#2791 |
Freelancer
Lokacija: Bilje (Osijek)
Postovi: 5,276
#2792 |
Postovi: 33,950
Moraš pokrenuti proceduru, a da bi dobio lovu moraš ići korak dalje i ići na Escalate the claim (ili tako nešto sličnog imena)
#2793 | |
Freelancer
Postovi: 5,276
sto imam kao opciju samo u ovim itmeima koji jos nisu prosli 45 dana. Sacekat cu jos sutra jer to je zadnji ETA dan pa cu onda poslat Message i nakon toga Resolve a problem. Thx
#2796 |
Nisko letim, visoko padam
Datum registracije: Mar 2010
Lokacija: RH
Postovi: 480
Lewis riješavaj to što prije. Ti imaš svoja prava i žali se na sve što ne dođe u roku, pa i za taj jedan dolar isto si trebao, jer ponovna kupovina istog i davanje negativnog feedbacka, ako je s itemom sve u redu i stigao je na vrijeme ne rezultira ničim korisnim. Samo se žali, coconut ti je sve rekao kako i šta.
"You never know what is enough unless you know what is more than enough." - William Blake |
#2798 |
Too much busy
Postovi: 1,540
Nadam se da će se situacija malo normalizirati prije blagdanskog kaosa. Prestao sam brojati koliko itema poslanih u rujnu nije stiglo...
It's nice to be important, but it's more important to be nice! |
#2799 |
Lokacija: Hrvatistan
Postovi: 4,164
Hi, Sorry to bother you. We just got an urgent notice from the shipping company that two containers of parcels have been lost on the way. The reason is still under investigation. So maybe some of our parcels shipped out From Oct.12th to Nov.1st were lost in this transit. Since your pacakge was shipped out during this period, if you can not receive it within the estimated timeframe, maybe it was lost. If so, please do not worry about it, just contact us freely, we will refund or reship a new one right now. We are really sorry for all inconvenince that have brought to you, but this is an accident, to some content, we can not control it. Your understanding is much appreciated. If you are still worried about it, please contact us for solving. We will always be here to assit you at any time. Any more ideas, please contact us freely. Sorry again. Wishes. - magicdigitals |
#2800 |
Datum registracije: Dec 2011
Lokacija: Virje
Postovi: 591
Bar nemas komplikacije, nadprosjecno pismeni seller ti nudi refund bez ijednog pitanja da provjeris sa susjedima, u posti, oko kuce, na terasi i cucku u ustima, a inace im je to redovita besmislena praksa. |
#2803 |
Freelancer
Postovi: 5,276
Trazi refund pa kupi ponovo jer ja kad god su mi radili ponovni shiping nije vrijeme pocelo teci iz pocetka. Sad vise nema cile mile, refund pa ja kupim ponovo od istog ako treba pa nek rade "reship" ![]()
#2805 |
Lokacija: Grobnik - Rijeka
Postovi: 3,253
Nema te opcije.. Nego zakaci "item nije stigao" i u poruci selleru napisi da zelis full refund i da mu tek nakon refunda dajes svih 5 zvjezdica. Budi sto kraci i jednostavniji, da odmah shvate sto zelis rec ![]() Ukoliko on ustraje na tome da pricekas jos par dana, ti samo odgovaraj da zelis full refund. Slucaj/case se dize (barem ja) 41. dan.. Jednostavnije ne moze biti.. Nakon sto dobijes refund, slucaj se automatski zatvara.. Jer prilikom vaseg dopisivanja unutar "case-a" sve nadgleda eBay, tako da nema cile mile.. |
#2806 |
Freelancer
Postovi: 5,276
Hehe moj se javio nakon 6 dana neodgovaranja na PM ![]() Klasicni sistem pogeldaj kod susjeda u sanducici, u posti vamo tamo, pitaj ovog onog... "hi dear friend, so sorry to know that you haven´t received the item.i think it may arrived your country.so if it is not trouble,could you please kindly find it in your nearest post or ask your neighbors if they help you receive the parcel? we are very appreciate your effort. and if it is still not arrive ,we will resend or refund you,that′s ok? hope your reply. and sorry to trouble you. nice day!"
#2808 |
Freelancer
Postovi: 5,276
#2809 |
Datum registracije: Aug 2008
Lokacija: Split, Croatia
Postovi: 380
I ja sam za item koji je naručen iz kine(19.rujna) pa je upao u onu zlatnu kolekciju itema koji nisu dostavljeni trazio refund, ima vec nekoliko dana. Sada mi tamo stoji 1 open case, i tako već neko vrijeme.. Koliko otprilike treba da oni to "rješe" i što mi je dalje raditi(nisam do sada jos refundao nikako) ![]() |
#2810 |
Lokacija: Našice
Postovi: 497
Sad tek čujem za te probleme s baterijama. Ko za vraga, imam 3 lampe za bic koje čekam. Jedna je pri kraju roka, druge dvije tek prošli tjedan naručene... Jel još traje ta blokada? Zašto je uopće i došlo do toga? Eksplozija ili nešto tako? |
#2811 | ||
Postovi: 7,643
Vidi , nakon 3 dana odgovara ![]() Citiraj:
__________________ |
#2812 |
Postovi: 33,950
Mislim da je to vrlo fer ponuda od njega. Ja u takvim slučajevima svojim sellerima nudim istu opciju - sada vrati pare, a ako ipak dođe jednog dana, ja ti ga platim ponovno.
#2813 | |
Postovi: 7,643
Do sada nisam imao neugodnih iskustva i paketi su uvijek redovito stigli. ![]()
#2814 |
Lokacija: Worldwide
Postovi: 2,553
Baterija za mob poslana 17.10, a stigla jucer.Poslano putem China Post. |
#2816 |
Lokacija: Worldwide
Postovi: 2,553
Kontaktiraj prodavaca i dogovori sve sa njim. |
#2818 | |
Lokacija: Sinj
Postovi: 3,533
Nekad je sutnja zlato. ![]() EDIT: Bilo bi ti bolje da ne pises svasta.
Pošten trgovac: 1, 2, 3 ,4, 5, 6, 7, 8, 9, 10, 11, 12, 13, 14, 15, 16 ,17, 18, 19 Zadnje izmijenjeno od: QuidZz. 06.11.2013. u 15:19. |
#2820 |
Lokacija: Sinj
Postovi: 3,533
