Staro 28.06.2005., 07:43   #1
Mailman
Mailman's Avatar
Postovi: 1,606
Talking Omega drivers ver. 2.6.42.
What's New in Omega Drivers?
v2.6.42
* Based on the Catalyst 5.6 Official drivers.
- Removed a lot of obsolete tweaks.
- Removed RadLinker from package.
+ Now ATI Tray Tools is included as default tweaker.
+ Re-enabled the default 3D and Color panels in the ATI Control Panel.
+ Added a desktop shortcut for the ATI CP and for ATT (both optional).
+ Included a few new OGL Smart Shaders.
Note: Since these drivers include a non-standard version of ATT, I would recommend that if you have any previous version of ATT installed, please uninstall it before installing these drivers, not doing so may cause unknown problems.
Note2: Please don't e-mail telling me there are a few references about the old CP on the site, I'm aware of this and will update as soon as I can.
What's new for ATI Tray Tools?
v1.0.2.705
+ Added Shell Context menu for executable files. Now you can easily create/edit and delete game profiles associated with selected executable file. Just click right mouse button and select apropriate menu item from "ATI Tray Tools" menu. ATT must reside in memory to be able to do this job.
+ Added option to add offset (by X and Y) for OSD position in game profile.
+ Added option to show temperatrure in Fahrenheit. (FAN Speed table use only values in Celsius)
+ Added new button in Game Profiles. "Detect 3D API Type". Using this button you can check what 3D API type is used in the selected profile. ATT will not be able to detect API type if the selected executable doesn't link directly to known 3D API library files like opengl32.dll, d3d8.dll, d3d9.dll.
* Updated Overlay Theater Mode. Now you can set separate settings for Clone and Extended Desktop Modes.
* Now TV settings accessible in Exntended Desktop mode too.
* Reenabled menu item to launch Windows Display Properties.
* Updated installation procedure. Now if installation procedure unable to overwrite some files, it replace these files after restart. You must restart your computer in this case.
* Fixed wrong file name creation in ScreenShot module.
* Fixed some errors with Game Profiles in Control Center mode.
* Fixed bug when ATT unable to start on system with Dual Monitors.
http://www.omegadrivers.net/
Mailman je offline   Reply With Quote
Staro 28.06.2005., 10:56   #2
Jelc
Super Moderators
Datum registracije: May 2002
Postovi: 17,485
http://www.omegadrivers.net/drivers/...ga_2642_7z.exe
http://www.treiber-koenig.de/download.php?list.15
http://amnezja.org/modules.php?name=...ticle&sid=4627
17.6 megi.
Skidam
E da, ovaj ATT u Omega driverima je napravljen specijalno baš za te drivere tako da je preporuka OBAVEZNO de-instalirati staru verziju ATT-a prije instalacije drivera.
Da nebi bilo nismo-znali
Staro 28.06.2005., 11:01   #3
Mailman
Mailman's Avatar
Postovi: 1,606
Originally posted by Jelc
Skidam
Već skinuto....
Samo da dođem doma....
Staro 28.06.2005., 13:08   #4
Codiac
bycod
Codiac's Avatar
Lokacija: Zagreb / Dubrava
Postovi: 6,699
skidam
.i.
Razer Blade 15
Staro 28.06.2005., 15:00   #5
damir1
Ancient
damir1's Avatar
Lokacija: Đakovo
Postovi: 893
Bem ti 56 kila muke i jada,skidam već pol sata i kaže Free Download Manager da će još 10 min.I tako svaki mjesec.
damir1 je offline   Reply With Quote
Staro 28.06.2005., 15:01   #6
Mailman
Mailman's Avatar
Postovi: 1,606
Evo nekoliko brojki:
Code:
UT2004, 4xAA, 8xAF
1.red su rezultati s Omegama, 2. red su orig. katalisti (softmodani)
AS-FallenCity
Resolution: 1024x768
Min 11.56	Avg 63.92	Max 131.11
Min 14.81	Avg 64.67	Max 128.40
BR-Slaughterhouse
Min 34.54	Avg 107.62	Max 179.54
Min 34.37	Avg 106.77	Max 178
CTF-MoonDragon
Min 11.80	Avg 81.37	Max 156.63
Min 11.80	Avg 81.51	Max 148.07
DM-Inferno
Min 22.49	Avg 68.09	Max 182.76
Min 22.53	Avg 68.07	Max 182.14
DOM-Ruination
Min 15.66	Avg 45.08	Max 124.70
Min 15.61	Avg 45.07	Max 124.78
ONS-Dawn
Min 8.60	Avg 61.07	Max 122.41
Min 7.87	Avg 61.06	Max 122.77
Code:
CS:Source Stress Test, 4x AA, 8xAF
Omege = 74 fps
Cat.5.6 = 72.52fps
Staro 28.06.2005., 15:48   #7
Jelc
Super Moderators
Postovi: 17,485
Skinuo jesam, instalirat ću navečer kad ohladi malo...
