Staro 21.07.2005., 17:32   #1
Kiko.hr
Lokacija: Cakovec
Postovi: 84
Problem s LAN-om
Spojio sam 2 kompa s cross-over kablom,komp A vidi komp B i obrnuto. Komp B moze skidati sherane fajlove s kompa A al obrnuto nece. Dok kliknem na komp B s kompa A pise da"Komp B is not accesible,you might not have permission to use this network, please contact your system administration.."
Probao sam pingati kompove, sve radi s obadvije strane.
Sherani net na kompu A radi na kompu B.
Ni jedan komp nema antivirusne programe ni firewallove (win firewall iskljucen).
Kak to sloziti? Probao sam mijenjati onaj link speed, nije mi bas jasno na sta trebam staviti..
Komp A ima:
10 full mode
100 full mode
10 half mode
100 full mode
Auto mode
Komp B ima:
Full autonegoataion
Force 10 full duplex
Force 100 full duplex
Force 10 half duplex
Autonegotaite for 100FD
Autonegotaite for 100HD
Autonegotaite for 10FD
Autonegotaite for 10HD
Sta sad od toga staviti?
HVALA
Kiko.hr je offline   Reply With Quote
Staro 21.07.2005., 18:43   #2
MasterX
do you speak it?
Lokacija: ::1
Postovi: 1,629
start->programs->accessories->communication->network setup wizzard
Drinking Rum before 10am makes you a Pirate, not an Alcoholic.
MasterX je offline   Reply With Quote
Staro 22.07.2005., 15:29   #3
Američanac
Američanac's Avatar
Datum registracije: May 2003
Lokacija: Metropola
Postovi: 156
Useri
Na oba kompa mora biti ISTI USER sa ISTIM passwordom...
Vjerojatno pristupaš sa kompa B sa komp A sa istim username-om ali različitim (ili blank možda?) pass-om...
Nediraj link speed jer nije problem u hardveru.
Kome se žuri - nek ide pješice
Trenutni hobi:
Klub IO
Američanac je offline   Reply With Quote
Staro 22.07.2005., 18:05   #4
BSA<AK-47>
Napokon dočekao DNF :)
BSA<AK-47>'s Avatar
Postovi: 1,460
može bit pucanj u prazno al dali si na kompu A sherao drajvove?
C:,D: i slično?
I dont know you. I dont know what you want. If you leave, that will be the end. I wont look for you, I wont pursue you. But if you dont, I will look for you, I will find you and I will ignore you.
BSA<AK-47> je offline   Reply With Quote
Staro 23.07.2005., 01:02   #5
Kiko.hr
Lokacija: Cakovec
Postovi: 84
Re: Useri
Cek cek, isti user i pass na cemu?
Account od windowsa?
Daj molim te
Kak bi to bilo da neko ko spaja po 20 kompa u mrezu ima 20 istih accounta u windozima? :confused:
A sta se tice sheranja, naravno da sam sherao, tolko glup ipak nisam
Staro 23.07.2005., 01:17   #6
BSA<AK-47>
BSA<AK-47>'s Avatar
Postovi: 1,460
hebiga,probaj ispočetka....
ja kad slažem mrežu,uvjek odaberem:
set up a home of office network->other-> i odaberem ono prvo
(da se računalo spaja na internet prek huba ili swicha i da se ostale kante isto tako spajaju)na svakom kompu isto!!
zatim ime kante,i ostale gluposti...instaliram sve protokole,enejblam sharing,napravim IP adrese,restartam kantu/kante,sheram drajvove.i sve radi ko blesavo
Staro 23.07.2005., 11:11   #7
Američanac
Američanac's Avatar
Lokacija: Metropola
Postovi: 156
Re: Re: Useri
Aao je Guest account disejblan - neće se moći pristupiti računalima OSIM ako ne postoji user account na svima.
Ako nije disejblan radi se autentifikacija po windowz fičuru "Simple file sharing".
Provjeri si na oba kompa da li su ti sigurnosne postavke identične - nedavno sam imao post o tome ovdje (druga mogućnost koju ne preporučujem) http://forum.pcekspert.com/showthrea...threadid=22519
Sve što je preko 20 ionako bi trebalo staviti u domenu (ako se radi o istom subnetu). Maximum workgrupe je 32.
Eto.
Trenutni hobi:
Klub IO
Staro 23.07.2005., 13:10   #8
MasterX
do you speak it?
Lokacija: ::1
Postovi: 1,629
Re: Re: Re: Useri
pravicu se da ovo za workgroup nisam procitao kako to kada je 50 ljudi u workgorup-u i sve radi?
Staro 23.07.2005., 13:20   #9
Američanac
Američanac's Avatar
Lokacija: Metropola
Postovi: 156
isti subnet ista workgrupa?
Imaš ilegalne PRO windowse
Radi se o Master Browser Electionu, ništa više...
No to ćemo riješit uz nekakvo kad se vidimo
Trenutni hobi:
Klub IO
Staro 23.07.2005., 14:00   #10
mann
mann's Avatar
Postovi: 2,230
Americanac da te pitam nes. Pretpostavljam da si neki MCP or whatever. Koja je prava funkcija workgroup -e. DAkle one postoje tako da bi ...
Uopce mi nisu jasne te workgroupe i sve te kluposti. Dva kompa u razlicitim workgroupama vide medjusobno share. Mogu shareati i sve ostalo. Dakle u mojom glavi jedina funkcija je nekakvo preglednije organiziranje kompova or what?
Staro 23.07.2005., 14:03   #11
Američanac
Američanac's Avatar
Lokacija: Metropola
Postovi: 156
MCP jesam ali to nema veze...
Odgovor je : DA
Trenutni hobi:
Klub IO
Staro 23.07.2005., 14:10   #12
Kiko.hr
Lokacija: Cakovec
Postovi: 84
Da, 255.255.255.0, workgroup MSHOME
Imam, odnosno ima frend kojemu to steka (a imam i ja, al meni radi
Sta? :confused:
If you say so
Staro 24.07.2005., 07:24   #13
mann
mann's Avatar
Postovi: 2,230
Re: MCP jesam ali to nema veze...
Odgovor je : DA
Dobro staro pitanje sa sata Hrvatskog Jezika: "Sto je pisat htijeo reci?"
Staro 24.07.2005., 11:13   #14
Američanac
Američanac's Avatar
Lokacija: Metropola
Postovi: 156
Originally posted by hYcOde
Americanac da te pitam nes. Pretpostavljam da si neki MCP or whatever. Koja je prava funkcija workgroup -e. DAkle one postoje tako da bi ...komp vide medjusobno share i sve ostalo. Jedina funkcija je nekakvo preglednije organiziranje kompova
Odgovor je (sa strane korisničkog dijela), DA.
Sa strane implementacije (tu ima još i onaj Master Browser Election, subnetiranje i još nekoliko sitnica) radi se o organizacijskoj shematici.
Trenutni hobi:
Klub IO
Staro 24.07.2005., 11:28   #15
GoGzS
GoGzS's Avatar
Lokacija: Novi Zagreb
Postovi: 979
Evo vako se ja umrežim s frendom....
Prvi komp nzovem A drugi B radi lakšeg testiranja u comand promptu
Onda odeš na Start>Control Panel>Network Connections> desni klik na mrežnu i Properties
Onda instaliraš IPX (još nešto piše, ali IPX uglavnom, za starije igre je)...
Kad instaliraš odeš na Internet Protocol (TCP/IP) stisneš Properties i Use the following IP adresses:
Tipkaš:
(za prvi komp)
192.168.0.1
255.255.255.0
(za drugi komp)
192.168.0.2
255.255.255.0
Ostale ti netrebaju, te ih nediraš....
Prođeš one Network Wizarda, prvo odbareš Other, zatim da mreža nema pristup na net, Workgroup ime staviš na svima isto npr LAN.....staviš enable file sharing i gotovo.....restartaš kompove i sve radi
GoGzS je online   Reply With Quote
Staro 25.07.2005., 04:22   #16
Kiko.hr
Lokacija: Cakovec
Postovi: 84
Tak je podeseno al ne radi.
Ma nema veze, glavno da sherani net sljaka.
