Staro 06.12.2002., 12:55   #1
zyclon
Postovi: 1
Exclamation Problem setup win2000 & outlook express
:confused::confused::confused: Pri instalaciji win2000 professional dižem sistem s cd-a i setup bi se trebao pokrenuti ali neće i javi mi poruku : Couldn't find NTLDR Znate li možda u čemu je problem???
Pri pokretanju outlook express-a 2000 javi mi se poruka :Outlook Express could not be started because MSOE.DLL could not be loaded. ZAŠTO??? imam win98SE i I.E 6.0
Zahvaljujem....:clap:
zyclon je offline   Reply With Quote
Staro 06.12.2002., 13:44   #2
Studano
Studano's Avatar
Datum registracije: May 2002
Postovi: 75
Prvo par mozda "glupih" savjeta za NTLDR
1. Probaj istalirati sa nove kopije (samo ne te koju koristis, neka ti neko snimi drugu.)
2. Mozdaa ti dobro ne cita CD-Rom
3.Odi vidi mozda ti pomogne neka od sljedecih stranica...
http://www.ntfaq.com/Articles/Index.cfm?ArticleID=14717
https://listman.redhat.com/pipermail...er/003148.html
http://www.storageadmin.com/Articles...rticleID=14717
.... i za MSOE.DLL
http://support.microsoft.com/default...;en-us;q232480
http://bizforums.itrc.hp.com/cm/Ques...9cd0f9,00.html
http://www.computing.net/windows95/w...um/130273.html
Mozda nesto pomogne
Take the path that is your own...INDIVIDUALITY.
Studano je offline   Reply With Quote
Staro 06.12.2002., 13:53   #3
razlo
Somewhere around Barstow
razlo's Avatar
Postovi: 316
Nisu glupi.
razlo je offline   Reply With Quote
