Staro 01.03.2011., 14:32   #1
bluefluid
bluefluid's Avatar
Lokacija: VG
Postovi: 1,758
Corsair H60 CPU cooler
Corsair Announces First Shipments of Hydro Series H60
Corsair, a worldwide designer and supplier of high-performance components to the PC gaming hardware market, today announced shipments of the new Hydro Series H60 High-Performance Liquid CPU Cooler. The Hydro Series H60 brings remarkable new technologies to the CPU cooling market at an affordable price point. New features include:
A low-profile, light-weight cooling unit that reduces clutter around the CPU
A redesigned microchannel cold plate with a new fin design that dramatically increases the surface area of copper available for heat absorption
A new split-flow manifold that delivers coolant directly to the center of the cold plate — the warmest area of the CPU — significantly improving cooling efficiency
A custom-designed 120mm fan with very high static pressure, which allows for more cold air to be drawn through the radiator to vent heat from the cooling liquid
Compatibility with the recently announced Corsair Link system for monitoring and control
"Corsair brought reliable, easy-to-install liquid CPU cooling systems to the masses with the groundbreaking Hydro Series H50," said Ruben Mookerjee, VP and General Manager for Components at Corsair. "With the new H60, Corsair provides a new level of performance, ease of installation, and affordability."
The Hydro Series H60 is currently shipping to distributors and resellers worldwide and should be available from Corsair-authorized retailers in the Americas, Europe, and Asia in early March. The Hydro Series H60 is available for a US suggested retail price of $79 USD.
Izvor: techpowerup
Staro 01.03.2011., 15:41   #2
Baja 001
Baja 001's Avatar
Postovi: 7,504
Začudo ovaj mi blok izgleda obećavajuće, i vidim da su stavili high static fan, možda će bit manja buka.
Staro 01.03.2011., 16:40   #3
bluefluid
bluefluid's Avatar
Lokacija: VG
Postovi: 1,758
Jedino sto je baza jos uvijek katastrofalna.
Na svom starom H50 prvo sto je slijedilo nakon vađenja iz kutije je bilo poliranje.
Staro 01.03.2011., 17:33   #4
borny
Too much busy
borny's Avatar
Postovi: 1,540
Bolje/lošije od H70?
Nadam se ovo dugo, čisto da mogu prc-prc bratića koji je bacio novce na H70, unatoč mojim savjetima
Staro 01.03.2011., 19:27   #5
Baja 001
Baja 001's Avatar
Postovi: 7,504
Autor bluefluid Pregled postova
Opet mi je to škakljivo, jer se gubi garancija ako se ne varam. Inače ovaj izgleda respektabilno, a već san gleda H7O jer mi je fora da iman minimalizam oko CPUa
Staro 01.03.2011., 22:40   #6
bluefluid
bluefluid's Avatar
Lokacija: VG
Postovi: 1,758
Naravno, da, ali se i dobiju nesto bolje perf.
Kod H70 mi je dvostruki killer nekako nepotreban, push-pull kombinacija je sasvim dovoljna, iako mi je njegov low profile predobar.
Ma, svi oni jako lijepo izgledaju, ali i kostaju, i steta sto nema i nekih drugih rjesenja kod nas na trzistu, tipa nesto od coolIT-a sa onim ekrancicima i sl. ili nesto od asetec-a sa duplim hladnjacima...
Ugl, vidjeti ce mo prve testove, ako H60 bude jeftiniji od H70 i imao slicne perf mogao bi biti dobra kupovina, ali naravno ne kod nas jer ce vjerojatno biti preskup (links za H70 trazi 900kn - sto je gotovo 300 kn vise od cijena vani!)
Zadnje izmijenjeno od: bluefluid. 01.03.2011. u 22:50.
Staro 01.03.2011., 23:37   #7
SRV
SRV's Avatar
Lokacija: n/a
Postovi: 6,128
Dzaba kad je to opet losije od high-end zracnih coolera. Jedan Megahalems ih otpuse a kosta osjetno manje, da ne spominjem puno vecu razliku pri nizem protoku zraka.
Ostaje samo cinjenica da je nekom fora imati vodeno hladjenje, te da toplina koju stvori procesor ide direktno van kucista (sto je imho i jedina prednost).
Staro 01.03.2011., 23:46   #8
tonisostaric
Datum registracije: Feb 2011
Postovi: 288
Autor SRV Pregled postova
http://www.youtube.com/watch?v=Dq8yOwcSarA
Ovi se ne slažu?? Jel to moguće?
tonisostaric je offline   Reply With Quote
Staro 02.03.2011., 00:42   #9
Sn4k3
Sn4k3's Avatar
Lokacija: Zd
Postovi: 4,747
Autor tonisostaric Pregled postova
Koji uber kewl "reviewer", ccc..
OnTopic
Mislim da ce kao i sve ostalo, kad dodje kod nas, imati paprenu cijenu a nece ju opravdati (nadam se da sam u krivu).
Staro 03.03.2011., 13:14   #10
Jelc
Super Moderators
Datum registracije: May 2002
Postovi: 17,485
Corsair H60 Liquid CPU Cooler Review
Staro 03.03.2011., 15:31   #11
Baja 001
Baja 001's Avatar
Postovi: 7,504
Hladniji i tiši od TRUE120, dosta
Možda da se polira dobio bi se koji stupanj, ali sasvim zadovoljavajuće. Najbolje od svega dobro se drži sa H7O.
Staro 18.03.2011., 13:25   #12
Matta
El Mattador
Matta's Avatar
Lokacija: <->
Postovi: 1,913
Pitanje u vezi Corsairovih vodenih:
Nabavljam i5 2500K i zanimljivi su mi ovi cooleri. No, uzimam ASRockovu P67 plocu koja podrzava i LGA775 coolere a imam Thermalright Utra 120 Extreme za Zalman ventom promjenjive brzine.
Pitanje je da li mi se uopce isplati ulagati u vodeno posto navedeni cooler mogu iskoristiti na novoj ploci ?
Da ne govorim da sam superzadovoljan tisinom ovog coolera a, koliko cujem, ova vodena i nisu nest tiha.
Matta je offline   Reply With Quote
Staro 18.03.2011., 13:53   #13
Postovi: 8,193
Pogledaj si malo usporedbe, al mislim da ti nije to baš opravdano ulaganje pošto za TRa nemožeš dobit više od 250-300kn a temperature nisu baš toliko bolje sa Corsom, pogotovo ako želiš tišinu
Staro 25.04.2011., 13:16   #14
JuiceBox
Xulos :)
JuiceBox's Avatar
Postovi: 7,543
Posto sam rijesio NH-D14 idem najvjerovatnije na h60/h70 (h60 ima magazin rs ali su se zeznuli i naisali h70) .Zanima me sto mislite dali cu dobit pad performansi ako maknem stock ventove i stavim 2x120mm scythe slip stream 1200 rpm ?
Staro 25.04.2011., 13:57   #15
rendula
Lokacija: Zagreb, Trešnjevka
Postovi: 5,767
To su oni tanki scytheovi? Sigurno ce postojati mali rast temperature, ali vjerojatno stupanj-dva.
Staro 25.04.2011., 15:12   #16
BojanZD
BojanZD's Avatar
Postovi: 1,398
Što nebi stavio verzije od 1600okr ili čak 2000okr?
BojanZD je offline   Reply With Quote
Staro 25.04.2011., 15:16   #17
JuiceBox
Xulos :)
JuiceBox's Avatar
Postovi: 7,543
@ rendula
Nisu tanki normalni su.
@ bojanZD, kupio sam si 3 kom za kuciste ta 1200 pa bi ih stavio onda na kuler a ove s kulera u kuciste i smanjio potenciometrom.
Staro 25.04.2011., 15:43   #18
MAGARAC
MAGARAC's Avatar
Postovi: 5,984
Autor xulos Pregled postova
Neces dobit nista, pogotovo ako ce stavljat druge ventove. DH14 je bolje hladenje za SB, vidit ces. Ima vise kapaciteta i bolji posao radi tise.
Pogledaj malo sto pise ekipa, 4.5ghz 72-74c sa H70. To je vise od mog Venomusa sa jednim ventom koji to drzi ispod 70c.
Staro 25.04.2011., 15:44   #19
BojanZD
BojanZD's Avatar
Postovi: 1,398
Ja mislim da će bit čak i dovoljan ovaj od 1200, posebno u push-pull kombinaciji.
Ako se ne varam, takav dolazi s Mugenom i bez problema gura zrak kroz cooler tak da nikako nebi smjelo bit problema ako će gurat zrak kroz radijator.
Staro 25.04.2011., 16:14   #20
JuiceBox
Xulos :)
JuiceBox's Avatar
Postovi: 7,543
Autor MAGARAC Pregled postova
Razmisljam o H60, d14 je ogromna i pola maticne mi zauzme a i teska je jako.Zato bi uzeo nesto "normalnije" ali da radi svoj posao. Neka zamjena onda ako je H60/70 toliko "los"?
Staro 23.05.2011., 11:58   #21
prt scr
Datum registracije: Jan 2011
Lokacija: wild west
Postovi: 321
pogledao review i h60 uopće nije loš,a osim toga dolaze novi H80 i H100 koji će popapat noctua-u
imaš i antec H20 920
prt scr je offline   Reply With Quote
Staro 23.05.2011., 12:21   #22
JuiceBox
Xulos :)
JuiceBox's Avatar
Postovi: 7,543
Popapat ce ga mozda 2-3 % a cijenom duplo .Uostalom sad imam super mega prlimatecha i deltu na njemu na 7 v, taj tornado nemoze ni jedan Hxx kuler zamjenit.Na 1.34 V temp u prime ne prelaze 55
Staro 23.05.2011., 12:49   #23
MAGARAC
MAGARAC's Avatar
Postovi: 5,984
Autor prt scr Pregled postova
Pa trebali bi posto kostaju vise nego duplo. Bilo bi sramotno da ne budu bolji.
Staro 10.01.2012., 03:12   #24
srale7
srale7's Avatar
Postovi: 5,768
Uglavnom, jel ima netko ovo vodeno i kakvi su utisci?
Ja razmisljam da si ga uzmem, čisto iz razloga sto bi s njim imao jedan vent manje u kućištu. Trenutno imam 120mm na procesoru i 120 na ispuhu, a s H60 bi imao jedan 120 na ispuhu
Zanima me koliko je glasna/tiha pumpa od H60, jer vidim da nisu sve pumpe bas "silent"
Zadnje izmijenjeno od: srale7. 10.01.2012. u 03:25.
Staro 10.01.2012., 11:25   #25
dean225
DD9512
dean225's Avatar
Postovi: 1,869
Znaš i sam da je to najlošije rješenje u corsaira.. uzmi h80, deblji radijator,više vode, pa skini jedan vent.isto prostora zauzima u kucistu i puno bolje temperature.. i nije buka zbog ventova, već zbog mrezice na radijatoru.. (strujanje zraka) ventovi se uopće ne čuju kada ih upalis nenamontirane na radijator..
EDIT: ja svoju pumpu ne čujem. Čini mi se da je tiha..
Zadnje izmijenjeno od: dean225. 10.01.2012. u 11:40.
dean225 je offline   Reply With Quote
Staro 10.01.2012., 11:39   #26
srale7
srale7's Avatar
Postovi: 5,768
Nisam znao da je to najlosije rijesenje, budem to malo googlao, ali meni performanse nisu tak prebitne, bitno samo da peoc ne kuha.
Pitao sam za buku pumpe, a znsm i sam da strujanje zraka stvara buku. Vent bi zamjenio i stavio GT@potenciometar.
Staro 11.12.2012., 15:01   #27
mzex
Lokacija: Varazdin
Postovi: 72
Bok!
da li je iko isprobal nove generacije corsairovih vodenih sistema?
mene konkretno interesira h60i.
a proc koji kupujem je i7 3930k.
mzex je offline   Reply With Quote
Staro 11.12.2012., 15:11   #28
ShanTech
Datum registracije: Apr 2011
Postovi: 3,784
Ne bi htio da ispadnem napadan, ali postavlja se pitanje treba li ti 3930K? Za što bi se koristilo računalo?
Ako treba sastaviti nešto, javi se u pripadajuću temu, ovisno s kolko novca raspolažeš i netko će već sastaviti.
http://forum.pcekspert.com/forumdisplay.php?f=28
Staro 11.12.2012., 15:52   #29
Shockre
Shockre's Avatar
Lokacija: Dublin
Postovi: 582
po meni je preslab taj cooler za 3930k ako ce se taj proc koristit za sto je namjenjen, a ne surfanje i igrice.
Shockre je offline   Reply With Quote
Staro 11.12.2012., 16:17   #30
antrax
antrax's Avatar
Lokacija: Vz - Zg
Postovi: 2,930
pricate o novom il starom h60? jer novi je zver
Msi x79a GD65
Intel i7 3930k @ 4.7 1.4V
4x 4GB Kingston 1866 9-11-9
Gigabyte gtx 460 1gb
Samsung 830 128GB
640GB WD AAKS
WD green 1.5TB
LG drzac za kavu
Seasonic S12 500W
Coolermaster Stacker 831
HP LP2065 / LG IPS231P
Windows 7 Enterprise
Trenutno nepostojeci
