Staro 09.01.2015., 22:58   #241
Drvoje
Split resist itself!
Drvoje's Avatar
Postovi: 4,037
Textures need to be addressed and filtered. This job is done by TMUs that work in conjunction with pixel and vertex shader units. It is the TMU's job to apply texture operations to pixels. The number of texture units in a graphics processor is used when comparing two different cards for texturing performance. It is reasonable to assume that the card with more TMUs will be faster at processing texture information.
The Render Output Pipeline is an inherited term, and more often referred to as the render output unit. Its job is to control the sampling of pixels (each pixel is a dimensionless point), so it controls antialiasing, where more than one sample is merged into one pixel. All data rendered has to travel through the ROP in order to be written to the framebuffer, from there it can be transmitted to the display.
Therefore, the ROP is where the GPU's output is assembled into a bitmapped image ready for display.
Zadnji dio o "Mantilu" , nemam pojma.
Pomelo mi sig -.-
Staro 10.01.2015., 17:08   #242
Kal-EL
Kal-EL's Avatar
Lokacija: Vinkovci
Postovi: 478
Ja ću svoju probat zamijenit za r9 290 ili neku nvidiju.
Nek' netko ko to voli čačka po gpu tweaku i biosu.
Kal-EL je offline   Reply With Quote
Staro 21.01.2015., 18:01   #243
DariX
DariX's Avatar
Datum registracije: Sep 2011
Lokacija: Velika Gorica
Postovi: 175
Da li je itko od vas reklamirao svoju 280x-icu i sta su vam rekli?
Kakvi su zakljucci nakon reklamacije?
DariX je offline   Reply With Quote
Staro 22.01.2015., 15:38   #244
Cloker
Cloker's Avatar
Datum registracije: Oct 2014
Lokacija: Bojnik
Postovi: 235
Ajd da pitam I ovde???DA li iko je upucen da li moze gigabite 7970windforce oc da joj se otkljuca napon ,ja probao nece,ako neko radio neka kaze a moze i na PM
http://prntscr.com/5vlnb2
http://prntscr.com/5vlo7q
Cloker je offline   Reply With Quote
Staro 22.01.2015., 15:50   #245
Strong
Strong's Avatar
Lokacija: Našice
Postovi: 186
Imao tu grafu..također je bila zaključana voltaža...
Strong je offline   Reply With Quote
Staro 24.01.2015., 13:32   #246
jed2i
jed2i's Avatar
Datum registracije: Jul 2004
Postovi: 1,771
Na techpower up-u imaš bios sa 1.256V na 1100mhz
http://www.techpowerup.com/vgabios/
Staro 28.01.2015., 16:08   #247
vorda22
za koju grafu mi se isplati zamijeniti 280x, a da mogu igrati na medium/high postavkama igre? proc je i3 2100
Staro 28.01.2015., 16:36   #248
JC Denton
dr. sc. tech. dipl. ing.
JC Denton's Avatar
Lokacija: Rijeka-Opatija
Postovi: 3,185
Autor vorda22 Pregled postova
Ako sada ne možeš igrati igre na medium/high, onda nije problem u grafi nego vjerojatno u procu (preslab?). Ako moja R9 270 može vrtiti medium/high detalje, 280X ne bi trebala imati problema prožvakati te postavke.
Uzmi neki polovni i5 koji ide u tvoju ploču, to bi trebalo riješiti tvoje probleme
JC Denton je online   Reply With Quote
Staro 28.01.2015., 16:48   #249
vorda22
hehe, mislio sam za koju slabiju grafu mogu zamijeniti + lova, a da sad ne steka bas na medium 1080p
Staro 28.01.2015., 20:41   #250
JC Denton
JC Denton's Avatar
Postovi: 3,185
HD7850/7870 ili R7 265 /R9 270, ali s 2gb rama. Ili neka gtx660/660ti
Staro 28.01.2015., 22:40   #251
Drvoje
Drvoje's Avatar
Postovi: 4,037
@blavor22
Ovakva HD7850 za 550kn je no brainer, čak i ako je rudarila razbojniče
http://forum.pcekspert.com/showpost....27&postcount=4
Pomelo mi sig -.-
Staro 29.01.2015., 01:52   #252
gunther
Postovi: 1,370
Stvarno je no brainer, ali je udomljena u roku keks nakon sto je pustena s lanca u prodaju
AMD Ryzen 5900X; Gigabyte Aorus X570 Elite; Corsair Vengeance RGB Pro SL DDR4 2X16 Gb 3600 Mhz; AMD Radeon Gigabyte 7900 XTX; SSD Patriot Viper VP4300 PCIe m.2 GEN4 2 Tb;Lian Li 011 Dynamic EVO; LG C2
gunther je offline   Reply With Quote
Staro 29.01.2015., 10:16   #253
jed2i
jed2i's Avatar
Postovi: 1,771
Nabavio Sapphire 290x tri-x
Windforce 280x mi je bila tiha, al ova je još tiša, gpu temp ide do 76, a gpu fan duty nikad iznad 44%
Prezadovoljan sam
Staro 29.01.2015., 10:52   #254
Sam Fischer
Džabe si krečio!
Sam Fischer's Avatar
Postovi: 5,191
Autor jed2i Pregled postova
Prezadovoljan sam
Moj čovjek!
Uživaj u svih 4Gb Vrama
Staro 29.01.2015., 11:26   #255
jed2i
jed2i's Avatar
Postovi: 1,771
Jasna stvar!
Čuo sam jedan coil whine od 970 i pozlilo mi je + shitarija s ramom....stvarno su đukci ovi iz nvidie
Od ove svoje mislim da sam jednom čuo coil whine dok je izlazio van iz Heaven-a...
Pokušao sam ga dobit da zazviždi još koji put al nisam uspio nikako
Možda je samo pas malo zacvilio da hoće van, nisam siguran
Staro 29.01.2015., 11:32   #256
vorda22
Autor Drvoje Pregled postova
@blavor22
to nije losa grafa, tak sam nesto i mislio od 7850-6950 range...
Staro 29.01.2015., 15:50   #257
Sam Fischer
Džabe si krečio!
Postovi: 5,191
Pa kaj ti nije ostala neka od majnanja?
Staro 29.01.2015., 15:51   #258
dmr
dmr's Avatar
Lokacija: Tuzla
Postovi: 1,267
Pa to su duplo slabije grafe!?
dmr je offline   Reply With Quote
Staro 31.01.2015., 17:59   #259
Odinarius
All-rounder
Datum registracije: Sep 2013
Postovi: 1,342
Da li je 280X optimalna za i5 4670 (3.4/3.8)? Ili taj proc može podnijeti više? Full hd.
Staro 31.01.2015., 18:33   #260
Strong
Strong's Avatar
Lokacija: Našice
Postovi: 186
Je... Može i jača, ako želiš
Staro 04.02.2015., 10:48   #261
vorda22
Autor dmr Pregled postova
evo zamijenit cu se za 6950 2gb (koja se moze otkljucat u 6970), bit ce dosta za medium-high na 1080p ovih 5-6 sati tjedno kaj se igram na kompu
Staro 04.02.2015., 13:10   #262
dmr
dmr's Avatar
Lokacija: Tuzla
Postovi: 1,267
nije bitno koliko se igras vec koliko kvalitetno
Staro 09.02.2015., 18:36   #263
vorda22
evo za ovu sam se zamijenio. ok je to...
najjaca stranica testa
http://www.ocaholic.ch/modules/smart...d=1207&page=14
Staro 11.02.2015., 20:22   #264
Kal-EL
Kal-EL's Avatar
Lokacija: Vinkovci
Postovi: 478
Zamijenio danas asusicu za gigabyte r9 280x, valjda ova nece imati problema kao asusica.
živi bili pa vidjeli
Staro 11.02.2015., 20:56   #265
dmr
dmr's Avatar
Lokacija: Tuzla
Postovi: 1,267
Sta su bili problemi?
Staro 11.02.2015., 21:00   #266
Kal-EL
Kal-EL's Avatar
Lokacija: Vinkovci
Postovi: 478
Artefakti u nekim igrama na manjim postavkama i takve stvari. Jednom graph. driver not found. Imala je oc memoriju po defaultu, a nije kolega mogao pronaci garanciju. Na ovoj imam do 11/2016 tako da mi je ova manji rizik.
Staro 11.02.2015., 21:03   #267
dmr
dmr's Avatar
Lokacija: Tuzla
Postovi: 1,267
To bila ona DirectCU II ili neka druga, na koliko je radila memorija i koja je memorija hynix ili elpida?
Staro 11.02.2015., 21:07   #268
Kal-EL
Kal-EL's Avatar
Lokacija: Vinkovci
Postovi: 478
Da, ta directcu II, ovo za memoriju moram provjerit, nisamkuci
Staro 11.02.2015., 21:08   #269
blava
blava's Avatar
Lokacija: スラボニア
Postovi: 3,062
Ja cu isto svoju pred istek jamstva iako nemam vise problena na podignutnoj voltazi ( 1130 na 1174 mV ) i BIOSU..
Mozda uleti R9 380x
Staro 11.02.2015., 21:11   #270
dmr
dmr's Avatar
Lokacija: Tuzla
Postovi: 1,267
kod mene ova powercolor turboduo ima hynix memoriju na 1,5V 1500MHz po def. al radi bez problema na 1750MHz na 1,575V , a gpu na 1130 na def. 1,2V
