Staro 19.01.2012., 10:28   #181
Doink the Clown
Jack of all, master of none
Doink the Clown's Avatar
Lokacija: Matulji - Rijeka
Postovi: 6,214
Cooler Master Unveils the X6 and X6 Elite CPU Coolers
Cooler Master, an industry leading enclosure, thermal solution, peripheral, and accessory manufacturer, showcases a tribute to their effort to continually innovate. The X6 CPU Cooler has arrived and is a daring new take on high performance cooling and design.
Bold Design and Innovative Features
Designed for overclockers and gamers, X6 is adorned in a satin black finish with crimson red fan blades and accents. The heatsink employs a unique honeycomb fin structure to maximize surface area for cooling. This is used in conjunction with an angled base that acts as a means to increase overall airflow throughout the chassis. Clever air duct deployment on the outer shell directs airflow to pass over critical cooling areas. X6 also comes equipped with a high performance PWM controlled fan that can be adjusted via BIOS or OS-based motherboard tuning applications.
Quick-snap for Easy Maintenance and Installation
Ease of use is often applied to mounting systems or other system components, but fan attachment can wind up being neglected. X6 breathes new life into this lost path by coming with time-saving quick-snap fan brackets that make installation and removal a simple affair. These quick-snap brackets means that fan maintenance times will become significantly shorter. Simply release a few tabs and the fan is free to be cleaned. Reattach everything in a few seconds and go back to enjoying the immense cooling power of the X6.
Gaming on a Budget
X6 Elite, the answer to building the best looking and performing gaming system on a budget. Much like Cooler Master Elite Series cases represent the best value for dollar in DIY system building, X6 Elite joins the fray to do the same for CPU Cooling in the U.S. and Canada. It focuses less on aesthetic flair and incorporates minor changes to performance to achieve a well balanced setup. Whichever the choice may be, X6 and X6 Elite represent excellent choices for users of every level.
Specifikacije u sklopu tablica u linku:
http://www.techpowerup.com/158953/Co...U-Coolers.html
C L O W N I N G A R O U N D
Staro 19.01.2012., 10:36   #182
Postovi: 8,259
Zanimljivo nadasve, sam koja svrha hladnjaka kad je s druge strane mala turbina. Mogli su to nekako rješit drugačije da taj hladnjak makar nećem služi. Ovo je fial ovako
Staro 21.02.2012., 22:27   #183
Doink the Clown
Postovi: 6,214
Noctua Presents the NH-L12 Low-Profile CPU Cooler
Noctua today presented its new NH-L12 low-profile cooler for Small Form Factor cases and HTPC environments. The NH-L12 features a flexible NF-F12 (120 mm) / NF-B9 (92 mm) dual PWM fan setup that can be configured either for full performance in dual fan mode or extra-low profile (66 mm) with the top fan removed.
"The industry trend towards Small Form Factor and Home Theatre PCs is well-established, but there's still a lack of suitable high-quality quiet CPU coolers", explains Mag. Roland Mossig, Noctua CEO. "Building a powerful PC always requires a capable CPU, which in return demands a competent cooling solution. But who wants his HTPC to sound like a jet engine? This is precisely where the NH-L12 steps in."
Thanks to its exquisite dual fan setup consisting of Noctua's highly optimised NF-F12 (120 mm) and NF-B9 (92 mm) premium fans, the NH-L12 pushes the bar in terms of low-profile quiet cooling performance. Alternatively, the NH-L12 can also be used with the NF-B9 92 mm fan only in order to reduce the overall height to 66 mm. This way, the cooler is suitable for many typical µATX or Mini-ITX enclosures and ideal for whisper-quiet HTPC systems.
The NH-L12's NF-F12 and NF-B9 fans support PWM for convenient automatic speed control. In addition, the maximum fan speed can be reduced to 1200/1300 rpm using the supplied Low-Noise Adaptors for even quieter operation. Bundled with the award-winning NT-H1 thermal compound and Noctua's SecuFirm2 multi-socket mounting system, the NH-L12 packs everything a premium quality quiet cooler needs into a highly compact package.
Price and Availability
The NH-L12 will be available immediately at a recommended retail price of EUR 49.90 / USD 59.90.
http://www.techpowerup.com/160955/No...PU-Cooler.html
Staro 27.03.2012., 21:57   #184
Doink the Clown
Postovi: 6,214
Arctic Reveals the Accelero Xtreme III VGA Cooler
The Arctic team has now confirmed that a new Accelero Xtreme VGA cooler is in the works and will reach stores in late May. Known as Accelero Xtreme III, the incoming product has a cooling capacity up to 300 Watts, it measures 288 (L) x 103 (W) x 50 (H) mm, and has 84 aluminum fins, five 6 mm copper heatpipes, three 92 mm (Fluid Dynamic Bearing) fans working at 900 to 2000 RPM, and a copper base with pre-applied MX-4 thermal compound.
Arctic's cooler is backed by a six-year warranty and is compatible with the following cards:
- AMD Radeon HD 7870, 7850, 6970, 6950, 6870, 6850, 6790, 5870, 5850, 5830, 4890, 4870, 4850, 4830, 3870, 3850
- NVIDIA GeForce 580, 570, 560Ti, 560 SE, 560, 550Ti, 480, 460 SE, 460, 450, 250, 240 (OEM), 150 (OEM), 130 (OEM), 9800 GTX+, 9800 GTX, 9800 GT, 9600 GT, 9600 GSO 512, 9600 GSO, 9500 GT (not LP), 8800 Ultra (G80), 8800 GTX (G80), 8800 GTS 512 (G92), 8800 GTS (G92), 8800 GTS (G80), 8800 GT, 8800 GS (9600GSO), 7900 GTX, 7800 GTX 512, 7800 GTX, 7800 GT, AND custom GeForce GTX 680s that don't have a 'double deck power socket' (unfortunately the AX III is of no use on stock cards).
The Accelero Xtreme III is set to become available on May 21st, priced at $119.95 / €90.41.
http://www.techpowerup.com/163112/Ar...GA-Cooler.html
Staro 27.03.2012., 22:05   #185
Postovi: 8,259
Sva sreća pa je skoro identičan starom Xtreme+, osim što dolazi odmah s mounting plateom za sve grafe i netreba ga kupovat zasebno, al bitno da je cijena odmah duplo veća
Staro 27.03.2012., 22:52   #186
Dottore
Dottore's Avatar
Postovi: 7,735
Uh, previše je. ^^
HP 845 G9
CPU: AMD Ryzen 7 PRO 6850U
RAM: 64GB Samsung DDR5 4800
Graphic: AMD Radeon 680M
LCD: 14" IPS @ 1920 x 1200
OS: Windows 11 Pro 25H2
Mice: Logitech MX Master 3S
Lenovo ThinkPad P15v Gen 3
CPU: AMD Ryzen 7 PRO 6850H
RAM: 64GB DDR5
Graphic: AMD Radeon
LCD: 15" IPS @ 3840x2160
Lenovo ThinkPad T14 Gen 5
CPU: AMD Ryzen 7 PRO 8840u
RAM: 64GB DDR5
SSD: Kioxia XG8 1 TB NVMe M.2
Graphic: AMD Radeon 780M
Mice: Logitech VX Nano
Lenovo X1 Carbon 7th Gen
CPU: Intel Core i7-8665U
RAM: 16GB soldered LPDDR3
Graphic: Intel HD 620
LCD: 14" IPS @ 2560x1440
Lenovo X1 Carbon 10th Gen
CPU: Intel Core i7-1260p
RAM: 16GB soldered LPDDR4
SSD: Sk Hynix 512 GB NVMe M.2
Graphic: Intel Iris Xe
LCD: 14" IPS @ 1920x1200
Staro 22.05.2012., 09:31   #187
Doink the Clown
Postovi: 6,214
Koolance Rolls Out GeForce GTX 690 Water Block
Koolance has now made available the VID-NX690 water block which is compatible with NVIDIA's dual-GPU beast, the GeForce GTX 690. This full cover block measures 25.40 x 12.70 x 1.91 cm, it weights 1.02 kg, and features G 1/4 BSP threading and a nickel-plated solid copper base boasting a high-performance microfin (0.5 mm) design.
The VID-NX690 is currently in stock and costs $144.99.
Staro 08.06.2012., 22:27   #188
Dottore
Dottore's Avatar
Postovi: 7,735
Noctua shows off noise-cancelling PC fan prototype http://t.co/sGf5ObCh
HP 845 G9
RAM: 64GB DDR5
Graphic: AMD Radeon
RAM: 64GB DDR5
Staro 13.06.2012., 22:40   #189
Doink the Clown
Postovi: 6,214
Prolimatech Black Series Genesis CPU Cooler Launched
Prolimatech, the master of cooling is going a step further after the success of the Prolimatech Megahalems by presenting another revolution in CPU cooling with the limited edition Prolimatech Black Series Genesis. Besides the immaculate quality - which is present across their entire product line-up - the Black Genesis sets new standards in cooling capability and cool looks.
Prolimatech continues the trend set by the Megahalems and Super Mega by utilising two separate towers, but instead of placing them next to each other, they have been rearranged for maximum performance. The large array of cooling fins can hold up to three 120 or 140 mm fans, two of which can be installed right out of the box with the included mounting materials. Besides keeping the CPU cool, the construction allows for direct air flow across critical areas like the memory and power phases of the system.
Due to the innovative construction, Prolimatech manages to raise the bar and cool down the CPU even more. Adding to the excellent performance, Prolimatech has included additional black mounting screws to add further contact pressure, which translates into even lower operational temperatures. The use of these screws is intended for experienced users, which aim to get the most out of the cooling solution, as the pressure surpasses the Intel specifications.
Overclockers will be happy to hear that Prolimatech continues the trend and allows for complete choice of fans, as none are supplied with the cooler. This enables every user, regardless of their preferences or needs, to select the right models to equip the Black Genesis. Even when only using a single 120 or 140 mm fan, the Black Genesis manages to cool the CPU and keep the noise level at a minimum.
The Prolimatech Black Genesis also features broad compatibility as it ships with an AMD mounting kit intended for all modern sockets like AM2, AM2+ and AM3. Intel users will also be able to mount the cooler with the included kit for Socket 775, 1155, 1156, 1366 and 2011. To enable the most efficient transfer of heat between the CPU and Black Genesis cooler, Prolimatech supplies their high-performance PK-1 thermal paste, while a sturdy backplate guarantees a stable hold, taking the strain off the mainboard and socket.
The Prolimatech Black Series Genesis is available for pre-order with a price tag of £59.90 exclusively at www.overclockers.co.uk.
http://www.techpowerup.com/167632/Pr...-Launched.html
Staro 26.06.2012., 10:20   #190
RaneZ
Vršni visioc
RaneZ's Avatar
Postovi: 2,210
Sandia CPU cooler 30x better heat transfer
http://youtu.be/JWQZNXEKkaU
Bez potpisa.
Staro 07.07.2012., 21:19   #191
Doink the Clown
Postovi: 6,214
Colorful Shark Bionic Cooler Detailed
Colorful released pictures of its new Shark Bionic graphics card cooling solution, which will feature on the company's upcoming GeForce GTX 670 iGame Ares X graphics card. The designers seem to have opted for a more conventional-looking dual-slot cooling solution (judging by its standards, at least). The Shark Bionic cooler uses a compound heatsink design. At a nickel-plated copper GPU base, nine 8 mm-thick heat pipes of the same material make indirect contact with the GPU. The heat pipes then transport heat to three aluminum fin stacks, one directly over the GPU base, one over the VRM area, and a smaller one along the top of the card. The three are ventilated by two 80 mm fans. The design of the cooler shroud and fan blades are inspired by the shark, which work to guide the most amount of air with the least turbulence (resulting in less noise).
http://www.techpowerup.com/168625/Co...-Detailed.html
Staro 29.10.2012., 00:01   #192
bahrija30
bahrija30's Avatar
Datum registracije: Dec 2009
Lokacija: KOPRIVNICA
Postovi: 272
Autor RaneZ Pregled postova
ovo je slično hlađenju motorke(motorne pile),ili skuteru onaj propeler na magnetu
Što ga više lome-to ga više volim!
bahrija30 je offline   Reply With Quote
Staro 12.11.2012., 23:28   #193
Doink the Clown
Postovi: 6,214
Thermalright Readies the Archon SB-E X2 CPU Cooler
Thermalright is now preparing the release of the Archon SB-E X2, a CPU cooler 'optimized' for high TDP chips like Intel's Sandy Bridge-E models. Seen below, this new Archon measures 155 (L) x 106 (W) x 170 (H) mm and features a mirrored copper base, eight 6 mm heatpipes (with a sintered heatpipe design), and two TY-141 PWM fans working at 900 to 1,300 RPM (max sound output is 21 dBA).
The Archon SB-E X2 supports Intel LGA 2011/1366/1155/1156/775 and AMD Socket FM1/AM3+/AM3/AM2+/AM2/939 processors and is bundled with Chill Factor3 thermal paste. No word on pricing yet.
Staro 30.11.2012., 15:58   #194
mamutarka
ODUZIMAM VAM RIJEČ
mamutarka's Avatar
Postovi: 13,601
Staro 30.11.2012., 16:39   #195
MAGARAC
MAGARAC's Avatar
Postovi: 5,997
To se nas previse ne tice. Nalsov ime je .....
Scythe Restructures U.S. Operation, Won't Leave
Jer se sjeca ko one trgovine u Sigetu od kud je krenuo Scyhte u HR, kak se to zvalo..
Staro 30.11.2012., 16:50   #196
ShanTech
Datum registracije: Apr 2011
Postovi: 3,784
Zola?
Staro 30.11.2012., 16:58   #197
MAGARAC
MAGARAC's Avatar
Postovi: 5,997
Je, svaka cast. Nisam se mogo sjetit nikako. Bili su mi smipa i tam sam kupio Katanu i jos jedan njihov hladnjak.
Staro 30.11.2012., 23:18   #198
ThePornstar
ThePornstar's Avatar
Postovi: 4,403
Smeće od članka!
Ne prestaje s poslovanjem, nego su izgubili najvećeg distributera u Sjevernoj Americi i traže novog.
Official statement for Scythe US office reorganization
(1)
The Scythe US office is managed separately from the Scythe Group. The mother
company of the US office had to close, resulting in the Scythe US office to close.
(2)
Other offices are not affected and will do business as usual.
(3)
Until a new US office is established or a main distributor has been
organized for, the Taiwan office will take over Scythe US business activities.
Staro 15.12.2012., 03:47   #199
ThePornstar
Postovi: 4,403
SAPPHIRE VAPOR-X UNIVERSAL CPU COOLER
Sapphire se bacio i u hlađenja procesora
LINK
Staro 15.12.2012., 12:37   #200
asibulj
Misanthrope
asibulj's Avatar
Lokacija: Neumünster
Postovi: 571
CoolerMaster V6
asibulj je offline   Reply With Quote
Staro 22.01.2013., 23:01   #201
Enter Sandman
dark paradise
Enter Sandman's Avatar
Postovi: 557
Danas sam u links naletio na ovo:
Thermaltake
Test
Jel netko ima kakva saznanja ili ga posjeduje?
Enter Sandman je offline   Reply With Quote
Staro 06.04.2013., 21:57   #202
Drvoje
Split resist itself!
Drvoje's Avatar
Postovi: 4,037
Asetek tuži Coolermaster
Dakle kako naslov kaže (patenti vezani za vodena hlađenja zatvorenog tipa).
Asetek je zapravo proizvodi Corsairova vodena uz još par drugih (Antec, Zalman, Thermaltake...), a CM se drznuo sam proizvesti svoju Seidon seriju vodenih
http://www.eteknix.com/asetek-are-ta...infringements/
Pomelo mi sig -.-
Staro 06.05.2013., 21:53   #203
conan
conan's Avatar
Lokacija: Bjelovar
Postovi: 116
Second optional fan for cpu cooler
Pozdrav ljudi
Imam jedno pitanje ili bolje reći želim čuti Vaša uvažena mišljenja...
Imam cpu hladnjak coolermaster hyper 612s i sad sam ja sebi mislio, pošto dolaze topliji dani, ugradit drugi ventilator na taj hladnjak.
E sad pitanje! Pošto ovaj ventilator koji sam dobio s njim tjera zrak kroz ventilator, što je logično, jel ovaj drugi (opcionalni) treba isto tjerat zrak u hladnjak (kroz hladnjak) ili ga bolje okrenut tako da izvlači zrak iz hladnjaka?
Koje je riješenje po Vama bolje? I koliko je uopće iskoristivo i funkcionalno ugradit taj drugi opcionalni ventilator?
Inaće kučište je antec p280 i uz jedan stražnji i dva gornja isisna ventilatora stavio sam dva prednja usisna ventilatora.
conan je offline   Reply With Quote
Staro 09.05.2013., 01:39   #204
Drvoje
Drvoje's Avatar
Postovi: 4,037
Oba ventilatora moraju bit okrenuta u istom smjeru (push-pull) a tema ti je ovdje
Budući da taj dodatni vent već imaš, isprobaj sam pa usporedi koliko si dobija nižu temperaturu u odnosu na povećanu buku.
Hladnjak/ventove je najbolje okrenit da pušu prema ta 2 venta za ispuh na gornjoj stranici kučišta.
Pomelo mi sig -.-
Staro 16.05.2013., 09:31   #205
Drvoje
Drvoje's Avatar
Postovi: 4,037
AVC Hercules
Uz sveprisutni Asetek (Corsair/Zalman/Antec/Thermaltake..) i novog igrača Coolemastera (Seidon serija), stiže nam još jedan model - Hercules proizvođača Asia Vital Components (AVC).
Recenzija je na FrostyTech
Ok performanse i kvaliteta izrade, zatvoreni sistem, dobre neoprenske cijevi (ali kraće nego u konkurencije), bučan vent na max (i izuzetno ružna prozirna izvedba pumpe/motora/PCB - moja opservacija )
MSRP cca 70$
Neka, šta više proizvođača kupcima bolje.
Pomelo mi sig -.-
Staro 26.06.2013., 00:28   #206
Postovi: 8,259
Eo nekih novih ventova od scythea
Grand Flex
Izgledaju zanimljivo, performanse i buku(koja bi trebala biti minimalna navodno) budemo vidjeli, jedini minus je 3pin konektor.
Još jedna zanimljivost je što se vent okreće kontra od većine ostalih ventova, pa je moguće slaganje dual vent kombinacija.
Staro 27.06.2013., 22:20   #207
partwish
Creeper
Datum registracije: May 2013
Postovi: 2,225
Pozdrav. Što preporučujete za hlađenje FX8320 ili 8350 bez OC. Ono što mene zanima je relativno tiho hlađenje koje neće imati problema s defaultnim clockovima.
Staro 28.06.2013., 12:19   #208
ECHO
Lokacija: CROATIA-Vukovar
Postovi: 2,354
Evo par prijedloga a sve ovisi koliko si spreman krznaša žrtvovati
1. , 2. , 3. ili nešto jaće opcije 4. , 5.
Prva 3 navedena su ok i nećeš imati problema ohladiti CPU na stock frekvencijama pa ćak i blago povećanje(do 4GHz) neće pretstavljati problem a ostala 2 navedena su za ipak neke veće ambicije tj. clock
Naravno vodi raćuna o opciji 4 i 5 da li ti stane u "case" da nebi bilo nismo znali, pošto nisi popunio opciju "Moj komp".
Staro 28.06.2013., 12:35   #209
partwish
Creeper
Postovi: 2,225
Autor ECHO Pregled postova
Hvala na savjetu. Sastavljat ću novu konfiguraciju. Kućište koje sam planirao uzeti ima mjesta za hladnjake do 160mm.
Staro 28.06.2013., 13:10   #210
ECHO
Postovi: 2,354
O kojem se kučištu radi ako nije tajna jer će opcija 4 i 5 onda pretstavljati problem pošto su na granici, pogledaj po specifikaciji na linkovima.
Ali ukoliko neželiš žešći OC onda nebi ni gledao te opcije, a i cijenom povoljniji su i odlićno će hladiti i prva 3 nabrojana, osobno bi moj izbor br. 1 bio Katana pod br. 3, a onda br. 1. pa na kraju 2 ako bi osobno kupovao.
Naravno pogledaj nevedene coolere i kupi gdje ti je jeftinije pa pogledaj na nabava.net
