Staro 15.09.2005., 14:22   #1
Rain
Postovi: 2
DVR-A07XLA/XLB problem
do prije par dana uredno pržio...prži i sada sve do lead-outa
počeo javljati greške tipa:
Session fixation error
Unable to recover TOC
Could not perform start of Disc-at-once
ponekad javi i Power Calibration error
napominjem da je firmware zadnji, od prije 5 mjeseci, DMA uredno ASPI uredno, memorije ima, virusa nema...win imapi disejblano, nema drugog burning softwarea
preporuke za novu DL pržilicu...samo da nije neki šrot tipa lite-on
Rain je offline   Reply With Quote
Staro 16.09.2005., 17:04   #2
Raven_1
Night shift
Raven_1's Avatar
Datum registracije: Jul 2002
Postovi: 884
Nemoj je odmah otpisati, probaj je očistit, pržit na druge medije. Ako kupuješ preporučujem LG GSA-4163B ili eventualno Pioneer 110 (mogući problemi s određenim kontrolerima).
Proc: AMD X2 3800+ cooled by TT BigTyphoon
Matična: ABIT AN8 SLI
RAM: 2x512MB OCZ Platinum EL rev2 PC3200
Grafička: SAPPHIRE ATI RADEON HD3450 256MB
HDD: WD 40GB i Samsung 160GB @ 7200
RW:DVD-ROM Pioneer DVD-106
PSU: 420W Xilence RedWing
"NOBODY expects the Spanish Inquisition! Our chief weapon is surprise...surprise and fear...fear and surprise.... Our two weapons are fear and surprise...and ruthless efficiency.... Our *three* weapons are fear, surprise, and ruthless efficiency...and an almost fanatical devotion to the Pope.... Our *four*...no... *Amongst* our weapons.... Amongst our weaponry...are such elements as fear, surprise.... I'll come in again."
--uoɥʇʎd ʎʇuoɯ--
Raven_1 je offline   Reply With Quote
Staro 16.09.2005., 22:05   #3
Rain
Postovi: 2
evo loga
1A23-0009-4130-2380-8653-2409
Windows XP 5.1
IA32
WinAspi: -
ahead WinASPI: File 'C:\Program Files\Ahead\Nero\Wnaspi32.dll': Ver=2.0.1.74, size=164112 bytes, created 26.10.2004 18:35:34
Nero Version: 6.6.0.16
Internal Version: 6, 6, 0, 16b
Recorder: <PIONEER DVD-RW DVR-107D>Version: 1.21 - HA 1 TA 0 - 6.6.0.16
Adapter driver: <atapi> HA 1
Drive buffer : 2000kB
Bus Type : default (0) -> ATAPI, detected: ATAPI
CD-ROM: <HL-DT-ST DVD-ROM GDR8161B>Version: 0100 - HA 1 TA 1 - 6.6.0.16
=== Scsi-Device-Map ===
DiskPeripheral : ST3200826A atapi Port 0 ID 0 DMA: On
CdRomPeripheral : PIONEER DVD-RW DVR-107D atapi Port 1 ID 0 DMA: On
CdRomPeripheral : HL-DT-ST DVD-ROM GDR8161B atapi Port 1 ID 1 DMA: On
CdRomPeripheral : NERO IMAGEDRIVE2 2.26 imagedrv Port 2 ID 0 DMA: Off
=== CDRom-Device-Map ===
PIONEER DVD-RW DVR-107D G: CDRom0
HL-DT-ST DVD-ROM GDR8161B H: CDRom1
NERO IMAGEDRIVE2 F: CDRom2
AutoRun : 1
Excluded drive IDs:
WriteBufferSize: 83886080 (0) Byte
ShowDrvBufStat : 0
BUFE : 0
Physical memory : 767MB (785904kB)
Free physical memory: 477MB (488680kB)
Memory in use : 37 %
Uncached PFiles: 0x0
Use Inquiry : 1
Global Bus Type: default (0)
Check supported media : Disabled (0)
14.9.2005
UDF/ISO compilation
14:40:11 #1 Phase 112 File dlgbrnst.cpp, Line 1832
DVD-Video files reallocation started
14:40:11 #2 Phase 114 File dlgbrnst.cpp, Line 1832
DVD-Video files reallocation completed (no file modified)
14:40:11 #3 Text 0 File Isodoc.cpp, Line 6356
UDF document burn settings
Determine maximum speed : FALSE
Simulate : FALSE
Write : TRUE
Finalize CD : TRUE
Multisession : FALSE
Burning mode : DAO
Mode : 1
UDF Mode : UDF/ISO bridge
UDF Revision : 1.02
UDF Partition Type : physical
ISO Level : 1 (Max. of 11 = 8 + 3 char)
Character set : ISO 9660
Joliet :FALSE
Allow pathdepth more than 8 directories : TRUE
Allow more than 255 characters in path : TRUE
Write ISO9660 ;1 file extensions : TRUE
14:40:11 #4 Phase 111 File dlgbrnst.cpp, Line 1832
DVD-Video files sorted
14:40:11 #5 Text 0 File Reader.cpp, Line 127
Reader running
14:40:11 #6 Text 0 File Writer.cpp, Line 122
Writer PIONEER DVD-RW DVR-107D running
14:40:11 #7 ISO9660GEN -11 File geniso.cpp, Line 3309
First writeable address = 0 (0x00000000)
14:40:11 #8 ISO9660GEN -11 File geniso.cpp, Line 3309
14:40:11 #9 Text 0 File Burncd.cpp, Line 3233
Turn on Disc-At-Once, using DVD media
14:40:11 #10 Text 0 File DlgWaitCD.cpp, Line 270
Last possible write address on media: 2295103 (510:01.28, 4482MB)
Last address to be written: 2050063 (455:34.13, 4004MB)
14:40:11 #11 Text 0 File DlgWaitCD.cpp, Line 282
Write in overburning mode: NO (enabled: CD)
14:40:11 #12 Text 0 File DlgWaitCD.cpp, Line 2483
Recorder: PIONEER DVD-RW DVR-107D, Media type: DVD+R
Disc Manufacturer ID: MCC, Media Type ID: 004, Product revision number: 0
Disc Application Code: 0, Extended Information Indicators: 7
14:40:11 #13 Text 0 File DlgWaitCD.cpp, Line 448
>>> Protocol of DlgWaitCD activities: <<<
14:40:11 #14 Text 0 File ThreadedTransferInterface.cpp, Line 838
Setup items (after recorder preparation)
0: TRM_DATA_MODE1 ()
2 indices, index0 (150) not provided
original disc pos #0 + 2050064 (2050064) = #2050064/455:34.14
relocatable, disc pos for caching/writing not required/ required, no patch infos
-> TRM_DATA_MODE1, 2048, config 0, wanted index0 0 blocks, length 2050064 blocks [PIONEER DVD-RW DVR-107D]
14:40:11 #15 Text 0 File ThreadedTransferInterface.cpp, Line 1051
Prepare recorder [PIONEER DVD-RW DVR-107D] for write in CUE-sheet-DAO
DAO infos:
MCN: ""
TOCType: 0x00; Session Closed, disc fixated
Tracks 1 to 1:
1: TRM_DATA_MODE1, 2048/0x00, FilePos 0 0 4198531072, ISRC ""
DAO layout:
__Start_|____Track_|_Idx_|_CtrlAdr_|_RecDep__________
0 | lead-in | 0 | 0x41 | 0x00
0 | 1 | 0 | 0x41 | 0x00
0 | 1 | 1 | 0x41 | 0x00
2050064 | lead-out | 1 | 0x41 | 0x00
14:40:12 #16 Phase 24 File dlgbrnst.cpp, Line 1832
Caching of files started
14:40:12 #17 Text 0 File Burncd.cpp, Line 4120
Cache writing successful.
14:40:12 #18 Phase 25 File dlgbrnst.cpp, Line 1832
Caching of files completed
14:40:12 #19 Phase 36 File dlgbrnst.cpp, Line 1832
Burn process started at 4x (5.540 KB/s)
14:40:12 #20 Text 0 File ThreadedTransferInterface.cpp, Line 2654
Verifying disc position of item 0 (relocatable, disc pos, no patch infos, orig at #0): write at #0
14:40:12 #21 Text 0 File Cdrdrv.cpp, Line 8862
---- DVD Structure: Physical Format Information (00h) ----
Layer: 0, Address: 0 (0 h), AGID: 0; Length: 2050
Book Type: DVD+R (10), Part Version: 1.0x (1)
Disc Size: 120 mm, Maximum Rate: <not specified> (F h)
Number of Layers: 1, Track Path: Parallel Track Path (PTP), Layer Type: recordable
Linear Density: 0,267 um/bit, Track Density: 0,74 um/track
Starting Physical Sector Number of Data Area: 30000 h (DVD-ROM, DVD-R/-RW, DVD+R/+RW)
End Physical Sector Number of Data Area: 26053F h
End Sector Number in Layer 0: 0 h (LBN: FFFD0000 h, 4193920 MB)
Data in Burst Cutting Area (BCA) does not exist
Disc Application Code: 0 / 0 h
Extended Information indicators: 7 h
Disc Manufacturer ID: MCC.....
Media type ID: 004
Number of Physical format information bytes in use in ADIP up to byte 63: 56
Media Specific [16..63]:
00 00 07 4D 43 43 00 00 - 00 00 00 30 30 34 00 38 ...MCC.....004.8
23 54 37 12 02 54 6C 02 - 92 5F 15 15 0B 0B 08 08 #T7..Tl.._......
01 19 1B 0C 0C 0C 0D 01 - 00 00 00 00 00 00 00 00 ................
14:40:12 #22 Text 0 File DVDPlusRW.cpp, Line 665
Start write address at LBA 0
DVD high compatibility mode: Yes
14:40:12 #23 Text 0 File Cdrdrv.cpp, Line 1286
14:40:12.578 - PIONEER DVD-RW DVR-107D\H1 T0 : Queue again later
14:40:41 #24 Text 0 File Cdrdrv.cpp, Line 1286
14:40:41.468 - PIONEER DVD-RW DVR-107D\H1 T0 : Queue again later
14:53:18 #25 Text 0 File WriterStatus.cpp, Line 116
<PIONEER DVD-RW DVR-107D> start writing Lead-Out at LBA 2050064 (1F4810h), lenght 0 blocks
14:53:18 #26 Text 0 File ThreadedTransfer.cpp, Line 228
all writers idle, stopping conversion
14:53:27 #27 SCSI -1061 File Cdrdrv.cpp, Line 1180
SCSI Exec, HA 1, TA 0, LUN 0, buffer 0x03AB5000
Status: 0x04 (0x01, SCSI_ERR)
HA-Status 0x00 (0x00, OK)
TA-Status 0x02 (0x01, SCSI_TASTATUS_CHKCOND)
Sense Key: 0x04 (KEY_HARDWARE_ERROR)
Sense Code: 0x44
Sense Qual: 0xD6
CDB Data: 0x51 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x20 0x00 0x00 0x00
Sense Data: 0x71 0x00 0x04 0x00 0x00 0x00 0x00 0x0E
0x00 0x00 0x00 0x00 0x44 0xD6
14:53:27 #28 CDR -1061 File ThreadedTransferInterface.cpp, Line 1909
Internal target failure
14:53:27 #29 TRANSFER -24 File ThreadedTransferInterface.cpp, Line 1909
Could not perform end of Disc-at-once
14:53:27 #30 SCSI -1122 File Cdrdrv.cpp, Line 1180
Sense Key: 0x03 (KEY_MEDIUM_ERROR)
Sense Code: 0x57
Sense Qual: 0x00
Sense Data: 0x70 0x00 0x03 0x00 0x00 0x00 0x00 0x0E
0x00 0x00 0x00 0x00 0x57 0x00
14:53:27 #31 SCSI -1122 File Cdrdrv.cpp, Line 1180
Sense Code: 0x57
Sense Qual: 0x00
CDB Data: 0x5B 0x01 0x05 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00
14:53:27 #32 Phase 127 File dlgbrnst.cpp, Line 1832
Generating DVD high compatibility borders
14:53:27 #33 CDR -1122 File WriterStatus.cpp, Line 167
14:53:27 #34 TRANSFER -24 File WriterStatus.cpp, Line 167
14:53:27 #35 Phase 38 File dlgbrnst.cpp, Line 1832
Burn process failed at 4x (5.540 KB/s)
Existing drivers:
File 'Drivers\atapi.sys': Ver=5.1.2600.2180 (xpsp_sp2_rtm.040803-2158), size=95360 bytes, created 3.8.2004 23:59:44 (Adapter driver for rec)
Registry Keys:
HKLM\Software\Microsoft\Windows NT\CurrentVersion\WinLogon\AllocateCDROMs : 0 (Security Option)
