Staro 26.09.2012., 16:35   #1
Luce
iVar
Luce's Avatar
Postovi: 353
(riješeno) Asus Eee PC - instalacija Windows XP-a preko USB sticka
Trebam podici windows Xp na navedeni notebook.
uspio sam preko HP USB Disk Storage Format Tool-a napravit bootabilno usb,ali uvjek mi pokrene cmd,kako da dodjem do toga da ni boota win a ne cmd.
hvala
Luce je offline   Reply With Quote
Staro 26.09.2012., 16:41   #2
MMI
MMI's Avatar
Postovi: 913
MMI je offline   Reply With Quote
Staro 26.09.2012., 16:43   #3
nino
nino's Avatar
Postovi: 12,613
Barem to nije frka napravit. Imas i microsoftov tool.
http://downloadsquad.switched.com/20...a-7-with-wint/
Staro 26.09.2012., 17:02   #4
Luce
iVar
Luce's Avatar
Postovi: 353
evo sad probam ovaj nacin od nino
@MMI
jel to samo za win 7?
Staro 26.09.2012., 17:20   #5
golfw12
golfw12's Avatar
Postovi: 424
pročitaj ovo
http://myeeeguides.wordpress.com/200...b-flash-drive/
meni je pomoglo za jedan hp sa neispravnim dvd-rwom
CPU: AMD Ryzen 5 PRO 4650G@3.7GHz@ CM Hyper 212X
MBO: Gigabyte B450 AORUS PRO
RAM: 2 x 8 GB DDR4 3200Mhz CL16 Kingston HyperX Predator RGB
GPU: Radeon Onboard Graphics
SSD: Samsung 1Tb, NVMe
HDD: Seagate 1TB, Sata III
PSU: Corsair RM650X 650W
CASE: Phanteks ECLIPSE P400
MONITOR: AOC 24G2U @ 144HZ
MOUSE: Logitech MX518 Batman Edition
KEYBOARD: Logitech K200
PERIPHERY: RAZER Goliathus Control Alpha
OS: Windows 10 Home x64
PRINTER: HP LaserJet Pro M12w
CONNECT: T-Com VDSL 30/6 Mb Flat
CPU: Intel® Core™ i5-8250U@1.6GHz
RAM: 2 x 8 GB DDR4 2400Mhz
GPU: Intel® UHD Graphics 620
HDD: 256 GB M.2 SSD
PSU: HP 90W
LCD: 1.920 x 1.080 FHD-Display SVA
golfw12 je offline   Reply With Quote
Staro 26.09.2012., 17:57   #6
Luce
iVar
Luce's Avatar
Postovi: 353
Uspio sam na nacin od nina,ali problem drugi kada treba otvorit particije dobijem bsod tocnije http://www.zaslike.com/files/mmchpxc2otur6l36j.jpg
dali se ikom to dogadjalo,da nije sta plesnulo u notebook-u
Staro 26.09.2012., 18:03   #7
nino
nino's Avatar
Postovi: 12,613
Staro 26.09.2012., 18:12   #8
Luce
iVar
Luce's Avatar
Postovi: 353
A ma probao sam i to,cjeli bios sam okreno naopako..jedino ga nisam flash-ao,a izgleda da mi negine
odem jos po veci stik da probam sa win7 oce zezat
Staro 26.09.2012., 18:15   #9
nino
nino's Avatar
Postovi: 12,613
Win7 ima drivere u sebi, za xp moras integrirat jer nema opcije za prebacivanje u ide mod u biosu.
Staro 26.09.2012., 18:58   #10
Vjeko
V.I.P. član
Vjeko's Avatar
Lokacija: Hennef, DE
Postovi: 796
Autor nino Pregled postova
Mislim da bi flash biosa otvorio opciju za IDE mod.
Ali nisam siguran za eee igračke :/
Zadnje izmijenjeno od: Vjeko. 26.09.2012. u 19:13.
Vjeko je offline   Reply With Quote
Staro 27.09.2012., 01:03   #11
Luce
iVar
Luce's Avatar
Postovi: 353
je,bio sam digao win 7 bez veci problema,al mi vrag nije dao mira pa sam flash-o bios i dobio nove "opcije" i bez problema digao xp.
@nino mozes kljucat rjeseno
