Staro 27.08.2014., 21:31   #1
Lewis
Freelancer
Lewis's Avatar
Lokacija: Bilje (Osijek)
Postovi: 5,369
(riješeno) Kako saznati IP HP switcha ?
Bok!
Vec pola sata pokusavam uci u WEB sucelje od HP 1810-24G level2 (J9803A) switcha i nikako da uspijem .
Naime u manualima pise je ovo:
By default, the switch is assigned the following static IP information for access to the Web interface:
■ IP address: 192.168.2.10
■ Network mask: 255.255.255.0
■ Gateway: 0.0.0.0
1. Connect the switch to the management PC or to the network using any of the available network
ports.
2. Power on the switch.
3. Set the IP address of the management PC’s network adaptor to be in the same subnet as the switch.
Example: Set it to IP address 192.168.2.12, mask 255.255.255.0.
4. Enter the IP address shown above in the Web browser. See page 1-3 for web browser requirements.
Thereafter, use the Web interface to configure a different IP address or configure the switch as a DHCP
client so that it receives a dynamically assigned IP address from the network.
Note ■ If you enable DHCP for IP network configuration, the switch must be connected to the same
network as the DHCP server. You will need to access your DHCP server to determine the IP
address assigned to the switch.
Naravno pokusao sam tu 192.168.2.10 i nista tu ne otvara ali swithc RADI, sve sot je ustekano najnormalnije radi (evo i surfma preko njega) sto pretpostalvjam znaci d aje sma pokupio DHCP i postelo. Ali ja zelim uci u WEB management servis a neznam kako ?
Pokusao sam odskenirati sve IP adrese u rangeu 192.168.0.0 do 192.168.2.255 i nadje mi samo router, printer, NAS, Andorid device i jednu adresu na 192.168.1.253 (sve pronadjene su u 192.168.1.1 -- 192.168.1.255 rangeu) koju kad ukucam u browser ne dobijem nista ?
Ima li neko ideju sto i kako?
Hvala
Staro 27.08.2014., 21:37   #2
Sinac
...samo te gledam...
Sinac's Avatar
Postovi: 2,838
Reset switcha na defaultne postavke ne postoji? Mene je tako zezao HP print server, nije htio otvoriti web sučelje dok ga nisam resetirao.
Staro 27.08.2014., 21:47   #3
Lewis
Freelancer
Lewis's Avatar
Postovi: 5,369
A postoji ona mala rupica za reset ali sve me strah hocu li onda moci na net ako se zblesira/resetira i ne uhvati DHCP .
Kolko sam ja upucen u mreze (a nisam puno ) ako i je u 192.168.2.X zoni nebi trebao "raditi" ako sam ja sa kompom u 192.168.1.X ali mozda grijesim?
Na drugom (Planetovom) switchu imam aplikaciju za odskenirat switch, spojit se (sa login/pass jasno navednim u manualu) promjenit IP switchu i snimit zeljenu u frmware i gotovo. Ovdje nema niti CDa niti progrma niti jasnih manuala pa sam se pogubio .
Staro 27.08.2014., 21:49   #4
mahoona
mahoona's Avatar
Postovi: 284
To što switch radi ne znači da mu je management adresa u defaultnom subnetu. Napravi factory reset, stisni zajedno RESET i CLEAR tipke, nakon par sekundi pusti RESET tipku i nakon par sekundi CLEAR. Tada će switch biti na 192.168.2.10
Odvoji pojmove switch management adrese i mreže koju on "propušta" kroz sebe. Nemaju veze jedna s drugom, i u poslovnom okruženju je normalno da switch management adresa ne bude u istom subnetu kao i korisnička računala koja su spojena preko njega, da netko od upornih ne bi došao u napast isprobavati passworde i malo se poigrati :-)
Slobodno odradi reset i raditi će ti net neovisno u kojoj si ti mreži, a switchu ćeš moći pristupiti na gore opisani način.
Zadnje izmijenjeno od: mahoona. 27.08.2014. u 21:58. Razlog: pojašnjenje
mahoona je offline   Reply With Quote
Staro 27.08.2014., 21:57   #5
Sinac
Sinac's Avatar
Postovi: 2,838
Switch kao switch će raditi u bilo kojim postavkama mreže, jedino neće biti dostupan za web managment. Za to treba računalo i switch biti u istom IP rangu, u ovom slučaju 192.168.2.xxx. Staviš računalo na npr. 192.168.2.15 i upišeš u Command prompt "ping 192.168.2.10" (bez navodnika) i vidiš imaš li odziv switcha. Tako ćeš barem znati da li je to prava adresa na koju je switch postavljen, bez obzira da li se otvara web sučelje ili ne.
Staro 27.08.2014., 22:04   #6
Lewis
Freelancer
Lewis's Avatar
Postovi: 5,369
Ok budem odradio reset samo jos jedna stvar ja nebi htio mjenjati kompovima IP (imam jos uredjaja i to mi komplicira mrezni render setup pa bi htio da kompovi ostanu kako jesu tj u 192.168.1.x rangeu
Znaci dali je moguce da switch koristim za web management u 192.168.2.x a kompovi da ostanu u 192.168.1.x ili cu switch morati prebaci tu 1 kad se napokon ulogiram jednom ? Nije da cu trebati konstatno nesto cackati ali ponekad bi htio nesto podesit i pregledat pa ono da znam da mogu bez peripetija .
Hvala
Staro 27.08.2014., 22:32   #7
Wuchko
Wuchko's Avatar
Postovi: 556
Ako adresa switcha nije 192.168.2.10, možeš u command promptu još probati "arp -a" (bez navodnika) pa ćeš vidjeti što je sve "spojeno" u tom subnetu, između ostalih bi trebala biti izlistana i ip adresa switcha. Naravno, računalo također mora biti u navedenom subnetu..
Zadnje izmijenjeno od: Wuchko. 27.08.2014. u 22:40.
Wuchko je offline   Reply With Quote
Staro 27.08.2014., 22:32   #8
Postovi: 23,689
Stani, prije nego odradiš (factory) reset ...
Ako napraviš factory reset onda ćeš izgubiti postojeći konfig u switch - u,
sad je pitanje jeli unutra definirano nešto "pametno" ili nije, ovisno o okruženju, mreži i sl.
Gornja uputa ima jedan sitan propust a to je šta "fali" Gateway, ili da kažem drugačije, recimo da je web managment na 192.168.2.10,
onda na kompu postavi IP=192.168.2.12, Subnet=255.255.255.0, Gateway=192.168.2.10,
nekada treba napraviti reboot da glupi winsi skuže ...
Ako web managment nije na default adresi onda si u gabuli jer ga treba tražiti / može biti bilo gdje u sva 3 segmenta pvt adresa,
10.0.0.0 - 10.255.255.255
172.16.0.0 - 172.31.255.255
192.168.0.0 - 192.168.255.255
Zadnje izmijenjeno od: Nikky. 27.08.2014. u 22:47.
Staro 27.08.2014., 22:34   #9
mahoona
mahoona's Avatar
Postovi: 284
Kompovi nek ostanu u mrezi u kojoj jesu. Kad resetiras switch samo jedno racunalo prebaci u 192.168.2.x mrezu, sa njega se spoji na switch management i promjeni mu management adresu u 192.168.1.x i vrati racunalo u tu istu mrezu. Tada ces imati i switch management adresu u mrezi sa racunalima.
Staro 27.08.2014., 22:36   #10
Lewis
Freelancer
Lewis's Avatar
Postovi: 5,369
Autor Nikky Pregled postova
Prsti su mi vec bili na spajalici kad sam procito ovo, stojim.. sta dalje ?
Staro 27.08.2014., 22:45   #11
Lewis
Freelancer
Lewis's Avatar
Postovi: 5,369
Rjeseno (bez reseta)
Otisao sam u mreznu karticu i dao workstationu staticki IP na 192.168.2.200, nakon toga sam bez problem usao u 192.168.2.10 u switch. Otisao u management i promjenio switchu 192.168.1.x stisnuo apply i vraito se na DHCP na workstaiton i sad sve sljaka .
Hvalal svima na pomoci, rjeseno.
Staro 27.08.2014., 23:01   #12
WraGG
WraGG's Avatar
Lokacija: Stuttgart
Postovi: 1,603
Zasto bi mu trebao definiran gateway za pristupiti web configu switcha? Nije da ide negdje iza njega, pa ga ovaj treba rutati.
@Lewis: U prvom postu i napisao upute koje si slijedio, ali ih ocito nisi ispravno slijedio. Naravno da moras PC-u s kojega se spajas dati staticki IP u istom IP rangeu u kojem ti je i web interface.
WraGG je online   Reply With Quote
Staro 27.08.2014., 23:05   #13
Postovi: 23,689
Eto dobro ispalo
Poviše smo ti napisali zašto je pametnije da web managment bude u drugom mrežnom segmentu, a ti sam procjeni šta ćeš i kako ćeš.
Sada prvo snimi konfig switch - a na komp da imaš rezervu ako ...
usput pogledaj šta je i kako konfigurirano u postavkama.
Zašto Gateway, zato jer onda nema mrdanja / vrdanja i 99,9% otvaraš tu managment stranicu,
bez njega često vrti li ga vrti i ne otvori mng. stranicu.
Staro 27.08.2014., 23:10   #14
Sinac
Sinac's Avatar
Postovi: 2,838
Ne zaboravi na DHCP serveru staviti adresu switcha u EXCLUDED listu adresa. Da ne ispadne da ti neko računalo dobije isti IP kao i switch pa da imaš greške/smetnje u mreži. Ili ako ti DHCP dodjeljuje adrese do recimo 192.168.1.199 i nemaš mogućnosti dodijeliti tu adresu u excluded listu, onda stavi switch na neku adresu iznad 192.168.1.199.
Staro 27.08.2014., 23:13   #15
Lewis
Freelancer
Lewis's Avatar
Postovi: 5,369
Da malo ga cackam i stelam sad po neke green/powersave opcije i slicno pa cu snimit config. Kasnije kad mi bude trebao LinkAggregation cu se jos s time pozabavit i to je to, netreba mi nista vise. Stavio sam i login password (po defaultu ga uopce nema) za svkai slucaj.
Hvala na uputama, pomoglo je da skontma st aga pati jer s aPlanetom sam isao obratno tj switc sam prebacio iz 192.168.0.1 u 192.168.1.x s anjegovim alatom/tooom koji dodje na CDu pa mie je ovo bilo malo zbunjujuce ovaj put zasto ga ne nadje i uz svo skeniranje nijedan IP scan app i slicni alat te cmd prompt arp -a koji sam probao nije nasao 192.168.2.10 prije nego sam promjenio IP workstationa .
Staro 27.08.2014., 23:14   #16
WraGG
WraGG's Avatar
Lokacija: Stuttgart
Postovi: 1,603
Nema to nikakve veze sa definiranjem adrese gatewaya. On je tu da bi mrezna kartica znala gdje je uređaj od kojeg dobije rutu van domaće mreže. Za ovo sto je njemu trebalo nije potreban niti definiran gateway niti DNS-ovi. Samo ip adresa u istom rangeu, te subnet maska.
Staro 27.08.2014., 23:31   #17
Lewis
Freelancer
Lewis's Avatar
Postovi: 5,369
Autor Sinac Pregled postova
Nema serevera (kao takvog). Samo workstation, par render slaveova, NAS, HTPC, HiFi, TV i poneki mobitel/tablet. Kucna mreza nist veliko/ozbiljno ali je preskocilo 8 uredjaja/portova da bi mogoa korisiti ove jeftine kucne switcheve. .
Staro 27.08.2014., 23:31   #18
mahoona
mahoona's Avatar
Postovi: 284
I da si odradio factory reset sve bi radilo, jer kad pročitam thread u tvojem kućnom okruženju nemaš potrebe za vlanovima, trunkovima na pojedinim portovima ili sličnim stvarima.
I da, i bez gatewaya komunikacija dva mrežna uređaja u istom subnetu mora raditi. Gateway služi za promet prema drugim mrežama, subnetima, internetima itd....
Bitno da je problem rješen.
Staro 27.08.2014., 23:41   #19
Sinac
Sinac's Avatar
Postovi: 2,838
Autor Lewis Pregled postova
/CUT/
Što ti dodjeljuje DHCP adrese? Neka kutija koju imaš ti dodjeljuje DHCP adrese i onda je to DHCP server bez obzira bio to PC ili router...
Staro 27.08.2014., 23:44   #20
WraGG
WraGG's Avatar
Lokacija: Stuttgart
Postovi: 1,603
Nemas server kao server, ali moras imati dhcp server ako automatski dobijes ip adresu na pc-u. Vjerojatno koristite dhcp server u routeru.
Drugo, imas ti kucne switcheve i sa vise od 8 portova, tako da ne vjerujem da je radi toga nabavljen upravljivi switch. Ali opet, vjerojatno vam je to "uvalio" vas dobavljac kad ste trazili veci switch, bez obzira treba li vam ili ne.
Staro 27.08.2014., 23:58   #21
Lewis
Freelancer
Lewis's Avatar
Postovi: 5,369
Jasno da ima DHCP u windowsima ali nemam tamo neke opcije kao na win server sa excludanjem nekih adresa (barem ja nisam nasao?). win8 64b, tamo ne nalazim ovako nesto kao na win server - http://technet.microsoft.com/en-us/l...=ws.10%29.aspx
Autor WraGG Pregled postova
Nije mi niko nista uvalio ja sam ga sam izabrao i kupio , trebao mi je zbog LA i setupa oko gasenja lampic apo noci (d ane trepere cjelu noc i powersave koji ovi kucni bas i nemaju (ba roni koje sma ja imao) i kao sto rekoh broj prtova/ulaza koji mi treba je narastao a ima i naznaka da ce jos rasti pa mi je 8 komada bio skucen (imao sam USR sa 8 portova i kasnije Dlink kad je USR odapeo jendog dana nakon 4-5 godina, D-Link i danas radi ali premalo portova).
BTW koji su to kucni switchevi sa 16-24 i vise portova ? Imas neke linkove ? Hvala
Staro 28.08.2014., 00:21   #22
Sinac
Sinac's Avatar
Postovi: 2,838
Mislim da se nismo razumjeli, svi uređaji na mreži pokupe adresu s nekog uređaja koji dodjeljuje DHCP adrese, pretpostavimo da je to router. Opet se moraš logirati na router, rang IP adresa unutar DHCP server postavi do max 192.168.1.199 i staviš switch na recimo 192.168.1.200 i riješio si problem. Inače se svi uređaji (switchevi, routeri, printeri, print serveri...) koji imaju fiksne IP adrese za bilo kakav managment/pristup/servise stavljaju izvan ranga IP adresa koje dodjeljuje DHCP server upravo zbog toga da se ne desi da neko računalo dobije isti IP kao i određeni uređaj. Ako dobije isti IP onda ti svako malo na računalu iskače obavijest da je dodijeljena IP adresa pridijeljena nekom drugom računalu/uređaju na mreži i može doći do grešaka pri radu u mreži, npr. printanja.
Staro 28.08.2014., 00:29   #23
Lewis
Freelancer
Lewis's Avatar
Postovi: 5,369
Aha, mislim da kuzim sad sta si milsio, Router je Tcomov Sx763 i tamo imam odredjeno po defaultu Frist i last issued IP adress pa cu onda staviti switch ispod/iznad toga za slucaj da Tcom resetira postavke ili neki vrag pa da nemoram mjenjati ponovno .
thx
Staro 28.08.2014., 00:47   #24
WraGG
WraGG's Avatar
Lokacija: Stuttgart
Postovi: 1,603
Ako pod "kucni" mislis na unmanaged switcheve, npr. ovakvo nesto: http://www.dlink.com/us/en/home-solu...gigabit-switch
Staro 28.08.2014., 00:56   #25
Lewis
Freelancer
Lewis's Avatar
Postovi: 5,369
Pod "kucni" sam mslilio na jeftine (naranvo ti su obicno unmanaged), ovo cudo (ithleda OK) cini mi se niti nema kod nas za kupit (bar ga nevidim na nabavi ?) a i cak da ima pretpostavljam da svejedno nebi bas kostao 450-550kn (60-70 EUR) nego blize 100+ EUR pa onda opet priblizavamo zoni ovih malo boljih semi-pro switcheva ?
Ili se varma oko cijene i ipak je jeftiniji?
Staro 17.09.2014., 04:24   #26
k1z+
k1z+'s Avatar
Datum registracije: May 2011
Lokacija: pred monitorom
Postovi: 110
probleme sa routerom rjsavam sa t-com operaterima.08009000(mislim)i ako imas srece dobijes kvalitetnog operatera koji ti postela sve u routeru kaj hoces.a ako je prekvalitetan,pomoci ce ti i da sve postelas u windowsima.(tak radim ne zato kaj neznam,nego kaj sam lijen )
k1z+ je offline   Reply With Quote
