Staro 29.10.2013., 19:54   #61
schetz
schetz's Avatar
Postovi: 1,570
Na W8 je radio OnTreeSeas, ne znam ako radi na W8.1
thnx..sacekam prvo official update,ako ne rijesi probam s ovim..
evo kažu da bi ovo trebalo riješiti, ofišl je, probam kad dođem doma:
http://support.microsoft.com/kb/2902864
edit2: fercera
Zadnje izmijenjeno od: schetz. 30.10.2013. u 19:36.
schetz je online   Reply With Quote
Staro 30.10.2013., 23:47   #62
rodriguez
rodriguez's Avatar
Postovi: 2,062
Jel se isplati prebaciti sa Win 7 na Win 8.1? Koja bi cijena bila prebacivanja?
Thinkpad T430 running
Staro 30.10.2013., 23:58   #63
Mad_Duke
Uz licencu od Windowsa 7 i ako nemaš touch ekran. Not so much.
Staro 01.11.2013., 22:34   #64
Tvrdi
Sremium
Datum registracije: Oct 2013
Postovi: 2,854
Jel neko ima bug koji se spominje na više mjesta na netu (8.1) verzija...radi se o tome da ponekad winsi cuclaju nenormalno puno CPU-a?....
yesterday I've upgraded to Windows 8.1 and since then my machine keeps with a constant CPU usage of about 30%, even if I'm not doing anything in the computer. My fan keeps running like a beast and the laptop is getting hotter than normal (Dell Vostro 3560, core i7 8gb ram).
It floats about 70 and 80%, it seems that there is a hidden process eating CPU but does not show in task manager... is that possible?
a neki lik je i napisao što je njemu bio uzrok...
Microsoft Windows Backup program was the culprit for me, filename sdclt.exe in system32 folder. It was infinitely loading and closing, if you look in your task manager you will probably see 2-4 copies open every update interval.
I fixed it by going to system32, granting myself the ownership and security restrictions for this file and renaming it to 1sdclt.exe. This fixed the CPU usage instantly. None of the conventional backup settings helped and all my backup settings are set to off... Looks like a bug in Windows 8.1, because this never happened on 8.0.
izvor:
http://stackoverflow.com/questions/1...guilty-process
Zadnje izmijenjeno od: Tvrdi. 02.11.2013. u 21:47.
Staro 04.11.2013., 15:45   #65
Colossus
Colossus's Avatar
Postovi: 379
Evo čitam po netu , i sam trazim riješenje za sad neuspješno, naime mnogi (uključujući mene) imaju problem sa win 8.1 file sharingom, tj sa brzinom transfera fajlova sa jedne mašine na drugu, iako se najnormalnije vide (ping, sharing, sharing permissions, firewalls itd sve štima) ali kada se prebacuju fajlovi preko virtualke, transfer speed je nenormalno spor, skoro neupotrebljivo, bez obzira na vrstu ili veličinu fajla (folder, ISO, docs, executable itd)
Ja specifično imam Win 8.1 Enterprise na svojoj mašini, na Virtualki isto. Na VMware workstationu 10 ta Enterprise verzija je evaluation, neznam jel to igra kakvu ulogu? (iako mislim da nebi trebalo)
Čitao sam da je problem specifičan ako je recimo na jednom računalu mreza detektirana/postavljena kao unindentified/public da radi toga usporava, ja iako sam recimo na oba računala VMware adapter u network settings namjestio preko group policy da bude private i kao takvog ga detektira, jos uvijek problem ostaje. Probao sam i paliti gasiti Public Sharing na obje mašine. Ništa.
Vidim ljudi su svašta probavali od gašenja homegroup servisa i slicnog nista ne pomaže.
Ima ko kakvih slicnih problema, savjeta, ideja?
Taman kad je bio kes od uha do uha, migracija na novi OS prosla maksimalno bezbolno, OS+Classic shell ftw , ali ali..
Podsvjesno uvijek čekam da MS ukenja motku sa nečim. Nisu razočarali
Edit : e da, dočepao sam se Microsoft Desktop Optimisation Packa 2013, da si napravim svoj DaRT 8 Rescue Disk, i naravno ni na mojoj fizičkoj mašini ni na virtualki (evaluation) mi neda da pokrenem DaRT installer, nešto drobi :
The setup has ended prematurely because of an error. Your sistem has not been modified. To install this program at later time, run this installation wizard again.
Do sad sam si uredno radio Dart 5.0 za Xp i Dart 7.0 diskove ovo mi nikad nije izbacivalo.
Colossus je offline   Reply With Quote
Staro 06.11.2013., 09:27   #66
Ati freak
aka Striko
Ati freak's Avatar
Lokacija: Krapina - Zagreb
Postovi: 1,742
Na HP Mini 2140 Win 8 ( org ) imam problem sa updateom na win 8.1 , ( da on ima pre malu rezoluciju da pokrene Store ), ali update je proban dok je bio spojen na monitor.
Prvi puta probao na dan izlaska , dobio sam poruku u stilu "Store isn't available right now, pls try again later" , i onda taj dan odustao mislio sam zbog izlaska su serveri , probao opet za par dana ista poruka......
Googlao rješenja, probao preko kabla i ne znam šta nisam....
Ati freak je online   Reply With Quote
Staro 08.11.2013., 09:33   #67
D.O.M.I.
D.O.M.I.'s Avatar
Datum registracije: Jul 2009
Postovi: 279
Autor Yax023 Pregled postova
Upgrade-o i tek onda skužio da Ati nema podršku drivera (win 8.1) za 4000 seriju pa catalyst ne radi.
Jesi siguran ? Upravo sutra mislim stavljat Win 8 pa update na 8.1 a kartica je 4850, pa me ovaj tvoj napis šokirao.
Kolko znam, ATi je dodao support za seriju 4000 sa legacy driverima, konkretno catalyst 13.1 kojeg trenutno imam (jedino ako baš misliš da ne radi na Win 8.1, a na Win 8 radi? )
EDIT: Da, dobro sam te skužio, na 8.0 sve radi ok, jedino je 8.1 još problematičan
Zadnje izmijenjeno od: D.O.M.I.. 08.11.2013. u 09:46.
D.O.M.I. je offline   Reply With Quote
Staro 08.11.2013., 10:10   #68
dejan1471
dejan1471's Avatar
Datum registracije: Dec 2011
Lokacija: Zanzibar
Postovi: 43
Zadnje izmijenjeno od: tor. 08.11.2013. u 10:22.
dejan1471 je offline   Reply With Quote
Staro 08.11.2013., 19:55   #69
RaWeN
RaWeN's Avatar
Datum registracije: Aug 2009
Postovi: 637
Kako podijelit ove driveove u Computeru na hard diskove i optičke diskove kao šta je bilo dosad na XP/7/8? Na slici se može vidit da je sve pod jednom grupom Devices and drives. Glupo je ovo kad je sve u jednoj grupi. Bezuspješno guglam. Hvala.
RaWeN je offline   Reply With Quote
Staro 10.11.2013., 19:28   #70
Juice
Fresh Juice
Juice's Avatar
Postovi: 4,559
Autor gnujko Pregled postova
Nope, nemam taj bug.
Autor RaWeN Pregled postova
Da, trenutno nema načina. Ima samo za micanje foldere i toga, al podjele grupa nema još.
Staro 10.11.2013., 20:53   #71
Mario92
Omicron Alpha resident
Mario92's Avatar
Lokacija: Bistra
Postovi: 5,066
Sad idem gledati i vidim da mi fali pržilica... otkrio sam da ju nisam spojio dok sam mjenjao pastu na kompu pred kojih 9-10 mjeseci
Tolko o tome koliko je koristim
Ryzen 7 5700G
AsRock B550 Pro4
Kingston A2000 1TB NVMe
Intel 660p 1TB NVMe
Fortron Hexa 400W
Random PC case
Proxmox VE
Fujitsu U7311
Intel i5 1135G7
16GB DDR4 3200MHz
SK Hynix P31 Gold 1TB
13.3" FHD IPS
Staro 10.11.2013., 21:40   #72
imaticx
Default
imaticx's Avatar
Lokacija: Požega
Postovi: 1,515
Moja je na laptopu iskljucena u device manageru
Sto se tice win 8.1, puno bolje mi je sjeo metro nego na 8. Sad vise nisam ni instalirao StartIsBack i naviknuo se. Cak i lakse od obicnog Start menu iz 7
Staro 10.11.2013., 21:55   #73
Juice
Fresh Juice
Juice's Avatar
Postovi: 4,559
Autor imaticx Pregled postova
To kod mene nema šanse. Clasic shell je odmah stavljen a metro ni ne koristim, užasno mi sve to na kompu, ti metro programi.
Staro 10.11.2013., 22:12   #74
Don Kihoty
Datum registracije: Apr 2011
Lokacija: Sisak
Postovi: 1,373
Kakvo je stanje sa driverima, kompatibilnost sa W8.1 iz W8?
RockAss-ica ima drivere:
http://www.asrock.com/mb/AMD/Fatal1t.../?cat=Download
Ali naravno, gofnari iz ASUS-a nemaju:
http://www.asus.com/Sound_Cards_and_...r_D2X/#support
Mislim zvučna od 1400kn i NEMA drivere za W8.1.
STOKA!
Don Kihoty je offline   Reply With Quote
Staro 10.11.2013., 23:19   #75
kasko
kasko's Avatar
Lokacija: Ivanić_Grad
Postovi: 2,009
Autor Don Kihoty Pregled postova
STOKA!
E sad sam zaboravil, al mislim da su radili najnormalnije od 8 driveri.
Staro 10.11.2013., 23:31   #76
Don Kihoty
Lokacija: Sisak
Postovi: 1,373
Provjerio - ne rade kako spada. Niti UniXonar ne rade kako spada,
fale opcije iz CP-a.
Krasno ASUS. Pogriješio sam što sam prešao sa Creative Labsa na ASUS.
Mogao sam predvidjeti da će se to desiti. Toj stoki sitnog zuba nisu bitni
korisnici - nego profit.
Staro 12.11.2013., 16:39   #77
keyser_s()ze
Postovi: 589
Neznam da li smijem stavit link na drugi forum?
Važan patch za sve korisnike win 8.1: http://www.guru3d.com/news_story/mic...aming_lag.html
keyser_s()ze je offline   Reply With Quote
Staro 12.11.2013., 17:13   #78
Juice
Fresh Juice
Juice's Avatar
Postovi: 4,559
Autor keyser_s()ze Pregled postova
Nije baš za sve korisnike, samo za one koji igraju.
Al stalno izlaze neki patchevi i fixevi.
Staro 12.11.2013., 20:02   #79
keyser_s()ze
Postovi: 589
Autor Juice Pregled postova
Ja sam uvjeren da ima ovdje na forumu poneki čovjek (neki su i trollovi) koji igraju
Staro 12.11.2013., 20:13   #80
demetrius
demetrius's Avatar
Lokacija: rijeka
Postovi: 3,857
ja nemam taj problem ali kolegica ima problema sa skypom i windows 8.1 kad se pokušam ulogirat skype se sruši??
Staro 12.11.2013., 20:27   #81
RaWeN
RaWeN's Avatar
Postovi: 637
Skype ne radi na 8.1. Rade na nekom fixu, kolko sam čita official forume.
Staro 12.11.2013., 20:40   #82
thuNdeR
thuNdeR's Avatar
Lokacija: na sombra
Postovi: 1,048
Meni radi normalno! Svaki dan ga koristim
thuNdeR je offline   Reply With Quote
Staro 12.11.2013., 20:42   #83
zlatko
zlatko's Avatar
Lokacija: slavonac
Postovi: 495
Skaype radi bez problema na 8.1. bez fixa. i desktop verzija i ona od windowsa
he,he
zlatko je online   Reply With Quote
Staro 12.11.2013., 21:12   #84
JuiceBox
Xulos :)
JuiceBox's Avatar
Postovi: 7,556
Bas to, skype radi savrseno kao svi programi koje ja koristim, od startisback pa do svih mogucih playera, programa i drivera, sve funkcionira uredno.
Staro 15.11.2013., 18:16   #85
dinos3
Dino Saur
dinos3's Avatar
Datum registracije: Jan 2012
Postovi: 940
Ima li kakva poboljsanja sto se tice gaming performancea u 8.1?
dinos3 je offline   Reply With Quote
Staro 18.11.2013., 23:13   #86
win32
win32's Avatar
Datum registracije: Apr 2008
Postovi: 1,517
Rade li ok igre na 8.1?
Mislim da bi mogao napokon staviti novi OS, ali nikako da to odradim posto imam hrpu posla oko aplikacija i instaliranja.
"In the beginning there was 0. And then there was 1. A mind-bending meditation on the transcendent power of digital computation."
Pošteni trgovac: 1, 2, 3, 4, 5...
win32 je offline   Reply With Quote
Staro 18.11.2013., 23:17   #87
Hrconja
Hrconja's Avatar
Postovi: 1,623
Da, Battlefield 4 npr koristi DX 11.2 i osjetno bolje ide naspram win7 sa DX 11
Hrconja je offline   Reply With Quote
Staro 18.11.2013., 23:19   #88
Don Kihoty
Lokacija: Sisak
Postovi: 1,373
Sva sreća ne gejmam
Nego, kakva su iskustva sa stabilnosti? Zna se da OC-eri i dan danas koriste
W-XP za max OC. W7 baš i ne voli visoke taktove, XP je tu "blaži" kod astabilnog stanja.
Staro 18.11.2013., 23:23   #89
Mad_Duke
Pa stabilniji je ohoho od XP-a. Ako ti neće bootati zbog OC-a u Win 7, 8, 8.1, a hoće u XP, onda nemaš baš najstabilniji clock, nego granični što baš i nije nešto dugoročno.
Staro 18.11.2013., 23:48   #90
Don Kihoty
Lokacija: Sisak
Postovi: 1,373
Ma znam da nije dugoročno - nego ako hoćeš izvući max rezultat za HWBOT,
to je to.
Makar je moj BD FX-8120 stabilan na 4GHz sa 1.206V, ja sam veoma zadovoljan s tim.
