Staro 09.11.2014., 17:38   #12781
Dottore
Dottore's Avatar
Postovi: 7,653
HP 845 G8
CPU: AMD Ryzen 7 PRO 5850U
Graphic: AMD Radeon 680M
OS: Windows 11 Pro 24H2
Mice: Logitech MX Master 3S
Lenovo ThinkPad P15v Gen 3
CPU: AMD Ryzen 7 PRO 6850H
RAM: 64GB DDR5
Graphic: AMD Radeon
LCD: 15" IPS @ 3840x2160
Lenovo ThinkPad T14 Gen 3
RAM: 16GB soldered LPDDR4
LCD: 14" IPS @ 1920 x 1200
Mice: Logitech VX Nano
Lenovo X1 Carbon 7th Gen
CPU: Intel Core i7-8665U
RAM: 16GB soldered LPDDR3
Graphic: Intel HD 620
LCD: 14" IPS @ 2560x1440
Lenovo X1 Carbon 10th Gen
CPU: Intel Core i7-1260p
SSD: Sk Hynix 512 GB NVMe M.2
Graphic: Intel Iris Xe
LCD: 14" IPS @ 1920x1200
OS: Windows 11 Pro 23H2
Staro 09.11.2014., 22:22   #12782
nino
nino's Avatar
Postovi: 12,613
Autor Milentije Pregled postova
Jos furas onu zelenu skodu?
Jok, razbio je u Slo, sada se fura ovo.
http://31.169.66.148:28/Dosyalar/Ara...a8_citroen.JPG
Staro 09.11.2014., 22:27   #12783
Milentije
Adrenaline junkie
Milentije's Avatar
Lokacija: Doboj - Banja Luka
Postovi: 3,593
Simpatican mi je taj c-elysee/301. Je li naftarica?
Staro 09.11.2014., 23:31   #12784
D1viry
D1viry's Avatar
Lokacija: Slavonija
Postovi: 2,066
Autor nino Pregled postova
Baš isti pežo, kao šogorov. Valjda je samo amblem drukčiji.
Pošten trgovac: 1,2,3,4,5,6
Staro 09.11.2014., 23:37   #12785
nino
nino's Avatar
Postovi: 12,613
Naftarica, jasta. Moras vidit koliko kucista ukrcam u njega.
1,6 dci - registriran 02.09.2014. i do danas presao 8200km Prosjek potrosnje 4,3 l/100km.
Mi-li-na nakon Fabie.
Autor D1viry Pregled postova
Peugeot 301. Pa nije bas, ipak je nos citroena lipsi od peugeotovog.
http://img1.imagilive.com/0113/startimes1.jpg
Staro 10.11.2014., 00:41   #12786
Dottore
Dottore's Avatar
Postovi: 7,653
HP 845 G8
RAM: 64GB DDR5
Graphic: AMD Radeon
Staro 10.11.2014., 01:42   #12787
IcyTexx
IcyTexx's Avatar
Postovi: 4,707
Po stoti put mi je žao kaj još nisam kupio kameru kao ivan...
Na Branimirovoj auto ispred mene pri 85 km/h u zavoju prije semafora za Dubravu kod Kauflanda ode ravno preko pune crte u frontalni sudar na drugi auto. U zadnji tren su se oba mimoišla... Nastradao bi i ja i svi mi skupa zajedno i bilo bi mrtvih.
Nakon toga prođe kroz čisto crveno kod Petrola.
Nadam se da se kasnije skucao negdje u stup i da nikog nije ubio osim sebe... Il je bio pijan ili idiot.
Staro 10.11.2014., 08:42   #12788
Problem
Pijem samo KAJ
Problem's Avatar
Lokacija: Vž
Postovi: 2,688
misliš HDI?
Staro 10.11.2014., 10:26   #12789
MAGARAC
MAGARAC's Avatar
Postovi: 5,990
Da je 1.6 dci tak lagan auto bi letio posto ima 130ks i vise biturbo verzije. Dobar je i taj hdi. 90 i sitno ks pokrecu c4 solidno a ovaj jos bolje.
Moj Megance je nedavno napunio godinu dana. Presao je oko 32 tisuce bez najmanjeg problema. Sad je fino sve razradeno i u top formi. Cak su mi i kocnice postale dobre. Potrosnja je vecinom ispod pet litara. Nije se razkanto, nema vibracija niti je postao bucan.
http://www.pohrani.com/f/1X/6N/1TRR167P/untitled.jpg
Zadnje izmijenjeno od: MAGARAC. 10.11.2014. u 22:57.
Staro 11.11.2014., 16:44   #12790
TomG
TomG's Avatar
Lokacija: Munich
Postovi: 2,222
Zna li netko sirinu rupa na kotacima kod meganea karavan 2006?
Imam nove gume i felge od renaulta 19 za malo novaca ali sam prilicno siguran da ne pasu kotaci.. Hvala..
TomG je online   Reply With Quote
Staro 11.11.2014., 17:11   #12791
jopis
gadget freak
jopis's Avatar
Lokacija: Jasenovac
Postovi: 2,224
Autor TomG Pregled postova
Krivo si siguran.
4x100 je i na 19ici i na megsu2, et je išao 35 ili 38, tako da, osim ako kojim slučajem gledaš 13ice, paše. No za svaki slučaj, probaj namontirati na prednji kotač da vidiš prolazi li kraj kočione čeljusti, s tim zna bit zavrzlama, jer megs2 ima veće diskove i veće kočione čeljusti pa bi moglo zapinjati ako je neki model felge sa izraženijim unutarnjim rubom.
Staro 11.11.2014., 18:21   #12792
TomG
TomG's Avatar
Lokacija: Munich
Postovi: 2,222
Autor jopis Pregled postova
Krivo si siguran.
E pa hvala kolega. Ali je radi se o 13 cola hah..
Ajde bas probam pa javim.. Pozdrav.
Staro 11.11.2014., 18:37   #12793
tech
Postovi: 1,687
Dobro provjeri, jer na karavana(ovisi o motoru doduše) su išli napred veći diskovi nego na drugim izvedenicama, promjer je od 260 do najćešće 280. Tak veli katalog za 2006 1.6, za kratkog su se našli i 240mm diskovi. Mislim da niš manje od 15" ne buš mogao namontirati.
Staro 11.11.2014., 20:17   #12794
IcyTexx
IcyTexx's Avatar
Postovi: 4,707
Nema teorije 13". I 14" je jako upitno.
Staro 12.11.2014., 15:17   #12795
MAGARAC
MAGARAC's Avatar
Postovi: 5,990
Dobar video. Terenci lome zube..
Staro 12.11.2014., 15:21   #12796
syss
syss's Avatar
Postovi: 10,805
pa mislim da bi tu jedino esp trebao imat i ideš.
Staro 12.11.2014., 15:36   #12797
MAGARAC
MAGARAC's Avatar
Postovi: 5,990
Meni ni ne izgleda tak opako taj uspon, ima gorih kod mene ali ovdje je specijalno zaledeno, Ruski. To neka policijska stanica gore ili nes sl. pa ide prijavi nesto..
Ovo su lose gume, po meni. Drugi je otisal gore sam tak..
https://www.youtube.com/watch?v=aqAfyA-Hus8
Staro 12.11.2014., 15:58   #12798
MuroF
MuroF's Avatar
Lokacija: VŽ-okolica
Postovi: 118
vjerujem da ima ljetne,da je kod nas bi uspjel,tu ljetne idu bilo kuda
MuroF je offline   Reply With Quote
Staro 12.11.2014., 16:24   #12799
1v@n
The mighty pirate
1v@n's Avatar
Lokacija: London
Postovi: 9,089
Drugi ima dosta ispuštene gume. Odmah većom površinom gazi po snijegu.
CPU: Intel Core i7 8809G
MBO: Intel NUC8i7HVK
RAM: 2x16GB Crucial DDR4 2400
GPU: Radeon™ RX Vega M GH
LCD: BENQ PD3200Q
OS: Windows 10 Pro x64
Staro 12.11.2014., 18:32   #12800
Pawzilla
Pawzilla's Avatar
Postovi: 312
Dečki (i cure ), molio bih pomoć! Znate li za kakav parking oko Iblerovog trga, gdje mogu ostaviti auto duže od 2-3 sata, a da ne moram platiti 80/100kn dnevnu kartu?
Pawzilla je offline   Reply With Quote
Staro 12.11.2014., 18:37   #12801
tech
Postovi: 1,687
Garaža langov trg, od iblerovog gore prema brdu/ribnjaku. 5kn je sat po danu ja mislim.
Staro 12.11.2014., 18:42   #12802
Pawzilla
Pawzilla's Avatar
Postovi: 312
Autor tech Pregled postova
Super, hvala ti! Bitno da nema nekog ograničenja, da ne moram brinuti
Staro 12.11.2014., 18:43   #12803
1v@n
The mighty pirate
1v@n's Avatar
Lokacija: London
Postovi: 9,089
Pa Importanne na Iblerovom ima garažu, isto je 5kn / sat
LCD: BENQ PD3200Q
Staro 12.11.2014., 18:46   #12804
Pawzilla
Pawzilla's Avatar
Postovi: 312
Ne znam jel Importanne ima neko vremensko ograničenje, googlam no nisam našao. Da nema, to bi mi bilo još bolje.
EDIT: http://www.importanne.hr/galleria/hrv/garaza.php
Sad ga znaj..
Staro 12.11.2014., 18:47   #12805
1v@n
The mighty pirate
1v@n's Avatar
Lokacija: London
Postovi: 9,089
Koliko ja znam, nijedna garaža nema vremensko ograničenje. Ne vidim logiku u tome da tjeraju van, kad što si duže u garaži, više im novaca ide u blagajnu
LCD: BENQ PD3200Q
Staro 12.11.2014., 18:49   #12806
Pawzilla
Pawzilla's Avatar
Postovi: 312
Davno prije mi je jedan poznanik pričao kako plaća na Iblerovom u garaži XXkn po danu, pa sam to shvatio kao da mora dnevnu uzeti nakon nekoliko sati stajanja (tipa ako tamo parkira i ode odraditi smjenu).
Autor 1v@n Pregled postova
Ma, tako i ja mislim. Ništa, onda na Iblerov odmah i super.
Staro 12.11.2014., 18:54   #12807
tech
Postovi: 1,687
Je zaboravil sam na tu, nisam se tamo parkirao skoro dvije godine pa nemam pojma koje su cifre u pitanju.
To se vjerojatno radi o dnevnoj karti koja te ispadne jeftinije nego da ti naplaćuju sat za satom. Al lako provjeriš, nazovi onaj telefon sa stranice pa pitaj, niš te ne košta a šanse su da bu jeftinije jer to nije garaža od lopova iz zgparkinga.
Staro 12.11.2014., 18:55   #12808
1v@n
The mighty pirate
1v@n's Avatar
Lokacija: London
Postovi: 9,089
Autor Pawzilla Pregled postova
Vjerojatno je dnevna jeftinija od 10 sati stajanja u garaži, ali tko zna. Broj telefona lako nađeš, nazoveš i pitaš za cijene. Možda ti se više i isplati dnevna, ako joj je cijena manja od tih x sati koje trebaš biti u garaži.
Ne mogu nać cjenik za importanne garažu, ali ostale garaže u gradu imaju cijene dnevnih od 20-60 kn, što ti se isplati na duži period.
LCD: BENQ PD3200Q
Staro 12.11.2014., 22:31   #12809
minotaur
minotaur's Avatar
Lokacija: sveta nedelja
Postovi: 118
Jedna fenomenalna vijest!
http://www.racing.hr/rally-beppo-har...anta-domenici/
BEPPO HARRACH PONOVO NA SANTA DOMENICI!!
Beppo Harrach, jedan od najbržih i najatraktivnijih europskih vozača i ove će godine nastupiti 29 i 30.11 na Rally Showu Santa Domenica. Prošlogodišnji pobjednik pokazao nam je svoje umijeće na svojoj najdražoj podlozi i sigurni smo da će i ove godine nagraditi publiku brzim i atraktivnim prolascima u Savrščaku. Brzi austrijanac nastupiti će u novom automobilu-Ford Fiesti R5, a suvozač će mu biti Dominik Jahn.
trenutna lista prijava 123 posade
http://akk-svetanedelja.com/index.ph.../lista-prijava
HP 6720s
minotaur je offline   Reply With Quote
Staro 12.11.2014., 22:35   #12810
zgmmax
zgmmax's Avatar
Postovi: 1,668
Besplatna ti je Novakova ulica, drito se skrene desno tam di skreces lijevo na Langovom trgu na bengu.
Jedino je problem nac prazno mjesto jer je to jedina ulica u centru u kojoj se neplaca parking.
