Staro 22.03.2012., 01:26   #2461
gsxr750k9
Datum registracije: Apr 2011
Lokacija: Agram
Postovi: 603
s bnetom prica ista kao i prije...nista novog sto se tice preopterecene mreze...
lovci u mutnom...
o programskoj shemi ne zelim ni govoriti jer se ista svakodnevno smanjuje...postojeci programi upucavaju se u kojekakve izmisljene pakete..informativni, sportski..balkanski..o cijenama i kvaliteti istih bolje da ne govorim...
sramota.
evo tih famoznih paketa pa mi molim vas recite ko je tu lud:
<table class="renderedtable" cellpadding="2" cellspacing="0" width="100%"><tbody><tr><th valign="top"> INFORMATIVNI PAKET </th><th class="centriranisadrzaj" colspan="2" valign="top" width="60%"> Cijena (mjesečno) </th></tr><tr class="bglight"><td valign="top"> </td><td class="centriranisadrzaj" valign="top" width="30%"> 30,74 kn </td><td class="centriranisadrzaj" valign="top" width="30%"> 15,37 kn* </td></tr><tr class="bgdark"><th valign="top"> SPORTSKI PAKET </th><th class="centriranisadrzaj" colspan="2" valign="top" width="60%"> Cijena (mjesečno) </th></tr><tr class="bglight"><td valign="top"> </td><td class="centriranisadrzaj" valign="top" width="30%"> 40,99 kn </td><td class="centriranisadrzaj" valign="top" width="30%"> 20,49 kn* </td></tr><tr class="bgdark"><th valign="top"> DJEČJI PAKET </th><th class="centriranisadrzaj" colspan="2" valign="top" width="60%"> Cijena (mjesečno </th></tr><tr class="bglight"><td valign="top"> </td><td class="centriranisadrzaj" valign="top" width="30%"> 30,74 kn </td><td class="centriranisadrzaj" valign="top" width="30%"> 15,37 kn* </td></tr><tr class="bgdark"><th valign="top"> GLAZBENI PAKET </th><th class="centriranisadrzaj" colspan="2" valign="top" width="60%"> Cijena (mjesečno) </th></tr><tr class="bglight"><td valign="top"> </td><td class="centriranisadrzaj" valign="top" width="30%"> 30,74 kn </td><td class="centriranisadrzaj" valign="top" width="30%"> 15,37 kn* </td></tr><tr class="bgdark"><th valign="top"> BALKANSKI PAKET </th><th class="centriranisadrzaj" colspan="2" valign="top" width="60%"> Cijena (mjesečno) </th></tr><tr class="bglight"><td valign="top"> </td><td class="centriranisadrzaj" valign="top" width="30%"> 40,99 kn </td><td class="centriranisadrzaj" valign="top" width="30%"> 20,49 kn* </td></tr><tr class="bgdark"><th valign="top"> PAKET ZA ODRASLE </th><th class="centriranisadrzaj" colspan="2" valign="top" width="60%"> Cijena (mjesečno) </th></tr><tr class="bglight"><td valign="top"> </td><td class="centriranisadrzaj" valign="top" width="30%"> 40,99 kn </td><td class="centriranisadrzaj" valign="top" width="30%"> 20,49 kn*</td></tr></tbody></table>hahaah ovo se samo u hrvatskoj moze naplacivati.
gsxr750k9 je offline   Reply With Quote
Staro 26.03.2012., 04:31   #2462
Vivaldi
Postovi: 5
Thomson TWG 850-4
Autor Maxim Pregled postova
Samo si pobogu nikada nemoj uzimati Carnet s tim uvijek i brdo problema, većinom, a većinom je greška kod računala i to takva sitnica s kojom se zezate nekoliko sati... Običan 3D paket ne biti škrt dati 30-ak kn više a imati bolji net
Ovako:
Činjenice:
1) imam Thomson TWG 850-4
Da li mi je potreban update firmwarea? Naime, možda mi ponekad se desi da izgubim konekciju , ali ako se to i desi, vrlo brzo se vrati, ali generalno sam veoma zadovoljan uslugom.
2) koristim Bnet standardni (ugovor potpisan 03.03 2009., uključeno 14.04.2009.), Thomsona sam platio odjednom platio pri zasnivanja ugovora, pa nemam mjesečni trošak najma.
3) imam stolno računalo, te se zna nakačiti 2 laptopa i 2 mobitela, sve uredno radi, kao urica.
Sad sam se malo zainteresirao za CARNet 3D, 35kn jeftinije me cima, iako sam i pri potpisivanju ugovora znao za shemu s njihovim modemom i mojim routerom, nije mi se tada dalo zezati s time.
Mene sada zanima, da li bih mogao ovaj njihov router iskoristiti ikako, ili bih morao dotičnog vratit (iako sam ga otplatio uodjednom), te bi mi oni dali samo modem, pa ja naknadno uzeti svoj router da bih mogao više računala koristiti na 3D CARNetu.
Ili, kako sada na
http://www.bnet.hr/paketi/3dcarnet#?...1&p1=bh-item-4
nude Bežični (WLAN) modem/router s 4-port switchem**
507,11 kn
a toliko sam ja platio svoj thomsona, možda je moguća kombinacija da zamjenim svog thomsona za novog kojeg bi mogao podesiti na 3D CARNet uz nadoplatu od 61,47 kn.
Ovo pretpostavljam u slučaju da ne mogu svog Thomsona namjestiti da mi bude jedini uređaj.
Mrzim redudanciju, odbija me pomisao o dodatnom uređaju, mada je to možda jedino rješenje.
Kao što vidite, možda je bilo najbolje da sam počeo post s pitanjem da li mogu uz jedan uređaj (zamjena starog, firmware starog promjeniti, ...) i dalje imati nesmetano spajanje više računala, uz manji mjesečni trošak...
Oprostite što sam razduljio, ali mislim da želim biti jasan u onom što želim...
Vivaldi je offline   Reply With Quote
Staro 26.03.2012., 09:06   #2463
gnjepar
gnjepar's Avatar
Postovi: 642
Autor Vivaldi Pregled postova
Konkretan odgovor na tvoje pitanje je NE. Ako želiš Carnet u kombinaciji sa B.net-om onda moraš imati minimalno dva uređaja da bi se mogao spajati sa više računala.
The Truth
gnjepar je offline   Reply With Quote
Staro 05.04.2012., 21:11   #2464
alen.s
alen.s's Avatar
Postovi: 1,441
niko ništa ne žuga odavno....izgleda da su svima sredili sve prob.....super - nek tako i ostane ( bar do novog dizanja brzine )
Staro 20.04.2012., 15:03   #2465
Delpiero
Delpiero's Avatar
Datum registracije: Aug 2008
Lokacija: Split, Croatia
Postovi: 380
Imam problem, pred godinu dana sam kupio KONAX-ov modula koji sam ukljucio u svoju TV(Panasonic S20) i s njim sam izbacio veliku Bnet-ovu "kutiju" koja mi je smetala u prostoriji i nisam imao prostora za nju(i jos sam morao koristiti nepotrebno 2 daljinska upravljaca).
Modul je godinu dana radio kako treba, sve dok se pred nekoliko dana nije dogodilo to da je na svim programima(osim hrvatskih nekoliko) pojavila crna slika i natpis "Nema signala".
Agenti iz sluzbe za korisnike su mi rekli da je mijenjana enkripcija i da radi toga isti modul vise ne radi. Zanima me dali se moze i na kakvim mjestima izvrsiti upgrade softwarea tih modula ili sta da radim?
Pomoc malu bih molio!
Delpiero je offline   Reply With Quote
Staro 20.04.2012., 15:04   #2466
Thermaltake
1
Thermaltake's Avatar
Postovi: 3,629
http://www.bnet.hr/podrska/obavijesti_administratora
odskorolaj malo niže ima o tome vijest.
Staro 20.04.2012., 17:15   #2467
Delpiero
Delpiero's Avatar
Postovi: 380
Hvala
Staro 21.04.2012., 13:16   #2468
dani9
Datum registracije: Mar 2011
Postovi: 82
Ja si mislim kupit cam modul za tv, pa ako moze neko preporucit neki koji radi sa bnetom nakon ove promjene. Hvala
dani9 je offline   Reply With Quote
Staro 21.04.2012., 13:32   #2469
IcyTexx
IcyTexx's Avatar
Postovi: 4,707
Autor alen.s Pregled postova
Ljudi se zale dok je gadno, kad je kak treba onda je to to... Nit se mos zalit nit se mos hvalit.
Staro 25.04.2012., 17:27   #2470
Delpiero
Delpiero's Avatar
Postovi: 380
Kako sam vec ranije napisao, imam problem s "starijom" verzijom CONAX modula, koja se nemoze update-ati, i sada su mi, nakon promjena sa signalom BNeta, nestali svi programi i piše kako "Nema Signala".
Odlucio sam se za kupovinu novog modula i trebao bi mi savjet gdje da kupim i kakav tocno modul a da mogu sa sigurnoscu pratiti BNetov program(ukljucujuci i HD programe na koje placam pretplatu). Procitao sam na Bnet-ovoj stranici da trebaju imati moduli neku " simulcrypt " podrsku a o tome ne znam puno..
Molim savjet..
Hvala unaprijed!
Zadnje izmijenjeno od: Delpiero. 26.04.2012. u 15:09.
Staro 25.04.2012., 20:54   #2471
Mileni
Mileni's Avatar
Postovi: 1,554
Kakav je BNET po pitanju sluzbe za korisnike po vasem iskustvu?
Imam trenutacno vezano za TV jednu smijesnu scenu sa njima, pa me samo to zanima.
Zahvaljujem na odgovorima
Staro 25.04.2012., 21:12   #2472
njuskalo
njuskalo's Avatar
Lokacija: Remetinec
Postovi: 925
Po mom iskustvu, grozan. Od kraja 11. mjeseca se natežemo s njima da se priključak prebaci s preminule bake na nasljednika i da se promjeni usluga sa 2d tel+TV na 2d internet+TV. Uspjeli su prebacit priključak i sad već 3 mjeseca šalju račune na 0 kuna jer u stanu nema ni TV-a ni telefona ni interneta. Nitko ništa ne javlja, a ja više ni ne zovem. Rekli smo podstanaru da ih zove i vidi kaj je s tim...
njuskalo je offline   Reply With Quote
Staro 25.04.2012., 21:21   #2473
Mileni
Mileni's Avatar
Postovi: 1,554
Ja kod njih uzeo TV u 11. mjesecu prosle godine. Sve ok, nisam ni ocekivao cuda. TV ko TV (malo los uredjaj, no ajde). Onda su idioti u mojoj ulici na Vrbanima (Trpanjska) prokopali kablove pogreskom dok su radili na staroj cimosovoj zgradi.
Ajde, ostao i bez neta i bez tv-a. Net imam preko amisa, dakle kod bneta sami tv.
I do dana danasnjeg tv mi nije proradio, a kanali prokopani prije 2 mjeseca. Amis je proradio nakon nekih tjedan dana, dakle oni su to u nekom normalnom vremenskom roku rijesili.
Sve bi bilo ok da meni SZK ne spominje da nisu imali prokopane kanale, i da usluga uredno radi (?????!). Mislim, pricao sam sa SZK prije nekih mjesec i pol zadnji puta, sredit ce kao uskoro. No sada tvrde da se scena sa prokopanim kanalima i pokidanim vodovima od bneta uopce nije odigrala? )))
Staro 26.04.2012., 12:15   #2474
VoodooRain
VoodooRain's Avatar
Lokacija: Požega
Postovi: 706
imam pitanje vezano za ovu reklamu sada sto vrte da za istu cijenu mozes dobiti vise recivera u kuci jel se to odnosi samo na one sto primaju signal kablom ili i za satelitske korisnike stari totaltv
posto kod mene nema kablova njihovis isao bi na satelitsko ima curka i po meni cist dobri programi za te pare
VoodooRain je offline   Reply With Quote
Staro 28.04.2012., 01:01   #2475
JuiceBox
Xulos :)
JuiceBox's Avatar
Postovi: 7,581
Gledao sam u cjeniku al nigdje nemogu naci koja je cijena osnovnog neta ( 6mbps ) ali bez ugovorne obveze ? i za koliko dodju otprilike postaviti instalacije ?
Staro 28.04.2012., 12:01   #2476
vedran031
vedran031's Avatar
Postovi: 549
Bolje da neznas 1523kn bez ugovora a 1015 na 12mj ugovor
vedran031 je offline   Reply With Quote
Staro 28.04.2012., 20:50   #2477
JuiceBox
Xulos :)
JuiceBox's Avatar
Postovi: 7,581
Cek ti oces rec da ja moram dat 1015 kn u startu u kešu plus ugovor na 12 mj ?to je nemoguce... Kablovi su provuceni, samo treba doc stavit ruter i da zato treba platit 1000 kn? Prije je bilo 300 kn jednokratno ruter plus normalna mjesecna cifra.
Staro 28.04.2012., 21:56   #2478
vedran031
vedran031's Avatar
Postovi: 549
Staro 29.04.2012., 00:56   #2479
pinkskin
pinkskin's Avatar
Lokacija: Daruvar
Postovi: 1,747
WTF, prije je bilo 200kn platiš i nemaš ugovorne obveze, sad 1500.
pinkskin je online   Reply With Quote
Staro 29.04.2012., 04:19   #2480
IcyTexx
IcyTexx's Avatar
Postovi: 4,707
Na sve kaj uzmes te vezu ugovorom. Nemres povecat brzinu na 20 mbit bez da te vezu ugovorom za tih 20 mbit na godinu dana.
Staro 30.04.2012., 11:43   #2481
JuiceBox
Xulos :)
JuiceBox's Avatar
Postovi: 7,581
Neka hvala, 1500 u dzep, backtrack ftw...
Staro 02.05.2012., 19:22   #2482
njuskalo
njuskalo's Avatar
Lokacija: Remetinec
Postovi: 925
Autor njuskalo Pregled postova
Evo konačno se saznalo o čem se radi. Naime, navodno nisu imali OIB od novog vlasnika priključka (dan im je jednom mailom, jednom telefonom i jednom osobno agentu kad je došao da se potpišu sve te *izdarije), ali ok, nema veze. Sve što su trebali je nazvat i tražit da im se da ponovo. Ukupno je oavljeno 16 poziva prema njihovoj korisničkoj službi i da nisu mogli niti jednom nešto konkretno reći. Sad su rekli da će se to brzo spojit, na što smo mi zatražili raskid ugovora. Nikad više na bnet, i naravno da ću svima koji me pitaju savjetovat isto.
Staro 03.05.2012., 13:53   #2483
Bono
Uptime 99.99%
Bono's Avatar
Postovi: 2,774
Ma Bnet je dobar samo za nekog tko nije zahtjevan, tipa hoce surfati i skidati torrente, za sve ostalo je smece. Evo u par dana na sto sam naisao, najveci problem je sto ne mozes raditi u SSH, non stop timeouta konekcije, remote desktop isto tako, a o Cisco VPN-u da ne pricam, moram preko remote desktopa raditi. Sve u svemu jad od mreze i dobar je samo za onog kome treba upload za torrente.
Staro 03.05.2012., 13:56   #2484
domy_os
domy_os's Avatar
Postovi: 19,018
Znači, nisam jedini koji ima problema s remote desktopom??? Opet sam mislio da je problem do mene lokalno. Nevjerojatno, počinju mi se gaditi...
RAM: 2 x 16 GB DDR4-3200
WLAN: Intel Wi-Fi 6 AX201
LCD monitor: AOC AG493UCX
SB: Mackie Onyx Producer 2x2
Speakers: 2 x JBL LSR305
MFP: Canon Pixma MP240
Staro 03.05.2012., 13:58   #2485
Bluzer
Bluzer's Avatar
Lokacija: localhost
Postovi: 1,075
Autor Bono Pregled postova
SSH mi radi najnormalnije, koristim seedbox (pa i remote desktop) jer sam na xcarnetu što je teoretski otegotna okolnost... epc2203 + tp-link tl-wr1043nd... Ako je i kod tebe seedbox u pitanju, onda promijeni seedbox providera jer sam bio na jednom na kojemu također ssh, remote i vpn nisu radili kako spada.
Zadnje izmijenjeno od: Bluzer. 03.05.2012. u 14:43.
Staro 03.05.2012., 13:59   #2486
Bono
Uptime 99.99%
Bono's Avatar
Postovi: 2,774
Autor domy_os Pregled postova
Doma imam Amis, a tu sam kod brata na Bnetu, sve zive konekcije timeoutaju, to je definitivno njihov problem.
Staro 03.05.2012., 14:28   #2487
the.elles.d
Datum registracije: Jul 2010
Postovi: 561
SSH radi normalno, RDP također, a bome i Cisco VPN. Svakodnevno koristim sve navedeno
the.elles.d je online   Reply With Quote
Staro 03.05.2012., 14:31   #2488
Bono
Uptime 99.99%
Bono's Avatar
Postovi: 2,774
Autor the.elles.d Pregled postova
I ja na Amisu, u Splitu na Bnetu eto ne radi.
Staro 03.05.2012., 17:13   #2489
domy_os
domy_os's Avatar
Postovi: 19,018
Meni VPN radi, a RDP štuca. Nekad bude sve OK, a nekad kad se spojim dobijem black screen pa zamrzava, puca itd.
Staro 03.05.2012., 20:05   #2490
Bono
Uptime 99.99%
Bono's Avatar
Postovi: 2,774
Radi meni isto VPN, samo ako ostavim malo vezu i idem nesto ucitati onda mi timeouta. U svakom slucaju nije bas previse upotrebljivo.
