Super Moderators
Datum registracije: May 2002
Postovi: 17,485
Novi Catalyst 5.3
Evo taze drivera OVERDRIVE™ Version 4 The latest version of OVERDRIVE™ includes a new 3D test and extra safety checks to ensure the best over-clocking experience - allowing manual over-clocking of both engine and memory while keep the user's graphics card safe from any of the dangers usually associated with over-clocking. eRecord The CATALYST™ Software Suite 5.3 introduces a new feature named eRecord. This feature is the first error logging system used by the ATI multimedia software. The eRecord feature provides a mechanism for software components to output error messages. A new System Messages (Event Viewer) menu has been added to the CATALYST™ CONTROL CENTER System Tray. This launches the Event Viewer, providing a mechanism for users to view the error messages. Windows XP Media Center Edition Display Control Panel Extension The CATALYST™ Software Suite 5.3 introduces enhanced capabilities of the display panel through a Windows Media Center Edition look-alike control panel. The control panel options include: Display devices. Provides the ability to select preferred display devices such as; TVs, LCDs, or Monitors Display options. A user controllable option for desktop color, brightness, contrast OpenGL Version 2.0 Support The CATALYST™ Software Suite introduces OpenGL Version 2.0 support. This version of OpenGL will be in line with the latest GL ARB approved specifications. New to this specification are GLSL, non-power-of-two-textures, separate stencil, multiple render targets, and point sprites. What's fixed in this driver? 3DMark2001: A black screen is no longer displayed when launching 3DMark2001 after launching Aquamark3, when the CATALYST™ CONTROL CENTER is installed. Topic number 737-1140 Code Creatures: Running the benchmark under Windows XP SP2 with an ATI RADEON™ 9250 installed, and the desktop display set to either 1600x1200, 1280x1024, or 1024x768 no longer results in the ground textures appearing corrupted. Topic number 737-10108 Pacific Fighters: Playing the game after playing any track for a short period of time and having the landscape detail set to perfect no longer results in the clouds becoming blocking when flying. Topic number 737-209 Thief Deadly Shadows: Setting the desktop display to 1024x768 32bpp and setting the Texture Preference to High Performance in the control panel no longer results in corruption being seen at the end of the introduction movie. Topic number 737-10109 Attempting to apply a higher refresh rate to a non-DDC monitor no longer results in the refresh rate reverting to 60hz. Topic number 737-10101 Accessing the Problem Report Wizard option from the ATI icon in the system tray no longer results in Problem Report Wizard not being translated in the supported localized languages. Topic number 737-341 Entering the Video option found in the Graphic Setting tab of the CATALYST™ CONTROL CENTER no longer results in the side scroll bar being missing for the secondary display device connected to an ATI RADEON™ 9800 series under Windows XP. Topic number 737-347 The Welcome tab found in the CATALYST™ CONTROL CENTER is now completely localized for the Japanese version of Windows XP, or 2000. Topic number 737-351 Using the CATALYST™ CONTROL CENTER to access the Display Manager no longer results in corruption being seen on top of menu text in the Dutch, French, Spanish, and Portuguese versions of Windows XP. Topic number 737-353 The TV formats now corresponds to the country selected in the TV properties. Topic number 737-1438 Having a CRT and TV connected to the ATI RADEON™ X850 series no longer results in the TV image quality page not being grayed out when enable video mode is enabled. Topic number 737-1439 Launching the Hotkey Manager found in the CATALYST™ CONTROL CENTER no longer results in the Hotkey Manager window not closing when hitting the ESC key. Topic number 737-10097 Using the CATALYST™ CONTROL CENTER to access the Display Manager no longer results in corruption being seen on top of menu text in the Dutch, French, Spanish, and Portuguese versions of Windows XP Entering the Video option found in the Graphic Setting tab of the CATALYST™ CONTROL CENTER no longer results in the side scroll bar being missing for the secondary display device connected to an ATI RADEON™ 9800 series under Windows XP Creating a profile for clone or stretch mode and attempting to change to that mode from an extended desktop mode, no longer results in the task failing to complete. Topic number 737-10098 The Windows desktop and Full-screen video options are no longer missing when clicking the back button found in the Video Wizard of the CATALYST™ CONTROL CENTER. Topic number 737-10098 The CATALYST™ CONTROL CENTER tool bar now displays correctly after applying a new skin and restarting the CATALYST™ CONTROL CENTER. Topic number737-10098 Defining a custom view in the CATALYST™ CONTROL CENTER by deselecting the graphic adapter and applying the changes, no longer results in the Advanced view taking on the properties of the defined custom view. Topic number 737-10102 The font size used in the CATALYST™ CONTROL CENTER for the Quicksilver and Steelblue skins have been readjusted in order to be seen clearer. Topic number 737-10103 Enabling Temporal AA no longer results in a noticeable flicker on the display device. Topic number 737-10103 Cijeli release notes je tu: http://www2.ati.com/drivers/Catalyst...ase_notes.html Catalyst 5.3 (Driver only)- http://www2.ati.com/drivers/wxp-w2k-...2a-021277c.exe Catalyst 5.3 (Driver + CCC)- http://www2.ati.com/drivers/wxp-w2k-...7c-english.exe |
Lokacija: Ispred kompa
Postovi: 2,004
ajel delaju kaj bolje od prosilh. po pitanju crashanja sistema i toga.
#3 | |
Super Moderators
Postovi: 17,485
Bude izašla i nova Omega, spremaju se i nekakvi novi zerop0int driveri (isto od ekipe sa driverheavena)... A možda ih i skinem (bez CCC-a ), čisto zbog bolje podrške za XL. |
Datum registracije: Apr 2004
Postovi: 301
a zasto bec ccca? prema ekipi sa beyond3da ccc se prilicno poboljso u zadnjih par mjeseci, kazu da nema vise onih cekanja, ucitavanja od 5 minuta i takih fora... al ok, kak oces btw, daj napisi vise kak tera ta xl ![]()
HARDCORE 4 LIFE athlon xp 2500+ @ 3200+ (11x200) gigabyte ga7n400l ( n force2 ) gigabyte radeon9600pro (@ 510/700 ) 2x256 Samsung ddr400 ŽENE SU KAO RAM, ŠTO VIŠE IMAŠ TO BOLJE |
#5 | |
Postovi: 2,004
#6 | |
Super Moderators
Postovi: 17,485
Za XL se nama kaj pričati, svaku igru sažvaće i ispljune u najvišim detaljima i AA i ANISO postavkama ![]() |
#7 | |
Super Moderators
Postovi: 17,485
Super Moderators
Postovi: 17,485
I još malo riješenih problema u igrama: The following section provides a brief description of known issues associated with the latest version of CATALYST™. These include the following: Call of Duty: Corruption is noticed when playing a saved game under Windows XP with an ATI RADEON™ 9100 PRO IGP series installed and having a variety of graphic options provided by the game set high. Topic number 737-674 Farcry: Playing the game under Windows XP SP2 with the display set to 1024x768 32bpp along with AA disabled results in flashing textures being noticed when setting the game's video options to high detail. Topic number 737-10089 Half-Life 2: Having the display set to 1024x768 32bpp and setting the video options in the game set to 1600x1200 and all other options set to their maximum values results in sluggish performance and missing textures. Topic number 737-10086 Rainbow six3: Athena Sword: Playing the game under Windows 2000 with an ATI RADEON™ X700 installed results in the game failing to retain its resolution option of 1600x1200 if you Alt-tab out of the game and then Alt-tab back to the game. Topic number 737-535 Serious Sam: The Second Encounter: Playing the game for approximately 5 to 10 minutes under Windows XP with the game quality set at normal/default, results in display corruption being seen in the menu. Topic number 737-10090 Star Wars Knights of the Old Republic 2: Playing the game under Windows XP with an ATI RADEON 9800 series installed, results in display corruption being noticed when changing the in-game options from low to maximum Topic number 737-10091 Star Wars Knights of the Old Republic: Loading the Dantooine level of the game under Windows XP results in slow game performance Topic # 737-10092 Star Wars Knights of the Old Republic 2: Setting the graphic option in the CATALYST™ CONTROL CENTER to Optimal Quality, followed by launching the game and setting the resolution option to 1600x1200, results in a performance drop being noticed. Topic # 737-10093 Assigning a hotkey to increase the overlay gamma results in the hotkey not functioning properly when playing an MPEG using the Windows Media Player. Topic number 737-494 The Apply button in the Custom settings of the Advanced mode found under the CATALYST™ CONTROL CENTER Video standard settings is grayed out when playing a media file. Topic number 737-497 Installing the display driver and the CATALYST™ CONTROL CENTER, results in a runtime error and the system tray failing to start when attempting to create multiple user accounts and enabling fast user switching. Topic number 737-10084 The CATALYST™ CONTROL CENTER installation currently does not check for the installation of Microsoft .Net Framework before preceding with the install, resulting in an error message being displayed when attempting to launch the CATALYST™ CONTROL CENTER. Topic number 737-10085 Setting the desktop display to 800x600 or 1600x1200 16/32bpp results in the incorrect display resolution information being provided when checking the video control panel in the CATALYST™ CONTROL CENTER. Topic number 737-10087 Using the ATI Problem Report Wizard under Windows XP SP2 with an ATI RADEON X850 XT installed results in an error message appearing when clicking the Finish button for the problem report. Topic number 737-10088 Hesitation and display corruption is noticed when moving an MCE window from the primary display device to a secondary TV or DVI display device. Topic number 737-114987 |
Postovi: 1,606
još samo da netko Omegu odvuče od Wacrafta.... |
#10 | |
Lokacija: Kutina
Postovi: 1,208
Re: Novi Catalyst 5.3
Treba kaj skurit??
Lokacija: Zgb
Postovi: 4,030
Ajde recite zgriženom nvIDIOTu koji su najbolji driveri za 9800PRO. |
prof.dr. gospodar svemira
Postovi: 432
OVERDRIVE™ Version 4 The latest version of OVERDRIVE™ includes a new 3D test and extra safety checks to ensure the best over-clocking experience - allowing manual over-clocking of both engine and memory while keep the user's graphics card safe from any of the dangers usually associated with over-clocking. Da li je ovo samo kod CCC verzije ili pali samo na x850 modelima? Skinuo sam nove 5.3 bez CCC i Overdrive je isti kao i prije...:confused:
If you are not paranoid you don't have enough information |
Super Moderators
Postovi: 17,485
Ha, Omegu svi već naveliko ganjaju, samo budući da znamo kakvi su ovisnici o WoW-u... OpenGL Version 2.0 Support je baš to kaj mu ime i veli Kaj se tiče GL-a u novim driverima mislim da sam vidio da se vlasnici 9800 PRO špinče sa boljim rezultatima u DOOM-u, ostalo još nisam stigao pogledat Za 9800/PRO ili 4.12, 4.12 beta Omega ili zadnji službeni dok ne izađe nova Omega ili ako će biti čemu novi zer0point. OVERDRIVE™ Version 4 je điđa koja dela samo sa CCC-om, mislim da najnovije fore podržava samo X850. Da li je probao netko nove drivere? |
#15 | |
Lokacija: Kutina
Postovi: 1,208
) ali mene zanimaju isključivo iskustva... daj čim saznaš nešt konkretno postaj... bio je i red da naš dragi ati napokon malkice pokrpa ogl, ak nizašta onda bar da nam oni nvidijoti prestanu nabijat ogl na nos... :burn: |
#16 | |
Super Moderators
Postovi: 17,485
To kaj buš malo-malo u nekom reviewu naletio na izjavu tipa "ATI i OGL", a nećeš naletjeti na izjavu da bi Nvidia mogla poraditi malo na svojim D3D driverima Ili "igra bolje paše ATI karticama", ili "poznato je da ATI bolje radi sa ..." itd...a to piše i kad ATI grafa iz soma kuna nižeg cjenovnog ranga odere skuplju Nvidiu u D3D-u U najboljem slučaju ćemo naletiti na izjavu tipa "valjda će se i to rješiti sljedećom revizijom drivera". Kak će se ponašati ATI sa GL-om 2.0 ne možemo znati dok ne bude igri/aplikacija pisanih u njemu. |
#17 |
Lokacija: Kutina
Postovi: 1,208
ma to je poznata problematika, nv orijentirani jednostavno ne mogu/žele reć da nešto-nv ne valja već je, kao što ti kažeš, ati optimizirano... al nema veze, navikli smo se ![]() vezano za ogl, šta nije bilo najavljivano da će ogl2.0 podrška izaći u sklopu generalno popravljenih ogl ati drivera? bilo je neke spike na tu shemu koliko se sjećam... zato te i pitam jer sam očekivao napredak na globalnom ogl planu... |
#18 | |
Super Moderators
Postovi: 17,485
Nekaj se malo popravi vezano uz sfecifičnu igru, čak se i neke rutine iz Nvidiinih drivera malo preprave i implementiraju Mislim-da će ATI ikad dostignuti Nvidiu u dogledno vrijeme-te sumnjam, te nije toliko ni bitno Većina IGARA u GL-u radi fino i na ATI-ju. Pacific Fighters je valjda jedina igra u kojoj je Nvidia malo jače dominantna, a to kaj čak i Ultra postiže samo 43FPS-a u 1280 je po meni više stvar neoptimizacije igre nego nekakve slabosti u GL-u. Mislim-kakva je to optimizacija kad high-end grafa na mrak stroju tjera malo više od igrivog frame-ratea??? |
#19 |
Treba kaj skurit??
Lokacija: Zgb
Postovi: 4,030
Trenutno sam doma na 9800SE (128bitna :BLJUV: ) i na 4.6 driverima. Idem se malo igrat da vidim jel to čudo išta bolje od moje Ti4600. Čisto sumnjam. Zadnje izmijenjeno od: vga killer. 11.03.2005. u 00:09. |
#20 |
do you speak it?
Lokacija: ::1
Postovi: 1,629
kaze se sumnjam (sumnjati - sumnjam) sumljam koriste polu(ne)pismeni ljudi
Drinking Rum before 10am makes you a Pirate, not an Alcoholic. |
#21 | |
Super Moderators
Postovi: 17,485
Kaj nisi uzeo neku pure, po mogućnosti sa R360 GPU-om. Fino je lupiš u XT i da vidiš veselja ![]() |
#22 |
Treba kaj skurit??
Lokacija: Zgb
Postovi: 4,030
Kupil sam je - NE. Na testiranju jer nisam mogao liku uvjerit da to nije 9800PRO neg da je 9800SE. |
#23 | |
Super Moderators
Postovi: 17,485
Ta ti je negdje u rangu 9600XT otprilike... Koja firma? |
#24 |
Treba kaj skurit??
Lokacija: Zgb
Postovi: 4,030
Da budem iskren, nemam pojma, al mislim da je Canyon, ak to uopće postoji. Pogledaj u atačmentu sliku iz everesta |
#25 |
Lokacija: Kutina
Postovi: 1,208
vidi pod ati display settings -> options -> details tamo bi trebao biti naveden proizvođač... |
#26 |
Treba kaj skurit??
Lokacija: Zgb
Postovi: 4,030
Piše CP Tehnology, al sam i skužio da grafa ima 256MB. |
#27 |
Lokacija: Kutina
Postovi: 1,208
to ti je powercolor... |
#28 | |
Super Moderators
Postovi: 17,485
#29 | |
Super Moderators
Postovi: 17,485
#30 |
Lokacija: Kutina
Postovi: 1,208
