#931 |
Banan već 100 puta, multiple acc (cropape, manoval, mydante, lumbrela, mandarina, vanna...)
Datum registracije: Feb 2012
Lokacija: solta
Postovi: 32
Zaboravila sam reči, mobitel nije rootan |
#932 | |
Lokacija: Rijeka / Grobnik
Postovi: 4,463
ovdje je to sve, pa koga interesira navalite :-) http://forum.xda-developers.com/show....php?t=1179809 http://forum.xda-developers.com/show....php?t=1308030 http://forum.xda-developers.com/show....php?t=1069924 https://spreadsheets.google.com/spre...=0&output=html
"We all must hang together, or surly we will hang separately." AMD Ryzen7 7800x3D+Noctua NH-D14 | MSI Tomahawk WIFI AMD B650 | 2x16GB Corsair Vengeance DDR5-6000 CL30 1,39v | SAPPHIRE Pulse RX 9070xt UV/OC | 1tb NVMe sammy 970 evo plus, 2TB Samsung 990 EVO Plus, Crucial MX500 500GB, Kingston 480gb | Riotoro ENIGMA G2 850W 80 Gold | Corsair Carbide 300R modded | Win10 ENT LTSC IoT (work) + Win11 ENT LTSC IoT (gejming) | logitech g403 | ROCCAT Horde | AOC CQ27C4 + AOC C24G1 + 50" Hisense H50A6140 AMD Ryzen5 2600+Xilence Cryon M806D.B | Asus x370 Prime Pro rev1.03 (bios 6203) | GSkill Aegis 32GB (2x16) DDR4@3,2GHz | 2x Intel 545s 128GB, 1x Crucial MX500 500GB | Gigabyte GTX960 | sisa 620w | Fractal Design Focus G | Win7 x64 + Win10 ENT LTSC IoT | logitech g403 | ROCCAT SuoraFX intel i5 2500k@4,5ghz (1,28v)+FSP Windale 4 | ASRock Z68 Ext4 Gen3 (bios 1.20) | 2x8gb DDR3 HyperX Savage, 1866mhz, 10-10-11-27,1,5V | Samsung SSD 64gb, 2x256gb SSD | iGPU | corsair vx450w | CoolerMaster Centurion 534 modded | Win7 x64 |
#933 |
Postovi: 4,463
#934 | |
Lokacija: Dubrovnik
Postovi: 2,583
Koristio sam SetCPU pa sam sad prešao na System Tuner Pro jer omogućava smanjivanje/dodavanje napona uz mnoštvo drugih stvari. Profili mi se baš i nisu dopali dok sam ih koristio. Na kraju se opet svede sve na to da je najbolje pobrisat te aplikacije i ručno podesit sve kroz settingse i budeš miran. |
#935 |
Dino Saur
Datum registracije: Jan 2012
Postovi: 941
sto se tice paljenja gasenja gpsa/wifi ja koristim widget , samo kliknem on se ugasi/upali ![]() |
#936 |
Postovi: 7,705
__________________ |
#938 |
Pink Floyd fan
Lokacija: Santa Clara, CA
Postovi: 5,559
Android aplikacija za PCE forum. Napravio u dva klika, probao i radi. Naravno nije ništa posebno, praktički je browser ali je fora ![]() http://www.appsgeyser.com/getwidget/...kspert%20forum Možete i sami napraviti svoju aplikaciju od web url-a, dokumenta ili HTML-a.
Zadnje izmijenjeno od: LAcy. 15.02.2012. u 10:08. |
#940 |
PRO
Postovi: 4,889
evo, isprobao i ja Chrome beta. Apsolutno fenomenalan browser ikad napravljen za Android! Ne da je milina surfati internetom preko njega, nego je zabavno! Čak mi je gušt i infractione na PCE pročitati! ![]()
#943 |
Lokacija: solta
Postovi: 32
ShootME android aplikacija, problem ?
Prije 10-tak dana sam instalirala odličnu aplikaciju "ShootME" za capturing screen-a. Pokrenula sam ga, protresla i stvarno uhvatio je sliku screena i spremio ju u folder. Danas ga ponovo pokrenem i pojavi se onaj početni ekran, gdje kliknem na accept i pojavi se poruka: Failed starting server***please check that you have ***ROOT*** access on your device and enabled access to the lower level graphic Triput sam ga reinstalirala i opet isto. Može li ko da pomogne |
#944 |
Dino Saur
Postovi: 941
problem ti je u rootu izgubio si ga ,mozda si stavljao nekalav rom na kojem nepodrzava root . to se i meni dogodilo . ali sam imao backup napravljen pa sam samo backupao system.. probaj unrootati pa rootati telefon opet.. |
#945 |
Lokacija: solta
Postovi: 32
Da napomenem imam Samsung Galaxy I9000S Sad sam se sjetila nečega (ako to ima veze sa mojim problemom). Prekjučer sam instalirala na comp Samsung kies, spojila mobitel sa compom i kod prvog pokretanja on me je nešto pitao (nešto kao update) i odgovorila sam potvrdno. Nakon toga je nešto radilo oko 3---5 min i nakon toga ne radi ShootMe i čini mi se da se promijenio izgled onog malog toolbara pri vrhu screena (wifi, bluetooth, gps, zvuk, rotacija). Sad neznam ima li to šta veze sa tim Zadnje izmijenjeno od: marijavigini. 16.02.2012. u 13:33. |
#946 | |
Postovi: 4,463
#947 | |
Postovi: 18,953
#948 |
Lokacija: solta
Postovi: 32
I ja mislim da mi je napravio neki upgrade. Kažeš "Stisni i drži tipku back, a zatim stisni home" To sam uradila ali je nemoguće istovremeno pritisnuti obje tipke, uvijek je jedna pritisnuta prije (makar i milisekundu prije) Znači ako je pritisnuta prije tipka back, vrati ekran na prijašnje stanje Ako pritisnem prije home onda se odmah prikaže home screen Neznam da li ste me razumjeli Ali opet ne razumijem, ako je uradio upgrade zašto ne radi ShootMe a prije je radio. Dva puta sam vratila na tvorničke postavke ali opet isto. Da li ikako mogu ukinuti taj upgrade |
#949 |
Lokacija: Grobnik - Rijeka
Postovi: 3,254
Nije poanta istovremeno stisnut, nego npr. stisneš i držiš back a zatim stisneš (i drzis) home, ili sto vec.. znaci nije bitno za što je ta kombinacija namjenjena, već princip stiskanja.. |
#950 |
Lokacija: solta
Postovi: 32
Ok, znači najvjerovatnije sam nesvjesno napravila upgrade (sa samsung kies) ali onako logički razmišljajuči, nakon toga bi mi trebalo sve još bolje raditi a ne suprotno. Druga stvar koja mi nikako nije jasna, kako to da mi nije sve vratilo u prijašnje stanje ako sam vratila mobitel na tvorničke postavke (sa formatiranjem SD) a tvorničke postavke su bez tog upgrade-a. Kako da vratim sve to na stvarne tvorničke postavke |
#951 | |
Postovi: 4,463
#952 |
Dino Saur
Postovi: 941
neces nista postic s tim . moras imati rootan mobitel . u tome ti je problem to jest izbacuje ti taj problem kojeg si skroz gore napisala..jesi probala koju drugu aplikaciju za SS? |
#953 |
Lokacija: solta
Postovi: 32
Probala sam još neke ScreenCapture aplikacije ali neče, kaže da za to treba Rootan mobitel. Jeli moguče da nema nijedna aplikacija za nerootane mobitele |
#954 | |
Postovi: 7,705
Standarni screenshot radi dobro. Trebaš stisnuti najprije back pa onda home i čut ćeš zvuk okidanja. To treba malo munjevito napraviti.
#955 | |
Lokacija: solta
Postovi: 32
Kad naprimjer uđem u aplikaciju za GPS navigaciju Copilot, kliknem na tools i otvori se izbornik čiji screen treban snimiti, čim kliknem na back i home isti sekund se gasi taj okvir. Meni najviše treba ta opcija da snima te slike koje se pojave nakon klika na settings i sl. Znači nema mogućnost snimanja raznih skočnih prozora, a aplikacija ShootMe to može |
#956 |
Postovi: 18,953
#957 |
► Play ▌▌ Pause ■ Stop
Datum registracije: Jan 2010
Postovi: 1,180
Ove su mi dobre: Tap Tap Glider i Ceramic Destroyer.
