Staro 23.02.2013., 13:56   #1
rodriguez
rodriguez's Avatar
Postovi: 2,065
Youtube i user account??
Jel imate problema sa Youtubom da vam želi prikazati vaše pravo ime i prezime a ne više nickname?
Guglam i očito nema rješenja?
Staro 23.02.2013., 14:29   #2
syss
syss's Avatar
Postovi: 10,805
pošto je google kupio jutub onda si u jednom trenu linkao accounte i eto sad je to tako.
Staro 23.02.2013., 14:55   #3
rodriguez
rodriguez's Avatar
Postovi: 2,065
Da,imao sam Google+ i prije nego što su promijenili ona svoja pravilo oko privatnosti-ukinuo sam ga. Imam gmail i youtube. I nemogu sad nikako se riješiti tog nametanja pravog imena i prezimena....
Staro 23.02.2013., 15:21   #4
Beetlejuice
Nisko letim, visoko padam
Beetlejuice's Avatar
Datum registracije: Mar 2010
Lokacija: RH
Postovi: 480
I ja sam imao s tim "problema" no kada bi me pitao da upišem svoje ime i prezime i odaberem tip profila(privatni ili "biznis") ja sam kiliknuo (koliko me sjećanje služi) na "biznis" profil u kojem sam onda upisao svoj nickname i to je riješilo sve moje muke. Dakako imam gmail i imao g+.
"You never know what is enough unless you know what is more than enough." - William Blake
Beetlejuice je offline   Reply With Quote
Staro 23.02.2013., 21:58   #5
rodriguez
rodriguez's Avatar
Postovi: 2,065
Hebiga mislim da sam ja odabrao privatni.
Staro 25.02.2013., 21:57   #6
rodriguez
rodriguez's Avatar
Postovi: 2,065
Odgovor YT teama
Hi xxxx,
Thanks for contacting us, and please accept my apologies for the delay in our response.
I’m sorry to hear that you’ve had concerns in relation to your username and whether or not you need to start using your full name on YouTube.
It's important to know that if you don’t want to use your full name on YouTube, you don’t have to. Just click “I don’t want to use my full name” when you see the prompt.
For background and to provide a little context, YouTube introduced the option to change how your appear on YouTube last year. You can choose to use your full name on your YouTube Channel. One Google-wide identity was something that proved popular with new YouTube users, and so YouTube made the choice available to to all YouTube users.
That said, this is your online identity, and it's important that you control how you appear online. If you don’t want to use your full name, you don’t have to.
I hope that the information I’ve provided is useful and helps clarify matters for you. Do let me know if you have additional questions or concerns.
Regards,
Stefanie
The YouTube Team
Hebe lud zbunjenog?
Nigdje se meni ne nudi kako da hoću da izgleda moj account. Nego me prisiljava,tj. ne daje izbora.
Poslao sam im screenshot pa ćemo vidit šta kažu.
Zadnje izmijenjeno od: rodriguez. 25.02.2013. u 22:07.
Staro 25.02.2013., 22:05   #7
Facelessone
Facelessone's Avatar
Postovi: 4,205
Re: Youtube i user account??
Probaj u drugom browseru. Meni isto nije prikazivalo izbor dolje na operi.
AMD Ryzen 7 5700X
BQ Pure Rock
MSI B450 Tomahawk Max
500GB Crucial MX500
Fractal Define R4
Corsair HX850 Platinum
Logitech MX Master 3
Logitech MX Keys
Logitech Z2300
Dell U2715H
Iskon 300/100 Mbps
CPU Intel i7-4810MQ
VGA nVidia GT730M 1 GB
RAM DDR3 16 GB 1600 MHz
SSD 500 GB Sandisk Ultra
LTE Modem
DVD-RW
9 cell battery
Napajanje 135 W
Windows 10 Pro
Logitech MX Anywhere 3s
AMD Ryzen 5 7640HS
AMD RadeonT 760M
14" 2,8K, 120Hz
16GB RAM
1TB HDD
Windows 11 Pro
H110M-DGS
Intel i3-7100
8GB RAM DDR4
WD Red 8TB
WD Purple 4TB
Seagate IronWolf 3TB
Seagate SkyHawk 6TB
Nanoxia Deep Silence 4
Seasonic X650 SS-650KM Gold
Staro 25.02.2013., 22:13   #8
rodriguez
rodriguez's Avatar
Postovi: 2,065
Iss svaka čast, odma mi je na IE ponudilo dali hoću pravo ili nickname...
Svaka čast Facelessone, tako jednostavno.
Opet Opera smeće jedno kojeg se ne želim riješit
