Staro 15.08.2005., 23:50   #1
s.u.l.e.l.u.s
s.u.l.e.l.u.s's Avatar
Lokacija: Matulji
Postovi: 305
C o d problem
ovako,ja ljepo instaliram coll of duty,napravim sve šta trebam i pojavi mi se ova poruka
Hunk_Clear: reset the hunk ok
Couldn't load default.cfg. Make sure Call of Duty is run from the correct folder.
IMa li ko kakvo rješenje,ljudi HITNO JE!!!!ajd pomozite
s.u.l.e.l.u.s je offline   Reply With Quote
Staro 16.08.2005., 00:40   #2
marko_1
marko_1's Avatar
Postovi: 750
Kad ti se to pojavi? Koju konfu imaš? I Jel imaš najnoviji patch instaliran?
marko_1 je offline   Reply With Quote
Staro 16.08.2005., 00:47   #3
s.u.l.e.l.u.s
Lokacija: Matulji
Postovi: 305
kliknem,šortkat od igre i pojavi se ono crno di piše call of duty.i nakon par sekundi dok to još uvjek stoji.Imam instaliran patch 1.50 ,sad sam ga stavio,al i dalje neće.
konfa.Athlon64 3000+,ploča je gigabyte k8ns pro(nforce 3 250),512 rama,gforce 4 mx 440 grafička,neznam koji hard.
Staro 16.08.2005., 21:39   #4
s.u.l.e.l.u.s
Lokacija: Matulji
Postovi: 305
Evo,u read me sam našo ovo:
4. Error Message: "Couldn't Load Default.cfg"
If you try to run Call of Duty™ and receive the error message, "Couldn't Load default.cfg,” this indicates that the program cannot find the "\main" directory that is essential to its proper function. This error commonly occurs when you install the game with no directory specified. For example, if you choose to install it to a hard drive or partition other than the C: drive (that is, D:,E:, etc.), but fail to specify a folder, the game will install everything to the root of the hard drive and the game will not launch.
If you want to install the game to a hard drive other than the default setting (C, please make sure you specify a folder when choosing the other drive (i.e.: D:\Call Of Duty).
Ima li ko kakvu ideju,ajd pomozite
Staro 16.08.2005., 21:52   #5
marko_1
marko_1's Avatar
Postovi: 750
U koji si ju directory instalirao?
Staro 16.08.2005., 22:00   #6
s.u.l.e.l.u.s
Lokacija: Matulji
Postovi: 305
Prvo sa probo u normalni,onaj koji igra ponudi,a poslje sam sam mapravio drugi folder i svejedno neće
Staro 16.08.2005., 23:52   #7
marko_1
marko_1's Avatar
Postovi: 750
Neznam jel ti tu mogu pomoc, jel igra origigi?
Staro 17.08.2005., 14:33   #8
s.u.l.e.l.u.s
Lokacija: Matulji
Postovi: 305
jel igra origigi?
Ne
Staro 17.08.2005., 14:52   #9
Jelc
Super Moderators
Datum registracije: May 2002
Postovi: 17,485
"Zasto ljudi bezveze dobivaju banove"???
Staro 17.08.2005., 18:53   #10
s.u.l.e.l.u.s
Lokacija: Matulji
Postovi: 305
To sam pitao za prijašnji accaunt(SulE),di sam pobro ban zbog vrijeđanja tovara ,pa ovo je jedna jedina piratska igra koju imam,pa neću valjda radi toga
Staro 17.08.2005., 19:03   #11
MRKONJA
M.U.P.
MRKONJA's Avatar
Datum registracije: Sep 2004
Postovi: 2,277
Riječi gusar,c****(msilim na vrstu droge ) i slične se ovdje ne koriste.
Abit AX8 VIA k8t890//Venice 3000@2250//1x1gb PQI//POV 7600gs silent//Seagate 7200.10 250gb(16mb//sata)//Hitachi 7k160 120gb@mobile kučište//Seagate 7200.7 200gb
//Samsung SH-w163A//Seasonic S-12 380w//Sharkoon silvation
MRKONJA je offline   Reply With Quote
Staro 17.08.2005., 19:19   #12
tor
Administrator
tor's Avatar
Lokacija: Sesvete
Postovi: 15,963
Možeš ti imati doma što hočeš, ali o tome ovdje nema rasprave.
Staro 17.08.2005., 20:21   #13
s.u.l.e.l.u.s
Lokacija: Matulji
Postovi: 305
ok
Staro 17.08.2005., 22:32   #14
marko_1
marko_1's Avatar
Postovi: 750
Ako ti treba ORIGINAL call of duty koji radi javi se meni na PM .
