Lokacija: Bjelovar
Postovi: 86
KVM Switch i kompatibilnost
naime priključio bih 2 kompa na 1 monitor, 1 miša i 1 tipkovnicu pa sam razmišljao o kvm svitchu najjeftiniji koji sam našao i da podržava DVI monitor i USB miša i tipkovnicu je rolline-ov Description - Controls two computers from a single console (USB keyboard, DVI monitor, USB mouse) - Switch with two attached KVM cables (each 1.2 m) - Max. resolution (nominal): 1920×1080 @ 60Hz - Connectors console side: 1× DVI, 2× USB, 2× 3.5mm audio plug - Connectors computer side: 2× DVI, 2× USB, 4× 3.5mm audio plug - Supports independent audio switching - Easy switching by push buttons or hot keys; auto scan function - Keyboard and mouse emulation - LED display for PC status monitoring - Hot-swapping and plug & play - Bus powered - Supports Windows 98SE/ME/2000/XP/2003 Server/Vista Technical Data - 19" compatible: No - Dimensions (H×W×D): 30×85×70 mm - Analogue Console: Mouse/Keyboard connection: USB - Analogue Console: Monitor connection: 1× HD 15pol. BU - Quantity of analogue consoles: 1 - Quantity of PCs: 2 - Print button on device: No - Colour (Design profile): silver - Hot plug compatible: No - Integrated Hub: No - Cascadable: No - Integrated console: No - Material (casing): plastic - Max. resolution (nominal): 1920×1080 60Hz - Monitor size of integrated console: not applicable - Power supply unit required: No - PC: connection on moulded cables: Yes - PC: mouse/keyboard connection: 2× USB - PC: monitor connection: 2× DVI - Switching over Hot Keys: Keyboard - Switching over OSD: No - Switching over Scan Run: Yes - Keyboard/mouse emulation: Yes - Keyboard layout: not applicable - Technical particularity: LED display for easy status monitoring - Trackball/Touchpad integrated console: not applicable - Supported PC-Systems: USB i košta 450-500 kuna to je prihvatljivo samo imam monitor od 23 incha a u specifikacijama piše "- 19" compatible: No" e sad me zanima da li će to čudo raditi sa mojim dellom U2311H hvala !
Lokacija: Vinkovci
Postovi: 531
mislim da ti se - 19" compatible: No odnosi na mogućnost ugradnje u komunikacijske ili mrežne ormare gdje je širina racka 19", nek me netko ispravi ako griješim |
Postovi: 23,603
Da, 19" je sinonim za 19" rack tj ormar. U ovoj priči nebitno. |
Iz iskustva: dobro obrati pozornost na hotkey-eve tj kombinacije tipki za prebacivanje sa kompa na komp, jer neki nisu kompatibilni sa određenim proizvođačima tipkovnica, a ulogu igra i USB/PS2 konektor (začudno, Logitech na jednome dijelu njih nije podržan), konkretno ja imao problema sa Aten-om u toj kombinaciji, dok je nekakva Genius-ova vulgaris tipkovnica šljakala najnormalnije... |
Lokacija: Bjelovar
Postovi: 86
hvala vam na objašnjenju izgleda da ću riskirati 450 kuna pa ćemo vidjeti
