Staro 24.09.2005., 11:47   #1
Mailman
Mailman's Avatar
Postovi: 1,606
Omega 5.9
What's New in Omega Drivers?
v2.6.71
* Based on the Catalyst 5.9 Official drivers.
+ Added support for a few new Mobility cards.
* Fixed various resolution problems, now wide screen resolutions for laptops should work.
* Reconstructed Mobility support (M10 and up), laptops that had problems before should work properly now.
* Fixed OGL support for FireGL cards (both Mobility and Desktop).
+ Added some install/uninstall options, now the drivers should install with less issues and they uninstall all registry traces.
+ Added the option to install ATT or not during setup.
Known Issues:
The settings for both D3D & OGL will not be synchronized between ATT and the normal ATI CP, you must only use one of them to make changes, the best option is to use ATT since the ATI CP does not support changes to AI and in order to use the advanced D3D/OGL features. Changes made in ATT will work on games and such but the changes will not be reflected in the normal ATI CP since ATI stores the registry values that the CP reads separate from the actual values in the registry.
Note: Since these drivers include a non-standard version of ATT, I would recommend that if you have any previous version of ATT installed, please uninstall it before installing these drivers, not doing so may cause unknown problems.
What's new for ATI Tray Tools?
1.0.3.730
* Updated display rotation module.
* Update device names database
+ Added Catalyst A.I. control into Direct3D submenu
* Improved OSD support for OpenGL games and applications.
* Moved all I2C control functions into kernel mode driver.
+ Added option in General Settings to disable reset clocks before suspend mode.
* Update "OSD Example" plugin. Added option to show power status. (Battery life time)
+ Added new auto overclocking mode depended on computer power status.
Available here http://www.driverheavendownloads.net/omegadrive.htm
www.omegadrivers.net
ovo je bilo brzo....
Mailman je offline   Reply With Quote
Staro 24.09.2005., 12:23   #2
Jelc
Super Moderators
Datum registracije: May 2002
Postovi: 17,485
Re: Omega 5.9
he-he-he
"Kuga hara WoWom!?
Ova bizarna vijest spada pod vjerovali ili ne. Nakon što je Blizzard dodao novu istancu pod nazivom Zul'Gurub, kuga se počela širiti serverima i igrači padaju kao pokošeni, dok oni ispod lvl50 uglavno umru u roku od par sekundi. O čemu se radi? Čini se da bog krvi u istanci, pod imenom Hakkar ima spell pod nazivom Corrputed Blood koji radi oko 250-300 damagea i pogađa sve igrače koji se nalaze u blizini. Problem je nastao što zbog buga neki igrači postanu “nositelji” ove bolesti koja se onda širi kroz gradove i mjesta izvan same istance. Pogođeni su svi pa i NPC likovi a neki serveri su gotovo u potpunosti zaraženi i čim se igrač približi nekom većem gradu biva pogođen crnom smrću. Ovakva pojava je do sada nezabilježena u MMORPG svijetovima pa će biti zanimljivo promatrati kako će ovo Blizzard suzbiti. Pokušano je sa karantetnom međutim igrači konstantno bježe i šire bolest dalje. Blizzard se još nije službeno oglasio. Najteže će ipak biti pogođeni kroneri koji bi bez dnevne doze normalnog, nezagađenog WoW-a uskoro mogli zapast u tešku apstinencijsku krizu
Svako zlo za neko dobro:clap:
Morao si je Angel nečim ublažiti apstinencijsku krizu pa se primio drivera
Nećemo se žaliti
Staro 24.09.2005., 12:31   #3
damir1
Ancient
damir1's Avatar
Lokacija: Đakovo
Postovi: 893
Si vidio,kažeš neće skoro-nikad se nezna
damir1 je offline   Reply With Quote
Staro 24.09.2005., 12:51   #4
Jelc
Super Moderators
Postovi: 17,485
Pomogao nam je Blizzard ovaj put
Skidam...
Staro 24.09.2005., 19:19   #5
maxtor
maxtor's Avatar
Postovi: 382
Nikad više te omega drivere svaki put kad stavim bilo koju verziju omega drivera grafa nestabilno radi
maxtor je offline   Reply With Quote
Staro 24.09.2005., 21:25   #6
Gemmy
smeghead
Gemmy's Avatar
Postovi: 3,155
Ja ću ih probat u pon ujutro
Na Catalist 5.9 mi neće da radi ccc,stalno javlja neku grešku,pa sam intalirao "starije" omege,a u pon ove nove
Staro 24.09.2005., 21:39   #7
Jelc
Super Moderators
Postovi: 17,485
Za CCC moraš imati instaliran net.framework.
Staro 24.09.2005., 21:47   #8
tor
Administrator
tor's Avatar
Lokacija: Sesvete
Postovi: 15,962
Oh, pa ja sam iznenadjen i uzbudjen! Omega, samo par dana nakon službenih. Gadna zaraza na WOW-u
Staro 25.09.2005., 00:57   #9
MAHER
Postovi: 1,583
bili su brzi
MAHER je offline   Reply With Quote
Staro 25.09.2005., 12:58   #10
Jelc
Super Moderators
Postovi: 17,485
Obratite pažnju:
BTW, for next release, be ready to have .NET Framework 1.1 SP1 installed since I will be dropping support for the standard ATI CP and will be releasing an Omega version of CCC along with the drivers (on that note, if you are a profesional WindowBlinds skinner and want to be part of the Omega team, please contact me ASAP).
http://www.omegadrivers.net/
ATI je najavio da će CP biti ukinut na kraju 2005.
Nabijem ih
Staro 25.09.2005., 13:50   #11
MadBoY
MadModerator
MadBoY's Avatar
Datum registracije: Sep 2002
Lokacija: N/A
Postovi: 5,195
Izgleda da ce 5.9 bit zadnja verzija koju cu koristiti...
Staro 25.09.2005., 18:47   #12
Mailman
Mailman's Avatar
Postovi: 1,606
CCC se u zadnjih nekoliko verzija drivera jaaako poboljšao tako da nema razloga za paniku...
Staro 25.09.2005., 23:26   #13
Jelc
Super Moderators
Postovi: 17,485
CCC ne stavljam dok postoji i najmanja šansa da mi sve dela kak treba bez njega
Staro 25.09.2005., 23:38   #14
Vedran
Vedran's Avatar
Lokacija: Kutina
Postovi: 1,208
same here.
Vedran je offline   Reply With Quote
Staro 25.09.2005., 23:42   #15
Gemmy
smeghead
Gemmy's Avatar
Postovi: 3,155
Čemu služi uopće taj CCC?
Jel to catalist control panel?
Staro 26.09.2005., 00:07   #16
Jelc
Super Moderators
Postovi: 17,485
Catalyst Control Center.
Služi za to da moraš skidati i instalirati net.framework, bugovit je , ždere resurse i usporava komp
Navodno je dosta toga poboljšano od prve verzije-ali me ne svrbi baš da bi ga skidao i isprobavao...
Staro 26.09.2005., 09:20   #17
doublev
the letter
doublev's Avatar
Lokacija: 127.0.0.1
Postovi: 794
svaka .net aplikacija guta resurse.. sve da i nista ne radi, samo ispise hello world, cap ode 10 megi... : hitthewa
ma bitno je samo da se to sranje ne pokrece prilikom dizanja i windowsa i sve pet...
jos mi nikako nije jasno od kud su dosli na ideju da jednostavnu aplikaciju kao sto bi trebao biti ccc, napisu u .netu...
nekome zasvrbilo kad je vidio visual studio pa iso progurat na board.. i proslo..
al ima jedna dobra stvar u svemu tome.. puno je lakse radit reverse engineering jer se iz .net koda moze dobiti cisti c# ili vb kod i fino se moze vidjet sto app radi... sweeet
Exception up = new Exception("Illegal operation.");
throw up;
doublev je offline   Reply With Quote
Staro 26.09.2005., 09:28   #18
segregator
Propali Amigaš
segregator's Avatar
Lokacija: Nin
Postovi: 6,995
Microsoft neće uskoro više dijelit WHQL ako driveri nisu pisani u .NET
Il barem ja tako negdje pročitao, pa ako su lagali mene i ja lažem vas
Staro 26.09.2005., 09:48   #19
doublev
the letter
doublev's Avatar
Lokacija: 127.0.0.1
Postovi: 794
koliko ja znam driveri tehnicki ne mogu biti pisani u .netu..
sto se toga tice driveri ne mogu biti pisani ni u nekim popularnijim dev alatima (delphi npr.)...
throw up;
Staro 26.09.2005., 10:52   #20
Jelc
Super Moderators
Postovi: 17,485
Pa treba znati pisati u c-u, papcima je puno lakše raditi sa net.-om, osim toga već par godina ATI pokušava malo jače ući u deal sa MS-om...
Striktno podržavanje svega kaj ima veze sa DX-om, novi X-box, net.framework, itd.
Ja sam koristio samo drivere i ATT koji ima 800kb i sve je radilo fino, ne treba mi kvragu net. i CCC od 15 megi da mi usporavaju cijeli komp
Staro 26.09.2005., 12:27   #21
Mailman
Mailman's Avatar
Postovi: 1,606
driveri nemaju veze s .net-om... CCC=.net
Staro 30.09.2005., 22:06   #22
Hrconja
Hrconja's Avatar
Postovi: 1,612
Re: Omega 5.9
da, baš :clap:
Hrconja je offline   Reply With Quote
