Staro 16.09.2005., 10:38   #1
Mailman
Mailman's Avatar
Postovi: 1,606
Exclamation crossfire...max rezolucija/refresh
As many are aware by now, ATI’s Crossfire technology uses an external link to connect the Master and Slave cards together (it's sort of like a 3-headed dongle with DVI connectors at the ends). What’s not generally known is that the backbone for this setup is a Silicon Image SiL 1161 chip which is installed on the X8-series Master cards. The SiL 1161 is there to receive output passed over the external link from the Slave card in the Crossfire setup and pass it on to the Master card.
Sounds decent on paper and everything, but if you check out the specs for the 1161 on this page you will see that it is limited to single-link TMDS @ 165MHz. This means that the max 3D resolution for any X8-series Crossfire setup is 1600x1200 @ 60Hz. That means no high-res Crossfire gaming beyond 1600x1200, no 1600x1200 at a flicker free refresh rate, and no widescreen 1920x1200.
http://www.rage3d.com/board/showthread.php?t=33828812
kao da im nije dosta što kasne x mjeseci sa R520, nego zaseru još i ovo...
Mailman je offline   Reply With Quote
Staro 17.09.2005., 22:17   #2
Mailman
Mailman's Avatar
Postovi: 1,606
Detaljno objašnjenje:
http://www.penstarsys.com/#xfire_sil
Ukratko, tresla se brda, rodio se miš....
Staro 17.09.2005., 23:59   #3
Jelc
Super Moderators
Datum registracije: May 2002
Postovi: 17,485
Vidio sam još prije par dana.
Po meni se nisu ni trebali zajebavati po javnosti dok ne izdaju finalni proizvod.
Sve je to marketing, svi su pizdili i o SLI-u a poznam samo jednog tipa koji to stvarno i koristi...
Staro 18.09.2005., 00:38   #4
Trek
Trek's Avatar
Postovi: 1,313
ma ovo je sve dio nvidijinih jadnih pokusaja da nas obeshrabi! E moje nofce nece dobit
Biti lud ima prednosti koje razumiju samo ludjaci
FKT meber jednog dana high priest...
Trek je offline   Reply With Quote
Staro 18.09.2005., 00:47   #5
Jelc
Super Moderators
Postovi: 17,485
Moje nofce ne bu nitko dobil
Ni za SLI ni za Crossfire
Staro 18.09.2005., 12:05   #6
SniperWolf
SniperWolf's Avatar
Postovi: 4,193
To sam ja poslao kao news prije nekoliko dana još ali izgleda da Beren spava
Pošteni Trgovci: 1,2
