Staro 07.05.2005., 20:40   #1
Mailman
Mailman's Avatar
Postovi: 1,606
DHzer0point Catalyst 0.54 'Public Preview'
This is a Public preview of the work we are doing on the DHzer0point ATI drivers, there are bound to be a few bugs we've yet to discover, however, overall we're very happy with the state of our project and wanted the community to be able to get a hold of them as well.
Included in the DHzer0point ATI release are two additional programs, Radclocker publicly available version. This version does not support the newer PCI/e boards so if you have one of those we're sorry however we are working with ChrisW to get an updated release with that support for our next release. Also included in the release is zackensaks Glidewrapper, a utility for using Glide, to play the older games they were meant to be played. Also included are, of course, the DHzer0point Game specific Enhancements for HL2, CSS, FarCry and Doom3.
-=[ Features ]=-
-Overall performance, IQ, and stability tweaks.
-Increased number of resolutions over the standard Catalyst choices
-HDTV Modes enabled
-DiVX, Mpeg2, WMV acceleration enabled
-Displacement Mapping enabled (if supported by hardware)
-Geometric Instancing enabled
-=[ To Do ]=-
-Fix installer so heading reads DHzer0point ATI Driver Setup and ATI's Eula is replaced with the DHZP Eula
-Fix minor installer bugs
-Further HL2 CSS Optimizations
-Support for wider range of resolutions
-Mobility support - MOBILITY BETA TESTERS NEEDED!
-Updated Overclocking utility for PCI/e boards
-=[ Errata ]=-
Fastwrites are on by default unless you have them turned off in your BIOS. These drivers are built around quality, first, last and always; if you're going to bitch about your 3dmarks going down slightly don't bother. That said HL2 and CSS currently take a larger than normal performance hit, most notably on older cards, due to the increased quality in the set. We are working on resolving this issue. However this can be limited in great part simply by turning down AF and or AA one or 2 levels, if you're used to 8x AF try 4x.
Currently, the set uses the old-style CP. Future releases will come in both CP and CCC flavors.
http://www.dhzeropoint.net/
Mailman je offline   Reply With Quote
Staro 09.05.2005., 15:08   #2
Jelc
Super Moderators
Datum registracije: May 2002
Postovi: 17,485
Ahhh...vidio sam, samo mi se čini da dečki imaju još dosta posla
