Staro 25.04.2012., 12:45   #301
QuidZz
QuidZz's Avatar
Lokacija: Sinj
Postovi: 3,538
Uzmi si Hyper 612S za 289kn, hladit ce 2500k na 4.5Ghz bez problema...
Staro 25.04.2012., 14:05   #302
lolofuxy
lolofuxy's Avatar
Datum registracije: Jun 2010
Postovi: 3,319
Samo izvadi matičnu kad ideš 612s instalirat i pazi da ti dobro sjedne da ga nebi morao 15-puta postavljat.
lolofuxy je offline   Reply With Quote
Staro 25.04.2012., 14:36   #303
KR-DI
KR-DI's Avatar
Lokacija: Zabok
Postovi: 389
Hvala obojici, kupujem Hyper 612S na kraju...
Autor QuidZz Pregled postova
Autor lolofuxy Pregled postova
KR-DI je offline   Reply With Quote
Staro 04.05.2012., 11:02   #304
Doink the Clown
Jack of all, master of none
Doink the Clown's Avatar
Lokacija: Matulji - Rijeka
Postovi: 6,214
Corsair Adds Cooling Fans to Product Line
Corsair, a worldwide designer and supplier of high-performance components to the PC gaming hardware market, today announced the new Air Series line of PC cooling fans. Unlike most other PC fans in the market, Corsair Air Series fans are offered in airflow and static pressure models, each specifically optimized for specific PC cooling roles.
Air Series fans are designed to deliver an extraordinary balance of airflow and low-noise to users who want to upgrade their PCs for quieter operation or higher performance. All feature an advanced hydraulic bearing system and rubber mounts for low-noise and reliability, and include red, white, and blue color rings to allow users to customize the look of their PC.
High Airflow Fans for Efficient Large-Volume Cooling
Air Series AF120 and AF140 airflow fans are designed to intake cool air into, and exhaust hot air out of, modern PCs. They are for ideal for mounting on the side, top, and rear of cases, to reduce component-killing heat. The airflow fans are designed with ultra-thin, custom-molded blades optimized to flow high volumes of air in unrestricted spaces with at least 3cm of clearance. They are available in a 140mm Quiet edition and in 120mm Quiet and Performance editions.
High Static Pressure Fans for Efficient Cooling on Radiators or Heatsinks
Air Series SP120 fans deliver focused air pressure in situations where air needs to be blown through a restricted space making them ideal for cooling radiators and heatsinks. They feature seven ultra-wide, custom-molded blades and a custom enclosure that delivers high static pressure, while maintaining a quiet noise profile. Available in a 120mm size, SP120 fans are available in Quiet and High Performance editions.
"Many PC fans on the market are general purpose designs that not always suited to the task which they’re assigned," said Ruben Mookerjee, VP and General Manager of the Components Business Unit at Corsair. "We took our expertise in PC case and cooling and designed fans that have very specific uses. Each fan is the right tool for the right job.”
Pricing and Availability
Air Series fans are immediately available starting at a suggested retail price of $16.99 USD for AF120/SP120 fans and $18.99 USD for AF140 fans.
For more information on Air Series fans, please visit the cooling section of our web site and our Air Series fan blog post.
http://www.techpowerup.com/165376/Co...duct-Line.html
Valjda će se nać i nešto šminkerskog LED-a
C L O W N I N G A R O U N D
Staro 08.05.2012., 21:50   #305
patakmeister
N6 Brušeno- N12 Turpijano
patakmeister's Avatar
Lokacija: Kuća
Postovi: 321
Šta predlažete imam Asrock Z68 Pro 3 ploču na njoj lagano jedan intel core i5 2500 K box hladnjak koji mi pije živce i 2 keksa ramčeka G.SKILL Ripjaws series, F3-10666CL9D-8GBRL i Radeon 4870 Vapor X pa me zanima koji od hladnjaka Scyte ili neki drugi može stati u tu gužvu da nije bučan i da radi posao. U drugom kompu imam Scythe Ninja 3 i čisto sam zadovoljan performansama.
Tko rano rani il je pekar il budala
Mirko S. Kojotovski Genije
patakmeister je offline   Reply With Quote
Staro 08.05.2012., 21:51   #306
QuidZz
QuidZz's Avatar
Lokacija: Sinj
Postovi: 3,538
Autor patakmeister Pregled postova
Budget?
Staro 08.05.2012., 21:56   #307
patakmeister
Lokacija: Kuća
Postovi: 321
Budget?
Do 450 kunića
Staro 08.05.2012., 21:59   #308
QuidZz
QuidZz's Avatar
Lokacija: Sinj
Postovi: 3,538
Hyper 612S za 289,00Kn, lijepo ce obavljat posao ako ces OC do 4.5 Ghz
Staro 08.05.2012., 22:01   #309
hammer_of_thor
its slightly turbocharged
hammer_of_thor's Avatar
Postovi: 5,430
Za 450 kn biraj očeš Prolimatech, Noctuu ili Thermalright (ako ga ima sad neki shop)
Sve ostalo je klasa ispod.
blaa
Staro 09.05.2012., 00:15   #310
seno
seno's Avatar
Datum registracije: Dec 2009
Lokacija: Bosna
Postovi: 762
Majka mu stara, skinem hladnjak sa svog i3-530... ocistim staru pastu nanesem novu i temperature skoce u idlu na 40 uz operu upaljenu ... no O.C. Stock je cooler.
seno je offline   Reply With Quote
Staro 09.05.2012., 00:17   #311
QuidZz
QuidZz's Avatar
Lokacija: Sinj
Postovi: 3,538
Nisi dobro stavio pastu, stavi je metodom "zrno rize" pa pogledaj temp
EDIT:
Ili možda hladnjak nije sjeo kako treba.
Ili to
Zadnje izmijenjeno od: QuidZz. 09.05.2012. u 00:36.
Staro 09.05.2012., 00:32   #312
Doink the Clown
Postovi: 6,214
Staro 09.05.2012., 00:36   #313
Postovi: 8,229
Nemora uopće biti ni do paste. Jel ti hladnjak dobro sjeo, tj. kopče jesu ušle do kraja u ploču i jesi sve dobro pokopčao?
Iako, te temperature u idleu su toliko nebitne, i nemjerodavne, pogotovo ako je na automatskoj regulaciji vent. Pogledaj si load, pa vidi kolika je temperatura i onda vidi jel u granicama normale.
Staro 09.05.2012., 00:51   #314
seno
seno's Avatar
Lokacija: Bosna
Postovi: 762
Da sjeo je hladnjak do kraja, nije auto regulacija jer inace procesor drzim na 50% i imam 29c-33c... Sada nakon ljetnog ciscenja imam sa 100% 34-37c.
Staro 09.05.2012., 01:01   #315
Postovi: 8,229
E da, ljeto dolazi, tj, ambijentalne temperature su sve veće pa i to treba uzeti u obzir. Lako je bilo imat super temperature dok je sobna temperatura 20 i možda koji sitno stupanj.
Uglavnom load si prati, pa se ravnaj prema njemu da li trebaš intervenirat il ne.
Staro 09.05.2012., 01:11   #316
seno
seno's Avatar
Lokacija: Bosna
Postovi: 762
Uredu hvala , vidjet cu da nabavim za ljeto cm 212. Inace ako load bude povis 70C sta mi je ciniti O.o? Jer u zadnje vrijeme igram emulatore malo vise pa mi zakucaju procesor preko 80%.Dok PC igre ne igram.
Staro 09.05.2012., 01:27   #317
Blue_Fatal1ty
Blue_Fatal1ty's Avatar
Lokacija: Čazma
Postovi: 1,728
Malo googlam i mislim si koji ću hladnjak za i5 3570K uzet i vidim nema noctua-e. Nigdje po zg za kupit...
Koja alternativa bi bila ok?
Price doesn't matter...
Staro 09.05.2012., 01:30   #318
Postovi: 8,229
Pa kupi noctuu kod oprića u Ri(čovjek dodje povremeno na forum pa mu se možeš i tu javit vjerujem). Lik je stvarno ok i izaći će ti maksimalno u susret što se tiče slanja poštom i svega ostaloga.
Staro 09.05.2012., 01:59   #319
Blue_Fatal1ty
Lokacija: Čazma
Postovi: 1,728
Autor Pupo Pregled postova
Da izgleda da ću morat jer ovo sve drugo je razina ispod.
Staro 09.05.2012., 13:35   #320
JuiceBox
Xulos :)
JuiceBox's Avatar
Postovi: 7,579
Autor Blue_Fatal1ty Pregled postova
Ne trkeljaj gluposti... . Klasa iznad. Imao sam to cudo, em je ogromno,em tesko ,em do pola maticne nemozes doci.Uzmi bilo koji prolimatech ili ako nadjes TR i to je to.Ja sam sa true black presao na noctuu i nisam bas primjetio razliku nekakvu.A za te pare radije bih dodao jos 100 kn i uzeo H100.
Zadnje izmijenjeno od: JuiceBox. 09.05.2012. u 13:41.
Staro 09.05.2012., 13:42   #321
Blue_Fatal1ty
Lokacija: Čazma
Postovi: 1,728
Autor xulos Pregled postova
Ne trkeljaj gluposti... . Ako je tebi 1-3 C klasa iznad onda ga yebi. Imao sam to cudo, em je ogromno,em tesko ,em do pola maticne nemozes doci.Uzmi bilo koji prolimatech ili ako nadjes TR i to je to.Ja sam sa true black presao na noctuu i nisam bas primjetio razliku nekakvu.A za te pare radije bih dodao jos 100 kn i uzeo H100.
H100 je 300 kn skuplji. Već sam dogovorio sve za noctua-u.
Staro 09.05.2012., 15:46   #322
Wolverine
Wolverine's Avatar
Postovi: 12,431
Ja bi osobno uzeo Intel LCS ili H60/70. No to sam samo ja
Ako meni uredno hladi 3960X onda ne bi bilo problema s 3570K.
Mark Twain
Intel Core i5 2520
8GB DDR3 Patriot
Intel HD3000
256GB LiteOn LMH-256V2M mSATA
NEC USB 3.0 ExpressCard
14" 1366x768
Windows 10 Pro x64
Gigabyte GTX 560Ti
DVD-RW LiteOn SATA
Corsair HX520
TT Chaser MK-1
Logitech MX3200
Windows 10 Pro x64
Intel DP67BG
Intel G1610
Hitachi 250GB
VTX3D HD6670
DVD-RW Asus SATA
FSP 350 PNF
CoolerMaster Cavalier
ViewSonic VX922
Win7 x64 SP1
Staro 09.05.2012., 16:20   #323
hammer_of_thor
Postovi: 5,430
Scythe, Xigmatek, CM, AC i slično je klasa ispod.
No Thermalright i Prolimatech sigurno nije.
Sveto trojstvo kod air coolinga su Noctua, Thermalright i Prolimatech.
Trenutno imam vlastite Megashadow, Venomous X i NH-C14 (uz još par drugih) i stvarno nema im ravnih.
blaa
Staro 09.05.2012., 17:53   #324
Blue_Fatal1ty
Lokacija: Čazma
Postovi: 1,728
Ma to sam sve šta ste naveli i gledao, al opet neak ni je noctua najbolje sjela. Da sam išao na corsair uzeo bih H100 jer fakat imam mjesta u kučištu. Cijena me na kraju odmamila iako ni noctua nije jeftina...
Staro 09.05.2012., 18:13   #325
Wolverine
Wolverine's Avatar
Postovi: 12,431
H100 mi je odbojan iz dva razloga.
A) Cijena
B) Potenciometar koji se kvari
Za Core i5 3570K je H60/H70 i više no dovoljan. Kao što rekoh hladi Core i7 3960X na 4,5 GHz kud neće taj Core i5. Plus nemam grdosiju koja mi onemogućuje pristup polovici ploče.
Mark Twain
Intel Core i5 2520
8GB DDR3 Patriot
Intel HD3000
14" 1366x768
Windows 10 Pro x64
Gigabyte GTX 560Ti
DVD-RW LiteOn SATA
Corsair HX520
TT Chaser MK-1
Logitech MX3200
Windows 10 Pro x64
Intel DP67BG
Intel G1610
Hitachi 250GB
VTX3D HD6670
DVD-RW Asus SATA
FSP 350 PNF
ViewSonic VX922
Win7 x64 SP1
Staro 09.05.2012., 21:02   #326
Postovi: 8,229
Za koji ono komp kupuješ taj hladnjak?
Staro 09.05.2012., 21:38   #327
patakmeister
Lokacija: Kuća
Postovi: 321
Zbog dimenzija
Me zanima jer mi je gužva u kućištu pa da ne kupim nešto što ne može da stane.
Nekad je zalman imao preporuke na koje ploče idu njihovi hladnjaci a sad to nema niko ili ima a da ja ne znam ?
Pa me zanima prvenstveno radi rama i grafičke koje mi djeluju blizu tako velikim hladnjacima?
Staro 09.05.2012., 22:08   #328
lolofuxy
lolofuxy's Avatar
Postovi: 3,319
Radi se o dosta velikom kuleru, računaj na vađenje matične van i barem pomoći druge ruke kod instaliranja ako si neiskusan (ako je tako bilo bi ti bolje da zamoliš da ti ga instaliraju di ga kupiš), a Ripjawsi će ti stat samo makni ventilator od kulera prije instalacije jer teško da ćeš ugurat naknadno s ventom gore u prvi slot 1 keks ripjawsa, a za drugi ne brini.
Sad ti samo preostaje da nam kažeš koje kućište imaš , a ovo su ti dimenzije CM 612S-a: 140 x 128 x 163 mm (duljina-širina-visina)
Staro 09.05.2012., 22:26   #329
patakmeister
Lokacija: Kuća
Postovi: 321
Čije je kućište stvarno se ne znam neko staro, što se stajanja tiče unutra je bez problema bilo prije AsusM2NSli Deluxe sa Scythe Ninja 3 hladnjakom i dalo se zatvoriti.
Zanima me da li bi možda takav hladnjak se uspio staviti na ovu ploču jer je ogroman ili nešto iz Scytheove game proizvoda.
Staro 09.05.2012., 23:01   #330
Blue_Fatal1ty
Lokacija: Čazma
Postovi: 1,728
za i5 3570K koji ću uzet u pon.
Neboj se nije za ovo s potpisa!
