#22621 |
sto da napisem ?!
Postovi: 880
ja se ponovio za vilicu ![]() mz 55 tst2 ![]() ![]() jos maloooooo ![]() |
#22625 |
Postovi: 2,880
CROATIA TEAM-Endomondo Challenge: 2012 - burn calories
CROATIA TEAM - Team Challenge: ! "2012" - all sports teams - burn calories Trenutno smo na 27 mjestu svjetske Endomondo ljestvice, a brojimo 49 clanova. Za usporedbu, prvoplasirani team na ljestvici broji 500 clanova :mrgreen: Si su dobrodosli u CROATIA team ... ajmo ih sve raz*guziti :twisted: Tko zeli pozivnicu ... PM! http://www.endomondo.com/teams/p7Lw4ocmxIQ
#22627 |
Postovi: 2,241
To se destro pravi pametan, a nije! "Endomondo FAQ (Official Rep) 11 months ago To change the units between Metric (kilometers, kg. etc.) and Imperial (miles, feet, lb. etc.), log into your profile at endomondo.com, go to Settings (upper right corner), select Account and simply select the units you want, Metric or Imperial. You can also go to Settings in the Endomondo app and change the units here - the best is to set the units in both phone and the website. Which units will be displayed when e.g. your friend is looking at your profile? There are 2 possibilities: 1. your friend has Endomondo profile and is logged in The units your friend can see will be the same as the units he/she set his/her profile to, so even though you set your profile to miles, he/she will see km if the set his/her profile to km - following his/her settings. 2. your friend does not have Endomondo profile or is not logged in The units your friend can see will be the standardized units for the country in which he/she is at that moment. So even though you set your profile to km, in case he/she is in e.g. Great Britain, he/she will see your profile in miles." Iako po ovome, ako je cuks stavio metrički sustav, mi bi trebali vidjeti u tom sustavu, osim ako server od pceksperta nije u GB ili USA ili ........!
![]() RedGreenBlue |
#22630 |
jedan i jedini :D
Lokacija: novi zagreb
Postovi: 5,211
Tamo mi djubre neda embedati link tako da nista. Evo ti direktan link pa reci kako ti se sad prikazuje http://www.endomondo.com/workouts/user/1853260 EDIT: ispravio link Zadnje izmijenjeno od: Cuky. 07.05.2012. u 16:46. |
#22633 |
sto da napisem ?!
Postovi: 880
ojla ! nije to ta od zmije, ovo je druga ali je napravljen isti mod itd. ali će svejedno prije nego se otisnem s njom u vožnje otići kod zmije na tweak i kontrolu. kako izgleda sve do sad, pogledaj dolje ![]() radi, na žalost ne mogu najbolje isprobati ali radi zadovoljavajuće. nadam se da će nakon zmije to sve doći na apsolutno savršenstvo. ![]() slička 1 slička 2 slička 3 slička 4 |
#22634 |
Datum registracije: Apr 2011
Lokacija: zg/vz tj vz/zg
Postovi: 0
Kolege bajkeri, znam da nije tema za to, al sam da pitam, ima tu puno PcEkspertovaca, tako i MobyExpertovaca (nadam se), pa me zanima dal zna tko rootati android uređaj (konkretno Htc Legend) na neki Sense rom (obavezno) i koji je trenuntno najbolji.... Skroz sam ispao iz te "mobitel" priče, pa pomagajte. Daljnji dogovor na pm ak možete pomoć, hvala! Da nebude baš sve OT, evo i link na video jučerašnje vožnjice; http://www.youtube.com/watch?v=qzX0yQUweKY Moje spomenuto "junačenje" počinje na 6:50 i traje punih 10 sec ![]() ![]() ![]() |
#22635 |
Lokacija: Zagreb - zapad
Postovi: 130
@čuki sada vidim metričke jedinice.... ostavi tako ![]() @željac odlično to izgleda, samo neka se što prije složi da se vozimo. vidim fali ti još lula, lanvo, gume, lanac, pedale i čniceko... @mic ma naravno da nema tebe snimljenog kad se ja i markec volimo čilati dok se vozimo a ti ga ganjaš non stop ![]() odlična je vožnja bila, a posebno je dobar dio onaj malo prije medvedgrada i onaj malo poslje njega. fcuk yea! |
#22636 |
sto da napisem ?!
Postovi: 880
da, to je popis svega što fali. najviše me muče kočnice (lova) i lula+ volan zbog toga što je skupo ono što mi se sviđa. kočnice će ići slx iz slovenije 90% sigurno. osim ako u pravo vrijeme ne uleti neka ponuda volan za sada bazooka + sunline am lulica nabere se troškova na sitnicama... ![]() ![]() ali, bit će to sve uskoro ![]() ![]() |
#22638 |
Postovi: 130
željac, zemi si neki specialized enduro volan kod marka u proteji, jer su odlični volani po ok cijeni a širina je 720.... vjeruj mi da 800mm je daleko previše za HT. (geometrija bicikla određuje širinu volana a ne širina ramena ![]() ja se sada vozim na 660 (volan od vuce) naspram 740 koji sam imao do nedavno, i moram reći da nije tako strašno.... tj. vidim da mi je 740 bilo previše na mom HT-u, a ovih 660 je mrvicu premalo. idealno bi mi bilo oko 700mm. |
#22639 |
sto da napisem ?!
Postovi: 880
hmmm... hvala na savjetu ! ima logike, cijena mi je više manje ista, samo je pitanje što će mi bolje sjesti. prije sam imao 710 i to mi je bilo taman. iskreno, destrov 740 ili 745 (ista stvar kod tebe Darac), je ta da su mi ruke bile malo kratke u zavojima. svakako preveliko... samo sam bio uvjeren da je stvar navike... što je uvelike, ali mislim da će 720 biti puno bolji ![]() hvala ! ![]() moram ti vratiti ključ ![]() |
#22640 |
Postovi: 0
Dečkovi evo mala pomoć za probijanje bajkom kroz gradsku gužvicu... ![]() http://www.klix.ba/magazin/zanimljiv...la/120505007#5 Cijena... Prava sitnica ![]() |
#22643 |
Lokacija: Zagreb, Tresnjevka
Postovi: 9,505
Dečki, ako netko treba kočnice neka se javi. Formula RX prednja, Deore M596 zadnja i Juicy 3 zadnju koju dobijete đabe. Ne znam koji je vrag ovoj Deore M596. Ne pušta ulje niti ništa i kad koči - koči odlično, ali pazite sad ovo - maknem čeljust sa diska, stisnem ručicu i nemrem spojiti pakne na čeljusti. Toliko se nazad vraćaju klipovi, ono maknu se od diska par mm sa svake strane !? ![]() Sad više nisam ziher jel do diska koji je možda preuzak mada to ne bi trebalo biti uopće upitno jer se klipovi sami prilagođavaju potrošenosti pakne (i rotora pritom). Jer kad su pakne blizu kako inače trebaju biti, kočnica hvata fenomenalno i blokira odmah zadnji kotač.
#22645 |
Datum registracije: Aug 2011
Postovi: 0
Kad vidim koje su te velicine volana i kad se sjetim da sam nekih 2 god vozio na 580mm volanu vrti mi se... Nik jesi bio sad navecer na Bikci?mislim da sam vidio tvoj auto na parkiralistu.... Jel bi mi mogo netko tko ima otvoren racun narucit neku dobru i jeftinu lampu za nocne voznje?vidim da ste se nakupovali toga pa mozete dat dobar prijedlog za lampu..imam 150kn rezervirano za to... |
#22646 | |
Postovi: 454
![]() Gore je inace 8°C, vidi se dah, srne u sumrak istrcavaju na veliko, a sove hucu tako da je bas zivahno na Bikci. Best buy ti je ona maxova lampa s punjacem, baterijama i futrolom, mislim da je 30$ negdje, to kupi, samo naruci i mount za kacigu (par $). |
#22647 |
Postovi: 9,505
#22648 |
Avocado
Postovi: 7,853
Zadnje izmijenjeno od: De5tr0yer. 08.05.2012. u 01:24. |
#22650 |
Truth is out there!
Datum registracije: Aug 2003
Postovi: 497
Ima netko ovdje s foruma iz SPLITA??????hitnooo!
"Covjek je star koliko i zena koju osjeca!" C.Sheen |
