Postovi: 1,606
CHKDSK log
Code:
Checking file system on C:
The type of the file system is NTFS.
Volume label is System.
A disk check has been scheduled.
Windows will now check the disk.
Cleaning up minor inconsistencies on the drive.
CHKDSK is verifying file data (stage 4 of 5)...
Read failure with status 0xc000009c at offset 0x8cbb000 for 0x1000 bytes.
Windows replaced bad clusters in file 14325
of name \DOCUME~1\SEBAST~1\MYDOCU~1\COMMAN~1\MAPPRE~1\MAPS_W~1.TGA.
File data verification completed.
CHKDSK is verifying free space (stage 5 of 5)...
Free space verification is complete.
CHKDSK discovered free space marked as allocated in the volume bitmap.
Windows has made corrections to the file system.
8393928 KB total disk space.
7219860 KB in 50725 files.
18192 KB in 4977 indexes.
0 KB in bad sectors.
102180 KB in use by the system.
44032 KB occupied by the log file.
1053696 KB available on disk.
4096 bytes in each allocation unit.
2098482 total allocation units on disk.
263424 allocation units available on disk.
Internal Info:
30 de 00 00 a1 d9 00 00 81 2b 01 00 00 00 00 00 0........+......
e3 03 00 00 00 00 00 00 db 02 00 00 00 00 00 00 ................
58 c0 64 0a 00 00 00 00 48 e3 20 36 00 00 00 00 X.d.....H. 6....
72 7d b8 07 00 00 00 00 86 b0 53 12 04 00 00 00 r}........S.....
d0 7f 8f 4d 00 00 00 00 ee 6d b8 af 04 00 00 00 ...M.....m......
99 9e 36 00 00 00 00 00 b8 3b 07 00 25 c6 00 00 ..6......;..%...
00 00 00 00 00 50 aa b8 01 00 00 00 71 13 00 00 .....P......q...
Windows has finished checking your disk.
Please wait while your computer restarts.
Kaže da nema bad sektora... |
Postovi: 1,606
update: skenirao sam disk HDD Regeneratorom koji pokazuje ovo: ![]() Kaže da je bad sektore popravio.... Sad, koliko je to pouzdano? Je li netko radio s tim progijem? Ili da krenem u potragu za novim diskom? btw, radi se o 'Cudi iz siga... |
