Staro 10.04.2012., 12:53   #121
syss
syss's Avatar
Postovi: 10,805
nedovoljno za zamjenu postojeće
Staro 10.04.2012., 13:08   #122
Dottore
Dottore's Avatar
Postovi: 7,693
Da, kako bi narodna glasila "Volim ono sto mladi imaju" i sigurno ce naci kupca zbog sminke i viska USB utora.
HP 845 G9
CPU: AMD Ryzen 7 PRO 6850U
RAM: 64GB Samsung DDR5 4800
Graphic: AMD Radeon 680M
LCD: 14" IPS @ 1920 x 1200
OS: Windows 11 Pro 25H2
Mice: Logitech MX Master 3S
Lenovo ThinkPad P15v Gen 3
CPU: AMD Ryzen 7 PRO 6850H
RAM: 64GB DDR5
Graphic: AMD Radeon
LCD: 15" IPS @ 3840x2160
Lenovo ThinkPad T14 Gen 3
RAM: 16GB soldered LPDDR4
Mice: Logitech VX Nano
Lenovo X1 Carbon 7th Gen
CPU: Intel Core i7-8665U
RAM: 16GB soldered LPDDR3
Graphic: Intel HD 620
LCD: 14" IPS @ 2560x1440
Lenovo X1 Carbon 10th Gen
CPU: Intel Core i7-1260p
SSD: Sk Hynix 512 GB NVMe M.2
Graphic: Intel Iris Xe
LCD: 14" IPS @ 1920x1200
Staro 10.04.2012., 13:16   #123
syss
syss's Avatar
Postovi: 10,805
ili nekoga tko ima 775/1156 platformu pa hoće apgrejd.
Staro 10.04.2012., 13:22   #124
dean225
DD9512
dean225's Avatar
Postovi: 1,869
fali mi usb 3.0 konektora i sata3 konektora. Vjerovatno cu se preselit na z77, brzina mi je nebitna. I vjerovatno opet neki asrock.
dean225 je offline   Reply With Quote
Staro 10.04.2012., 13:24   #125
syss
syss's Avatar
Postovi: 10,805
ne želim ni pitatati kako i za šta ti fali
Staro 10.04.2012., 13:25   #126
Wolverine
Wolverine's Avatar
Postovi: 12,429
Autor Dottore Pregled postova
Na sluzbenom sajtu Gigabytea imaju sarolikih ploca. Npr.model UD3H sa i bez Wifi adaptera na pci-e x1 ( mini pci kartica u adapteru ).
Mogu oni imat i 101 verziju ploče kad i dalje imaju uvjerljivo najgori UEFI
Mark Twain
Intel Core i5 2520
8GB DDR3 Patriot
Intel HD3000
256GB LiteOn LMH-256V2M mSATA
NEC USB 3.0 ExpressCard
14" 1366x768
Windows 10 Pro x64
Gigabyte GTX 560Ti
DVD-RW LiteOn SATA
Corsair HX520
TT Chaser MK-1
Logitech MX3200
Windows 10 Pro x64
Intel DP67BG
Intel G1610
Hitachi 250GB
VTX3D HD6670
DVD-RW Asus SATA
FSP 350 PNF
CoolerMaster Cavalier
ViewSonic VX922
Win7 x64 SP1
Staro 10.04.2012., 13:31   #127
dean225
DD9512
dean225's Avatar
Postovi: 1,869
Autor syss Pregled postova
odgovorit cu ti.. Imam 1 ssd na sati3 i imam 1 sata3 green od 1tb (pun)
Ubo bi jos jedan isti green u neki raid ili nest ali nemam vise sata3.
Usb3.0 imam 2. Jedan koristim iskljucivo za mob (fast charge) i imam icy box spojen na usb 3.0.
Nije mi to neka velika investicija. Isao bi na neku plocu u ovom rangu koju imam, nista specijalno!
Plus sto me jako zanima kako funkcionira ovaj novi virtu, od ovog mog nemam koristi!
Staro 10.04.2012., 13:31   #128
zen_sux
zen_sux's Avatar
Postovi: 278
Oce Ausu Sabertooth P67 Rev. 3.0 bez problema udomiti ivy?
Pretpostavljam da ce trebati bios update, koji ne mogu napraviti bez sandy-a kojeg nemam?
zen_sux je offline   Reply With Quote
Staro 10.04.2012., 13:32   #129
Wolverine
Wolverine's Avatar
Postovi: 12,429
Autor dean225 Pregled postova
Zašto misliš da trebaš SATA3 konektor/kontroler za SATA3 HDD, posebice iz green serije?
Spoji ga na SATA2 i to je to.
Mark Twain
Intel Core i5 2520
8GB DDR3 Patriot
Intel HD3000
14" 1366x768
Windows 10 Pro x64
Gigabyte GTX 560Ti
DVD-RW LiteOn SATA
Corsair HX520
TT Chaser MK-1
Logitech MX3200
Windows 10 Pro x64
Intel DP67BG
Intel G1610
Hitachi 250GB
VTX3D HD6670
DVD-RW Asus SATA
FSP 350 PNF
ViewSonic VX922
Win7 x64 SP1
Staro 10.04.2012., 13:33   #130
syss
syss's Avatar
Postovi: 10,805
pa znao sam da ću požaliti pošto wd green i bilo koji drugi mehanički profitira od sata3 isključivo u ničemu
Staro 10.04.2012., 13:37   #131
dean225
DD9512
dean225's Avatar
Postovi: 1,869
a ono, vec kad je sata3 neka bude na sata3.. Ili, kupio bi neki mali sata3 ssd max60 gb i koristio ga kao IRST. Ovaj green me je blago razocarao sto se tice brzine. Puno je brzi na papiru nego svakodnevno. Ma imam kombinacija 100.
@zen_sux prerano je o tome govorit. Ivya nema jos ni u cpu support listi te ploce tako daa... Vjerovatno postojeci biosi nece upaliti ivy cpu. Morati ces posuditi sandya na 5 min.
EDIT: Ovo me zanima najvise..
http://www.youtube.com/watch?v=6OdoV...ature=youtu.be
Evo jos bolji video!! Moglo bi ovo bit korisno, pogotovo u laptopima..
http://www.youtube.com/watch?v=hvoMWXPzTlg
Zadnje izmijenjeno od: dean225. 10.04.2012. u 14:07.
Staro 10.04.2012., 13:42   #132
Elpresidente1
Datum registracije: May 2009
Postovi: 389
Khm, ali z77 ima isto samo 2 sata 3 kao i z68 i p67 h67 h77.
Elpresidente1 je offline   Reply With Quote
Staro 10.04.2012., 13:56   #133
Ranma 1/2
Anything Goes Martial Art
Ranma 1/2's Avatar
Lokacija: Tendo Dojo
Postovi: 542
err, nisam 100% siguran ali mislim da recenzija koju sam linkao govori baš o tome i koliko se da naslutiti razilka je minorna. možda zato jer još uvijek koriste SB procesor, ali dam se kladiti da i sa IB neće biti tolika razlika koliku reklamiraju. naravno daj bože da sam u krivu.
"Water! Why does it always have to be water?!"
Ranma 1/2 je offline   Reply With Quote
Staro 10.04.2012., 14:34   #134
Dottore
Dottore's Avatar
Postovi: 7,693
Napisao sam kao na primjer Nisam favorizirao nikakvu plocu. Mislim da ce pravi boom na trzistu igraci MSI, Asrock i Asus.
HP 845 G9
RAM: 64GB DDR5
Graphic: AMD Radeon
Staro 10.04.2012., 17:34   #135
FitzTN
FitzTN's Avatar
Lokacija: Samobor, HR
Postovi: 1,615
Ima li neko /po iskustvu/ neku ideju kada bi cca. mogli IB procesori doći u naše trgovine? Kupujem jedan ili dva nova kompa za ured, a ne žuri mi se previše, pa bi sačekao IB ili bar pad cijena SB-a
Staro 10.04.2012., 19:05   #136
Ranma 1/2
Ranma 1/2's Avatar
Postovi: 542
29. travanj je release date znači početkom 5. mjeseca, a možda će biti dućana koji će imati već prvi dan. svakome kome nije turska sila SAD kupiti novi procesor bi trebao sačekati izlazak IB. posebno mislim da će profitirati oni koji kupuju laptop.
Staro 12.04.2012., 21:35   #137
Doink the Clown
Jack of all, master of none
Doink the Clown's Avatar
Lokacija: Matulji - Rijeka
Postovi: 6,214
Intel to Bring Ivy Bridge Launch Forward to April 23: Report
With eager OEMs such as ASUSTek, HP, Acer, and Lenovo breathing down its neck, Intel is reportedly pulling forward the official launch date of its 3rd Generation Core processor family based on 22 nm "Ivy Bridge" silicon, to the 23rd of April, from its older date of 29th April. 23rd April will be the day Intel announces all its processor models originally slated for the 29th.
Notebook OEMs are expected to launch their products based on these chips at the earliest, by May. The date of market-availability of these chips in the retail channel, however, remains unclear. One possibility is that Intel will announce and make these chips available on the same day (23rd), while another possibility is that it announces these chips on the 23rd, allows the media to digest them (by posting reviews), and open them up for sale on the 29th. Two models every PC enthusiast and their cat are looking out for, are the Core i7-3770K and Core i5-3570K.
http://www.techpowerup.com/164061/In...23-Report.html
C L O W N I N G A R O U N D
Staro 14.04.2012., 10:07   #138
timmy
timmy's Avatar
Lokacija: N/A
Postovi: 1,242
Zadnje izmijenjeno od: timmy. 14.04.2012. u 12:40.
timmy je offline   Reply With Quote
Staro 14.04.2012., 16:56   #139
Ranma 1/2
Ranma 1/2's Avatar
Postovi: 542
dok čekamo prve primjerke evo usporedbe iz svijeta prijenosnika: i7-2960XM vs i7-3820QM
sukladno očekivanjima. oko 10% bolje performanse procesora na stocku, ali zato puno veći napredak sa novom intelovom integrušom. kad se u igru ubaci dedicirana mobilna grafika razlika nije velika.
Staro 14.04.2012., 17:10   #140
KorisNick
Datum registracije: Aug 2010
Lokacija: daleko, daleko iza 9 sela, daleko sam ja...
Postovi: 260
Koliko je poželjno imat ovakve temperature na 4.0Ghz, 52-53-54? Odnosno jesu to dobre temperature, za tu brzinu rada.
KorisNick je offline   Reply With Quote
Staro 14.04.2012., 18:15   #141
Ranma 1/2
Ranma 1/2's Avatar
Postovi: 542
meni se to čini kao sasvim ok vrijednost. dok ovo tipkam radim na laptopu sa T4500, dakle 45 nm proces, i temperature su oko 45 stupnjeva dok je idle. ovih 52-55 dok je pod overclockom mi se čini normalnim za IB
Staro 18.04.2012., 15:16   #142
Doink the Clown
Postovi: 6,214
Core i7-3770K Retail Boxes Pictured, TDP 95W, Overclocks Worse Than Sandy Bridge?
Here are the first pictures of retail boxes of Intel's Core i7-3770K "Ivy Bridge" processors in the LGA1155 package. Pictured below are boxes sourced from a Chinese distributor. Regional branding aside, the box-art hasn't changed from that of the 2nd Generation Core processor family, even the die-shot CGI in the center hasn't changed, which is a missed opportunity. Intel could have used art inspired by the Ivy Bridge silicon, which could have helped identify the new chips easier. The box simply marks the model number "3770K" and socket type "LGA1155" on the key sticker.
The side sticker is where the action is. We know from countless earlier reports, including Intel's RetailEdge marketing material that the TDP rating of "Ivy Bridge" quad-core parts, including the i7-3770K, was rated to be 77W. The sticker on retail i7-3770K, however, tells a different story. The TDP is rated at 95W, on par with previous-generation parts such as i7-2700K. The S-spec number is revealed to be "SR0PL". Before such an important CPU launch as "Ivy Bridge", it's hard to control pre-launch proliferation of retail parts to people who are not NDA signatories. Such people have put the i7-3770K through overclocking, and voices are getting louder that the i7-3770K is a worse overclocker than previous-generation "Sandy Bridge". The chip was found to get too hot, too soon, when overclocking.
http://www.techpowerup.com/164411/Co...y-Bridge-.html
Staro 18.04.2012., 19:33   #143
kopija
DIY DILETANT
kopija's Avatar
Lokacija: Čistilište
Postovi: 3,698
A ja bio naumio danas otić po z77 ploču i ostatak "IB builda".
Možda ipak uzmem onaj 2600k na akciji u Protisu...
Ne samo veći TDP, nego i veće temperature i potrošnja.
Prošle godine fail sa chipsetom, ove godine fail sa procesorom...
Zadnje izmijenjeno od: kopija. 18.04.2012. u 20:02.
Staro 19.04.2012., 00:06   #144
DuHc
DuHc's Avatar
Lokacija: Dubrovnik
Postovi: 204
DuHc je offline   Reply With Quote
Staro 19.04.2012., 00:25   #145
MAGARAC
MAGARAC's Avatar
Postovi: 5,992
Cuo sam jos ranije da nisu nista bolji od SBa za 24/7 OC ali se to pripisivalo ES primjercima. Nije bas dobro da ni prvi retail procevi nisu nista bolji. U extremnom OC su vecinom preko 6hgz ali i skloni degradaciji pa ih treba stedit.
Ovo sa 95w po meni nije nista lose i vise, manje nebitno.
MAGARAC je online   Reply With Quote
Staro 19.04.2012., 02:50   #146
suedamA obmaR
Game, PC ,motobikes, bike
suedamA obmaR's Avatar
Datum registracije: Jan 2010
Lokacija: Sibenik
Postovi: 778
Magarac, šta znači ovo skloni degradaciji, kako se to manifestira?
suedamA obmaR je offline   Reply With Quote
Staro 19.04.2012., 03:15   #147
KorisNick
Postovi: 260
A ja stvarno nemam previše razumjevanja, za one koji procesor ganjaju preko 5Ghz. Mislim to je toliko nepotrebno, da nije uopće ni čudno da proc doživi degradaciju pri tolikom OC. Za većinu stvari danas, 4.5Ghz je i više nego dovoljno. S time da je 5Ghz, extremni OC trenutno. Preko toga tko ide, stvarno nema previše razuma. Em što radikalno diže temperaturu procesora, em što mu za korištenje bilo kojeg programa i igre to nije potrebno. Al ne kaže se uzalud, sto ljudi sto ćudi.
Staro 19.04.2012., 10:06   #148
Nick7
Lokacija: Velika Gorica
Postovi: 1,532
Pa kak' ne ku'is... bitno je da se Firefox otvori 14μs brze, ili da min FPS poraste sa 180 na 193FPS!
Staro 19.04.2012., 11:13   #149
Bullet1
Bullet1's Avatar
Lokacija: Dubrovnik
Postovi: 2,583
Autor suedamA obmaR Pregled postova
S vremenom postane žedniji odnosno traži veći napon za rad na istoj frekvenciji pa je moguće da i ne postigneš opet istu tu frekvenciju.
Nebitno za nekog tko neće davat 1.6v+
Staro 19.04.2012., 11:27   #150
Lewis
Freelancer
Lewis's Avatar
Lokacija: Bilje (Osijek)
Postovi: 5,323
Autor KorisNick Pregled postova
Autor Nick7 Pregled postova
Nebih se slozio s ovim, svakih 100Mhz gore se osjeti (na ovim sadasnjim Quad/six core 8/12T CPUovima) ubrzanje u renderu, a nebi vjerovo ali svaka sekunda/minuta tamo puno znaci jer ako ti se frame renda 10min ili 11min nije svejedno, ako trebas 30 sekundi animacije racunica je ovakva.
30sec*25fr=750 frameova * 10 min = 7500min = 125h
30sec*25fr=750 frameova * 11 min = 8250min = 137,5h
znaci "ustedis" 12.5 sati oliti vise od pola dana .
OnTopic - posto je IB ionako predvidjen za dobar dio 1155 ploca ljudi ce ga svejedno kupovat ako nista drugo intel ce namjerno polako izbacivati SB tak da nece ni biti neke velik mogucnosti odabira. Mozda SB postane "ekskluziva" za godinu dana pa poskupe ako se IB pokaze losim overclockerom .
