#1 | ||||||||
Senior Member
Lokacija: K.Š.Đalskog 3a, 10290 Zaprešić, Hrvatska
Postovi: 440
Avi...!"##$$%&#$&&
Zna li mi ko reći kako da pogledam film u divx formatu! Imam BSplayer i javi mi da nemože otvoriti DIV3 format, probao sam na mdvdplayeru, na mediaplayeru, i na GDiVX Player. Od codeca imam instaliran 5.0.2 verziju. Druge fileove mogu fledat, ali imam par fileova, na kojima mi javi to i nemogu niš vidjet ![]() I nemojte me pitat koju konfiguraciju imam! ![]()
Datum registracije: May 2002
Postovi: 75
Evo ti neki od odgovora sa vanjskih foruma ... mozda ti pomogne install codec 3.11 install ffdshow You need to install the Indeo Codec which was omitted by Msft when WinXP SP1 was released Odi vidi tu: http://www.divxmovies.com/codec/ Yeah, it's a DivX codec. You need to d/l a program, I think it's called DivX Alpha. This will install the codec so that you can play those MPEG movies with your Windows Media Player. Eto mozda pomogne... ![]()
Take the path that is your own...INDIVIDUALITY. |
#3 | |||||||||
Senior Member
Postovi: 440
#4 | |
Administrator
Lokacija: Sesvete
Postovi: 15,963
Re: Avi...!"##$$%&#$&&
A ako si instalirao 4.12 on te je pitao kod instalacije da li želiš s njim gledati 3. .. codece, ako si odgovorio s ne, jebiga. Ako ga nisi instalirao instariraj ga ALI TEK NAKON ŠTO PROBAŠ S 3.. VERZIJAMA. Jerbo si najebo ako se potuku. |
#5 | |||||||||
Senior Member
Postovi: 440
Re: Re: Avi...!"##$$%&#$&&
#8 | |||||||||
Senior Member
Postovi: 440
#9 | |
Datum registracije: Oct 2001
Lokacija: Vinkovci
Postovi: 5,231
jedino ponekad nece ![]() i okani se tih smrdljivih playera, skini radlight ali onu 3.03 stariju verziju a ne ovu novu komercijalnu |
#10 | |||||||||
Senior Member
Postovi: 440
#11 | |
Night shift
Datum registracije: Jul 2002
Postovi: 884
i njega makni.Ja imam na win2k 4.12, a na win98 5.0.2.
"NOBODY expects the Spanish Inquisition! Our chief weapon is surprise...surprise and fear...fear and surprise.... Our two weapons are fear and surprise...and ruthless efficiency.... Our *three* weapons are fear, surprise, and ruthless efficiency...and an almost fanatical devotion to the Pope.... Our *four*...no... *Amongst* our weapons.... Amongst our weaponry...are such elements as fear, surprise.... I'll come in again." --uoɥʇʎd ʎʇuoɯ-- |
#13 | |||||||||
Senior Member
Postovi: 440
#14 | |
Lokacija: Vinkovci
Postovi: 5,231
