Staro 28.11.2011., 03:08   #31
denied
denied's Avatar
Postovi: 1,193
Evo i 11.11b drivera.....
http://support.amd.com/us/kbarticles...rformance.aspx
Elder Scrolls Skyrim
New in Catalyst 11.11b: Delivers AMD CrossFire performance scaling for AMD Radeon HD 6000 Series
AMD Radeon HD 5000 CrossFire support will be supported soon in an updated driver
Improves performance 2-7% on single GPU configurations
Resolve corruption seen when enabling Multi-Sample Anti-Aliasing on the AMD Radeon HD 6970 Series
Assassin's Creed: Revelations
Batman Arkham City
Improves DirectX 11 performance for single GPU configurations
Rage
Delivers AMD CrossfireX performance scaling
Resolves a number of image / stability issues seen with the title:
Fix geometry corruption, sometimes seen in Bash TV entrance
Fix issues with Low-memory conditions on 32bit systems.
Fix issue with extreme corruption with missing textures on 32bit systems.
Fix memory leaks when deleting/reusing sync objects.
Fix hitching and pausing, especially noticeable on some Quad Core systems when doing races and Stanley Express runs.
Fix some missing shadows
Battlefield 3
Resolves intermittent corruption seen when playing the game at specific camera angles
denied je offline   Reply With Quote
Staro 28.11.2011., 03:38   #32
Sniper
Community Manager
Sniper's Avatar
Postovi: 313
Stavio drivere i prilicno sam zadovoljan.
Sve igrice mi rade kako bi i trebale, COD4 bez prijekorno, stvarno ugodno sam se iznenadio kako ovakva igrica moze glatko i lagano raditi.
BF3 nisam jos probao tako da necu nista rec, ali uskoro cemo vidjeti kako se ponasa u tome.
Sniper je offline   Reply With Quote
Staro 28.11.2011., 06:05   #33
imaticx
Default
imaticx's Avatar
Lokacija: Požega
Postovi: 1,509
Obicno skidam drivere sa ati stranice pa izaberem posebno za laptop. Tu pise samo za seriju 5000 i 6000, a ja imam na laptopu HD5650. Jel ti driveri vrijede i za moj laptop ili samo za komp?
Staro 28.11.2011., 09:04   #34
Jelc
Super Moderators
Datum registracije: May 2002
Postovi: 17,485
Pa trebalo bi ako si odabrao notebook/HD/5xxx
Staro 28.11.2011., 11:52   #35
suedamA obmaR
Game, PC ,motobikes, bike
suedamA obmaR's Avatar
Datum registracije: Jan 2010
Lokacija: Sibenik
Postovi: 777
Jel ima smisla ovo stavljat na 4890 ili je samo za 5000 i 6000 seriju.
Applicable Products:
This article applies to the following configuration(s):
Software
Batman Arkham City
Rage
Battlefield 3
Elder Scrolls : Skyrim
Hardware
AMD Radeon HD 5000 Series
Vidim da ne navode 4000 seriju.
suedamA obmaR je offline   Reply With Quote
Staro 01.12.2011., 12:49   #36
IGoR_2803
IGoR_2803's Avatar
Lokacija: N/A
Postovi: 758
o jebemti, prošli tjedan sam stavio ove 11.11a performance driver zbog skyrima... i sad opet ovo...
iako mi se čini da sam njihovim stavljanjem malo profitirao u skyrimu... i sa starijim driverima mi je glatko radio ali je znao zaštucati prilikom naglog okretanja, međutim sad toga više skoro uopće nema...
tak da ću ipak staviti i ove 11.11b
Staro 01.12.2011., 21:57   #37
ukiy
ukiy's Avatar
Datum registracije: Apr 2008
Lokacija: ST
Postovi: 398
AMD Posts Catalyst 11.11c Performance Driver
Izvor: techPowerUp
AMD published the third performance driver based on Catalyst 11.11, the Catalyst 11.11c. The driver addresses some glaring issues ahead of the upcoming Catalyst WHQL monthly update. The new performance driver addresses the following issue:
  • Delivers AMD CrossfireX performance scaling for the AMD Radeon HD 5000 Series
Apart from the applied changes, the new Catalyst 11.11c includes all the changes brought about by previous Catalyst 11.11 performance drivers.
ukiy je offline   Reply With Quote
Staro 08.12.2011., 10:01   #38
bAKa-47
Postovi: 157
bAKa-47 je offline   Reply With Quote
