#6392 |
Lokacija: Koprivnica
Postovi: 120
#6393 |
Pa od jednake kao i na drugim tenkovima. Ili ne radi na KV-2? ![]() |
#6394 |
Postovi: 120
#6395 |
Lokacija: Slav. Brod
Postovi: 491
Danas katastrofa, 0-9 izadem iz igre, kasnije ponovo probam 0-5. Dosta za danas
X:: Maus, E-100, T110E5, T57 Heavy Tank, 113, AMX50B, IS4, E-50M, Leopard 1, M48 Patton, 121, G.W. E 100, T92, Obj. 261, JagdPz E-100, WT auf E100, T110E4, T110E3, IX::IS8 VIII:: Lorr. 155 51, AC Mle 48 PREM:IS6, T34, T26E4, Pz. IV Schmalturm, T-25, Ram II, T14, Matilda BP, 105 leFH18B2, Chi-Nu Kai, T15, T2 LT, T1E6, Tetrarac, LTP, T7 Combat Car, Light MK. VIC, Type 97 Te Ke |
#6396 |
Datum registracije: Dec 2013
Postovi: 88
OWEND!Opet sa T34-85. http://www.wotreplays.com/site/861170
#6397 |
našikan pravim haos
Lokacija: u zabrani
Postovi: 2,707
#6398 |
Postovi: 491
Neke od zanimljivih novosti vezanih za 9.1 -skill MM? Storm: “If it will come, then in a separate mode, such as ‘ranked random’ as an addition to normal random battles - ovo vjerovatno cuvaju kad WTGF izade iz bete ![]() - developers are slowly working on (now admitted) issue of freezes whenever you detect (light up) a new tank - konacno - one of the variants is making nerfs/buffs in batches by tiers (for example “in patch 9.2, tanks of tier 6 will be rebalanced”) - the 9.1 patch will be technical with various fixes, not much on a content (just one map) - Storm admits that FPS issues were not fixed unfortunately in 9.1 - Storm confirms that patch 9.1 has FPS issues, they are looking for the problem - ovo ne mirise na dobro ![]() - WT RhB is OP and will be nerfed
#6401 |
Nema smisla stavljat BiA-u prvo, pored mnogo boljih skillova. Najranije se može staviti kao 3. skill, na tenkovima koji nemaju koristi od kamuflaže. Posada tada izgleda ovako: 6th i ostali nužni perkovi + BiA + Repair Na većini medium tenkova, TD-ova i na svim skautovima ide najranije kao 4. skill pa se dobije nešto ovakvo: 6th i ostali nužni perkovi + Camo + BiA + Repair. Stavljanjem BiA-e ranije od toga se namjerno potkopavaju statsi tenka. BiA daje +2.5% na sve statse tenka, to je super, ali plaća se velika cijena jer zauzima po jedan slot na svakom članu posade. Loader i Radioman nemaju neke super dobre skillove, ali svi ostali imaju 2-3-4 skilla, ovisno o tenku, koji znače mnogo više od BiA-e a zauzimaju samo jedan skill slot. ![]() |
#6402 |
al se nekad dobro jelo...
Postovi: 3,312
Slazem se Nybelung. Na mediumu je bolje imati full cammo + full repair nego samo jedno od toga + bia. Idealno je 4 skilla. Heavy, lightovi, arty i TDi mogu na BIA s 2.5 skilla. Full cammo ili full repair ce cesce dobiti partiju nego 2,4% brzi reload i sl. Pogotovo jer neki "rezervni skillovi" (ss, recon, safe stowage, skillovi za bolji aim) daju veci bonus nego sam BIA.
Zenfone 9 | Zephyrus M16 | HP Chromebook X2 | Tesla Model Y LR |
#6403 |
našikan pravim haos
Lokacija: u zabrani
Postovi: 2,707
Ljudi,KV-2 i 99% ostatka heavya imaju cammo value jendog brooklyn bridgea....predviđeni su za frontline borbu ne za ambushanje i skrivanje. Samim tim ak se skrivaš škodiš momčadi sa 99% heavija. 6th sense ima smisla ko i isušivanje Jadranskog mora... |
#6404 | |
Ok, eto u pravu si. ![]() Citiraj:
#6405 | |
Datum registracije: Apr 2003
Lokacija: RI
Postovi: 4,918
6th sense je must za sve tenkove... Inače,bit će zanimljivo ovo čudo http://world-of-tanks-leaks.wikia.com/wiki/T23E3 Citiraj:
#6407 | |
Kako mi je samo žao koliko su ova unaprijeđenja točnosti ciljnika i sveprisutni gold uništili ovaj zbilja poseban tenk... ![]() Mislim da mi je još uvijek najigraniji po statsima, a nisam ga vozio u zadnjih god. dana možda sve skupa 10-ak puta (valjda). Stvarno su tenkovi u novijim vezijama izgubili generalno na originalnosti...sada se čak i sa gore spornim i spominjanim KV-2 može sasvim fino igrati i na solidnoj udaljenosti sa "stopedeseticom"... sjećam se KV-1 sa tim setupom nije mogao slona na deset metara potrefiti, bliže je bio SPG-ovima po tome pitanju, nego tenkovima. |
#6408 | |
Lokacija: RI
Postovi: 4,918
Ni ja nisam duuuuugo vozao KV5...i meni je još uvijek top tenk po broju odigranih a također sigurno nisam godinu dana niti jednu random odigrao,ili jednu-dvije... Što se KV2 tiče,ima par desetaka stranica unazad u ovoj temi replay gdje sam derpom na slijepo one shotao Hellcata udaljenog 600+ metara ![]()
#6409 |
Postovi: 491
#6410 | |
#6412 |
Postovi: 491
Igram WTGF nemam pojma ni kud ni kako ali meni je ZAKON. Skinio igru 7 gb, instalirao onda opet skidao 700 mb, pa sam morao resetirati igru jedno 4 puta da spremi sve postavke. Glavni je meni konfuzan i nije bas logicki postavljen. Dosada sam igrao samo Arcade mode GF i igra je odlicna. Mape enormne, igleda fantasticno, brzo nema kampiranja. Svi su jos pogubljeni pa moses nakupiti killova .Naravski ima i gluposti, zabijem se u drvo ode tracnica, upadnem u vodu nemoze se utopiti ali ni izacu iz jebene bare.... Za sada sam odusevljen, vidjet cemo kako ce biti dalje. Na minimum postavkama u Wot-u imam 30-50 fps (na lapcu), u GF isto 30-50 fps ali na medium postavkama.
#6413 |
Datum registracije: Jun 2011
Lokacija: Katolibanovina Apsurdistan
Postovi: 175
Nakon što je WT izbacio tenkove nadam se da će WOT izgubiti barem 20% igrača.A to je za wargaming jak udarac. Sinoć sam rasprodao sve tenkove(13 tier X), goldi su iskorišteni za premium,premium tenkovi su prodani.WOT nalog je sada pustoš. Osjećaj kada stisneš sell na američkom T34 premium.Znaš da je gotovo, zauvijek! NIkada više WOT! Kada nešto u životu radiš prvi puta, naučiš lekciju za ubuduće.Isto je i u virtualnoj zabavi. WOT to odavno nije.Zabava. Na mojem WT nalogu neće nikada biti premium nalog također mi neće pasti na pamet kupiti premium avion ili tenk..ebe mi se za bilo kakvu statistiku ili neko suludo pridruživanje klanu gdje će mi neki nedo.ebani balavac naređivati kuda da idem i nametati diktaturu. NIje mi žao, a osjećaj je odličan. Zadnje izmijenjeno od: donbon. 17.05.2014. u 11:42. |
#6414 |
Ako te to usrećuje, samo naprijed Meni je drago da ću igrati sa/protiv manjega broja nezadovoljnika WoT-om, što automatski znači meni bolje iskustvo igranja. Ugl., vijest je dobra, sretan vam put i dobru zabavu želim. ![]() |
#6415 |
Postovi: 491
Pa sto nisi prodao acc. barem za pivu opet bi bio dobar osjecaj. Ja jos nemam muda za takvo sta, pricekat cu da WTGF izade iz bete pa odluciti koju igru igrati, sudeci po ovo malo sto sam igrao WTGF mi je sjeo kao budali samar, meni neusporedivo bolji i ono najvaznije PUUUUUUUNO zabavniji, a tek grafika, ovo su hd modeli a ne oni plasticni iz WOTa. Ako u gajinu ne zaseru motku nikada vise necu upaliti WOT. Sto se tice broja igraca na wotu je pad od gotovo 50% otkako je WTGF u open beti unatoc SP misiji. Storm se vec izjasnio da je to uobicajeni proljetni pad igraca. ![]() Nego nastavio sam SP misiju: danas subota i majstorica sa hellcatom, samo 1000 vise base xp od prvog do mene ![]() I nemogu se logirati na wot replays ali evo SS ![]() ![]()
X:: Maus, E-100, T110E5, T57 Heavy Tank, 113, AMX50B, IS4, E-50M, Leopard 1, M48 Patton, 121, G.W. E 100, T92, Obj. 261, JagdPz E-100, WT auf E100, T110E4, T110E3, IX::IS8 VIII:: Lorr. 155 51, AC Mle 48 PREM:IS6, T34, T26E4, Pz. IV Schmalturm, T-25, Ram II, T14, Matilda BP, 105 leFH18B2, Chi-Nu Kai, T15, T2 LT, T1E6, Tetrarac, LTP, T7 Combat Car, Light MK. VIC, Type 97 Te Ke Zadnje izmijenjeno od: Audi45. 17.05.2014. u 13:54. |
#6417 |
Postovi: 175
#6418 |
Lokacija: RI
Postovi: 4,918
#6420 |
I ja se pridružujem čestitkama. Sretan put svima koji gase WoT račune i želim Vam da se nikad više ne vratite. ![]() |
