#1081 |
Fresh Juice
Postovi: 4,586
Ne znaju se sve specke skroz još, no mogao bi imat. |
#1082 |
ODUZIMAM VAM RIJEČ
Postovi: 13,593
#1084 |
Fresh Juice
Postovi: 4,586
Evo i live slike Turba ![]() |
#1085 |
Postovi: 34,124
Turbo u svom pakovanju. Škrci ne daju sluške u njemu. http://www.gsmdome.com/motorola-droi...ws-live-photos
#1086 |
Ili jesi ili nisi
Datum registracije: May 2011
Lokacija: vrgorac
Postovi: 737
Pa koliko im je teško bilo napravit crn ekran, da se dok je izgasen ne vidi razlika boje ekrana i ruba... Jos uvijek stoji to da je mobitel iskljucivo Verizonov, nema novosti o int. verziji? |
#1088 |
Postovi: 34,124
Mislim da ne bi. Gledam specke drugog modela i kaže "Pre-installed SIM card" pa smatram da je zapravo ni nema. http://www.verizonwireless.com/smart...2nd-gen/#specs
#1089 |
Fresh Juice
Postovi: 4,586
#1090 |
Fresh Juice
Postovi: 4,586
Stigao je Droid Turbo, tj. predstavljen službeno Ima dviej verzije, 32GB i 64GB. A osim toga postoji Ballistic Nylon koji ima 176g i Metalized Fiber koji ima 169g. Ostatak specki: http://www.droid-life.com/2014/10/28...pecs-official/ Cijena je $199 na dvije godine ugovor za 32GB model i $249 za 64GB model. Slike uživo: http://www.droid-life.com/2014/10/28...-a-true-droid/ Strava mob Dimensions: Ballistic nylon: 73.3 x 143.5 x 11.2mm; Metalized fiber: 73.3 x 146.5 x 10.6mm; Weight: Ballistic nylon: 176g; Metalized fiber: 169g Display: 5.2" AMOLED touchscreen, 1,440 x 2,560 resolution; around 565ppi; Gorilla Glass 3 Chipset: Snapdragon 805 chipset: quad-core Krait 450 @2.7GHz; Adreno 420 GPU; 3GB RAM OS: Android 4.4.4 KitKat Camera: 21MP main camera with 2160p@24fps video capture, dual-LED flash Front camera: 2MP front-facing camera with 1080p video capture Storage: 32GB/64GB built-in Connectivity: LTE Cat. 4, Wi-Fi a/b/g/n/ac, Bluetooth 4.0, A-GPS + GLONASS; microUSB 2.0 Battery: 3,900mAh, Motorola Turbo Charger Misc: DuPont Kevlar on the back, infrared |
#1092 |
Fresh Juice
Postovi: 4,586
Bubreg za ovo ![]() Izašle prve fotografije. Meni osobno kamera i više nego dobra za moje svrhe. http://www.gsmarena.com/motorola_dro...iew-1156p3.php |
#1095 |
Fresh Juice
Postovi: 4,586
#1096 |
Lokacija: Ivanić_Grad
Postovi: 2,018
#1098 |
Fresh Juice
Postovi: 4,586
#1100 | |
Fresh Juice
Postovi: 4,586
A i metalna konstrukcija i ostatak idu u prilog težini. Al 10mm nije tak debelo, 1cm. |
#1101 |
Lokacija: Sv.Nedelja
Postovi: 5,839
Nemam provjerene informacije, al sam (glasine, jel) cuo da navodno nece radit.. Ak sebe smatras kompetentnijim za odgovor, onda reci neupucenima ukljucujuci i mene, dal ce radit na nasim mrezama? Edit: mob je nezamjetno deblji od Z3, jedino kaj je tezak (rang L920 ak se ne varam) A baterija bi trebala bit vrhunska, kolko vidim koristi sonyev senzor, znaci da ne bi trebali sumnjat u kvalitetu fotki, jedino sam ne znam kakv je softver od motorole za fotkanje... |
#1102 | |
Fresh Juice
Postovi: 4,586
Networks and Bands CDMA/EVDO Rev A (850, 1900MHz) LTE Cat 4 (bands 2, 3, 4, 7, 13) Carrier Aggregation (B4+13) GSM/GPRS/EDGE (850, 900, 1800, 1900MHz) UMTS/HSPA+ (850, 900, 1900, 2100MHz) U linku su koji sam stavio sa speckama. |
#1104 |
Fresh Juice
Postovi: 4,586
Ma GSMarena ima i krive dimenzije čak. Ja u ZG lovim 4G često, kad god ga upalim, samo kaj ga i ne koristim baš toliko često. No, uz ovakav mob 4G mi bi bio najmanji kompromis ![]() |
#1105 | |
Postovi: 5,997
#1106 |
Postovi: 5,839
A ne znam kaj su onda na areni krivi podaci il koji vrag... Naisel sam na debljinu od 7.8.. http://www.gsmarena.com/motorola_droid_turbo-6727.php |
#1107 |
Fresh Juice
Postovi: 4,586
A taman napisao post iznad da su na GSMareni krivi podaci. Gledaj ovaj link: http://www.droid-life.com/2014/10/28...pecs-official/ |
#1109 |
Fresh Juice
Postovi: 4,586
kad stavite masku na ove vaše koje imate svi dođu do tih dimenzija ,a za ovog ne trebate masku ![]() |
#1110 |
Postovi: 5,997
Mozda a mozda i treba. Taj metalni obruc je problemcic kaj se toga tice. Bubnes ga malo u stok i imas trag gore 99%. Inace sam veci fan metala sa Xperia ili Nokia. Bolje mi izgleda taj look od ovog sjajnog sa Motorola i jos nekih. |
