Staro 21.07.2015., 22:54   #16081
morbid_angel
Lokacija: Tokyo
Postovi: 196
Moj auto sad ima 11 godina. Stalno je na alu felgama, i to istim - bilo ljeto ili zima. Samo gume mijenjam. Vozim ga po Zagrebu i Varazdinu (kad sam u RH) i sol jos nis nije nagrizla.
Bome ak ti je uspjelo razbit sajbu - jel to zasipavaju soli, kamencicima ili stijenama?
CPU: i7 4710HQ
MBO: NEXTGEAR-NOTE i5700
RAM: 4*8 GB DDR3 1600 MHz
GPU: nvidia GTX970M
SSD1: Crucial MX100 512 GB
SSD2: Samsung 850 EVO 1TB
OS: Windows 8.1
MBO: HP NW9440
CPU: C2D T7600
RAM: 2*2 GB DDR2 667 MHz
GPU: nvidia Quadro FX 1500M 512MB
SSD: SanDisk 32GB
HDD: Toshiba 100GB 7200 rpm
Dock: HP Advance Docking Station 180W
OS: Windows 8.1 Professional x64 / OpenSUSE 13
CPU: Intel Core i5 3570K & Scythe Mugen 4
MBO: ASRock Z77 Extreme 4
RAM: 4*8 GB DDRIII 1600 MHz
GPU: VTX3D 7970 & XFX 280X-TDFD
SSD: 2*Vertex 4 128GB (RAID 0)
HDD: Seagate 2TB
PSU: Coolermaster Silent Pro M2 1500W
Case: Coolermaster CM 690 III
LCD: 2*Dell U2412M
Periferija: Logitech G510 & G500, Denon AH-D400
CPU: AMD FX-6200 & Scythe Ninja 3
MBO: Asus M5A97 Evo R2 AMD3+
RAM: 2*8 GB DDRIII ECC
HDD: 2*WD Red 2TB
PSU: XFX 550W
Case: Fractal Design Define XL R2
OS: ESXi 5.5
CPU: AMD Athlon II X4 & Scythe Big Shuriken 2
MBO: ASRock 880G Extreme 3
RAM: 4*4 GB DDRIII 1333 MHz
HDD1: WD Red 2TB
HDD2,3,4: 3*WD Green 2TB
HDD5: Samsung 1 TB
HDD6: Seagate 1500GB
PSU: Corsair VX 450W
Case: Chieftec BA-02B-B-B
OS: Windows Server 2012 R2
CPU: AMD Athlon x2
MBO: Gigabyte GA-M55plus-S3G
RAM: 4*2 GB DDRII 800 MHz
HDD1,2,3: Seagate PATA 320GB
PSU: Corsair CX 400W
Case: White ;D
OS: ESXi 5.5
MBO&CPU&GPU: ASRock E350
RAM: 1*4 GB DDRIII 1333 MHz
SSD: SanDisk 32GB
Case&PSU: Inter-Tech e-i7
OS: Windows 7 Pro x64 + XBMC
SSD: SanDisk 32GB
CPU: C2D 2.4 GHz
MBO: MacBook Pro 13" mid-2010
RAM: 2*4 GB DDR3 1066 MHz
GPU: nvidia 320M
SSD: Kingston HyperX 3K 120GB
HDD: Toshiba 250GB 5400 rpm
OS: OS X 10.9
morbid_angel je offline   Reply With Quote
Staro 22.07.2015., 00:24   #16082
Bubba
E Pluribus UNIX
Bubba's Avatar
Datum registracije: Oct 2002
Lokacija: M82
Postovi: 6,818
Zahvaljujuci kolegi Alisteru, nabavio sam danas taj sugavi displej za P407.
Raskupusam stari, idem vidjet kaj ima unutra, i nabasam na nekakav uC, vidim Fuđicu, reko ajde, posteno preduzece, nema sta.
Skinem datasheet, skrolam dolje...
Smece
Jel cudno sto je krepo?!
Programer
Staro 22.07.2015., 00:56   #16083
syss
syss's Avatar
Postovi: 10,805
vidio na ipadu ovako usput... ne, reko, ne nije istina da se ipak moram dignut za komp i aplauzirat ovom masterpiece-u kojeg je buba ulovio
jedino smiješnije bi bilo da je via napravila isto, ali čak možda ni to
Staro 22.07.2015., 08:31   #16084
jed2i
jed2i's Avatar
Datum registracije: Jul 2004
Postovi: 1,771
Autor syss Pregled postova
maestralna birokracija
Sreća pa je čovjek na tehničkom bio normalan...
Kaže on meni : a ko ti je pobogu ovo napisao
Otišao slikat naljepnicu na vratima i upisao mi sve dimenzije koje mogu stavit na auto
Dečki, neka preporuka, u kojem periodu ići na Stelvio pass?
Staro 22.07.2015., 10:03   #16085
X-Plosiv
X-Plosiv's Avatar
Postovi: 1,811
Kada čitam to vaše "zimske, ljetne" gume i koliko problema sa felgama, tako mi je drago što živim na moru gdje zima padne jednom u 10 godina ^^
Staro 22.07.2015., 11:53   #16086
pixxeel
pixxeel's Avatar
Datum registracije: Dec 2010
Postovi: 219
Problema imaš koliko si sam natovariš sa ekstra željama
Stvar je jednostavna. Jedan set alu/čelik s ljetnim, jedan set čelik sa zimskim gumama (oba serijski upisanih dimenzija). Dva puta godišnje sat(ipo) vremena posla sa uključenim pranjem. Niti je to neki posao niti neki novac da bi iole sigurno vozio tokom cijele godine. Kome je bitniji izgled ili "ležanje u krivinama" bolje neka mi ne uleti u traku sa svojim izlizanim šlapama.
pixxeel je offline   Reply With Quote
Staro 22.07.2015., 13:28   #16087
lowrider
lowrider's Avatar
Lokacija: KR
Postovi: 1,176
Al sam se nasmijao na ovaj post Bubbe i AMD, stvarno ko bireko, Peugeot i AMD. Sad treba samo staviti iza onu naljepnicu AMD inside.
Isto imam alu zimski set, nikakvih problema oko boje, isto kak je spomenuto, sam montiram, nakon sezone operem, posušim, namažem gumee i pospremim na suho
Staro 22.07.2015., 13:40   #16088
buljo
Strichek Moderator
buljo's Avatar
Postovi: 9,347
Autor burmuz Pregled postova
IMHO najbolje je imati dimenzije koje si dobio s autom. Ekvivalent zimske i vozi.
Potpis.
Dva kompleta guma, alu + ljetne i celicane + zimske.
Naravno nije problem ak imas standardnu dimenziju onda je cijena ok, ak nije standardna onda psujes proizvodaca kaj je stavio tu dimenziju na auto.
Stari ima 195/55/16 a ja 205/55/16 i njegove skuplje ak se dobro sjecam 40%
žmnpp
buljo je online   Reply With Quote
Staro 22.07.2015., 14:30   #16089
X-Plosiv
X-Plosiv's Avatar
Postovi: 1,811
Ja imam 205/45/17, feeling the pain..
Staro 22.07.2015., 14:39   #16090
JC Denton
dr. sc. tech. dipl. ing.
JC Denton's Avatar
Lokacija: Rijeka-Opatija
Postovi: 3,186
Autor X-Plosiv Pregled postova
Da, da...sjecam se kaosa u Puli pred koju godinu kad je pao snijeg, a svi "biseri puležani" krenuli po tom vremenu autom na posao... sva sreća pa je moja "bolja polovica" imala zimske gume pa je uspješno izbjegla nekoliko budala s ljetnima koji su klizali prema njoj...
Sve je to još OK ako se po zimi ne ide u unutrašnjost Istre, ali ako se ide dalje od Savičente, zimske dobro dođu... ne treba bit snijega, dovoljne su niske temperature i/ili mraz pa da te ljetne iznenade nedostatkom gripa...
Staro 22.07.2015., 14:43   #16091
syss
syss's Avatar
Postovi: 10,805
mislim da su vozači (prošlog, nadam se ne i ovoga) swifta sport najglavoboljniji narod na svijetu - 195/45/17
Staro 22.07.2015., 15:00   #16092
D1viry
D1viry's Avatar
Lokacija: Slavonija
Postovi: 2,066
Nemojte opet o zimskim/ljetnim gumama.
Pošten trgovac: 1,2,3,4,5,6
Staro 22.07.2015., 15:42   #16093
acer
Whatever :)
acer's Avatar
Datum registracije: Nov 2002
Lokacija: Rijeka,Bulevard
Postovi: 1,756
Krivo postano.
Mac Mini M4
Zadnje izmijenjeno od: acer. 22.07.2015. u 16:04.
Staro 22.07.2015., 16:57   #16094
X-Plosiv
X-Plosiv's Avatar
Postovi: 1,811
Autor JC Denton Pregled postova
Puljani ne znaju voziti po snijegu. Prije par godina neki idiot nije mogao krenuti sa parkirališta, i daje gas kao munjen. Kažem mu da pričeka malo, nađem neki karton i stavim mu malo ispod gume i kažem "kreni polagano", a on opet kao idiot. Pitam ga zašto to radi, a on "da brže krenem". Dobro, probaj polagano...krene malo i op op izvuče se, kaže "ne mogu vjerovati". Niti ja, koji si tenkre frende.
Ovu zimu pao je snijeg u unutrašnjosti istre...a ja sam morao ići raditi nešto u Žminj....bilo je gušt malo se izvrtiti po livadi, ali po cesti polagano jer nitko nema zimske gume...osim seljaka koji su pametni..i to sve zimske na autima +20g
Staro 23.07.2015., 00:33   #16095
ozren
PC Ekspert
ozren's Avatar
Datum registracije: Sep 2000
Lokacija: Zagreb, Hrvatska
Postovi: 1,214
Autor ozren Pregled postova
Dodao još fotki, skužil da fali jedan cijeli dan....
Nissan GT-R Black Edition
Zadnje izmijenjeno od: ozren. 23.07.2015. u 11:47.
ozren je offline   Reply With Quote
Staro 23.07.2015., 13:24   #16096
ti.le
[CTN]Mr.Ti
ti.le's Avatar
Lokacija: Zg, Novi Zg
Postovi: 567
U koju kategoriju ovo spada?
CPU: Ryzen 7 5700G / Noctua D15S; MBO: MSI B550 Tomahawk; RAM:Corsair Vengeance 2x16 3200MHz; GPU: XFX Merc 319 RX 6900 XT; HDD: 1. Samsung 970EVO 256 GB; 2. Crucial P2 500GB; PSU: EVGA Supernova G2 750; CASE: NZXT H440 White; MONITOR: Asus MG279Q; KEYBOARD: Roccat Vulcan 100; MOUSE: Razer ViperMini @ SteelSeries QCK mass; HEADPHONES: Kingston HyperX Cloud (I) - Superlux HD-681 EVO
ti.le je offline   Reply With Quote
Staro 23.07.2015., 13:34   #16097
X-Plosiv
X-Plosiv's Avatar
Postovi: 1,811
U kategoriju zapaliti i više nikada ne postati
Staro 23.07.2015., 13:34   #16098
Milentije
Adrenaline junkie
Milentije's Avatar
Lokacija: Doboj - Banja Luka
Postovi: 3,593
Svidjace mi se samo ako je unutra 1.9JTD.
Staro 23.07.2015., 13:53   #16099
lowrider
lowrider's Avatar
Lokacija: KR
Postovi: 1,176
S obzirom što je čovjek napravio od tog ormara-svaka čast na trudu
Staro 23.07.2015., 15:30   #16100
Milentije
Adrenaline junkie
Milentije's Avatar
Postovi: 3,593
Staro 23.07.2015., 20:06   #16101
ozren
PC Ekspert
ozren's Avatar
Postovi: 1,214
Autor Milentije Pregled postova
I tak je jedan CLS AMG naletio na ravnom na neki plavi Micek s tetrapakom od 2 litre na Bračkoj cesti, s ženom za volanom, pa je nestao iza prvog zavoja..
Bitno da ima grudnjak naprijed hahaha
Staro 23.07.2015., 20:28   #16102
webstartm
Sandy!!!
webstartm's Avatar
Postovi: 1,695
brački kralj sekundarnog otpada (seljacina žešća) ,bijeli cls v12 amg
Staro 23.07.2015., 22:43   #16103
syss
syss's Avatar
Postovi: 10,805
1.2 powah
Pohrani.com
ne ide preko 100
Pohrani.com
znači nekih 15ak litara za 10km... bikoz rejskar i bikoz musclekar istovremeno
Staro 23.07.2015., 23:34   #16104
Nybelung
ne ide preko 100
Spojler bi ti odmah dao +10.
Staro 23.07.2015., 23:37   #16105
syss
syss's Avatar
Postovi: 10,805
jedino ako se spoji na brojač i da mu još jednu znamenku
Staro 23.07.2015., 23:41   #16106
darkydark
N0teb00k n00b
darkydark's Avatar
Lokacija: Zagreb/Koprivnica
Postovi: 2,123
Kenwood zakeljnica +10 i jaggermaister +20 :-)
1TB A2000, 2TB KC3000
Linđa
1x 150GB Intel S3520, 3x2TB Crucial MX500, 5x12TB Toshiba MG07ACA12TE
Truenas Scale
darkydark je online   Reply With Quote
Staro 23.07.2015., 23:41   #16107
syss
syss's Avatar
Postovi: 10,805
ali ne potrošnje nego konja
Staro 23.07.2015., 23:47   #16108
darkydark
N0teb00k n00b
darkydark's Avatar
Postovi: 2,123
:-) i spuh s rupom!!!
Linđa
Truenas Scale
Staro 24.07.2015., 01:01   #16109
Milentije
Adrenaline junkie
Milentije's Avatar
Postovi: 3,593
Ništa to. Je li 2 manje od 6.3? Jeste! KRAJ!
Staro 24.07.2015., 08:03   #16110
X-Plosiv
X-Plosiv's Avatar
Postovi: 1,811
Sys, ne zaboravi ovo što nosi dečko oko vrata - http://cs309418.vk.me/v309418096/7353/o6TTCaTdmOA.jpg
To ili oko unutarnjer retrovizora ili oko mjenjača....daje ti na shift +10
