Staro 23.05.2014., 21:58   #2251
nathan.fake
Lokacija: n/a
Postovi: 1,258
nema veze sa akcijama, ali sa zadnjim updateom Steam je dobio mogucnost streamanja igara na druga racunala u lokalnoj mrezi.
STEAM IN-HOME STREAMING
WITH IN-HOME STREAMING YOU CAN...
Play your Windows games on devices running other operating systems
Currently Mac OS X, Linux, and SteamOS, with support for more systems coming soon.
Play your demanding games on lower-end systems
System requirements dictate the rig you’ll need to run your game, but with In-Home Streaming they won’t limit where you can play.
Kick back with your laptop or home theater PC
Your Steam games are now available throughout your home when you stream them from your PC to your computer, netbook, laptop, or HTPC.
Seamlessly pick up where you left off
Looking for a change of scenery? Steam knows whether your game is already running. Move to another device and start streaming your game right as you left it on your PC.
Download once, play anywhere
No need to wait for your game to download again when it’s already installed on one of your home computers.
stvar funkcionira tako da na glavnom (gaming) stroju vec imas instaliran steam i sve igre i onda na neko drugo racunalo u lokalnoj mrezi samo instaliras steam i logiras se sa istim acc-om i igras (streamas) igru
sama igra se izvodi na gaming stroju, tako da client ne mora bit neka pila...
isprobo sam na HTPC racunalu (AMD X2, 2 GB RAMA, int. VGA, spojen kablom) i Win8 tabletu (ASUS T100, spojen na Wi-Fi) i stvar funkcionira ok
jedina mi je zamjerka sto se igra na glavnom racunalu izvodi u front-endu (ali bez zvuka).. bilo bi dobro da naprave da glavno racunalo vrti igru u backgroundu (ako je tehnicki moguce)...
Zadnje izmijenjeno od: nathan.fake. 23.05.2014. u 22:11.
nathan.fake je offline   Reply With Quote
Staro 29.05.2014., 15:40   #2252
oPTIXEEY
oPTIXEEY's Avatar
Datum registracije: Sep 2013
Lokacija: Dubrovnik
Postovi: 6
Nema veze sa steamom ali danas je bf3 besplatan na originu
oPTIXEEY je offline   Reply With Quote
Staro 29.05.2014., 18:36   #2253
Beetlejuice
Nisko letim, visoko padam
Beetlejuice's Avatar
Datum registracije: Mar 2010
Lokacija: RH
Postovi: 480
Autor oPTIXEEY Pregled postova
LINK
"You never know what is enough unless you know what is more than enough." - William Blake
Beetlejuice je offline   Reply With Quote
Staro 29.05.2014., 18:51   #2254
X-Plosiv
X-Plosiv's Avatar
Postovi: 1,811
Hvala, upiknuo ga
Staro 30.05.2014., 09:29   #2255
pogi
aka Mali Mirko
pogi's Avatar
Postovi: 3,150
Čitam danas u novinama da je BF3 besplatan do 3.lipnja. Probaću ga i ja danas.
Verifikacija poštenog trgovca #1, #2, #3, #4, #5, #6, #7, #8, #9
Staro 30.05.2014., 16:40   #2256
Nybelung
Ček, jel to kao neki free pass? Ili ako uzmeš do 3. imaš za uvijek?
Staro 30.05.2014., 17:15   #2257
iNoob
Game Collector
iNoob's Avatar
Datum registracije: Jun 2010
Lokacija: Viškovo (Rijeka)
Postovi: 366
Ako uzmeš do 3 imaš zauvjek.
Trust me - I know what I'm doing!
iNoob je offline   Reply With Quote
Staro 30.05.2014., 20:15   #2258
kasper_sky
Drive. vruummm,shatatataa
kasper_sky's Avatar
Lokacija: 1.Rijeka-2.VG-3.Zg
Postovi: 779
koje su to fore da dijele tako igre?
kasper_sky je offline   Reply With Quote
Staro 30.05.2014., 20:27   #2259
hedgehog
hedgehog's Avatar
Datum registracije: Apr 2013
Postovi: 1,336
Citram : i oni su gejmeri i vole gejmere pa da gejmeri olakšaju život kolegama u biti vjerojatno žele da se ekipa navuče na bf3 pa kupuje 4 i/ili dlc i packove za bf3...isplatit će se njima ovo bez brige
hedgehog je offline   Reply With Quote
Staro 30.05.2014., 20:51   #2260
xGAME
xGAME's Avatar
Lokacija: Chernobyl NPP
Postovi: 4,778
A i novi BF izlazi krajem ove godine.
xGAME je offline   Reply With Quote
Staro 01.06.2014., 13:00   #2261
golfw12
golfw12's Avatar
Postovi: 424
poklanjem neke steam keyeve iz kupljenih bundlova koje mi se nesviđaju
Weird Worlds: Return to Infinite Space Steam Key: N5352-R22EL-CB5J7
Disciples III: Renaissance Steam Special Edition Steam Key: ZC53G-CKE4D-MPIQH
Deadly 30 Steam Key: GBQMR-PQ2CA-6546Y
Fearless Fantasy Steam Key: KBM0N-9L2ZP-5DMT5
Iron Grip: Warlord Steam Key: Q5VCH-FBF07-XM5MA
Iron Grip: Warlord - Scorched Earth DLC Steam Key: LF4QI-3M9WW-9VJ0X
Demolition Master 3D Steam Key: G0CW9-FT0MX-GX4T3
Recovery Search & Rescue Simulation Steam Key: VCYF9-CBWL5-X7NAI
Mining & Tunneling Simulator Steam Key: BIFGJ-Y9YTX-KXC6D
Bridge Constructor Steam Key: MLP05-BA69P-LWCCJ
Eurofighter Typhoon Steam Key: IYLB0-WQL6N-MN6QK
dovoljno bi bilo reči samo hvala
CPU: AMD Ryzen 5 PRO 4650G@3.7GHz@ CM Hyper 212X
MBO: Gigabyte B450 AORUS PRO
RAM: 2 x 8 GB DDR4 3200Mhz CL16 Kingston HyperX Predator RGB
GPU: Radeon Onboard Graphics
SSD: Samsung 1Tb, NVMe
HDD: Seagate 1TB, Sata III
PSU: Corsair RM650X 650W
CASE: Phanteks ECLIPSE P400
MONITOR: AOC 24G2U @ 144HZ
MOUSE: Logitech MX518 Batman Edition
KEYBOARD: Logitech K200
PERIPHERY: RAZER Goliathus Control Alpha
OS: Windows 10 Home x64
PRINTER: HP LaserJet Pro M12w
CONNECT: T-Com VDSL 30/6 Mb Flat
CPU: Intel® Core™ i5-8250U@1.6GHz
RAM: 2 x 8 GB DDR4 2400Mhz
GPU: Intel® UHD Graphics 620
HDD: 256 GB M.2 SSD
PSU: HP 90W
LCD: 1.920 x 1.080 FHD-Display SVA
golfw12 je offline   Reply With Quote
Staro 01.06.2014., 13:03   #2262
X-Plosiv
X-Plosiv's Avatar
Postovi: 1,811
Htio sam samo uzeti Disciples, ali kaže da je već aktiviran tako da ne mogu
Staro 01.06.2014., 13:17   #2263
1v@n
The mighty pirate
1v@n's Avatar
Lokacija: London
Postovi: 9,194
Demolition Master 3D - hvala!
CPU: Intel Core i7 8809G
MBO: Intel NUC8i7HVK
RAM: 2x16GB Crucial DDR4 2400
GPU: Radeon™ RX Vega M GH
LCD: BENQ PD3200Q
OS: Windows 10 Pro x64
Staro 01.06.2014., 13:20   #2264
chika7ilo
chika7ilo's Avatar
Datum registracije: Sep 2011
Postovi: 178
Hvala.
chika7ilo je offline   Reply With Quote
Staro 01.06.2014., 14:02   #2265
Sa_Stilom
Sa_Stilom's Avatar
Postovi: 2,724
Ako će tko ikada imati CSGO, neka mi ja vi...
MMA
Staro 04.06.2014., 20:26   #2266
xGAME
xGAME's Avatar
Postovi: 4,778
Ajde trk na Steam. Sniper Elite V2 je besplatan unutar sljedeća 24h. Skinite igru u tom periodu i ostaje vaša zavuijek
Staro 04.06.2014., 21:32   #2267
panda505
panda505's Avatar
Lokacija: Beertopia
Postovi: 2,013
Autor xGAME Pregled postova
Ček, a ako samo dodaš u library i ne skineš, šta onda ?
54' / 74' / 90' / 2014
Staro 04.06.2014., 21:37   #2268
Mario92
Omicron Alpha resident
Mario92's Avatar
Lokacija: Bistra
Postovi: 5,139
Bitno da ti ostane u libraryju. Ne trebaš skidati i instalirati.
Ryzen 7 5700G
AsRock B550 Pro4
Kingston A2000 1TB NVMe
Intel 660p 1TB NVMe
Fortron Hexa 400W
Random PC case
Proxmox VE
Fujitsu U7311
Intel i5 1135G7
16GB DDR4 3200MHz
SK Hynix P31 Gold 1TB
13.3" FHD IPS
Staro 04.06.2014., 21:39   #2269
veve
woot!!!
veve's Avatar
Postovi: 2,502
Samo dodas igru u library u tom odredenom roku i to je to, ne moras je ti instalirati, ona ostaje zauvijek.
veve je offline   Reply With Quote
Staro 04.06.2014., 22:02   #2270
xGAME
xGAME's Avatar
Postovi: 4,778
Tako je
Staro 04.06.2014., 22:22   #2271
X-Plosiv
X-Plosiv's Avatar
Postovi: 1,811
Hvala lipi!
Ako naletite na COD 4, a da je free ili ono do 30 40 kn, bio bih najsretniji
Staro 05.06.2014., 00:00   #2272
Omerta
Omerta's Avatar
Lokacija: Grobnik - Rijeka
Postovi: 3,257
Thx, igra preuzeta
Iako sam ju igrao kada je izašla, izbrisao sam ju negdje na pola jer me živcirala, nisam mogao jednu misiju preći.. No valjalo bi ovo opet zaigrati jednog dana..
Odgovoran trgovac:1, 2, 3, 4, 5, 6, 7, 8, 9,10
Staro 05.06.2014., 17:42   #2273
ivan77
Propaganda..jasna stvar. Rusi su neprijatelji u igri.
Zašto je besplatna? Hint : Ukrajina..
Staro 05.06.2014., 19:27   #2274
PointDexter
PointDexter's Avatar
Lokacija: Éire
Postovi: 1,812
A da nije možda zato jer Sniper Elite 3 izlazi za 3 tjedna?
Osim toga, zar nisu negativci Nijemci?
alien-smilies-0046.gif von smiliesuche.de
PointDexter je offline   Reply With Quote
Staro 05.06.2014., 19:34   #2275
ivan77
Ne, ovo je hladni rat.
Može biti, ali ja ne vjerujem u takve slučajnosti.
Staro 05.06.2014., 19:56   #2276
X-Plosiv
X-Plosiv's Avatar
Postovi: 1,811
Good for you, ovo je prvi put u životu da vidim da je neka igra pojeftinila jer izlazi njen nastavak za koji tjedan/mjesec
//sarcasm off
Staro 07.06.2014., 01:46   #2277
Necto
Necto's Avatar
Postovi: 751
Šteta što je igra sranje žešće. =(
Jedino što valja je bullet cam i penetracija lubanje.
Necto je offline   Reply With Quote
Staro 11.06.2014., 19:51   #2278
xGAME
xGAME's Avatar
Postovi: 4,778
Izgleda da Summer Sale ove godine počinje 19. i traje od 30. (kraja mjeseca).
Staro 11.06.2014., 21:00   #2279
Omerta
Omerta's Avatar
Postovi: 3,257
Se može očekivat Watch Dogs snižen?
Staro 11.06.2014., 21:23   #2280
xGAME
xGAME's Avatar
Postovi: 4,778
Watch Dogs se već sada može nabaviti po 50-60% sniženoj cijeni. Baš sam jučer na takav popust naletio.
