Staro 13.02.2012., 18:02   #931
marijavigini
Banan već 100 puta, multiple acc (cropape, manoval, mydante, lumbrela, mandarina, vanna...)
Datum registracije: Feb 2012
Lokacija: solta
Postovi: 32
Zaboravila sam reči, mobitel nije rootan
marijavigini je offline   Reply With Quote
Staro 13.02.2012., 18:03   #932
geronimo_2
geronimo_2's Avatar
Lokacija: Rijeka / Grobnik
Postovi: 4,461
Autor Bullet1 Pregled postova
I kod mene je tek u testnoj fazi pa nemogu reć koliko stvarno utjece na vijek baterije.
Pošto mjenjam ROMove svako malo, ne stignem vidjet kolika je stvarno razlika.
Do sada sam i sam koristio ručno podešavanje svega u postavkama ROMa no JuiceDefender mi omogućava par stvari koje u postavkama nema.
Program mi koristi tek 0.21% procesora (gledajući na sve procese) te ~5MB RAMa pa čisto sumnjam da može toliko doprinjeti battery drainu.
ak se ne varam bilo je spomena da prouzrocuje wakelock-ove.
ovdje je to sve, pa koga interesira navalite :-)
http://forum.xda-developers.com/show....php?t=1179809
http://forum.xda-developers.com/show....php?t=1308030
http://forum.xda-developers.com/show....php?t=1069924
https://spreadsheets.google.com/spre...=0&output=html
"We all must hang together, or surly we will hang separately."
AMD Ryzen7 7800x3D+Noctua NH-D14 | MSI Tomahawk WIFI AMD B650 | 2x16GB Corsair Vengeance DDR5-6000 CL30 1,39v | SAPPHIRE Pulse RX 9070xt UV/OC | 1tb NVMe sammy 970 evo plus, 2TB Samsung 990 EVO Plus, Crucial MX500 500GB, Kingston 480gb | Riotoro ENIGMA G2 850W 80 Gold | Corsair Carbide 300R modded | Win10 ENT LTSC IoT (work) + Win11 ENT LTSC IoT (gejming) | logitech g403 | ROCCAT Horde | AOC CQ27C4 + AOC C24G1 + 50" Hisense H50A6140
AMD Ryzen5 2600+Xilence Cryon M806D.B | Asus x370 Prime Pro rev1.03 (bios 6203) | GSkill Aegis 32GB (2x16) DDR4@3,2GHz | 2x Intel 545s 128GB, 1x Crucial MX500 500GB | Gigabyte GTX960 | sisa 620w | Fractal Design Focus G | Win7 x64 + Win10 ENT LTSC IoT | logitech g403 | ROCCAT SuoraFX
intel i5 2500k@4,5ghz (1,28v)+FSP Windale 4 | ASRock Z68 Ext4 Gen3 (bios 1.20) | 2x8gb DDR3 HyperX Savage, 1866mhz, 10-10-11-27,1,5V | Samsung SSD 64gb, 2x256gb SSD | iGPU | corsair vx450w | CoolerMaster Centurion 534 modded | Win7 x64
Staro 13.02.2012., 18:04   #933
geronimo_2
geronimo_2's Avatar
Postovi: 4,461
Autor marijavigini Pregled postova
mislim da u tom slucaju nemos bas puno toga. mislim da cak ni autoruns-e nemos podesit :-(.
Staro 13.02.2012., 18:17   #934
Bullet1
Bullet1's Avatar
Lokacija: Dubrovnik
Postovi: 2,583
Autor domy_os Pregled postova
Najbolje stavi neku aplikaciju za profile (MyProfiles je meni jedan od boljih), spusti napone procesora i testiraj druge CPU governore.
Koristio sam SetCPU pa sam sad prešao na System Tuner Pro jer omogućava smanjivanje/dodavanje napona uz mnoštvo drugih stvari. Profili mi se baš i nisu dopali dok sam ih koristio.
Na kraju se opet svede sve na to da je najbolje pobrisat te aplikacije i ručno podesit sve kroz settingse i budeš miran.
Staro 13.02.2012., 19:19   #935
dinos3
Dino Saur
dinos3's Avatar
Datum registracije: Jan 2012
Postovi: 941
sto se tice paljenja gasenja gpsa/wifi ja koristim widget , samo kliknem on se ugasi/upali
dinos3 je offline   Reply With Quote
Staro 13.02.2012., 19:46   #936
Dottore
Dottore's Avatar
Postovi: 7,703
Dottore, updejtaj na 4.2 što prije.
Bilo je slučajeva da se izgubi IMEI kad se freeza mob, jer nije fsync uključen u kernelu.
Apdejtao sam odavno
Ali prikazuje krive IMEI
HP 845 G9
CPU: AMD Ryzen 7 PRO 6850U
RAM: 64GB Samsung DDR5 4800
Graphic: AMD Radeon 680M
LCD: 14" IPS @ 1920 x 1200
OS: Windows 11 Pro 25H2
Mice: Logitech MX Master 3S
Lenovo ThinkPad P15v Gen 3
CPU: AMD Ryzen 7 PRO 6850H
RAM: 64GB DDR5
Graphic: AMD Radeon
LCD: 15" IPS @ 3840x2160
Lenovo ThinkPad T14 Gen 3
RAM: 16GB soldered LPDDR4
Mice: Logitech VX Nano
Lenovo X1 Carbon 7th Gen
CPU: Intel Core i7-8665U
RAM: 16GB soldered LPDDR3
Graphic: Intel HD 620
LCD: 14" IPS @ 2560x1440
Lenovo X1 Carbon 10th Gen
CPU: Intel Core i7-1260p
SSD: Sk Hynix 512 GB NVMe M.2
Graphic: Intel Iris Xe
LCD: 14" IPS @ 1920x1200
Staro 14.02.2012., 14:25   #937
Ivo_Strojnica
PRO
Ivo_Strojnica's Avatar
Postovi: 4,889
Ma, glavno da radi
Staro 15.02.2012., 10:01   #938
LAcy
Pink Floyd fan
LAcy's Avatar
Lokacija: Santa Clara, CA
Postovi: 5,559
Android aplikacija za PCE forum. Napravio u dva klika, probao i radi. Naravno nije ništa posebno, praktički je browser ali je fora
http://www.appsgeyser.com/getwidget/...kspert%20forum
Možete i sami napraviti svoju aplikaciju od web url-a, dokumenta ili HTML-a.
Core i7-6700K LGA1151 Skylake
RTX 2080 TI 11GB GDDR6
Samsung 850 EVO M.2 1TB SSD
MacBook M1 Pro
MacBook Air M2
Moto Edge
Zadnje izmijenjeno od: LAcy. 15.02.2012. u 10:08.
Staro 15.02.2012., 10:42   #939
tor
Administrator
tor's Avatar
Lokacija: Sesvete
Postovi: 15,964
fino si ti to sprogramiro
Staro 15.02.2012., 11:18   #940
Ivo_Strojnica
PRO
Postovi: 4,889
evo, isprobao i ja Chrome beta.
Apsolutno fenomenalan browser ikad napravljen za Android!
Ne da je milina surfati internetom preko njega, nego je zabavno!
Čak mi je gušt i infractione na PCE pročitati!
Staro 15.02.2012., 11:30   #941
LAcy
Pink Floyd fan
LAcy's Avatar
Postovi: 5,559
Autor tor Pregled postova
Svakako bolje od službene PCE aplikacije
MacBook M1 Pro
MacBook Air M2
Moto Edge
Staro 15.02.2012., 20:54   #942
Dottore
Dottore's Avatar
Postovi: 7,703
tnx LAyc
HP 845 G9
RAM: 64GB DDR5
Graphic: AMD Radeon
Staro 16.02.2012., 10:26   #943
marijavigini
Lokacija: solta
Postovi: 32
ShootME android aplikacija, problem ?
Prije 10-tak dana sam instalirala odličnu aplikaciju "ShootME" za capturing screen-a. Pokrenula sam ga, protresla i stvarno uhvatio je sliku screena i spremio ju u folder.
Danas ga ponovo pokrenem i pojavi se onaj početni ekran, gdje kliknem na accept i pojavi se poruka:
Failed starting server***please check that you have ***ROOT*** access on your device and enabled access to the lower level graphic
Triput sam ga reinstalirala i opet isto.
Može li ko da pomogne
Staro 16.02.2012., 12:05   #944
dinos3
Dino Saur
dinos3's Avatar
Postovi: 941
problem ti je u rootu izgubio si ga ,mozda si stavljao nekalav rom na kojem nepodrzava root . to se i meni dogodilo . ali sam imao backup napravljen pa sam samo backupao system..
probaj unrootati pa rootati telefon opet..
Staro 16.02.2012., 13:26   #945
marijavigini
Lokacija: solta
Postovi: 32
Da napomenem imam Samsung Galaxy I9000S
Sad sam se sjetila nečega (ako to ima veze sa mojim problemom).
Prekjučer sam instalirala na comp Samsung kies, spojila mobitel sa compom i kod prvog pokretanja on me je nešto pitao (nešto kao update) i odgovorila sam potvrdno.
Nakon toga je nešto radilo oko 3---5 min i nakon toga ne radi ShootMe i čini mi se da se promijenio izgled onog malog toolbara pri vrhu screena (wifi, bluetooth, gps, zvuk, rotacija).
Sad neznam ima li to šta veze sa tim
Zadnje izmijenjeno od: marijavigini. 16.02.2012. u 13:33.
Staro 16.02.2012., 13:29   #946
geronimo_2
geronimo_2's Avatar
Postovi: 4,461
Mobitel nije rootan, jer o rootanju nemam pojma.
Samo sad sam se sjetila nečega (ako to ima veze sa mojim problemom).
Prekjučer sam instalirala na comp Samsung kies i kod prvog pokretanja on me je nešto pitao i odgovorila sam potvrdno.
vjerovatno ti je napravio upgrejd na noviju verziju softvera ?
Staro 16.02.2012., 13:35   #947
domy_os
domy_os's Avatar
Postovi: 18,953
Ako imaš Samsung, ne treba ti dodatna aplikacija jer za screen shot postoji već integrirana aplikacija. Stisni i drži tipku back, a zatim stisni home. Trebao bi se čudi zvuk fotoaparata i na ekranu bi morao biti neki efekt.
RAM: 2 x 16 GB DDR4-3200
WLAN: Intel Wi-Fi 6 AX201
LCD monitor: AOC AG493UCX
SB: Mackie Onyx Producer 2x2
Speakers: 2 x JBL LSR305
MFP: Canon Pixma MP240
Staro 16.02.2012., 13:49   #948
marijavigini
Lokacija: solta
Postovi: 32
I ja mislim da mi je napravio neki upgrade.
Kažeš "Stisni i drži tipku back, a zatim stisni home"
To sam uradila ali je nemoguće istovremeno pritisnuti obje tipke, uvijek je jedna pritisnuta prije (makar i milisekundu prije)
Znači ako je pritisnuta prije tipka back, vrati ekran na prijašnje stanje
Ako pritisnem prije home onda se odmah prikaže home screen
Neznam da li ste me razumjeli
Ali opet ne razumijem, ako je uradio upgrade zašto ne radi ShootMe a prije je radio.
Dva puta sam vratila na tvorničke postavke ali opet isto.
Da li ikako mogu ukinuti taj upgrade
Staro 16.02.2012., 14:23   #949
Omerta
Omerta's Avatar
Lokacija: Grobnik - Rijeka
Postovi: 3,254
Nije poanta istovremeno stisnut, nego npr. stisneš i držiš back a zatim stisneš (i drzis) home, ili sto vec.. znaci nije bitno za što je ta kombinacija namjenjena, već princip stiskanja..
Odgovoran trgovac:1, 2, 3, 4, 5, 6, 7, 8, 9
Staro 16.02.2012., 15:53   #950
marijavigini
Lokacija: solta
Postovi: 32
Ok, znači najvjerovatnije sam nesvjesno napravila upgrade (sa samsung kies) ali onako logički razmišljajuči, nakon toga bi mi trebalo sve još bolje raditi a ne suprotno.
Druga stvar koja mi nikako nije jasna, kako to da mi nije sve vratilo u prijašnje stanje ako sam vratila mobitel na tvorničke postavke (sa formatiranjem SD) a tvorničke postavke su bez tog upgrade-a.
Kako da vratim sve to na stvarne tvorničke postavke
Staro 16.02.2012., 15:57   #951
geronimo_2
geronimo_2's Avatar
Postovi: 4,461
AFAIK kad napravis reset na tvorniceke postavke resetiras ga na default od zadnjeg flashanog ROM-a, ne na ROM/postavke koje su bile unutra kad je kupljen. ak oces nazad na stari ROM moras to sama napravit i mislim da to nije moguce kroz Kies (nisam ga nikad koristio pa neznam).
Staro 16.02.2012., 20:37   #952
dinos3
Dino Saur
dinos3's Avatar
Postovi: 941
neces nista postic s tim . moras imati rootan mobitel . u tome ti je problem to jest izbacuje ti taj problem kojeg si skroz gore napisala..jesi probala koju drugu aplikaciju za SS?
Staro 16.02.2012., 23:19   #953
marijavigini
Lokacija: solta
Postovi: 32
Probala sam još neke ScreenCapture aplikacije ali neče, kaže da za to treba Rootan mobitel.
Jeli moguče da nema nijedna aplikacija za nerootane mobitele
Staro 16.02.2012., 23:29   #954
Dottore
Dottore's Avatar
Postovi: 7,703
Ta aplikacija radi dalje i bez roota.
Standarni screenshot radi dobro. Trebaš stisnuti najprije back pa onda home i čut ćeš zvuk okidanja. To treba malo munjevito napraviti.
HP 845 G9
RAM: 64GB DDR5
Graphic: AMD Radeon
Staro 17.02.2012., 00:22   #955
marijavigini
Lokacija: solta
Postovi: 32
Nije to to.
Kad naprimjer uđem u aplikaciju za GPS navigaciju Copilot, kliknem na tools i otvori se izbornik čiji screen treban snimiti, čim kliknem na back i home isti sekund se gasi taj okvir.
Meni najviše treba ta opcija da snima te slike koje se pojave nakon klika na settings i sl.
Znači nema mogućnost snimanja raznih skočnih prozora, a aplikacija ShootMe to može
Staro 17.02.2012., 00:36   #956
domy_os
domy_os's Avatar
Postovi: 18,953
Staro 17.02.2012., 00:56   #957
DiRT
► Play ▌▌ Pause ■ Stop
DiRT's Avatar
Datum registracije: Jan 2010
Postovi: 1,180
Ove su mi dobre: Tap Tap Glider i Ceramic Destroyer.
PC:
CPU:
Intel Core i7-7700
COOLER:
SCYTHE Mugen 3 rev. B
MBO:
MSI B250 GAMING M3
GPU:
ASUS Dual Radeon RX 6650 XT OC Edition 8GB GDDR6
RAM:
Kingston HyperX Fury (2x8GB) 2133MHz@2400MHz CL16 DDR4
SSD:
Samsung 870 EVO (500GB)
Samsung 970 EVO Plus (2TB)
HDD:
WD1003FZEX (1TB)
WD20EZRZ (2TB)
EXTERNI HDD/SSD:
Seagate Basic Portable Drive (1TB)
WD My Passport (1TB)
WD My Passport (2TB)
WD Elements (2TB)
Verbatim Vx500 (240GB)
Silicon Power PC60 (240GB)
Kingston XS1000 (1TB)
PSU:
Corsair 650W RM650, 2019, 80 PLUS Gold
MONITOR (TV):
Dell G2724D + Dell U2414H
Samsung UE55NU8002TXXH
Samsung QE43Q60AAUXXH
Philips 43PUS8506/12
KUĆIŠTE:
Antec 300, 2xSCYTHE Slip Stream 120mm (500rpm, 7.5 dB)
OS:
Windows 10 Pro 64-bit
TIPKOVNICA:
Logitech K800 Illuminated
MIŠ:
Logitech G502 Proteus Spectrum RGB + SteelSeries QcK Edge - Medium
Logitech MX Master 3 Black
Logitech MX Master 2S Bluetooth Edition Graphite
Logitech M590 Silent
ZVUČNICI:
Logitech Z-5500 (S/PDIF) + Logitech Bluetooth Audio Receiver
MAGNAT Monitor Supreme 202 Black 2-way bass reflex bookshelf speakers
MAGNAT Monitor Supreme Center 252 Mocca
SLUŠALICE:
Logitech Zone Vibe 100
Samsung Galaxy Buds3 Pro
Xiaomi Redmi Buds 5 Pro
Xiaomi Buds 3 Star Wars Edition
Mi True Wireless Earbuds Basic 2
Sennheiser CX 3.00
AKG Samsung Galaxy Earbuds
AKG Y500 Wireless
MOB:
Samsung Galaxy S7 Black, 4/32GB +
Samsung microSDXC 64GB EVO+
Samsung Galaxy S10e Black, 6/128GB +
Samsung microSDXC 256GB EVO+
Huawei P50 Pro Golden Black, 8/256GB
Samsung Galaxy A55 5G Awesome Navy, 8/256GB
Samsung Galaxy S24+ Onyx Black, 12/256GB
Samsung Galaxy S25+ Blue Black, 12/256GB
LAPTOP:
(Lenovo ThinkPad E560)
CPU: Intel Core i3-6100U
MBO: -
GPU: Intel HD Graphics 520
RAM: 2x4GB DDR3L 1600MHz
SSD: Kingston A400 480GB
OSTALO: 15.6-inch HD TN
OS: Windows 11 Pro 64-bit
PC POSAO:
(HP Z2 Tower G9 Workstation)
CPU: Intel Core i7-14700K
MBO: HP 895C
GPU: Nvidia RTX A2000 12GB
RAM: 1x16GB DDR5
SSD: Samsung 512GB
HDD: WD 2TB
MONITORI: 2 komada HP Z27 27-inch 4K UHD
PERIFERIJA: Logitech K750 Solar, Logitech MX Master 3 Graphite + Logitech MX Master 2S Bluetooth Edition Graphite
LAPTOP POSAO:
(Apple MacBook Air 13.6-inch M2 8/256GB MLXY3CR/A Silver)
(HP EliteBook x360 1040 G11 2-in-1, 14-inch WUXGA Touchscreen, Intel Core Ultra 7 155H, 16GB LPDDR5x, Samsung 1TB PCIe Gen4 NVMe TLC M.2 SSD, Backlit Keyboard, Windows 11 Pro 64-bit)
(HP ProBook 450 G7, 15.6-inch FHD, Intel Core i5-10210U, 8GB DDR4, Samsung 512GB NVMe M.2 SSD, MX250 Graphics, Backlit Keyboard, Windows 11 Pro 64-bit)
DiRT je offline   Reply With Quote
Staro 18.02.2012., 15:05   #958
Dottore
Dottore's Avatar
Postovi: 7,703
Ma, glavno da radi
Pogodi
HP 845 G9
RAM: 64GB DDR5
Graphic: AMD Radeon
Staro 18.02.2012., 16:54   #959
Ivo_Strojnica
PRO
Postovi: 4,889
Uuuu, koji je to ROM?
Ja imam AOKP build 23, ali baterija mi prebrzo odlazi.
Staro 18.02.2012., 17:17   #960
Dottore
Dottore's Avatar
Postovi: 7,703
ICS Blues 1.0
HP 845 G9
RAM: 64GB DDR5
Graphic: AMD Radeon
