Staro 17.03.2013., 10:10   #1
estugarda
"Samo vodu ne!"
estugarda's Avatar
Lokacija: ZG istok > Legrad
Postovi: 1,744
Transfer Win7 sa SSD na drugu particiju HDD
Moram privremeno izvaditi SSD iz laptopa u kojem je drugi disk HDD. Ideja je da na HDD napravim particiju veličine SSD-a (120GB) i napravim image. E sad, pitam se hoće li tu biti kakvih problema s obzirom da je transfer SSD>HDD, a ne klasični HDD>HDD. Nisam to nikad radio.
Postoji li kakva posebnost?
Koju aplikaciju koristiti?
Zna tko za kakav koristan tutorial?
It just works. Except when it doesn't.
CPU: AMD Ryzen9 7950X3D @ stock + AC Liquid Freezer II 360
MBO: Asus ProArt X670E-Creator WiFi
RAM: 4x32GB DDR5 G.Skill Trident Z5 Neo 6000
GPU1: NVIDIA GeForce RTX 4090 MSI Suprim Liquid X
GPU2: NVIDIA RTX A4000 custom cooled
SSD1: Samsung 990 PRO 2TB m.2 NVMe
SSD2: Samsung 970 EVO 4TB
PSU: Seasonic Prime GX-1300
CASE: Fractal Design Meshify 2 XL
Display: Asus Proart PA329CRV + 2x Dell 2715h
Audio: Asus Xonar U7 MK2 + Logitech X-530 5.1
Input: Ducky One 3 Classic RGB + Logitech MX Master 3
OS: Windows 11 Pro x64
HP Zbook 17 G6
CPU: i7-9850H @ 2.60GHz
RAM: 4x16GB DDR4 2400
GPU: NVIDIA Quadro RTX 4000
SSD: 512GB NVME SSD
Audio: Fiio Q1 DAC + AudioTechnica M50x
OS: Windows 10 Pro x64
CPU: AMD Ryzen Threadripper 2950X @ stock + Noctua NH-U12S
MBO: Gigabyte X399 Aorus Pro
RAM: 4x16GB DDR4 Corsair Vengance LPX 3200
GPU: NVIDIA GeForce RTX 1080 Ti 11GB
SSD: Samsung Evo Plus 500 m.2 NVMe
HDD: Toshiba 3TB
PSU: Corsair CX650M
CASE: Fractal Design Meshify C
Display: LG IPS231P
Audio: OnBoard + display speakers
Input: Microsoft Natural Keyboard + Logitech G602
CPU: AMD Ryzen 4350G @2.8GHz + AMD stock cooler
MBO: ASrock B550m Phantom Gaming
RAM: GSkill 2x8GB DDR4 3600MHz
GPU: AMD Vega 6
SSD: Samsung Evo Plus M.2 NVME 250GB
PSU: Seasonic 620W
CASE: Fractal Core 2300
Display: 32" LCD TV + BENQ W1070 DLP projector
Sound: Yamaha RX481 + ELAC Cinema 5.1
Input: Logitech vulgaris
CPU: AMD Athlon X2 5050e @0.8-2.6GHz + AC Freezer 64 Pro PWM
MBO: Gigabyte GA-M720-US3
RAM: Kingmax 2x2GB DDR2 800MHz
GPU: Gigabyte GeForce 8600 GTS SP
HDD: Seagate 7200.10 250GB single platter (Speedy Gonzales)
PSU: Chieftec 400W
CASE: Frontier generic
Display: 22" LCD AOC 2230Hf + ACER X1160 DLP projector
Sound: Logitech S-220 2.1
OS: Windows 8.1 PRO x64
2017: FX-8370E, ASRock 990FX Extreme3, nVidia GTX970, Windows 10 x64
2016: FX-8320E, Asus M5A97 PRO, nVidia GTX970, Windows 10 x64
2015: i7 6700k, Asus Z170-A, nVidia 750Ti 4GB, Windows 7 x64
2014: FX-8350, ASRock 990FX Extreme3, nVidia GTX660, Windows 8.1 x64
2012: i7 3610QM, Asus N76VZ, nVidia GT650M, Windows 7 x64
2011: AMD Athlon II X4 640, Gigabyte MA770-UD3, nVidia 9600GS, Windows 7 x64
2010: AMD Phenom II X6 1090T, Thuban, ASrock 880G Extreme3, nVidia GTX260, Windows 7 x64
2010: AMD Phenom II X4 Deneb 945, Gigabyte 790X-DS4, nVidia 8800GTS Ultra 320bit, Windows 7 x64
2009: Intel C2Q Q6600, GIGABYTE EP31, nVidia 8600GS, Windows 7 x64
2008: AMD Athlon X2 Winsdor 5600+ AM2, MSI K9N Neo V3, Gigabyte 790x, nVidia 8600GS, Windows Vista x64
2008: Intel Core2Duo T7200, Toshiba A100-847, nVidia 7600 Go, Windows Vista x64
2007: AMD Athlon X2 4600+ Manchester S939, ASUS A8n32-SLI Deluxe, nVidia 7600GT, Windows Vista x64
2005: AMD Athlon 64 3200+ Venice S939, Asus A8V Deluxe, ATI Radeon X700 PRO, Windows XP x64
2003: AMD Athlon XP 2400+ Thoroughbred, Matsonic MS8137C, Matrox G450, Windows XP
2003: Intel Pentium III Mobile 1000 Tualatin, Compaq Evo N110, ATI RAGE LT Pro, Windows 2000
2002: AMD Duron 1200, Matsonic MS8127C, Matrox G450, Windows XP
2001: AMD Duron 750, Matsonic MS8127C, Matrox G400 DH, SB PCI 128, Windows98,
1998: Intel Pentium II 300 Klamath, Matrox G200, SB AWE64, Windows98
1996: Intel Pentium 120, Matrox Millenium, SB AWE32, Windows95
1993: Intel i386SXSA 40MHz(turbo)
1991: Intel 286 @20Mhz
Zadnje izmijenjeno od: estugarda. 14.04.2013. u 07:39.
estugarda je offline   Reply With Quote
Staro 17.03.2013., 15:35   #2
D1viry
D1viry's Avatar
Lokacija: Slavonija
Postovi: 2,066
Biti će sporije sve na hdd-u. Nema nikakvih posebnosti. Kloniraj disk i to je to. Pripazi da kloniraš sve potrebno. Znači sistemsku particiju, ali i onu malu od 100MB.
Bilo bi najbolje kada bi na hdd-u pomaknuo postojeće particije da ti ostane prostora na početku diska pa da tu kloniraš sistem.
Acronis disk director obavi posao brzo, a jednostavan je za skužiti.
Pošten trgovac: 1,2,3,4,5,6
D1viry je online   Reply With Quote
Staro 17.03.2013., 18:49   #3
estugarda
"Samo vodu ne!"
estugarda's Avatar
Postovi: 1,744
Znam da će biti sporije.
Dakle, tretiram proces kao daq se radi o dva HDDa.
OK. Hvala.
HP Zbook 17 G6
SSD: 512GB NVME SSD
HDD: Toshiba 3TB
PSU: Corsair CX650M
Display: LG IPS231P
GPU: AMD Vega 6
PSU: Seasonic 620W
PSU: Chieftec 400W
Staro 17.03.2013., 21:36   #4
D1viry
D1viry's Avatar
Lokacija: Slavonija
Postovi: 2,066
Da.
No problemo.
Staro 11.04.2013., 17:42   #5
estugarda
"Samo vodu ne!"
estugarda's Avatar
Postovi: 1,744
Konačno sam pronašao nešto vremena za ovo, ali ne mogu skužiti ovaj Acronis disk director ni pod razno.
Kao prvo, u njemu se ne vidi ona mala particija koju naprave Win7.
Nemam pojma kako "pomaknuti" postojeću particiju.
Podijelih drugi disk na dvije particije (Split volume). Aktivirao sam novu particiju. Dalje ne znam.
Ako na novoj particiji napravim create mirror from (ili tako nešto) i odaberem sistemski (SSD) disk, dobijem neki error i error code, koji na njihovoj stranici ne vodi na ništa.
Ništa drugo mi nema smisla.
Ima kakav tutorial?
HP Zbook 17 G6
SSD: 512GB NVME SSD
HDD: Toshiba 3TB
PSU: Corsair CX650M
Display: LG IPS231P
GPU: AMD Vega 6
PSU: Seasonic 620W
PSU: Chieftec 400W
Zadnje izmijenjeno od: estugarda. 11.04.2013. u 17:48.
Staro 11.04.2013., 18:35   #6
ThePornstar
ThePornstar's Avatar
Postovi: 4,403
Disk Director je odličan, samo za tvoje potrebe nepotreban - jednostavniji je Acronis True Image. Pogledaj si njega, a ak slučajno zapneš - javi.
Znači ako direktno želiš kopirat particije s jednog diska na drugi - prva opcija. Naravno, oba diska moraju bit uključena u sistem u ovom slučaju.
Druga i treća opcija su klasični backup i recovery. Naravno, pod uvjetom da prebacuješ sistemsku particiju, kao što kolega Diviry veli, odaberi i ovu od 100MB.
Mislim da s ovim ne može bit jednostavnije.
EDIT: Zaboravio sam napomenuti da u postavkama možeš poštimat prioritet backupa te vrstu kompresije, što uvelike smanjuje vrijeme.
Preko Acronisa možeš napravit i bootabilni medij.
Zadnje izmijenjeno od: ThePornstar. 11.04.2013. u 18:47.
Staro 11.04.2013., 18:42   #7
Mihael
Mihael's Avatar
Lokacija: Home
Postovi: 2,186
Staro 11.04.2013., 19:53   #8
estugarda
"Samo vodu ne!"
estugarda's Avatar
Postovi: 1,744
Autor Mihael Pregled postova
Dobro. S obzirom da koristim Hiren boot cd, dat ću prednost toj metodi.
Ok. Zbutam Hiren, pokrenem CloneDisk...i kaj dalje?
Slučaj je pomalo specifičan. Moram klonirati sistemski disk C: (SSD), na particiju HDD-a i ta particija mora postati butabilna za Win7 koji mi je trenutno na SSDu.
Postoje li kakve upute za to?
Ne mogu nigdje naći nikakav tjut za taj scenarij.
HP Zbook 17 G6
SSD: 512GB NVME SSD
HDD: Toshiba 3TB
PSU: Corsair CX650M
Display: LG IPS231P
GPU: AMD Vega 6
PSU: Seasonic 620W
PSU: Chieftec 400W
Staro 11.04.2013., 22:47   #9
Forace
Lokacija: Petrinja
Postovi: 1,604
Iz vlastitog iskustva idi kroz image/restore proceduru acronisa. clone nešto sa hirena nisam koristio, a akronisovs opcija 'kopiranja diska' (ona prva) je beskorisna jer zahtijevs iste veličine hdd.ova ne particija. Uglavnom znam da sam ga otkanto s tom opcijom iako je jako privlačno izgledala.
Znači napraviš acronis boot medij te gs bootaš:
1. napraviš klasičan image ssd diska sa njegovim particijama.
2. prilikom restora napraviš povrat particija iz tog imagea, ako ti drugi disk nije u potpunosti prazan.
Znači par puts ćeš proć kroz wizard mislim 3 put, jednom zs onu od 100, drugi put za normalnu particiju te u trećem vraćaš mbr ako se ne varam.
Forace je offline   Reply With Quote
Staro 11.04.2013., 23:01   #10
Mihael
Mihael's Avatar
Lokacija: Home
Postovi: 2,186
Autor estugarda Pregled postova
na hdd stvori particiju od 100mb i drugu za c:
u clonedisk kopiraj tu sa ssd-a particiju od 100mb na particiju od 100mb na hddu. isto napravi i za c particiju.
Stavi flag da je ta od 100mb bootabilna.
Ako će raditi probleme
Sa MBR fix / MBRTool / MBR save/restore skini mbr sa ssd-a i digni na hdd.
Mora raditi.
Staro 11.04.2013., 23:33   #11
D1viry
D1viry's Avatar
Lokacija: Slavonija
Postovi: 2,066
Acronis disk director ne zahtjeva iste veličine particija. Zahtjeva da ima mjesta za podatke, kao i svaki clone program. Nemojte pisati ako niste probali. Druga stvar, bitna, je da nema uvijek 100MB particije. Ako si instalirao sedmicu kao drugi sistem, onda je nema.
Napravi image 100MB+sistem i restoraj na hdd. "Prosto k'o pasulj" .
Staro 12.04.2013., 08:31   #12
Forace
Lokacija: Petrinja
Postovi: 1,604
Nisam pisao o directoru nego true imageu koji ima sličnuu opciju clone disk ali kad ju probaš koristit traži da odredišni disk bude potpunosti prazan te mislim da mora bit veći ili isti izvoru, bez obzira na količinu podataka ili veličinu particije.
Nisam se ispravno izrazio jer postoji acronis director i true image .
Staro 12.04.2013., 20:20   #13
estugarda
"Samo vodu ne!"
estugarda's Avatar
Postovi: 1,744
Nemam sreće. Problem.
Bootao sam Hiren. U Acronis Partition Wizard Home sam prvo pomaknuo (resize) particije na hdd. Ispred toga sam napravio particiju od 120gb, formatirao je, proglasio za primary.
One particije od 100mb jednostavno nemam. Lap mi je dosao s nekim LinuxDOS ili tako nešto. Ja sam to formatirao, ubacio SSD i instalirao na njega Win7 koji nije napravio onu prvu 100MB particiju. Zato je valjda ništa ni ne vidi.
Da se vratim na temu. Nakon stvaranje particije, u CloneDisk sam napravio clone disk>disk, dakle sa ssd na novu particiju hdd i to je prošlo ok. Aktivirao sam particiju, i u biosu namjestio hdd kao prvi boot priority. Nije zbootalo. Kaže: " "
Kad tu novu particiju pokušam otvoriti Win Exploreru u Mini XP na Hirenu, kaže "C:\ is not accessible. The file or directory is corrupted and unreadable."
Disk check ne prolazi. Surface test bez greške. Ista stvar je i kad zbootam stari sistem sa SSDa i pokušam otvoriti ovu novu particiju.
Nemam pojma kako koristi MBRfix, a ove druge ne vidim na hirenu. Što sad?
Još uvijek nisam našao nikakav detaljniji tut na netu. Ovak samo tapkam. Ima tko link?
EDIT: Acronis Disk Director, kad zbootam stari sistem sa SSDa na novoj particiji prikazuje mali uskličnik umjesto flaga.
Ako probam napraviti Check iz Directora na tu cloniranu particiju kaže: "Unable to determine volume version or state. CHKDSK aborted."
Takodjer, prikazuje tu particiju kao skroz punu, iako je nekoliko GB veća od cijelog SSD-a.
HP Zbook 17 G6
SSD: 512GB NVME SSD
HDD: Toshiba 3TB
PSU: Corsair CX650M
Display: LG IPS231P
GPU: AMD Vega 6
PSU: Seasonic 620W
PSU: Chieftec 400W
Zadnje izmijenjeno od: estugarda. 12.04.2013. u 22:32.
Staro 12.04.2013., 22:26   #14
ThePornstar
Postovi: 4,403
Ne kužim čemu pomicanje particija, ako ti je HDD prazan i želiš istu veličinu particije, kao što sam kažeš. Dakle pri backupiranju odabereš sistemsku particiju koju želiš i system reserved particiju (odnosno onih 100MB kod Win7).
Veliš da nemaš te system reserved particije, stoga bih te zamolio da okačiš sliku tu, da vidimo kak to kod tebe izgleda. (kad odeš na backup wizard)
Evo kak bi trebalo izgledat s dvije particije + System Reserved particija (moja je 350MB, umjesto onih 100 - radi se o Win 8):
Kod restora odabireš MBR + System Reserved + sistemsku particiju.
Znači nemoj radit nikakve particije prije restora, jednostavno izbriši sve kaj si do sad napravio na tom HDD-u na koji želiš napravit restore i kreni otpočetka. Nemoj ni poravnavat particije.
Kad napraviš restore, kasnije u winsima samo napravi novu particiju od preostalog prostora i to je to.
Staro 12.04.2013., 22:32   #15
estugarda
"Samo vodu ne!"
estugarda's Avatar
Postovi: 1,744
Sve riješeno iz novijeg Disk Directora. Iz Win7. Verzija koju sam koristio prije očito je bila bugovita jer mi je stalno bacala errore uz besmislene logove, a CloneDisk iz Hirensa nije radio kako treba. Još me brine činjenica da nemam 100mb particiju, ali neću se previše žaliti jer sve radi. Čemu uopće služi ta 100mb system reserved particija?
BTW Stvarno drastična razlika u brzini. WD Scorpio black je spor strašno u usporedbi sa SSDom. Nije mi se činilo tako drastično prilikom tranzicije hdd>ssd. Nadam se da će biti malo brže kad malo "sjedne". Dok ne stigne novi ssd.
HP Zbook 17 G6
SSD: 512GB NVME SSD
HDD: Toshiba 3TB
PSU: Corsair CX650M
Display: LG IPS231P
GPU: AMD Vega 6
PSU: Seasonic 620W
PSU: Chieftec 400W
Zadnje izmijenjeno od: estugarda. 12.04.2013. u 22:42.
Staro 12.04.2013., 22:42   #16
ThePornstar
Postovi: 4,403
Nek te ne brine ta particija od 100 MB. Sve kaj je trebalo bit u njoj ti je u sistemskoj particiji.
Drago mi je da si uspio riješit problem
Staro 12.04.2013., 22:59   #17
estugarda
"Samo vodu ne!"
estugarda's Avatar
Postovi: 1,744
Hvala kolege!
HP Zbook 17 G6
SSD: 512GB NVME SSD
HDD: Toshiba 3TB
PSU: Corsair CX650M
Display: LG IPS231P
GPU: AMD Vega 6
PSU: Seasonic 620W
PSU: Chieftec 400W
Staro 12.04.2013., 23:41   #18
D1viry
D1viry's Avatar
Lokacija: Slavonija
Postovi: 2,066
Eto, riješio ipak sa Acronis disk direktorom .
Nemoj se brinuti za nedostatak reserved particije. Nekad je ima, a nekad ne. Ja je nemam, ali ja imam stari xp na prvoj particiji pa je tu boot manager i sve ostalo. Na nekoliko laptopa se nije stvorila ta 100MB particija, iako instaliram sa istog sticka.
Sistem je "kako mu se sprdne, tako mu se sprdne" .
Staro 13.04.2013., 01:53   #19
Forace
Lokacija: Petrinja
Postovi: 1,604
Ajd imam pitanje u vezi tog direktora (ne da mi ga se sad skidat, a i ne treba mi trenutno, al sam u par navrata imao situaciju pa su clonezilla i akronisov true image fejlali):
Znači situacija: prebacivanje jedne particije iz starog u jednu particiju na novom disku. Particija na starom je veća od particije na novom, postoji još particija na starom i na novom, ali podaci na njima trebaju ostat.
Znači imamo na starom [system] + data, na novom [prazno] + data gdje je [system] particija na starom veća od ove prazne (međutim ima manje podataka).
Inače to rješavam sa Acronisovim true imageom kroz image/restore proceduru jer jedino tako može resizat particiju. Clone disk funkciju odbija izvest zbog razlike u ukupnoj količini podataka.
Staro 13.04.2013., 06:22   #20
estugarda
"Samo vodu ne!"
estugarda's Avatar
Postovi: 1,744
Kladio bih se da je mene Director tražio da unallocated disk space bude velik onoliko koliko imam zauzetog prostora na starom disku, a ne koliko je velik disk. Koristio sam "Copy". Na kraju je ipak napravio particiju koja je bila velika kao i disk, a ne kao zauzeti prostor. Mislim da ćeš morati probati.
HP Zbook 17 G6
SSD: 512GB NVME SSD
HDD: Toshiba 3TB
PSU: Corsair CX650M
Display: LG IPS231P
GPU: AMD Vega 6
PSU: Seasonic 620W
PSU: Chieftec 400W
Zadnje izmijenjeno od: estugarda. 13.04.2013. u 08:58.
Staro 13.04.2013., 10:59   #21
Mihael
Mihael's Avatar
Lokacija: Home
Postovi: 2,186
Staro 13.04.2013., 15:04   #22
estugarda
"Samo vodu ne!"
estugarda's Avatar
Postovi: 1,744
Ne znam. Meni CloneDisk nije odradio posao. Prošlo sve OK, ali particija je bila neupotrebljiva. Puta 2.
HP Zbook 17 G6
SSD: 512GB NVME SSD
HDD: Toshiba 3TB
PSU: Corsair CX650M
Display: LG IPS231P
GPU: AMD Vega 6
PSU: Seasonic 620W
PSU: Chieftec 400W
Staro 13.04.2013., 15:18   #23
nino
nino's Avatar
Postovi: 12,613
HDClone je meni odradio barem 20tak puta posao. Jedino sto kod Viste i win7, nakon kloniranja moras napraviti "Startup repair". Nakon toga radi normalno.
Staro 14.04.2013., 07:38   #24
estugarda
"Samo vodu ne!"
estugarda's Avatar
Postovi: 1,744
Na žalost, opet nemam sreće.
Doduše ovaj put nema veze sa tansferom sistema. Nakon povratka u izvorno stanje, zblesirao se HDD.
Uglavnom došao novi SSD. Prebacio sam na njega sistem sa particije koju sam napravi prekjučer i to se fino boota. Onda sam htio vratiti HDD u prvobitno stanje. Pobrisao sam sistemsku particiju (delete volume) i napravio resize one druge veće data particije na tom disku. Disk Doctor je restartao, ali prilikom izvšenja brisanja i resize-anja je javio neki "corruption" eror, restartao se u Windowse i sad mi je taj HDD totalno neupotrebljiv. Traži format. NIje totalna katastrofa, jer postoji backup HDDa, ali par dana star. Postoji li šansa da se ovo nekako osposobi? Ima tko kakvu ideju?
EDIT: Probao sam sa TestDisk-om. Napravio je kao partition table recovery, ali fileovi su ispali neki hijeroglifi, pa sam napravio format i vratio stari backup. Tu se više ništa ne može...
ALi bih volio znati gdje sam zeznuo, za ubuduće.
HP Zbook 17 G6
SSD: 512GB NVME SSD
HDD: Toshiba 3TB
PSU: Corsair CX650M
Display: LG IPS231P
GPU: AMD Vega 6
PSU: Seasonic 620W
PSU: Chieftec 400W
Zadnje izmijenjeno od: estugarda. 14.04.2013. u 08:26.
Staro 14.04.2013., 11:40   #25
Mihael
Mihael's Avatar
Lokacija: Home
Postovi: 2,186
Nigdje. To je jednostavno tako. Svaka ta aplikacije prije pokretanja određene radnje prikazuje upozorenje da se takvo nešto može dogoditi, da se napravi backup i da oni ne odgovaraju za moguću štetu ili gubitak podataka.
