Staro 04.11.2011., 22:21   #841
lit
Lokacija: hr
Postovi: 976
Inače ne volim 'priključke' s gornje strane, prašina se vrlo lako skupi unutra.
lit je offline   Reply With Quote
Staro 09.11.2011., 08:59   #842
Doink the Clown
Jack of all, master of none
Doink the Clown's Avatar
Lokacija: Matulji - Rijeka
Postovi: 6,214
ENERMAX Announces New, Capacious Fulmo Series Cases
ENERMAX is pleased to announce the new flagship tower series: Fulmo GT and Fulmo. They are the fusion of performance and style, with exceptional compatibility and ease-of-use design. This series comes in both full-tower and mid-tower sizes, each providing different configurations. The Fulmo and Fulmo GT meet different demands from advance users to performance craving enthusiasts.
A Monster Is Never Full
Fulmo GT is a HPTX MB-supported full-tower case. Its jaw-dropping volume allows massive storage of up to 14 devices, dual PSU mounts, and quad VGA cards with 425mm /16.73 inches in depth with astonishing support for 15 to 20 fans.
Newly-adopted 18cm Vegas LED fans with multi-lighting keeps you delighted by its nice effects. An integrated fan speed knob allows total control of three fans to provide dynamic thermal solution for systems under different loads. In addition, there are more than sufficient USB 3.0 ports with one external SATA dock that makes massive data transfers in no time.
Whether you are looking for a robust workstation or want to build an ice fortress for your hard-core gaming rig, Fulmo GT is definitely your answer!
No more struggling for inches
Though packed in mid-tower size, there is no compromise on its performance. Fulmo proposes a real novel solution for space restrictions, which allows up to 410mm/16.14 inches of clearance for VGA card installations, and saves struggling for inches or trade-off between HDD devices.
In addition, the Fulmo has upgradability for triple VGA cards and a total of 10 to 14 fan mounts, makes it the ideal choice to maintain pleasant temperature while keeping extreme visual experience.
Sharing the same design attributes with Fulmo GT, the Fulmo inherits the fan LED control, top USB 3.0 interface, and external SATA dock. All in all, Fulmo surpasses rivals both functionally and aesthetically.
For more information, visit the product pages of Enermax FulmoGT, Fulmo Advance, and Fulmo Basic.
C L O W N I N G A R O U N D
Staro 09.11.2011., 10:56   #843
1v@n
The mighty pirate
1v@n's Avatar
Lokacija: London
Postovi: 9,070
Još jedan CM690 ripoff, samo veći
CPU: Intel Core i7 8809G
MBO: Intel NUC8i7HVK
RAM: 2x16GB Crucial DDR4 2400
GPU: Radeon™ RX Vega M GH
LCD: BENQ PD3200Q
OS: Windows 10 Pro x64
Staro 09.11.2011., 11:55   #844
JuiceBox
Xulos :)
JuiceBox's Avatar
Postovi: 7,552
Autor Bluzer Pregled postova
http://www.techpowerup.com/154555/Ro...?cp=2#comments
CM690 na steroidima. Zapravo, kućište uopće nije loše.
Samo dragi Bog nemoze istjerat prasinu iz svih tih rupica kad se to jednom zaprasi
Staro 09.11.2011., 12:09   #845
Postovi: 8,214
Autor xulos Pregled postova
Kompresor majka. A i četka za cipele pomaže, naravno bez kreme. Iako, ja sam svoj P182 prao u kadi
Staro 22.11.2011., 20:15   #846
bluefluid
bluefluid's Avatar
Lokacija: VG
Postovi: 1,758
Silverstone Raven 2 Evolution USB 3.0
We have reviewed a large number of Silverstone products in the past and today are taking a look at the Raven 2 Evolution with USB 3.0. It takes the very successful Raven 2 and updates it with modern connectivity along with various internal layout changes. The chassis is available in black and white.
Izvor: techpowerup
Staro 24.11.2011., 12:19   #847
Šole
Šole's Avatar
Datum registracije: Aug 2009
Lokacija: Zürich
Postovi: 709
Šole je offline   Reply With Quote
Staro 24.11.2011., 12:44   #848
zen_sux
zen_sux's Avatar
Postovi: 278
Za nekoga ko vec duze vrijeme trazi Silverstone RV02 ili FT02, jako sam se razveselio kad sam vidio da je jedini silverstone uvoznik dobavio cjelu hrpu novih kucista partnerima, i da je mom cekanju kraj (eno ih puna nabava.net), kad ono sve RV03 i FT01
zen_sux je offline   Reply With Quote
Staro 24.11.2011., 17:12   #849
bor1s
bor1s's Avatar
Lokacija: Vratlo
Postovi: 300
Autor zen_sux Pregled postova
Zašto ne kupiš RV02 ili FT02 u BiH imaš ih u genelecu i dostupni su koliko vidim a cijena je oko 1200kn za RV02 i 1800kn za FT02. Nije ti tako daleko Mostar, ja isto razmišljam da uzmem ovaj RV02 jer mi je nekako previše nadoplatiti za FT02 za praktički istu stvar.
bor1s je offline   Reply With Quote
Staro 24.11.2011., 17:42   #850
1v@n
The mighty pirate
1v@n's Avatar
Lokacija: London
Postovi: 9,070
Autor bor1s Pregled postova
Taman se poveselim oko FT-02, i onda opet samo crno. Gadnih crvenih HAF-ova posvuda, a srebrnog FT-02 ne možeš nigdje nać...
LCD: BENQ PD3200Q
Staro 25.11.2011., 11:56   #851
zen_sux
zen_sux's Avatar
Postovi: 278
Ne pada mi na pamet preko granice samo po kuciste
Al lijepo ja znat da negdje i postoji, tnx!
Staro 05.12.2011., 20:23   #852
TheBigFella
TheBigFella's Avatar
Datum registracije: Sep 2011
Postovi: 15
Pozdrav
Evo ovo je moj prvi post ovdje iako vas pratim dosta dugo...
Nisam htio otvarati novu temu za moje pitanje, a ono glasi gdje bih u HR mogao kupiti Silverstone TJ07 ili TJ11?
Hvala
TheBigFella je offline   Reply With Quote
Staro 05.12.2011., 20:37   #853
baban
baban's Avatar
Datum registracije: Aug 2008
Lokacija: DE
Postovi: 591
po nabavi najjeftiniji tj07 imas ovdje http://www.magazinrs.hr/chassis-silv...umin/SST-TJ07B
baban je offline   Reply With Quote
Staro 05.12.2011., 20:38   #854
Postovi: 8,214
TJ07 ima u MagazinRSu, TJ11 je još relativno novo kućište pa nema kod nas a s obzirom na cijenu upitno je hoće li ga ikad biti.
EDIT:
Pretekao me agent, uglavnom na nabavi ti je najlakše naći bilo koju komponentu. U ovom slučaju TJ07
Staro 05.12.2011., 20:43   #855
TheBigFella
Postovi: 15
Pupo i agent puno zahvaljujem na brzim odgovorima...
Ne znam kako se nisam sjetio na nabavai pogledati
Staro 05.12.2011., 20:47   #856
baban
baban's Avatar
Lokacija: DE
Postovi: 591
vidim na silverstone webu da je uvoznik za hrv asbis
pa ako te bas interesira tj11 kontaktiraj njih za vise informacija
Staro 13.12.2011., 12:24   #857
QuidZz
QuidZz's Avatar
Lokacija: Sinj
Postovi: 3,533
Kad se ovaj Phantom 410 moze ocekivat u nasim trgovinama. Mislim da ce biti i vise nego dobra zamjena za mog Nzxt Apollo. Dobar protok zraka, dobar cable management, lijepo izgleda...
Nzxt Phantom 410
Review
Zadnje izmijenjeno od: QuidZz. 13.12.2011. u 12:35.
Staro 13.12.2011., 12:51   #858
baban
baban's Avatar
Lokacija: DE
Postovi: 591
kontaktiraj links, mislim da su oni uvoznici
Staro 13.12.2011., 12:53   #859
QuidZz
QuidZz's Avatar
Lokacija: Sinj
Postovi: 3,533
Nisam zna da su oni uvoznici. Kontaktirat cu ih, hvala
EDIT: Stigao odgovor...
Poštovani,
Provjerili smo s kolegama s nabave vezano za traženo kućište.
Informacija koju smo dobili je da traženo kućište Phantom 410 neće dolaziti ove godine.
Također neće dolaziti nesto od ostale Phantom serije bar ne kroz slijedećih mjesec dana.
Šteta
Zadnje izmijenjeno od: QuidZz. 13.12.2011. u 17:22.
Staro 13.12.2011., 18:41   #860
Halos
muimerP
Halos's Avatar
Lokacija: VG
Postovi: 3,334
Šta recimo, ako mogu dobit Obsidiana 800D za 900 kn...?
Sad sam nekako Li-La, Stacker mi je odličan. A opet, slina mi curi hehe
Staro 13.12.2011., 18:44   #861
Postovi: 8,214
Pa nema se tu što mislit previše, nego uzet pare i ubost 800D
Staro 19.12.2011., 13:17   #862
mhadina
mhadina's Avatar
Postovi: 436
KUĆIŠTE veliko i kućište okapoan (č: naopako)
Sorry ak je bilo, al ja sam ostao paf...
Kućištte ili škatula ili kanta .... ovdje
a isto tako ostao sam zbunjen, nakon Silverstonovih kućišta s "naopako" dizajniranim položajem matične ploče radi boljeg hlađenja grafičkih kartica, nisam očekivao ovakav razvoj kućišta, ali svakako pohvalno ...ovo
  • Vidiš li čovjeka koji se sam sebi mudrim čini? Znaj, i od bezumnika ima više nade nego od njega!
  • San dolazi od mnogo briga, a lud govor od mnogo riječi.
  • Neka su ti mnogi poznanici, ali pouzdanik samo jedan od tisuću.
  • Ne ponizuj se pred budalom i ne budi pristran pred mogućnicima.
  • Ne budi silovit na jeziku a lijen i mlitav na djelu.
Zadnje izmijenjeno od: mhadina. 19.12.2011. u 13:19. Razlog: dodane slike
mhadina je offline   Reply With Quote
Staro 19.12.2011., 13:23   #863
Garro
Postovi: 2,379
Autor Halos Pregled postova
Onda lijepo uzmi 800D za 900 kuna i prodaj ga meni...
Možda čak i nešto zaradiš.
Staro 22.12.2011., 22:37   #864
Thundercool
Plebium
Thundercool's Avatar
Lokacija: Sisak
Postovi: 156
Cosmos II
"I might be one of those idiots who carrys this to a lan party"
haha
Zadnje izmijenjeno od: Thundercool. 22.12.2011. u 23:11.
Thundercool je offline   Reply With Quote
Staro 22.12.2011., 22:45   #865
Halos
muimerP
Halos's Avatar
Lokacija: VG
Postovi: 3,334
Čudovište! Mene ovi "nosači" malo nervaju, da ih barem nema
p.s. - ja odustao od 800D, nije bilo do para, ali decko je kemijao unutra po tray-u i tako, huliganstvo uglavnom.
Staro 22.12.2011., 23:09   #866
hammer_of_thor
its slightly turbocharged
hammer_of_thor's Avatar
Postovi: 5,430
Autor Thundercool Pregled postova
Cosmos II
"I'm might be one of those idiots who carrys this to a lan party"
haha
The king is back!
Zaljubio sam se!
Iako sam rekao da sam sa Lian Liem miran idučih 10 godina ozbiljno ću razmisliti o Cosmosu II. Jednostavno previše volim to kučište!
Kako dobro izgleda, to nije za vjerovati!
A lik je legenda; "that's 15.15 inches for the...aaa... mentally impaired people out there"
Prejaki su mi ti likovi sa TigerDirectTV-a
blaa
Staro 23.12.2011., 02:01   #867
SetH
SetH's Avatar
Lokacija: ZG/Borongaj
Postovi: 3,324
njaaa...previše jako glupih minusa
SetH je offline   Reply With Quote
Staro 23.12.2011., 08:24   #868
mr Rockwell
mr Rockwell's Avatar
Datum registracije: Mar 2008
Postovi: 354
Po meni naljepsi i najsuptilniji full tower case ikad. http://www.silverstonetek.com/produc...id=242&area=en
Cijena 1650 kn
mr Rockwell je offline   Reply With Quote
Staro 23.12.2011., 08:33   #869
Mad_Duke
Fala Bogu neki full tower koji ne izgleda kao transformer sa greškom! :P
Interesantan raspored!
Staro 23.12.2011., 08:52   #870
Postovi: 33,952
Kao i većina SS-ova.
