Staro 13.10.2012., 20:00   #721
estugarda
"Samo vodu ne!"
estugarda's Avatar
Lokacija: ZG istok > Legrad
Postovi: 1,744
Autor Pomo Pregled postova
Tele2 koristi T-mobile odašiljaće gdje nemaju svoj ili imaju slab signal.
Očekuj prekide prilikom prebacivanja sa mreže na mrežu i slične stvari.
Nije strašno, ali zna bit iritantno.
I ako staviš da ti fiksno koristi T-mobile mrežu, kad dođeš recimo u Zagreb, mob ti neće raditi, jer tu imaju svoju pokrivenost. Dakle postavka za izbor mreže mora biti na automatik.
Hvala...Pokušat ću. Ionako idem bez ugovora, pa ću u najgorem slučaju istrpit ta 3 mjeseca, i vratit se na staro.
It just works. Except when it doesn't.
CPU: AMD Ryzen9 7950X3D @ stock + AC Liquid Freezer II 360
MBO: Asus ProArt X670E-Creator WiFi
RAM: 4x32GB DDR5 G.Skill Trident Z5 Neo 6000
GPU1: NVIDIA GeForce RTX 4090 MSI Suprim Liquid X
GPU2: NVIDIA RTX A4000 custom cooled
SSD1: Samsung 990 PRO 2TB m.2 NVMe
SSD2: Samsung 970 EVO 4TB
PSU: Seasonic Prime GX-1300
CASE: Fractal Design Meshify 2 XL
Display: Asus Proart PA329CRV + 2x Dell 2715h
Audio: Asus Xonar U7 MK2 + Logitech X-530 5.1
Input: Ducky One 3 Classic RGB + Logitech MX Master 3
OS: Windows 11 Pro x64
HP Zbook 17 G6
CPU: i7-9850H @ 2.60GHz
RAM: 4x16GB DDR4 2400
GPU: NVIDIA Quadro RTX 4000
SSD: 512GB NVME SSD
Audio: Fiio Q1 DAC + AudioTechnica M50x
OS: Windows 10 Pro x64
CPU: AMD Ryzen Threadripper 2950X @ stock + Noctua NH-U12S
MBO: Gigabyte X399 Aorus Pro
RAM: 4x16GB DDR4 Corsair Vengance LPX 3200
GPU: NVIDIA GeForce RTX 1080 Ti 11GB
SSD: Samsung Evo Plus 500 m.2 NVMe
HDD: Toshiba 3TB
PSU: Corsair CX650M
CASE: Fractal Design Meshify C
Display: LG IPS231P
Audio: OnBoard + display speakers
Input: Microsoft Natural Keyboard + Logitech G602
CPU: AMD Ryzen 4350G @2.8GHz + AMD stock cooler
MBO: ASrock B550m Phantom Gaming
RAM: GSkill 2x8GB DDR4 3600MHz
GPU: AMD Vega 6
SSD: Samsung Evo Plus M.2 NVME 250GB
PSU: Seasonic 620W
CASE: Fractal Core 2300
Display: 32" LCD TV + BENQ W1070 DLP projector
Sound: Yamaha RX481 + ELAC Cinema 5.1
Input: Logitech vulgaris
CPU: AMD Athlon X2 5050e @0.8-2.6GHz + AC Freezer 64 Pro PWM
MBO: Gigabyte GA-M720-US3
RAM: Kingmax 2x2GB DDR2 800MHz
GPU: Gigabyte GeForce 8600 GTS SP
HDD: Seagate 7200.10 250GB single platter (Speedy Gonzales)
PSU: Chieftec 400W
CASE: Frontier generic
Display: 22" LCD AOC 2230Hf + ACER X1160 DLP projector
Sound: Logitech S-220 2.1
OS: Windows 8.1 PRO x64
2017: FX-8370E, ASRock 990FX Extreme3, nVidia GTX970, Windows 10 x64
2016: FX-8320E, Asus M5A97 PRO, nVidia GTX970, Windows 10 x64
2015: i7 6700k, Asus Z170-A, nVidia 750Ti 4GB, Windows 7 x64
2014: FX-8350, ASRock 990FX Extreme3, nVidia GTX660, Windows 8.1 x64
2012: i7 3610QM, Asus N76VZ, nVidia GT650M, Windows 7 x64
2011: AMD Athlon II X4 640, Gigabyte MA770-UD3, nVidia 9600GS, Windows 7 x64
2010: AMD Phenom II X6 1090T, Thuban, ASrock 880G Extreme3, nVidia GTX260, Windows 7 x64
2010: AMD Phenom II X4 Deneb 945, Gigabyte 790X-DS4, nVidia 8800GTS Ultra 320bit, Windows 7 x64
2009: Intel C2Q Q6600, GIGABYTE EP31, nVidia 8600GS, Windows 7 x64
2008: AMD Athlon X2 Winsdor 5600+ AM2, MSI K9N Neo V3, Gigabyte 790x, nVidia 8600GS, Windows Vista x64
2008: Intel Core2Duo T7200, Toshiba A100-847, nVidia 7600 Go, Windows Vista x64
2007: AMD Athlon X2 4600+ Manchester S939, ASUS A8n32-SLI Deluxe, nVidia 7600GT, Windows Vista x64
2005: AMD Athlon 64 3200+ Venice S939, Asus A8V Deluxe, ATI Radeon X700 PRO, Windows XP x64
2003: AMD Athlon XP 2400+ Thoroughbred, Matsonic MS8137C, Matrox G450, Windows XP
2003: Intel Pentium III Mobile 1000 Tualatin, Compaq Evo N110, ATI RAGE LT Pro, Windows 2000
2002: AMD Duron 1200, Matsonic MS8127C, Matrox G450, Windows XP
2001: AMD Duron 750, Matsonic MS8127C, Matrox G400 DH, SB PCI 128, Windows98,
1998: Intel Pentium II 300 Klamath, Matrox G200, SB AWE64, Windows98
1996: Intel Pentium 120, Matrox Millenium, SB AWE32, Windows95
1993: Intel i386SXSA 40MHz(turbo)
1991: Intel 286 @20Mhz
Zadnje izmijenjeno od: estugarda. 13.10.2012. u 22:05.
estugarda je offline   Reply With Quote
Staro 14.10.2012., 01:48   #722
Pomo
Laughing Man
Pomo's Avatar
Postovi: 3,041
Autor FERRYS Pregled postova
negdje čuo a sad zovem jednog lika koji radi u tele 2 da potvrdim, kao kod njih ti se cijena formira za svakog individualnog korisnika pojedinačno ovisno koliko si dugo pretplatnik kod njih, koliko redovno plaćaš račune, kolika mjesečna potrošnja itd... Tako i piše na tele2 stranicama...
Problem je jedino što u svim uredima rade neki šonjoti koji pojma nemaju...
Pisalo i na tarabi pi... pa Mujo našpranjio kurac. Eto.
Imam tele 2 otkako su došli u 'rvacku. Zakasnio sam im ravno za jedan račun. JEDAN.
Znaš što sam dobijo? Kujac, eto. Kad vidim (osjetim što se novčanika tiče pri kupovni mobitela), onda ću vjerovat i iskustvo ovdje postat.
Ono što bi bilo oke je neki mid range mob po pristojnoj cijeni od parsto kuna, na godinu do godinu i pol dana, i da nije minimalna potrošnja od 300 kuna.
Recimo ranije navedeni S2 ili slično
Ovako sam na ugovoru od dvije godine za kujac od mobitela. E to je Tele2.
Staro 14.10.2012., 02:37   #723
pinkskin
pinkskin's Avatar
Lokacija: Daruvar
Postovi: 1,747
Nevjerovatno, ponuda telefona im je užasna, a cijene još gore, utjeha je što i kod t-mobila nije jako različito, izgleda da kad mi istekne ugovor budem dobro razmislio dali ću ga produžit, doduše imam još godinu dana fore, ali kako stvari sada stoje, sljedeći mob budem kupio preko oglasa.
Staro 16.10.2012., 14:09   #724
Valley7
Datum registracije: Apr 2012
Lokacija: qsd
Postovi: 567
Autor hammer_of_thor Pregled postova
10.9. 2012 je poslan masovni SMS svim korisnicima SMART-a (OK možda nisu baš svi dobili) retardiranog sadržaja "dragi naš smartovac, mi smo spremni da ova našpa veza uđe u ozbiljnu fazu..." bla, bla, bla,
)ni sam neznam zašto mi taj SMS još stoji u mobitelu )
Basically, rekli su da svi koji produže smart do 30.9. tarifa se od tad automatski produžuje svaki mjesec.
Neznam sad čemu frka oko tih 30 kn, a ako si im na osnovnoj tarifi onda pogotovo ne vidim problem jer je SMART 10 puta bolja od osnovne tarife, a imaš i besplatne minute i promet, a ja dobivam i neke besplatne poruke makar neznam na konto čega.
Kužim da si ljuta jer je to "bez tvog pristanka" ali oni jesu obavijestili korisnike, a tko zna zašto ti nisi dobila tu poruku.
Mislim, ako tako reagiraš na tih 30 kn, šta bi tek napravila da su ti naplatili >>ovoliko<<
Frka oko tih 30 kn je zato sto je to moj novac, a ne njihov... I, koliko znam, sve sto ti netko uzme bez tvojeg izricitog pristanka zove se kradja.
No da vise ne tupim, danas mi stigao sms da je aktivirana osnovna tariva. Gledam stanje na racunu i bogme su mi vratili pare. Ipak se isplati zauzeti za sebe i svoja uvjerenja...
Evo, neki dan kupujem mikrovalnu - ona koju sam htjela bila je zadnja tj izlozbena. Po njoj je pipkalo, kasljalo i mrdalo X ljudi. I probali to oni meni prodati kao stvar koja nikad nije napustila kutiju. Ja se nisam dala sve dok nije dosao neki njihov sef i pristao na popust...
Ako se ne zauzmes za sebe, nece nitko...
Valley7 je offline   Reply With Quote
Staro 17.10.2012., 01:12   #725
Andrija M
Postovi: 469
Autor Valley7 Pregled postova
Ja nebi kupio stvar koju je pipkalo, kašljalo i mrdalo X ljudi ni da mi daju popust 100%
Andrija M je offline   Reply With Quote
Staro 17.10.2012., 13:25   #726
Valley7
Lokacija: qsd
Postovi: 567
Autor Andrija M Pregled postova
Tvoja stvar, tvoja mišljenje...
Bitno da je sve fizički bilo u besprijekornom stanju, bez ogrebotina i sličnog, a ovo ostalo lako doma dezinficiraš... Garancija je ionako ista. A niti ono što dođe direktno iz kutije nije sterilno, ako ćemo biti realni.
Staro 26.10.2012., 23:55   #727
generic
generic's Avatar
Postovi: 1,081
Je li danas tko imao kakvih problema s teletinom? Dobar dio dana se nisam mogao čuti s curom jer joj data promet i smsovi nisu radili.
Staro 27.10.2012., 08:51   #728
lowrider
lowrider's Avatar
Lokacija: KR
Postovi: 1,176
Nisu mi automatski produžili tarifu smart 30 (izabrao sam tu opciju jer mi se neda razmišljati jel mi tarifa istekla, pa nisam produžio itd), pa sam par dana bio na osnovnoj tarifi. Nakon što sam im priprijetio da prelazim na drugu mrežu ak to ne riješe kroz koji dan, odmah su to riješili i još mi uplatili 10 kuna na račun uz isprike.
Staro 28.10.2012., 13:21   #729
hrvoje_zg91
hrvoje_zg91's Avatar
Datum registracije: Jan 2011
Lokacija: Sesvete
Postovi: 27
Autor generic Pregled postova
Zadnjih tjedan dana je signal u totalnoj banani. NIti pozivi,niti poruke iti mobilni podaci. Zvao sam ih . PRijavio loš signal ,ali niš od toga.
Sad je malo bolje ali isto loš signal.
Prevelik sig...
hrvoje_zg91 je offline   Reply With Quote
Staro 07.11.2012., 15:39   #730
Xenon
Postovi: 1,542
U ponudi nove tarife za bonove, pričalica i sedmica
Xenon je offline   Reply With Quote
Staro 07.11.2012., 15:43   #731
vga killer
Treba kaj skurit??
vga killer's Avatar
Lokacija: Zgb
Postovi: 4,032
Radi netko u Tele2 da mi kaze kada napokon dolazi Samsung Note2?
Svugdje je dosao osim u Tele2
Staro 20.11.2012., 15:40   #732
RAUL
Lokacija: Worldwide
Postovi: 2,553
Staro 21.11.2012., 11:33   #733
acer
Whatever :)
acer's Avatar
Datum registracije: Nov 2002
Lokacija: Rijeka,Bulevard
Postovi: 1,756
Ma tele2 je postao u zadnje vrijeme blagi ocaj, ljudi mi se zale da me ne mogu dobiti, 3G promet i da ne govorim, u pojedinim djelovima Rijeke kao da ne postoji.
Samo cekam da mi istekne ugovor i bjezim od njih odmah.
Mac Mini M4
Staro 21.11.2012., 15:28   #734
Xenon
Postovi: 1,542
Staro 21.11.2012., 15:30   #735
Postovi: 34,112
@acer
Znaš onu staru: "Koliko para, toliko muzike".
Staro 21.11.2012., 15:42   #736
acer
Whatever :)
acer's Avatar
Postovi: 1,756
Ma jasno mi je "koliko para toliko muzike" ali ipak ocekujem malo vise za 150kn mjesecno koje placam.
Mac Mini M4
Staro 21.11.2012., 15:53   #737
Postovi: 34,112
Za 150kn si svakako trebao dobiti bolju uslugu.
Staro 26.11.2012., 12:22   #738
FERRYS
AutoCad & Allplan expert
FERRYS's Avatar
Postovi: 2,159
Ja nemam apsolutno nikakvih primjedbi na tele2( možda zato jer imam šrot od mobitela )
Ističe mi ugovor za tjedan dana i oću uzet novi mob. Nemam pojma što da uzmem... Ramišljam o xperia S...
Nego ponuda i cijene im se zadnjih mjesec dana mijenjaju iz dana u dan, čak u poslovnicama sam vidil stvari kojih opće nema na stranicama...
none
Staro 28.11.2012., 12:50   #739
Dizel
3.14zda ®
Dizel's Avatar
Lokacija: Orahovica
Postovi: 8,320
Šta je ustvari onaj tel2fon v2? koji je to rebrandirani telefon? Neki Alcatel?
http://www.tele2.hr/privatni-korisni.../d353-t1/#vise
Staro 28.11.2012., 12:52   #740
Router
Hejter
Postovi: 6,521
Autor Dizel Pregled postova
To je Mobiwire Pyxis.
http://mobiwire.com/portfolio/pyxis/
Staro 28.11.2012., 12:54   #741
Dizel
3.14zda ®
Dizel's Avatar
Lokacija: Orahovica
Postovi: 8,320
I? Jel čemu kvaliteta? Ima 1GHz, što i nije loše...
Staro 28.11.2012., 14:51   #742
ECHO
Lokacija: CROATIA-Vukovar
Postovi: 2,354
Nekako mi izgleda još najbolja kupnja ZTE Blade 3 s obzirom na ono što nudi i da je uređaj novi, ali sve zavisi za što se mob treba i koliko se traži od istog.
Neznam kakva je podrška za isti sobzirom da je uređaj noviji i slabo poznat barem kod nas.
Ćak se i sam premišljam uzeti isti jer netražim ništa specijalno i neke bijesne nadogradnje i unaprijeđenja s kojekakvim romovima mi netrebaju dakle samo osnovno korištenje(pozivi,poruke relativno ok 5mpix. kamera i 4.0" ekran) što me osobno zadovoljava pa još važem....
Staro 28.11.2012., 23:19   #743
Dizel
3.14zda ®
Dizel's Avatar
Lokacija: Orahovica
Postovi: 8,320
Daj link
Staro 28.11.2012., 23:40   #744
antrax
antrax's Avatar
Lokacija: Vz - Zg
Postovi: 2,930
ZTE blade 3 @ tele2
ovo zbilja nije lose, smrdi mi na poklon za bozic za curu
Msi x79a GD65
Intel i7 3930k @ 4.7 1.4V
4x 4GB Kingston 1866 9-11-9
Gigabyte gtx 460 1gb
Samsung 830 128GB
640GB WD AAKS
WD green 1.5TB
LG drzac za kavu
Seasonic S12 500W
Coolermaster Stacker 831
HP LP2065 / LG IPS231P
Windows 7 Enterprise
Trenutno nepostojeci
Staro 29.11.2012., 10:26   #745
Postovi: 34,112
Škrtare na ramu. Malo više tabova u browseru i ode sav ram u klinac.
Staro 29.11.2012., 11:14   #746
ECHO
Postovi: 2,354
A mora se negdje zaštekati ali s obzirom koliko košta(a i dosta skuplji modeli su pretežno sa 512MB rama) vjerujem da je to OK kupnja naravno ako se nepati na marku i potrebe nisu pretjerane a obićno tko traži više ni negleda taj rang mobitela već opali na Samsung S3 ili HTC X i sl.
Ovo je više mobitel za sirotinju
Staro 29.11.2012., 11:17   #747
antrax
antrax's Avatar
Lokacija: Vz - Zg
Postovi: 2,930
sto je je, malo je 512mb rama, ali ako uzmemo da jedan htc one v kosta drasticno vise od ovoga sa samo malo boljom grafickom karticom!?
za do 1000kn bez ugovora u ovoj drzavi, meni zvuci dosta dobro. Sasvim dobar entry smartphone.
Msi x79a GD65
Samsung 830 128GB
640GB WD AAKS
WD green 1.5TB
LG drzac za kavu
Seasonic S12 500W
Staro 29.11.2012., 11:18   #748
Router
Hejter
Postovi: 6,521
Mislim da sirotinja ne traži android 4.0 i ekran 4 incha 480x800 Zte za 945kn je odlična kupnja, jedna od najboljih prilika na našem tržištu sigurno, za novo iz dućana. Mobitel ima jako dobre mogućnosti,i zadovoljit ce sigurno vecinu prosječnih potreba jer je nakrcan hrpom toga.
Staro 03.12.2012., 02:09   #749
rossoneri
Datum registracije: May 2012
Lokacija: dalmeJša
Postovi: 139
Autor acer Pregled postova
meni su godinu dana dolazili računi između 60 i 80kn, sve 5, sasvim normalno... i zadnja 4 miseca uredno od 120-140kn a ništa više ne zovem nego šta san prije...
nemogu ja svaki put na papir pisat kad pošaljem poruku il nazovem nekog, nit se na pretplati može više od jednom dnevno provjerit stanje računa. a onaj ispis šta ga oni pošalju pitaj boga jeli točan, jel šta nadodaju, koji poziv, par minuta vamo tamo... kontam da su me počeli gadno krast. Ili su digli neke cijene dosta, ili nadodaju vrijeme poziva... inače dobia san mob za kunu kad san potpisa na 24miseca, valjda sad na krađi misle vratit i pare od mobitela šta su mi za kunu dali, haha... nikad više na njih, samo da ovo istekne...
rossoneri je offline   Reply With Quote
Staro 03.12.2012., 03:16   #750
Xenon
Postovi: 1,542
Autor rossoneri Pregled postova
nije mi jasno zašto ljudi telefonske račune povezuju s krađom? Baš se netko u tele2 namjerio na tebe 1 od neznam koliko tisuća korisnika i tebi druka račun ... a svašta možeš čut od ljudi ....
Inače sustav koji bilježi pozive, promet i sms je praktički nepogrešiv! Pogreške se mogu jedino pojavit kod krivog obračuna ...
