Staro 28.12.2011., 20:30   #1
Laxarus
Laxarus's Avatar
Datum registracije: Nov 2011
Postovi: 70
Powerline net max domet?
Zanima me, ako koristim one uredaje sto se spajaju u struju da bi dijelili net i napravim posebnu instalaciju samo za njih, tj instalaciju koja nema skretnica da se signal "izgubi" vec samo jedna zica koja ide od tocke a do tocke b koliki bi bio max domet?
Na ovo mislim http://protis.hr/products/details/de...rter-kit/43824 (ne mora biti tocno taj model)
Laxarus je offline   Reply With Quote
Staro 28.12.2011., 20:39   #2
nino
nino's Avatar
Postovi: 12,613
Negdje sam citao da uz dobar kabel ide i do 300m. Eh sad...
13. What is the maximum distance of two devices in a Powerline Network?
* We recommend using distances up to 200 meters. Under ideal conditions it is possible to reach longer distances. This depends on the type of cable and the quality of the joints. Diagnostics Kit will help you find out the maximal distance between the most distant outlets, so that you still reach sufficient throughput.
Staro 28.12.2011., 20:47   #3
Laxarus
Laxarus's Avatar
Postovi: 70
Samo? a u pm..
Staro 30.12.2011., 11:18   #4
Tomba_NZXT
Tomba_NZXT's Avatar
Lokacija: Daleko, daleko ...
Postovi: 54
za dulje imas wifi ili optiku ...
Tomba_NZXT je offline   Reply With Quote
