Staro 27.07.2015., 16:31   #16141
Dottore
Dottore's Avatar
Postovi: 7,712
Majstor preletio rotor kod Hotovillea
HP 845 G9
CPU: AMD Ryzen 7 PRO 6850U
RAM: 64GB Samsung DDR5 4800
Graphic: AMD Radeon 680M
LCD: 14" IPS @ 1920 x 1200
OS: Windows 11 Pro 25H2
Mice: Logitech MX Master 3S
Lenovo ThinkPad P15v Gen 3
CPU: AMD Ryzen 7 PRO 6850H
RAM: 64GB DDR5
Graphic: AMD Radeon
LCD: 15" IPS @ 3840x2160
Lenovo ThinkPad T14 Gen 5
CPU: AMD Ryzen 7 PRO 8840u
RAM: 64GB DDR5
SSD: Kioxia XG8 1 TB NVMe M.2
Graphic: AMD Radeon 780M
Mice: Logitech VX Nano
Lenovo X1 Carbon 7th Gen
CPU: Intel Core i7-8665U
RAM: 16GB soldered LPDDR3
Graphic: Intel HD 620
LCD: 14" IPS @ 2560x1440
Lenovo X1 Carbon 10th Gen
CPU: Intel Core i7-1260p
RAM: 16GB soldered LPDDR4
SSD: Sk Hynix 512 GB NVMe M.2
Graphic: Intel Iris Xe
LCD: 14" IPS @ 1920x1200
Staro 27.07.2015., 16:35   #16142
Guls
Guls's Avatar
Lokacija: Sveta Nedelja
Postovi: 2,938
Fascinantno, ali to nije prvi put. Tj to se događa već u nekakvim pravilnim razmacima od mjesec - dva. Genijalci ne vide rotor pred sobom. Ne samo na toj lokaciji, već i na drugim rotorima u gradu.
Intel i7 9700F
32GB Hyper-X DDR4-2666
2TB 970Pro PCIe NVMe M.2
Windows 11 Professional
Periferija
2 x 27" Dell P2723D
Corsair SP2500 2.1
Logitech MK270
17,3 FHD IPS 144Hz
AMD Ryzen 7 5800H
16GB DDR4-3200 RAM
1TB PCIe NVMe SSD
Sony Playstation 5
Staro 27.07.2015., 17:20   #16143
ozren
PC Ekspert
ozren's Avatar
Datum registracije: Sep 2000
Lokacija: Zagreb, Hrvatska
Postovi: 1,214
Autor Dottore Pregled postova
Ma nije kriv
Nissan GT-R Black Edition
ozren je offline   Reply With Quote
Staro 27.07.2015., 17:27   #16144
esc
Lynnfield
Datum registracije: Sep 2012
Postovi: 1,023
Autor ozren Pregled postova
Ma nije kriv
Ne kužim ništa,kakav rotor i šta ne vide...
esc je offline   Reply With Quote
Staro 27.07.2015., 18:02   #16145
1v@n
The mighty pirate
1v@n's Avatar
Lokacija: London
Postovi: 9,157
Autor esc Pregled postova
Ovo
Koliko se vidi na snimci, došao je iz smjera zapada prema Zagrebu i sletio na ogradu Tahografa. Srećom da je bilo tako kasno, jer je autobusna stanica malo dalje. Izgleda da se zaustavio mrvicu prije nje.
CPU: Intel Core i7 8809G
MBO: Intel NUC8i7HVK
RAM: 2x16GB Crucial DDR4 2400
GPU: Radeon™ RX Vega M GH
LCD: BENQ PD3200Q
OS: Windows 10 Pro x64
Staro 27.07.2015., 18:18   #16146
Garro
Postovi: 2,398
Pozdrav Ozrenu i Ivoni, jučer sam vidio GT-Ra i Eveka u pol 12 kod skretanja za Brački aerodrom. Prekrasni auti, GT-R je baš prava pojava.
Staro 27.07.2015., 18:40   #16147
Facelessone
Facelessone's Avatar
Postovi: 4,205
Autor 1v@n Pregled postova
Ovo
Ovdje je došao. Događa se tu i tamo po noći, ali večinom ne završe na krovu kao ovaj negu se malo zapikiraju na rubnjak i stanu nasred otoka. Ali ovaj ima baš fini skok, prošao je kao da nije ni kočio.
https://www.google.hr/maps/@45.80325...7i13312!8i6656
AMD Ryzen 7 5700X
BQ Pure Rock
MSI B450 Tomahawk Max
500GB Crucial MX500
Fractal Define R4
Corsair HX850 Platinum
Logitech MX Keys
Logitech Z2300
Dell U2715H
Iskon 300/100 Mbps
CPU Intel i7-4810MQ
VGA nVidia GT730M 1 GB
RAM DDR3 16 GB 1600 MHz
SSD 500 GB Sandisk Ultra
LTE Modem
DVD-RW
9 cell battery
Napajanje 135 W
Windows 10 Pro
Logitech MX Anywhere 3s
AMD Ryzen 5 7640HS
AMD RadeonT 760M
14" 2,8K, 120Hz
16GB RAM
1TB HDD
Windows 11 Pro
H110M-DGS
Intel i3-7100
8GB RAM DDR4
WD Red 8TB
WD Purple 4TB
Seagate IronWolf 3TB
Seagate SkyHawk 6TB
Nanoxia Deep Silence 4
Seasonic X650 SS-650KM Gold
Staro 27.07.2015., 18:47   #16148
MAGARAC
MAGARAC's Avatar
Postovi: 5,997
Taj je bil jampi 100% ili mobitel.. Ima srece kaj je ograda bila dobra. Mogal je uletit nutra i imat jos gori udes na onoj prikolici, u horror stilu..
Zadnje izmijenjeno od: MAGARAC. 27.07.2015. u 18:52.
Staro 27.07.2015., 19:20   #16149
esc
Lynnfield
Postovi: 1,023
Kak je došal odatle,onda bi se prije zaletio u ovaj bijeli zid a ne u ogradu,on je pogodio baš u ogradu odnosno u vrata jel tako
Ne čini mi se pijan
Staro 27.07.2015., 19:22   #16150
Facelessone
Postovi: 4,205
Od tuda je jedino i mogao doći, lijevo je samo ulaz u hoto vile i tu je porta sa rampom.
AMD Ryzen 7 5700X
BQ Pure Rock
500GB Crucial MX500
Fractal Define R4
Logitech MX Keys
Logitech Z2300
Dell U2715H
Iskon 300/100 Mbps
CPU Intel i7-4810MQ
LTE Modem
DVD-RW
9 cell battery
Napajanje 135 W
Windows 10 Pro
AMD Ryzen 5 7640HS
AMD RadeonT 760M
14" 2,8K, 120Hz
16GB RAM
1TB HDD
Windows 11 Pro
H110M-DGS
Intel i3-7100
8GB RAM DDR4
WD Red 8TB
WD Purple 4TB
Seagate SkyHawk 6TB
Staro 28.07.2015., 09:28   #16151
ozren
PC Ekspert
ozren's Avatar
Postovi: 1,214
Autor Garro Pregled postova
Bok! Da išli smo se malo propeljat do Nerežišća
Autor MAGARAC Pregled postova
Da čujete kak ga jedan tip brani na FB-u... ispada da je praktički sitnica i da ga trebamo žalit, a tip ukrao bratu auto i odmah se zapiknul na par metara od autobusne stanice koja zna bit krcata ljudima.
Staro 28.07.2015., 10:51   #16152
burmuz
burmuz's Avatar
Lokacija: Bjelovar
Postovi: 464
Pa to je normalna pojava. U današnjem društvu je žrtva onaj koji radi zlo a žrtve su negativci. Osim ako ne voze dobar auto, u tom slučaju je inkvizicija.
Jučer sam imao najgore iskustvo s prodavačem automobila ikad. Dođem sa starim, kaže da hoće zakapariti novi Mazda CX3 full oprema dizel. Kaže ovaj cijena je 168 k kn. Veli stari ok, el može popust neki, tipa 5k kn ili nešto ( zimske gume, dodatak neki). Lik, neće vjerovati neće sniziti jednu kunu. Ne može ništa, niti metalic boja, ni tepisi za auto. Nula bodova. Nisam mogao vjerovati.
SAd se stari zainatio i neće cx3 je su "svi u mazdi kreteni" i sad gleda šugu od Captura koji košta 136 k kn a ne daje ništa za tu paru, motori ubi bože 90 ks dizel na takav crossover, gledam specs 12.6 do 100, naša Fiesa stara 18 godina ima identične specs.
A rekao sam ćaletu, uzmi Q3 polovni iz DE i imaš auto za cijeli život al neće.
Staro 28.07.2015., 11:51   #16153
syss
syss's Avatar
Postovi: 10,805
pa prije 8g kada sam kupovao svoja kola mi je frajer reko istu stvar, oke cifra je bila skoro duplo manja, ali je čovjek iskreno reko - gle sa ovim popustima i za tu cijenu autokuća će zaraditi 100ak€ na tvojoj prodaji i fakat ti nemrem ni tepihe dat maltene.
ajd platio je pivu kad sam podignuo auto
mislim korektan lik skroz, ono otvoreno je reko da ako hoću popust odmah odem negdje drugdje ako mogu bolje proći jer nema šanse da ikako spusti cijenu.
da ne bi bilo rekla-kazala popust je bio oko 18k kn na auto koji je na kraju izašao 74k kn... što stvarno nije malo.
Staro 28.07.2015., 11:58   #16154
1v@n
The mighty pirate
1v@n's Avatar
Lokacija: London
Postovi: 9,157
Ni u Fordu ni Hyundaiju nije to prošlo, ni trznuli nisu na to da imamo keš kod sebe i hoćemo kupiti auto.
LCD: BENQ PD3200Q
Staro 28.07.2015., 12:19   #16155
burmuz
burmuz's Avatar
Lokacija: Bjelovar
Postovi: 464
Očito nema krize. Dobro im ide. Jer odj... čovjeka koji uzima auto za 20k + eura je meni malo čudno. Osim ako im je plaća fix pa im se j....
Ali sama bit trgovanja je da se s kupcem nekako dogovoriš, pa da daš borić za auto. Neka gesta. Mislim općenito, čast iznimkama, prodavači automobila su najneljubazniji od svih.
Žena skače oko tebe za kilu kruha maltene a ovi neće prstom maknuti za velik novac. Nije mi to baš jasno.
Ali da, ne bi uzeo kod takvog ništa, čisto iz principa.
Staro 28.07.2015., 12:32   #16156
1v@n
The mighty pirate
1v@n's Avatar
Lokacija: London
Postovi: 9,157
Ajd, prošlo je tri godine od toga, ali nastup većine prodavača je bio kao da tebi rade uslugu time što ti prodaju auto.
Sjedi i gleda nešto u kompjuteru, čak te ni ne pogleda, samo generički odgovara na pitanja. Ne daj bože da pitaš da ti pokaže auto detaljnije, onda sljiedi naporno dizanje sa stolca uz glasan uzdah...ili "tamo vam je, pogledajte si"
LCD: BENQ PD3200Q
Staro 28.07.2015., 12:38   #16157
MAGARAC
MAGARAC's Avatar
Postovi: 5,997
Nije ni sad puno drugacije. Uopce se ne trude prodat auto.. Kaj je najbolje cesto rede ljudi koji nemaju poima kaj prodaju.
Staro 28.07.2015., 12:51   #16158
Moto001
Moto001's Avatar
Datum registracije: Sep 2014
Lokacija: Slavonija bajnaaaaa
Postovi: 237
Zato nam i je u državi tako naravno ima iznimaka ali su rijetki.....
Ako se radi samo za plaću onda i nije čudo što se tako ponašaju ali ako je tu i provizija onda nešto neštima ali.....jbg. očito smo u velikoj depresiji kao narod
Pratim Auto klub i mislim da sam u nekom od zadnjih brojeva vidio Nisan Qashqai za taj iznos cca 170 tk sa 1.5 Dci 81kw meni osobno jako lijep model i uzeo bi ga u obzir umjesto Mazde CX3
Moto001 je offline   Reply With Quote
Staro 28.07.2015., 13:05   #16159
IcyTexx
IcyTexx's Avatar
Postovi: 4,707
@burmuz
Ne napadam tebe, al imam pik na ovo. Kaj ti tocno znaci "full oprema"? Full oprema CX3 je "Revolution Top" i takav najjaci dizel (ako se takvo nesto moze reci u istoj recenici sa 105 konja) automatik je 244k kn. I to je jedino sta ima smisla stajati uz rijeci "full oprema". Ovo sta si ti reko za 168k je skoro pa pocetni model.
Imam strasan pik na rijeci "full oprema", ljudima je to jos uvijek valjda elektricno podizanje stakala.
Staro 28.07.2015., 13:39   #16160
burmuz
burmuz's Avatar
Lokacija: Bjelovar
Postovi: 464
Autor IcyTexx Pregled postova
@burmuz
Vozili smo na probnoj vožnji taj primjerak od 105 ks diesel i baš smo taj mislili kupiti.
Ali ok, ima i veća oprema. Nisam ni rekao da je najjača razina nigdje već da je "full" što je po onome što sam vidio jer ima sve što mi je potrebno a više od toga. . Najveća razina opreme i full oprema su dva različita termina, meni. Da budem jasniji, full opremu mi ima Bentley makar ne mora biti najviša razina opreme istog
Početni model je 130 k kn tako da do 160+ k ima malo "propuha" još.
Staro 28.07.2015., 14:10   #16161
danijel_b
danijel_b's Avatar
Datum registracije: Jun 2004
Lokacija: Sj. Njemacka
Postovi: 504
Ovaj novi Renault Kadjar bi trebao biti jeftiniji Quashqai
danijel_b je offline   Reply With Quote
Staro 28.07.2015., 14:17   #16162
IcyTexx
IcyTexx's Avatar
Postovi: 4,707
Aha, kuzim te.
Pocetni model od 130k se nema sta ni gledat, to je onaj da mogu reci "vec od 130k kn" a socijala oprema... Prava cijena auta je 160k+.
Staro 28.07.2015., 14:18   #16163
1v@n
The mighty pirate
1v@n's Avatar
Lokacija: London
Postovi: 9,157
Autor burmuz Pregled postova
Pa to je točno taj "full oprema" sindrom koji je gore spomenut i slučajevi tipa
"golf 3 full oprema" a pod to idu sve 4 gume, volan, naslon za vozačevu glavu i pepeljaru.
Kad pitaš kakva je to full oprema onda, pita kaj hoćeš, pa to je sve kaj ti treba u autu
Ima i specijalaca koji napišu: "full oprema, osim kože, klime, krovnog prozora, bočnih zračnih jastuka i branika u boji vozila"
Pod full opremom smatram sve što je navedeno u dodatnoj opremi za auto. Ništa manje od toga.
LCD: BENQ PD3200Q
Staro 28.07.2015., 14:30   #16164
burmuz
burmuz's Avatar
Lokacija: Bjelovar
Postovi: 464
Uredu, prihvaćam.
Ovako, koliko sam shvatio, "full oprema" je, ako ćemo po pravo, top razina opreme nekog modela + sve žive nadoplate koje se teoretski mogu naručiti iz kataloga. E, to je je prava full oprema jer si kupio sve što se može kupiti od opreme.
I ako je tako, to je točno, i govorim opet, krivo sam se koji post prije izrazio
Staro 28.07.2015., 14:43   #16165
1v@n
The mighty pirate
1v@n's Avatar
Lokacija: London
Postovi: 9,157
Pa, tako bi to trebalo biti. Sva dostupna oprema za taj auto. Danas su stvari puno jasnije i jednostavnije kad svaki auto ima najmanje 3 serijska paketa opreme i jasnu oznaku pa lako dođeš do informacije što sve ima od opreme, i lako dođeš do popisa dodatne.
Mogu sad na primjeru svojeg staviti. Clio Authentique koji od dodatne opreme ima to, to, to i to.
Odeš na web i nakon par klikova vidiš što Authentique oprema ima u sebi. Ne vidim zašto bi to itko označavao kao full opremu. Staviš serijska oprema za model Authentique i nabrojiš dodatnu.
Deda recimo fura Passata iz 91. i onda je auto dolazio s CL i GL oznakom "opreme". Razliku si izvana mogao vidjeti samo po prednjim žmigavcima i eventualno branicima koji su kod GL bili u boji karoserije, a po opremi iznutra još nisam vidio 2 ista.
I onda mi netko napiše full oprema, a ima milijun varijanti u toj opremi
LCD: BENQ PD3200Q
Staro 28.07.2015., 14:54   #16166
MAGARAC
MAGARAC's Avatar
Postovi: 5,997
Autor Moto001 Pregled postova
Kad vec spominjes Reanult tam je nes bolje jer obicno radi starija i iskusnija ekipa. Nema mulaca i mulkinja kaj ne znaju nis izvan prospekta i nemreju mrdnut bez pretrazivanja po kompu. Jos bi to meni bilo ok da su bar nekakvi trgovci po prirodi a nisu ni to pa onda ljudi izlaze iz salona sa e bas sad necu kupit mislima. Prodaval sam sve i svasta 10 godina i kao trgovca, komercijalista me te stvari bas razljute, kad vidim kak su jadni.
Staro 28.07.2015., 14:57   #16167
lowrider
lowrider's Avatar
Lokacija: KR
Postovi: 1,175
IFrend kupuje neki mali autić za 20-25 000kn i išli u Suzuki salon u V. Gorici, vidjet nekog rabljenog Getza. Ja naoružan mjeračem debljine laka i nekim iskustvom. Iznenadio sam se kad veli lik, tu su ključevi, isprobajte auto, javite se dečkima u radioni da ga dignu na dizalicu pa pogledajte od ispod. Ko bi rekao. Autu je cifra 28 000kn, ima svu osnovnu opremu, 2008.g. 104 000km, jedna ogrebotina na boku, neregistriran Auto prodaju od 11.mj prošle goddine.Sve super, al našao sam luft naa letvi volana, ne sponi, ne krajniku. I ne puštaju ispod 25 000kn. Letva je nabavljiva za nekih 2500kn, veliki servis naptavljen, al mislim da je to prevelika cifra za taj auto, ne?
Staro 28.07.2015., 20:14   #16168
Vuco
Vuco's Avatar
Lokacija: Zagreb, Tresnjevka
Postovi: 9,505
Velika je to cifra, usto još ima i problema. Tko zna što još nisi našao. Ima kojekakvih klasu većih autiju (a opet je mali auto), reganih, na oglasniku, za iste pare. Možda su godinu stariji, sa sličnom kilometražom, a mogu biti u boljem stanju nego taj Getz kojeg nisu niti popravili.
Staro 28.07.2015., 20:26   #16169
D1viry
D1viry's Avatar
Lokacija: Slavonija
Postovi: 2,066
Ne znam gdje bih stavio pa ću ovdje.
Koliko realno mogu dobiti za Clio 2 2003. 1,2 8v 10x000km?
2 seta čel. felgi i guma, centralno daljinsko, zračni jastuci i u sjedalima, maglenke, zvuk (ako je bitno: blaupunkt radio i zvučnici 40W).
Regan do 05/2016, kupljen od kume i mažen i pažen.
U zadnje 3 godine zamijenjeno kvačilo, korpa kvačila, diskovi, bubnjevi, kočioni cilindri, čašice amortizera i još neke sitnice.
Dijelovi su zamijenjeni jer je to bio primarni auto i ulagao sam u njega.
Zimske su 4 komada Michelin Alpin 4, npr. Nije se štedilo na njemu.
Problem je što mi sada više treba lova nego 2 auta pa me zanima jel se isplati prodavati.
Od svega bitnoga jedino nema klimu.
Unaprijed zahvalan na procjenama.
Znam da je nestandardan post .
Pošten trgovac: 1,2,3,4,5,6
Zadnje izmijenjeno od: D1viry. 28.07.2015. u 20:35.
Staro 28.07.2015., 21:24   #16170
Dottore
Dottore's Avatar
Postovi: 7,712
Automobili
Uskoro će izaći novi Continental SportContact 6.
Novost od contija, SC6:
http://www.continental-tires.com/www...contact-6.html
HP 845 G9
RAM: 64GB DDR5
Graphic: AMD Radeon
RAM: 64GB DDR5
Zadnje izmijenjeno od: Dottore. 28.07.2015. u 21:31.
