Staro 27.04.2012., 10:09   #1
Doink the Clown
Jack of all, master of none
Doink the Clown's Avatar
Lokacija: Matulji - Rijeka
Postovi: 6,214
Nvidia GeForce GTX 670
Gainward GeForce GTX 670 Goes Up For Pre-Order in The Philippines
A Gainward-branded GeForce GTX 670 graphics card went up for pre-order in The Philippines, listed for pre-order for PHP 19,990 (US $470), by Philippine retailer PCHub. The price is backed by "price protection", which as we understand, transacts the difference between launch-price and pre-order listing price with the buyers before shipping (refunds the difference, if the launch price is lower, collects the difference to ship, if the launch price is higher (we doubt), or refunds the pre-order amount). The store sale page doesn't list any other specifications than memory size (2 GB) and memory bus width (256-bit GDDR5). Other specifications of the GTX 670 could be found here (older article).
C L O W N I N G A R O U N D
Staro 28.04.2012., 12:55   #2
mamutarka
ODUZIMAM VAM RIJEČ
mamutarka's Avatar
Postovi: 13,551
http://www.techpowerup.com/165033/Re...-Pictured.html
Reference NVIDIA GeForce GTX 670 Graphics Card Pictured
Here is the first picture of an NVIDIA reference design GeForce GTX 670. For the most part, its design will resemble that of reference design GTX 680. The card pictured below is said to have had Leadtek branding, which later got removed. GeForce GTX 670 is carved out of 28 nm GK104 silicon by disabling one of the card's eight SMX units, resulting in a CUDA core count of 1344. Its clock speeds are lower than those of the GTX 680, with around 950 MHz core base clock, and core boost clock a little over 1 GHz. It features 2 GB of memory across a 256-bit wide GDDR5 memory interface. The latest price speculation puts it at US $399-$429.
Staro 28.04.2012., 16:37   #3
JuiceBox
Xulos :)
JuiceBox's Avatar
Postovi: 7,580
Third GK104-based Single GPU Graphics Card SKU Detailed
"After GeForce GTX 680, which has all components of the 28 nm GK104 enabled, a dual-GPU GeForce GTX 690, which features two of these chips, and the GeForce GTX 670, NVIDIA is readying its third single-GPU GK104-based SKU. We know from older reports that this SKU could be named GeForce GTX 660 (Ti). A fresh report suggests that it will be carved out by disabling an entire graphics processing cluster (GPC) on the GK104 silicon, resulting in a CUDA core count of 1152; reducing the memory bus width of 192-bit GDDR5; and most likely reducing the ROP count to 24. This SKU could be used to capture a price point of around US $249, targeting AMD's Radeon HD 7800 series. "
Staro 30.04.2012., 20:36   #4
demetrius
demetrius's Avatar
Lokacija: rijeka
Postovi: 3,890
dobro je to sam htio pitat gtx 660 ti,izlazi.
Staro 30.04.2012., 21:10   #5
MAGARAC
MAGARAC's Avatar
Postovi: 5,997
Autor demetrius Pregled postova
Ne zna se. Ne zna se tocno ni kad gtx 670 dolazi.
Staro 01.05.2012., 10:49   #6
musso
Unregistered User
musso's Avatar
Datum registracije: Jun 2002
Lokacija: Beč
Postovi: 722
Negdje sam nasao informaciju da ce se predstaviti i izaci na trziste oko 10.5. 670 i 660 model, ne spominje se Ti. A Ti verzija da navodno zadnja izlazi, kojih mjesec dana jos iza.
musso je offline   Reply With Quote
Staro 02.05.2012., 08:17   #7
QuidZz
QuidZz's Avatar
Lokacija: Sinj
Postovi: 3,538
MSI's GEFORCE GTX 670 poses for the camera
The GTX 670 sports 1344 CUDA cores, 112 TMUs, 32 ROPs, a 256-bit wide GDDR5 memory interface with 2GB of RAM and clock speeds on the Core of 900MHz, 1250MHz or 5GHz effective on the memory.
Sviđa mi se design
Izvor
Zadnje izmijenjeno od: QuidZz. 02.05.2012. u 08:24.
Staro 02.05.2012., 10:32   #8
RaneZ
Vršni visioc
RaneZ's Avatar
Postovi: 2,209
Obozavam ove "feature"...features sales politika, koju je po mom misljenju uveo gigabyte te prvi put ulozio lovu u dizajn koji je digo firmu jebeno.
Mislim ono: "Ready for 3D Mark 11"
Bez potpisa.
RaneZ je online   Reply With Quote
Staro 02.05.2012., 11:40   #9
Doink the Clown
Postovi: 6,214
Baš me zanima koliko će biti brža u odnosu na GTX570.
Staro 02.05.2012., 11:57   #10
sapunko_HR
Datum registracije: Oct 2011
Lokacija: _
Postovi: 277
Trebala bi bit brža barem malo od gtx 580 ako nebude gtx 670Ti
Zadnje izmijenjeno od: sapunko_HR. 02.05.2012. u 12:03.
sapunko_HR je offline   Reply With Quote
Staro 02.05.2012., 16:46   #11
gnomisa
gnomisa's Avatar
Datum registracije: Feb 2003
Postovi: 1,556
Autor sapunko_HR Pregled postova
ma neku twin frozr verziju i rokaj miško...ima da pere gtx580 (na njenim defoltnim taktovima)
gnomisa je offline   Reply With Quote
Staro 02.05.2012., 17:00   #12
MAGARAC
MAGARAC's Avatar
Postovi: 5,997
Nije tesko za izracunat u grubo koliko ce bit sporija od 680...
10tak % manji takt i oko 12.5% manje CUDA jezgri = 15 do 20% manje perf = 15% brze od gtx 580, 10% brze od 7950
Bit ce to super grafa samo nebu jeftina.
Staro 03.05.2012., 09:49   #13
JuiceBox
Xulos :)
JuiceBox's Avatar
Postovi: 7,580
GTX 670 PCB Pa ovo je krace i od gt 420 Neznam kako su takvu grafu uspjeli na takav PCB utrpat
Staro 03.05.2012., 10:40   #14
sapunko_HR
Lokacija: _
Postovi: 277
Autor xulos Pregled postova
Pa kaj su ovo nadoštukali ventilator turbinski na PCB,to znači da bi custom hlađenje sa jednim centralnim venilatorom bilo sasvim dosta i još bi kartica bila kraća
Staro 03.05.2012., 11:45   #15
pci_e3x
Premium spammer
pci_e3x's Avatar
Datum registracije: Aug 2010
Lokacija: D.Zagora
Postovi: 776
A wild GTX 670 has appeared!
http://www.gpureview.com/a-wild-gtx-...ticle-943.html
Colorful GeForce GTX 670 Graphics Card Pictured
http://www.techpowerup.com/165336/Co...-Pictured.html
Staro 05.05.2012., 15:41   #16
sapunko_HR
Lokacija: _
Postovi: 277
GTX 670 REVIEW
Brža od HD7970
Staro 05.05.2012., 16:12   #17
MAGARAC
MAGARAC's Avatar
Postovi: 5,997
Njihova 670 ima 1000mhz visi efektivni klok memorije i 15mhz(tko zna koliko turbo kloka) vise GPUa od ove gore MSIjeve ali svejedno mi je malo cudno da je samo par% sporija 680. Nije im ni izbor igri bas neki, fale najbitnije igre. Treba pricekat ostale..
Bilo bi super da je tak, odmah trcim po novu trgovinu..
Ova je ocito full size. Ima 8 + 6 pin napajanje i djeluje jako dobro..
Zadnje izmijenjeno od: MAGARAC. 05.05.2012. u 16:54.
Staro 05.05.2012., 23:09   #18
sapunko_HR
Lokacija: _
Postovi: 277
Autor MAGARAC Pregled postova
Ne učitava mi više,da je i 10% sporija od 680 opet je brža od 7970 zar ne?
Čini mi se da 570 hvata 580,7950 hvata i prestiže 7970, onda je moguće da nereferentne gtx 670 overclockom lako preskoče i prestignu gtx 680 obične
Staro 05.05.2012., 23:44   #19
syss
syss's Avatar
Postovi: 10,805
... onda je moguće da nereferentne gtx 670 overclockom lako preskoče i prestignu gtx 680 obične
ko i desetljećima do sada
Staro 06.05.2012., 00:44   #20
QuidZz
QuidZz's Avatar
Lokacija: Sinj
Postovi: 3,538
Autor syss Pregled postova
upravo tako
@sapunko_HR i onda kloknes GTX 680 i opet imas brzu karticu
Staro 06.05.2012., 00:51   #21
Brlja
Postovi: 874
GTX 670 REVIEW
Brža od HD7970
Meni ta stranica baš i ne radi.
Brlja je offline   Reply With Quote
Staro 06.05.2012., 09:14   #22
sapunko_HR
Lokacija: _
Postovi: 277
Autor QuidZz Pregled postova
upravo tako
Da ali gtx 670 bi trebala bit oko 3000kn a 680 je 4000kn
Staro 06.05.2012., 14:03   #23
tole_
Casual Racist
tole_'s Avatar
Lokacija: Sneed's feed and seed (formerly Chuck's)
Postovi: 422
Slike su ponovo up na TT reviewu.
Valjda su imali Gigabyte OC karticu na testu kad je tako blizu gtx680. Vidjeh na Hforumu da ta GB ima base 980MHz, a boost 1058, dakle slicno kao gtx680. Stoga ne cude ovakvi rezultati. Inace je stock 915->980MHz, a memorija je svima na 6GHz
tole_ je offline   Reply With Quote
Staro 06.05.2012., 14:06   #24
syss
syss's Avatar
Postovi: 10,805
560ti je 1700, a 570 je 2700
Staro 06.05.2012., 14:24   #25
musso
Unregistered User
musso's Avatar
Lokacija: Beč
Postovi: 722
http://www.overclock.net/t/1253432/g...rsion-hands-on
Kupujem prvi dan dolaska nereferentnih modela. AWESOME
Staro 06.05.2012., 14:26   #26
syss
syss's Avatar
Postovi: 10,805
ni pod razno... plavi pcb
Staro 06.05.2012., 14:32   #27
musso
Unregistered User
musso's Avatar
Lokacija: Beč
Postovi: 722
hahh
Ma svejedno koji pcb, najradije bih MSI twin frozr al vidjet cemo koji ce modeli prvi stici.
Staro 07.05.2012., 00:40   #28
JuiceBox
Xulos :)
JuiceBox's Avatar
Postovi: 7,580
I ja mislim da ce ovo bit moja iduca grafa ova GB oc krasna stvarcica
Staro 07.05.2012., 01:17   #29
MAGARAC
MAGARAC's Avatar
Postovi: 5,997
Ja bi isto jednu. Jedva cekam neke ozbiljnije rezultate, OC i ostalo. Jer uopce pise gdje kad ce bit pustena u prodaju? Naso sam 10.5. za 400$ ili oko 3200 - 3500kn.
Klasicna Gigabyte, WindForce, plavi PCB itd. Provjeren recept za dovoljno hladnu i tihu grafu. Ova ima 6 +8 pin adapter pa vjerojatno i custom PCB. Jos jedan + 670 je da ima mogucnost 3 SLI kao prava high end grafa..
Zadnje izmijenjeno od: MAGARAC. 07.05.2012. u 01:29.
Staro 07.05.2012., 01:22   #30
syss
syss's Avatar
Postovi: 10,805
plavi pcb je i dalje za papke
