's Avatar
Lokacija: negdje
Postovi: 1,800
Mislio sam na oc potencijal ddr2 667 mhz u odnosu na ddr2 800mhz i proc sa fsbom 1333mhz.
Staro 09.11.2015., 09:43   #4615
Postovi: 17,143
Ma to ti je neprimjetna razlika.
Staro 09.11.2015., 11:11   #4616
tintin
tintin's Avatar
Lokacija: negdje
Postovi: 1,800
Ok, za memoriju je sve jasno.
Pitanje vezano za hdd, imam jedan wd red 2tb viška pa me interesira jel ok ako ga stavim u comp za storage iako je to nas hdd?
Staro 09.11.2015., 11:36   #4617
Postovi: 17,143
Nema nikakvog problema.
Wd je normalan disk koji može biti nas.
Staro 10.11.2015., 11:03   #4618
Orc
Orc's Avatar
Postovi: 27
Imam komp star 6 godina. Core 2 duo E6300 na 2,8 GHz, 4GB RAM-a (DDR3), SSD 128GB, HD 500GB, ATI Radeon 4870 1GB, Aopen kučište s 400W napajanjem (vrti uredno redeonku 4870).
Razmišljam do nove godine nadograditi gornju konfiguraciju za cca 2500kn.
Čini mi se najpametnije zamijeniti MB, cpu i grafičku. Preferiram Intel. Kod MB mi treba barem 6 eksternih USB portova.
Orc je offline   Reply With Quote
Staro 10.11.2015., 11:47   #4619
ibme74
ibme74's Avatar
Datum registracije: Jan 2013
Lokacija: Planet Zemlja
Postovi: 1,635
Trebao bi mjenjati i napajanje ako mislis uzimati neki bolji GPU... a za čega ti služi komp najviše?
Zadnje izmijenjeno od: coconut. 10.11.2015. u 13:57.
ibme74 je offline   Reply With Quote
Staro 10.11.2015., 13:02   #4620
Postovi: 17,143
Za 2500kn sigurno neće trebati jače napajanje, osim ako sve uloži u grafu. Uzmi neki G serije intel, matičnu i rame za sada. Grafu probaj rabljenu. Jer to nije neka velia cifra za 4 komponente.
