#391 |
Postovi: 5,997
Cijene su vec korigirane ali kod nas se bas vise ne uvoze pa vjerojatno ni nece cijena dolje. Kod nas je vrijeme kupovine 580 proslo cak i proje izlaska 7970.. Mnogi costum modeli sad kostaju kao ref. 580. Ultra sa 3gb na 900mhz kosta 550$, Giga SOC je na 500$ i tako. Jedino takvi modeli imaju sansu za prodavat se. Ref. bi kupio samo mamlaz jer kosta prakticki isto. |
#395 | |
gadget freak
Lokacija: Jasenovac
Postovi: 2,224
), jer dolazi iz švice sa grafom i ssd-om za 2 tj, a ostatak kompa je već doneo u 12 mj. Taman stigne razmislit još koji dan hoće li 7970 ili 7950...
#396 |
Datum registracije: Aug 2009
Lokacija: Zürich
Postovi: 711
#397 |
Postovi: 5,997
#398 |
Ova XFX dual fan grafulja moćno izgleda. A ni prvi review-ovi nisu loši. |
#400 |
Super Moderators
Datum registracije: May 2002
Postovi: 17,485
Ne ![]()
#401 |
Outer Space
Lokacija: Vinkovci
Postovi: 853
Najnoviji info.Ni pod zivu glavu ne kupujte Dual Fan xfx.Design flaw. http://forums.guru3d.com/showpost.ph...&postcount=141 http://www.tomshardware.co.uk/forum/...blem-reference Hot VRMs, not VRAM is an issue with most axial fan design coolers. These coolers are actually cheaper to make than reference designs and often lack the large heat plate that covers all the VRMs and VRAM that dissipate the heat into the body of the shroud and the heatsink to be completely exhausted out of the system by the high static pressure of the blower fan. VRM temps may be in spec but it's actually VRM temps that limit your overclock these days moreso than anything regarding the actual core voltage. But we can note a few differences. First of all, the reference Radeon HD 7970 features 5+1 power circuit design with 6 phases for the GPU and 1 phase for the graphics memory. The power system is managed by a CHiL CHL8228G controller. High-quality DirectFETs can be spotted on the PCB. We’ve seen them before on MSI’s graphics cards. They are superior to the Radeon HD 6970’s Volterra components in electrical resistance, inductance and heat dissipation. These chips can give their heat away both to the heatsink and to the PCB. Zadnje izmijenjeno od: Romano.Cule. 01.02.2012. u 18:55. Razlog: Update informacija |
#402 | |
Postovi: 1,082
#403 |
Datum registracije: Feb 2012
Postovi: 14
živo me interesira taj napredak i skok od6970 na 7970 kolika bu razlika u efektivi vjerovatno nekih 3% i u overclocku nekih 7% morat će biti neki opaki advance da me ponuka da zamjenim 6970 za seriju 7 pošto i ova tjera sve na max u full hd-u na 25incha montoru nekak se prije vidim u nekom egzibicionizmu sa mbo i novim procom. A po cijeni onda rađe piknem 6990 njoj ipak mislim da nebu bježala ta 7970 niti malo ![]() Zadnje izmijenjeno od: Jelc. 02.02.2012. u 12:28. |
#405 |
PRO
Postovi: 4,936
#406 |
Super Moderators
Postovi: 17,485
Nije da nema na stranici prije... Sapphire Radeon 7950 Overclock Edition vs 7970 OC vs GTX 580 OC vs 6970 OC Review http://www.hardwareheaven.com/review...roduction.html
#407 | |
Outer Space
Lokacija: Vinkovci
Postovi: 853
Ne,imam ovu .Ne furam se ja na izgled graficke i kulere,fensi,šmensi.Bitno je da se ne grije i da radi stabilno,a za ostalo me zaboli papak ![]() Citiraj:
.U 3d marku 2011 razlika samo 11.000 poena izmedju 6970 i 7970. To je 3%.A u BF3 samo razlika 20 FPS-a.To je vec 7%![]() Zadnje izmijenjeno od: Jelc. 02.02.2012. u 12:39. Razlog: Koristi edit a ne duplo postat... |
#408 | |
Super Moderators
Postovi: 17,485
Pa onda lijepo otvori novu temu ATi Radeon HD 7970 pa nek se odsad sve vezano za tu grafu posta tamo ![]() Do sad nije bilo smisla otvarat posebnu budući da nitko od forumaša nije imao taj model...
#410 | |
Super Moderators
Postovi: 17,485
ATi Radeon HD 7970 A ne i o 7950 i ostalima ![]() I napiši više koju riječ o grafi kad je već imaš... ![]() Citiraj:
#411 |
Lokacija: Sveta Nedelja
Postovi: 2,938
Ok, ajmo ovako. Da u džepu imaš 3.909,15kn koliko košta najjeftinija 7970 na tržištu, a doma u računalu 6970/570, da li bi te novce potrošili na upgrade ili bi čekali (da se cijene spuste, ili slijedeću generaciju 8xxx, ili još jednu 6970/570, ili nešto treće četvrto...)? Pitam čisto rasprave radi, jer ne čini mi se da će se cijene tako brzo spuštati, a i definitivno mislim da ta kartica ne vrijedi te novce. Je, brža je, bolja je, ali i skoro duplo skuplja od tamo nekakve 6970...
#412 |
Krivo si postavio pitanje. Onaj tko si mora postaviti to pitanje nema kaj tražiti u iznad ~1.600, ~1.800 kuna kategoriji. Onaj tko kupuje tu klasu kada tek izlazi i za kojeg je namijenjena ima novaca za takvo nešto i ne zanimaju ga neki kompromisi. Isto kao i što se tiče supporta. Zašto se ne trude toliko sa driverima za high end dual gpu 5xxx seriju. Zato jer uskoro dolazi ista stvar u 7xxx seriji, a pretpostavka je da si tak i onak već zamijenio svoju 5xxx kartulju sa 6xxx kartuljom (ako slučajno nisi, evo dolazi 7xxx). Svi znamo da se više isplati kupiti GPU za ~1600 kuna pa ga prodati za godinu dana i kupiti opet za ~1600 kuna pa ga prodati i onda kupiti opet neš za ~1600 (te da će te taj princip koštati isto kao da sada iskeširaš za takvu neku zvijer koja neće biti jača od za dvije serije nečeg kaj dođe ~1600). Ovo sada karikiriam ali zna se o čemu pričam) |
#413 |
Postovi: 1,082
#414 | |
Outer Space
Lokacija: Vinkovci
Postovi: 853
To je fakticki 5 godina si miran sa high end grafuljom.A da sam mrljavio i svake godine kupovao mid range da mogu igrati normalno pojedine igre na rubu igrivosti u high detaljima. Gtx260,275,pa 285,pa onda gtx460,470 pa 570 izgubio bih vise nego s tom jednom.Ovako sam preskocio sve te generacije grafickih i zajebancije s prodajom,kupnjom i uzivao. Razlog promjene je bio samo mini display port kojeg 295 nema ,a bio mi je potreban za apple cinema.Zaseban adapter kosta 300 kn,a trebala su mi 2 komada.Znaci miniDP na DVI i miniDP na HDMI.600 kn.Isplativije mi je onda kupiti novu graficku.A kad vec uzimam oduzmem tih 900 kn sto sam prodao gtx295,oduzmem 600 za adaptere,oduzmem PDV (897 kn) jer sam uzeo na firmu i sta dobijem ? 7970 je mene kostala 1500 kn !I miran sam narednih 4 godine sa mojim zahtjevima. Zadnje izmijenjeno od: Romano.Cule. 03.02.2012. u 16:27. |
#415 |
Lokacija: Zgb
Postovi: 215
Ne vijedi te novce. 6970 će vrtiti sigurno sve naslove do kraja godine bez problema, i potrošiti te 4 tkn za godinu dana kad izađe nešto konkretnije naspram 6970. Ovako bi izišao preskup taj upgrade sa 6970 na 7970. |
#419 |
Premijum
Postovi: 1,360
Kad bubne cijena 7970 na 3000 onda mozemo pricat o opravdanoj kupnji, samo sto se to nece sigurno dogoditi prije izlaska GTX 6XX. |
