Staro 23.09.2013., 23:44   #1
mamutarka
ODUZIMAM VAM RIJEČ
mamutarka's Avatar
Postovi: 13,551
Steam OS
http://store.steampowered.com/livingroom/SteamOS/
ovo ce bit poput neke konzole valjda, i bit ce free
Staro 24.09.2013., 09:28   #2
tomek@vz
White Rabbit
tomek@vz's Avatar
Postovi: 5,483
http://www.osnews.com/story/27340/Va..._devs_on_board
Valve goes beyond just building a Linux distribution and grafting Steam on top of it. They are actually working very closely with hardware manufacturers and game developers, which has already resulted in graphics performance improvements. They are also working on reducing input latency as well as audio performance. In other words, they are very serious about upending Windows as the default PC gaming operating system.
Valve also unveiled that it's working with the major game developers so that triple-A titles will be natively available on SteamOS. As for your existing Windows games - SteamOS will support game streaming from your existing PC so you can play them on your SteamOS machine in the living room (or anywhere else, of course). 'Hundreds of great games' are already available natively on Linux through Steam, too.
Linux dobiva boost u gaming segmentu, kvaliteti grafičkih i audio drivera i ostale sitnice koje dolaze uz to. Plus - Steam konzola bazirana na Linuxu.
Staro 24.09.2013., 10:01   #3
Pomo
Laughing Man
Pomo's Avatar
Postovi: 3,041
Još jedan bubuntu fork
Although not confirmed by Valve, we’ve been told that Steam OS is based on Ubuntu 12.04 LTS.
Staro 24.09.2013., 10:10   #4
domis
Lokacija: Hrvatistan
Postovi: 4,165
me like
Staro 24.09.2013., 10:10   #5
Mad_Duke
Jedan od zadnjih relevantnih vlakova za linux gaming. Osobno držim fige.
Staro 24.09.2013., 10:27   #6
Jeba ih OS. oćemo Half Life nastavak
Staro 24.09.2013., 10:55   #7
ivo_k
Datum registracije: Dec 2011
Lokacija: .hr, .com
Postovi: 448
odlično, rješavamo se polako, ali sigurno windowsa za rad i za igranje.
ivo_k je offline   Reply With Quote
Staro 24.09.2013., 10:59   #8
Mad_Duke
Autor ivo_k Pregled postova
Jako polagano i jako nesigurno
http://en.wikipedia.org/wiki/Usage_s...rating_systems
Ali zaboravio sam da ti imaš neki velike inside informacije o propasti MS-a
Staro 24.09.2013., 11:35   #9
ivo_k
Lokacija: .hr, .com
Postovi: 448
sve se to da promijeniti u roku 3 godine, kao što se promijenilo u mobilnom.
npr. možda već sad na svijetu ima više uređaja s androidom nego s windowsima.
ali nije poanta u tome nego da već danas za vecinu stvari u poslu nije potrebno imati windowse, a ako ovo uspije neće biti potrebno ni za igre.
eto sad si dobio besplatne informacije, nema na čemu
Staro 24.09.2013., 13:26   #10
tomek@vz
White Rabbit
tomek@vz's Avatar
Postovi: 5,483
Živi bili pa vidjeli...osobno me ne zanima ništa više osim kad će hebeni HL2 EP3 konačno VAN!!!!! Inače kažu da imaju 3 nove stvari za navjestiti...jedna je SteamOS, druga konzola a treća...???
Staro 24.09.2013., 13:42   #11
burmuz
burmuz's Avatar
Lokacija: Bjelovar
Postovi: 464
Koliko sam ima prilike pročitati najave, nisam služio do kraja da li je to standalone OS ili samo neki mod ili nadogradnja postojećih. Bazira se na linuxu da, ali mene jako zanima na koji će način raditi sve ostalo ( osim igara koje kupiš na Steamu te ostalih usluga koje isti pruža).
Drugim riječima, hoće li se korisnici koji koriste računalo prvenstveno za rad, a tek onda za igre moći nesmetano služiti ovim OS-om, tj. u potponosti zamjeniti windowse ili Mac-ov Os?
Koliko sam mogao vidjeti sučelje mi se čini kao optimizirano za konzole, te me nekako, uvjetno rečeno, brine kako će se koristi PC periferija sa svime što nosi sa sobom ( i miševi, i tipkovnice, zvučnici), pri tome mislim na tipa: podešavanje zvuka softverski, podešavanje miša na razne načine, makroi za tipkovnicu itd. itd....
Evo u promotivnom materijalu govore kako će se moći spojiti na tv u dnevnom boravku i sl. ali to nije ništa revolucionarno, pa svatko si s HDMI-jem može razvuči igru s PC-a na TV.
Za kraj, nekako mi se to sve čini "svašta nešto" ali nekako nisam baš siguran da će to "šljakati" kao na Windowsima ( kojih nisam fan, ali mi služe svrsi). Jedino možda segemnt tržišta koji preferira "konzolašku" filozofiju, to mi se čini da bi bilo zadovoljavajuće.
Staro 24.09.2013., 13:57   #12
potemkin.hr
Akutna lijenčina
potemkin.hr's Avatar
Lokacija: Fiume
Postovi: 1,834
Mene najviše impresionira stream gameplaya preko lokalne mreže. Ako to proradi kak spada ko sretniji od mene, moći će se prašiti Rome 2 iz kreveta na starom lapu
potemkin.hr je offline   Reply With Quote
Staro 24.09.2013., 21:44   #13
cccp
cccp's Avatar
Datum registracije: Feb 2004
Postovi: 1,030
Autor burmuz Pregled postova
I mene zanima hoće li biti kakvog desktopa ili će korisnik sam naknadno instalirati. Tu je uvijek konzola preko koje jednom linijom instaliraš cijeli DE. Sigurno je da će OS bootati u Steam Big Picture mod. Možda njega prošire medijskim funkcijama. Što se tiče periferije, to je za Valve jedna od važnijih točaka pa ne sumnjam da će se to dobro izvesti, a i sam Linux ima drajvere za jako puno postojeće periferije. Još uz to ako uspiju dobro napraviti taj pretpostavljani kontroler bit će super.
cccp je offline   Reply With Quote
Staro 25.09.2013., 08:01   #14
tomek@vz
White Rabbit
tomek@vz's Avatar
Postovi: 5,483
Autor cccp Pregled postova
Bit će desktopa u to sam siguran, pa 99% svih distri ti dolaze sa GUI-em...
Staro 25.09.2013., 10:20   #15
cccp
cccp's Avatar
Postovi: 1,030
Mislio sam pošto je specifična namjena da će ga možda izostaviti i ostaviti samo BP.
Staro 03.10.2013., 19:08   #16
drle1
drle1's Avatar
Lokacija: Velika Gorica
Postovi: 182
steam dovodi novi OS - steamOS an amd zeli ubacit svoj mantle kao adekvatnu, ako ne i bolju zamjenu za directx11. tko zna sta ce bit u vrlo skoroj buducnosti
drle1 je offline   Reply With Quote
Staro 03.10.2013., 19:34   #17
Baja 001
Baja 001's Avatar
Postovi: 7,504
Autor drle1 Pregled postova
Prd u šišu, bilo je još APIa pa niko nije izgura DirectX, Mentel navodno (koliko san vidio) radi s grafikom, a ko dalje radi Audio/Mrežu i sve ostalo šta DirectX radi... Nekako mi je sve preoptimistično. Ove navode o igrama i Androidu neću komentirat, jer su smišne
Isto tako san vidio tweet, di je lipo objašnjeno da baš neće Sony i MS pustit da ih AMD samo tako naguzi...
Staro 05.10.2013., 00:30   #18
PointDexter
PointDexter's Avatar
Lokacija: Éire
Postovi: 1,812
U svih 300 Steam Machine prototipova se nalaze nvidia-ine GTX-ice
http://steamcommunity.com/groups/ste...28928746175450
alien-smilies-0046.gif von smiliesuche.de
PointDexter je offline   Reply With Quote
Staro 05.10.2013., 01:41   #19
hedgehog
hedgehog's Avatar
Datum registracije: Apr 2013
Postovi: 1,336
16GB RAM-a za igrice.... -.-
hedgehog je offline   Reply With Quote
Staro 05.10.2013., 02:21   #20
MAGARAC
MAGARAC's Avatar
Postovi: 5,997
Ak zazive Maltle i NVapi, 16gb nebu na odmet.. SteamOS je u bliskoj suradnji sa Nvdijom tak da nije nist cudno da su grafe od Nvdije.
Staro 12.10.2013., 14:25   #21
newyxX
newyxX's Avatar
Datum registracije: Jun 2011
Postovi: 418
newyxX je offline   Reply With Quote
Staro 07.11.2013., 00:51   #22
Don Kihoty
Datum registracije: Apr 2011
Lokacija: Sisak
Postovi: 1,373
Ovako će za sada izgledati finalni oblik konzole:
http://www.theverge.com/2013/11/4/50...-of-the-future
Valve je dakle ipak odlučio ne raditi vlastiti PCB, nego jednostavno ASRock ITX ploču + raiser card za PCI-e grafiku:
http://www.asrock.com/mb/Intel/Z87E-ITX/
Dakle, tko hoće raditi svoj steambox - zna šta mu treba za 100% kompatibilni hardware:
1. Navedena ASRock Z87E-ITX ploča
2. nVidia VGA kartica
3. Kontroler (vjerovatno najteže za nabaviti)
Makar sumnjam da SteamOS neće dobro raditi i na drugim konfiguracijama -
bitan je samo Bluetooth s kojim komunicira kontroler, za ostalo je lako.
Don Kihoty je offline   Reply With Quote
Staro 07.11.2013., 19:45   #23
Mario92
Omicron Alpha resident
Mario92's Avatar
Lokacija: Bistra
Postovi: 5,123
I onda vele da Xbox One izgleda ogavno
Ryzen 7 5700G
AsRock B550 Pro4
Kingston A2000 1TB NVMe
Intel 660p 1TB NVMe
Fortron Hexa 400W
Random PC case
Proxmox VE
Fujitsu U7311
Intel i5 1135G7
16GB DDR4 3200MHz
SK Hynix P31 Gold 1TB
13.3" FHD IPS
Staro 07.11.2013., 19:50   #24
Mad_Duke
Autor Don Kihoty Pregled postova
Pa to je jako pametno. Dobra ploča i platforma koja će imati puno godina iza sebe. Samo, nadao sam se AMD-u i Mantleu.
Staro 08.11.2013., 00:05   #25
Don Kihoty
Lokacija: Sisak
Postovi: 1,373
Pa uzmeš SteamBox sa najslabijom nVidiom i staviš R270, i milina.
Ili samo kupiš GamePad (vjerovatno će dilati i posebno) - i digneš si dualboot sa SteamOS-om.
Slažem se da je ta mala ASRock ITX-ica vrhunska - dovoljno USB-a, WiFi, BT, sve što ti treba.
Staro 17.11.2013., 10:10   #26
BlackDwarf
BlackDwarf's Avatar
Lokacija: Novska
Postovi: 2,445
Mislis da bi Steam omogucio dodavanje graficke po zelji? Pogotovo na linux stavit AMD..
BlackDwarf je online   Reply With Quote
Staro 17.11.2013., 10:42   #27
Postovi: 8,248
Sumnjam, testne konzole su intel-nvidia kombinacije.
@Mario
Nemaju svi isti ukus, meni recimo izgleda super
Staro 27.11.2013., 03:08   #28
veve
woot!!!
veve's Avatar
Postovi: 2,501
veve je offline   Reply With Quote
Staro 30.11.2013., 19:14   #29
Don Kihoty
Lokacija: Sisak
Postovi: 1,373
Podsjeća na PS2, samo drugačije boje.
Staro 01.12.2013., 09:23   #30
Charmander
Ultrapiretik
Charmander's Avatar
Postovi: 903
istina.
Moja trgovanja: 1, 2, 3, 4, 5, 6, 7, 8
Picoin invite: bass999 // minepi.com/bass999
Charmander je offline   Reply With Quote
