Spermich Termich
Lokacija: Zaprešić
Postovi: 885
dx 9.0c na xp i 98
kad uđem u dxdiag (na xp-u) i pokrenem "test direct3D"piše: "Hardware-accelerated Direct3D 9 is not available because the display driver does not support it. You may be able to get a newer driver from the hardware manufacturer. Direct3D 7 test results: All tests were successful. Direct3D 8 test results: All tests were successful. Direct3D 9 test results: Display driver does not support API (DDI version too low)" a na 98:"Direct3D 7 test results: All tests were successful Direct3D 8 test results: All tests were successful Direct3D 9 test results: All tests were successful" I kad pokrenem 3dmark03 u Xp-u pojavi se brdo errora i mogu vidjet samo demo, a na 98ici imam rezultat 988 i radi bez frke na svim testovima. u čemu je problem????:confused:
Lokacija: Zagreb, Centar
Postovi: 1,796
Ma sve ti pise u upozorenju koje si postao. Tvoja grafa nema podrsku za DX9 - to je to. |
Rider of the Storm
Lokacija: Hacienda, Vodice
Postovi: 204
Točnije, nemaš punu directx9 podršku!!! Imaš neke sitne stvari šta ti podržava directx9, al neka sranja!!! (zato ti u win98 izbecuje da ti je sve dobro) ![]()
Dobra vila mi je ispunila dvije želje. Treći put nisam mogao |
